Zigbee inline switch for USB devices
This is the new dedicated driver for the ZigUSB device that I put together.
It can be installed manually from GitHib :
https://raw.githubusercontent.com/kkossev/Hubitat/development/Drivers/ZigUSB/ZigUSB_lib_included.groovy
The automatic reporting time period is configured in the Preferences :
If the V/A/W measurements are not really needed, I recommend to disable the automatic reporting.
Unfortunately, it is not possible to refresh the voltage/amperage/power readings manually - the only way to have these is when the periodic reporting is enabled.
@TheUsualSuspect can you compare the amperage reading accuracy of his device with the other device that you have?
still no way to get these easily in the u.s?
I just purchased 5 and got them shipped without issue to Canada. Received them last week.
I have 4 that I'm willing to part with. They work great, I just never found a use case for them. Super interesting item though!
No, it is powered by a wall-wart but I have several AA to usb battery packs that would do the job.
Sorry for the delay. Finally installed the new driver, and on-off reverse is fixed. Below is a comparison between the reported voltage/power/amperage and measured.
Edit: Switched On-Off comparison twice (reversal keeps getting me).
Thank you for the test! It looks like the readings make sense (adding the 40..50 mA ZigUSB device own consumption to the amperage drawn by the load)?
thanks.. i just got 4 of these used from user3432 they are working well thanks for the driver. i replaced the sonoff ones that were wifi only..
these i am using on my micro usb repeaters as i have found that occasionaly i need to reboot them and its always when the house is empty
here is the rule i used to reset them
I tried a larger load to help in case absolute error on small values was causing a problem. I watched the V/A/W values refresh about 15 times. It seems to me that the voltage and current are chronically under the real value. I believe the USB is probably putting out close to 5[V]. Below is a representative capture. I note that one time the voltage did read 5[V] but I didn't capture it and it.
Thank you for the tests!
A question about this device. Are both USB ports individually controllable? Or, are they both on or off? Is the outlet plug controllable separately ?
i believe it is all one.. the switch and usb ports turn on/off as one.. i dont see a separate child driver for it in my hug.. but it is in a remote location..
Noob user here, but I can't get the new version of this device (ZigUSB_C6) to pair with Hubitat at all. It gets discovered but I get errors during initialization (with generic drivers or kkossev's). The log below is from a pairing attempt.
dev:3082025-02-01 00:21:44.800warnZigUSB parseZdoClusters: ZDO Device announce error: 0x61 (statusCode: 0x61)
dev:3082025-02-01 00:21:40.283warnZigUSB parseZdoClusters: ZDO Device announce error: 0x61 (statusCode: 0x61)
dev:3082025-02-01 00:21:35.628warnZigUSB parseZdoClusters: ZDO Device announce error: 0xCD (statusCode: 0xCD)
dev:3082025-02-01 00:21:35.381debugZigUSB clearing the Status event
dev:3082025-02-01 00:21:31.039warnZigUSB parseZdoClusters: ZDO Device announce error: Unsupported Cluster (statusCode: 0xC3)
dev:3082025-02-01 00:21:26.342warnZigUSB parseZdoClusters: ZDO Device announce error: 0xC8 (statusCode: 0xC8)
dev:3082025-02-01 00:21:21.804warnZigUSB parseZdoClusters: ZDO Device announce error: 0xD9 (statusCode: 0xD9)
dev:3082025-02-01 00:21:17.087warnZigUSB parseZdoClusters: ZDO Device announce error: 0x77 (statusCode: 0x77)
dev:3082025-02-01 00:21:12.450warnZigUSB parseZdoClusters: ZDO Device announce error: Time out (statusCode: 0x94)
dev:3082025-02-01 00:21:07.783warnZigUSB parseZdoClusters: ZDO Device announce error: 0xFD (statusCode: 0xFD)
dev:3082025-02-01 00:21:03.166warnZigUSB parseZdoClusters: ZDO Device announce error: 0x58 (statusCode: 0x58)
dev:3082025-02-01 00:20:58.549warnZigUSB parseZdoClusters: ZDO Device announce error: 0x39 (statusCode: 0x39)
dev:3082025-02-01 00:20:53.913warnZigUSB parseZdoClusters: ZDO Device announce error: Duplicate Exists (statusCode: 0x8A)
dev:3082025-02-01 00:20:49.286warnZigUSB parseZdoClusters: ZDO Device announce error: Invalid Value (statusCode: 0x87)
dev:3082025-02-01 00:20:44.718warnZigUSB parseZdoClusters: ZDO Device announce error: Insufficient Space (statusCode: 0x89)
dev:3082025-02-01 00:20:40.038warnZigUSB parseZdoClusters: ZDO Device announce error: 0x5D (statusCode: 0x5D)
sys:12025-02-01 00:20:39.455infoZigbee Discovery Stopped
dev:3082025-02-01 00:20:35.472debugZigUSB parseZdoClusters: ZDO Bind Response success: [2B, 00]
dev:3082025-02-01 00:20:35.423warnZigUSB parseZdoClusters: ZDO Device announce error: 0x5E (statusCode: 0x5E)
sys:12025-02-01 00:20:35.400warnUnable to send Zigbee message: [he raw 0x155E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200] from zigbee id: 404CCAFFFE42F9C0, message type is unknown.
