I use the Nexia Doorbell device. Works perfectly, but chews through AAA batteries a bit. If you have a traditional doorbell with a chime, all you have to do is wire the Nexia sensor inside the chime itself. Here's mine:
I think the Sage one might be better since it runs straight off the AC voltage supplied by the transformer. Plus it’s 1/10th the price and Zigbee (which I prefer). I will test it when I get it this weekend. Worse case I’m out $5.00
Heck, I bet those'd pay for themselves in battery savings in no time.
Also, I think Zigbee is winning the smarthome race.
I thought the Sage one runs off of a battery? Mine should here on Saturday.
It's running on CR2 3V battery.
Oh my bad. I just assumed.
Pretty sweet - I bought the sage sensor on eBay for $5 and now have my doorbell integrated into hubitat!
Next step - I’d love to have hubitat pull a still photo from my unifi camera and text it to me. I don’t think this is possible at this time, unless someone knows something I don’t.
I found one here
I made some changes for my needs.
Update: commented out SendEvents per @ogiewon recommendation below
* SAGE Doorbell Sensor
* For device information and images, questions or to provide feedback on this device handler,
* please visit:
* darwinsden.com/sage-doorbell
* White wire: common
* Green wire: doorbell 1 / front
* Yellow wire: doorbell 2 / back
* Factory reset:
* Remove the plastic cover and the battery.
* Press and hold the tiny RESET button (next to where the wires attach to the circuit board) while you reinstall the battery.
* Continue holding RESET until the red LED blinks.
* Copyright 2016 DarwinsDen.com
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Author: Darwin@DarwinsDen.com
* Date: 2016-06-13
* Changelog:
* 0.40 (03/23/2017) - set numberOfButtons attribute for those smart apps that rely on this
* 0.30 (11/20/2016) - Removed non-operational battery capability; was preventing device display on 2.2.2 mobile app
* 0.20 (08/02/2016) - Added preference option for allowed time between presses to eliminate duplicate notifications on some systems
* 0.10 (06/13/2016) - Initial 0.1 pre-beta Test Code
metadata {
definition (name: "SAGE Doorbell Sensor", namespace: "darwinsden", author: "darwin@darwinsden.com") {
//capability "Battery"
capability "Configuration"
capability "Pushable Button"
capability "Refresh"
command "enrollResponse"
fingerprint endpointId: "12", inClusters: "0000,0003,0009,0001", outClusters: "0003,0006,0008,0019", model: "Bell", manufacturer: "Echostar"
preferences {
input "timeBetweenPresses", "number", title: "Seconds allowed between presses (increase this value to eliminate duplicate notifications)", defaultValue: 10, displayDuringSetup: true, required: false
//log.debug "description: $description"
Map map = [:]
if (description?.startsWith('catchall:')) {
map = parseCatchAllMessage(description)
else if (description?.startsWith('read attr -')) {
map = parseReportAttributeMessage(description)
//log.debug "Parse returned $map"
def result = map ? createEvent(map) : null
if (description?.startsWith('enroll request')) {
List cmds = enrollResponse()
////log.debug "enroll response: ${cmds}"
result = cmds?.collect { new hubitat.device.HubAction(it) }
return result
private Map parseCatchAllMessage(String description) {
Map resultMap = [:]
def cluster = zigbee.parse(description)
if (shouldProcessMessage(cluster)) {
//log.debug ("cluster: $cluster")
switch(cluster.clusterId) {
case 0x0006:
resultMap = getDoorbellPressResult(cluster)
break
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
// 0x07 is bind message
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
cluster.command == 0x07 ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
private Map parseReportAttributeMessage(String description) {
Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
//log.debug "Desc Map: $descMap"
Map resultMap = [:]
if (descMap.cluster == "0001" && descMap.attrId == "0020") {
log.debug descMap.value
resultMap = getBatteryResult(Integer.parseInt(descMap.value, 16))
return resultMap
private Map getBatteryResult(rawValue) {
log.debug "Battery rawValue = ${rawValue}"
def linkText = getLinkText(device)
def result = [
value: '--',
translatable: true
def volts = rawValue / 10
if (rawValue == 0 || rawValue == 255) {}
else {
if (volts > 3.5) {
result.descriptionText = "{{ device.displayName }} battery has too much power: (> 3.5) volts."
else {
if (device.getDataValue("manufacturer") == "SmartThings") {
volts = rawValue // For the batteryMap to work the key needs to be an int
def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
def minVolts = 15
def maxVolts = 28
if (volts < minVolts)
volts = minVolts
else if (volts > maxVolts)
volts = maxVolts
def pct = batteryMap[volts]
if (pct != null) {
result.value = pct
result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
else {
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
result.value = Math.min(100, (int) pct * 100)
return result
private Map getDoorbellPressResult(cluster) {
def buttonNumber = (cluster.command as int)
def result = [:]
// map buttons per Hughes described defaults for green and yellow wires
switch(buttonNumber) {
case 0:
if (!isDuplicateCall(state.lastButton2Updated, state.timeBetweenPresses) )
log.debug ("Rear Doorbell Pressed!")
result = [ name: 'pushed', value: "2", isStateChange: true ]
//sendEvent(name: "pushed", value: "2", isStateChange: true)
state.lastButton2Updated = new Date().time
break
case 1:
if (!isDuplicateCall(state.lastButton1Updated, state.timeBetweenPresses) )
log.debug ("Front Doorbell Pressed!")
result = [ name: 'pushed', value: "1", isStateChange: true ]
//sendEvent (name: "pushed", value: "1", isStateChange: true)
state.lastButton1Updated = new Date().time
return result
def refresh() {
log.debug "Refreshing Battery"
def refreshCmds = [
"he rattr 0x${device.deviceNetworkId} 18 0x0001 0x20", "delay 500",
sendEvent(name: "numberOfButtons", value: 2, displayed: false)
setPrefs()
return refreshCmds + enrollResponse()
def configure() {
setPrefs()
String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
log.debug "Configuring Reporting, IAS CIE, and Bindings."
def configCmds = [
"zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}", "delay 200",
"send 0x${device.deviceNetworkId} 1 1", "delay 500",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 1 {${device.zigbeeId}} {}", "delay 500",
"zcl global send-me-a-report 1 0x20 0x20 30 21600 {01}", //checkin time 6 hrs
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 0x402 {${device.zigbeeId}} {}", "delay 500",
"zcl global send-me-a-report 0x402 0 0x29 30 3600 {6400}",
return configCmds + refresh() // send refresh cmds as part of config
def enrollResponse() {
log.debug "Sending enroll response"
//Resending the CIE in case the enroll request is sent before CIE is written
"send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 500",
//Enroll Response
"raw 0x500 {01 23 00 00 00}",
"send 0x${device.deviceNetworkId} 1 1", "delay 200"
private isDuplicateCall(lastRun, allowedEverySeconds) {
def result = false
if (lastRun) {
result =((new Date().time) - lastRun) < (allowedEverySeconds * 1000)
result
def setPrefs()
log.debug ("setting preferences")
if (timeBetweenPresses == null)
state.timeBetweenPresses = 10
else if (timeBetweenPresses < 0)
state.timeBetweenPresses = 0
else
state.timeBetweenPresses = timeBetweenPresses
def updated()
setPrefs()
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
private hex(value) {
new BigInteger(Math.round(value).toString()).toString(16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
I just installed the Sage sensor after it came in the mail today. Seems to work well and it’s very fast as you’d expect from