sys:12025-02-01 00:20:35.397infoFound previously joined Zigbee device ZigUSB
dev:3082025-02-01 00:20:35.393debugZigUSB sendZigbeeCommands(cmd=[[he raw 0x155E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200], zdo bind 0x155E 0x01 0x01 0x0006 {404CCAFFFE42F9C0} {}, delay 251, he cr 0x155E 0x01 6 0 16 1 60 {}, delay 251, he raw 0x155E 1 0x01 0x0006 {10 00 08 00 0000}, delay 251, zdo bind 0x155E 0x02 0x01 0x000C {404CCAFFFE42F9C0} {}, delay 2000, he cr 0x155E 0x02 12 85 33 65535 65535 {} {}, delay 2000, he raw 0x155E 1 0x02 0x000C {10 00 08 00 5500}, delay 200])
dev:3082025-02-01 00:20:35.390debugZigUSB configure(): returning cmds = [[he raw 0x155E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200], zdo bind 0x155E 0x01 0x01 0x0006 {404CCAFFFE42F9C0} {}, delay 251, he cr 0x155E 0x01 6 0 16 1 60 {}, delay 251, he raw 0x155E 1 0x01 0x0006 {10 00 08 00 0000}, delay 251, zdo bind 0x155E 0x02 0x01 0x000C {404CCAFFFE42F9C0} {}, delay 2000, he cr 0x155E 0x02 12 85 33 65535 65535 {} {}, delay 2000, he raw 0x155E 1 0x02 0x000C {10 00 08 00 5500}, delay 200]
dev:3082025-02-01 00:20:35.360infoZigUSB sent device configuration
dev:3082025-02-01 00:20:35.358debugZigUSB customConfigureDevice() : [zdo bind 0x155E 0x01 0x01 0x0006 {404CCAFFFE42F9C0} {}, delay 251, he cr 0x155E 0x01 6 0 16 1 60 {}, delay 251, he raw 0x155E 1 0x01 0x0006 {10 00 08 00 0000}, delay 251, zdo bind 0x155E 0x02 0x01 0x000C {404CCAFFFE42F9C0} {}, delay 2000, he cr 0x155E 0x02 12 85 33 65535 65535 {} {}, delay 2000, he raw 0x155E 1 0x02 0x000C {10 00 08 00 5500}, delay 200]
dev:3082025-02-01 00:20:35.355infoZigUSB configuring the automatic reporting : DISABLED
dev:3082025-02-01 00:20:35.353debugZigUSB configureReporting operation=Write, measurement=Switch, minTime=1, maxTime=60, delta=0 )
dev:3082025-02-01 00:20:35.351infoZigUSB Configuring the device...
dev:3082025-02-01 00:20:35.349infoZigUSB configureDevice...
dev:3082025-02-01 00:20:35.347infoZigUSB initializeDevice...
dev:3082025-02-01 00:20:35.344infoZigUSB tuyaBlackMagic()...
dev:3082025-02-01 00:20:35.341debugZigUSB configure(): settings: [voltageToPercent:false, flashRate:750, healthCheckMethod:1, healthCheckInterval:240, txtEnable:true, logEnable:true, alwaysOn:false, autoReportingTime:0, ignoreDuplicated:false, inverceSwitch:false, advancedOptions:true, threeStateEnable:false, traceEnable:true]
dev:3082025-02-01 00:20:35.339infoZigUSB configure...
sys:12025-02-01 00:20:31.440infoZigbee Discovery Running
dev:3082025-02-01 00:20:30.777warnZigUSB parseZdoClusters: ZDO Device announce error: 0x2D (statusCode: 0x2D)
sys:12025-02-01 00:20:30.548infoZigbee Discovery Stopped
dev:3082025-02-01 00:20:26.261debugZigUSB parseZdoClusters: ZDO Bind Response success: [23, 00]
dev:3082025-02-01 00:20:26.214warnZigUSB parseZdoClusters: ZDO Device announce error: Invalid Field (statusCode: 0x85)
sys:12025-02-01 00:20:26.192warnUnable to send Zigbee message: [he raw 0x0085 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200] from zigbee id: 404CCAFFFE42F9C0, message type is unknown.
sys:12025-02-01 00:20:26.188infoFound previously joined Zigbee device ZigUSB
Try to pair it using this method.... although these are very strange errors, I have not seen anything like this before.
Thanks for the tip, I did but same errors.
From what I could find, the latest ZigUSB C6 uses a different ESP32 C6-based zigbee module. This thread covers some issues in trying to get that module to work with Hubitat. It might be related to a zigbee v3 support issue :man_shrugging:
Yep, it seems to be a Zigbee 3.0 implementation issue here ... :frowning:
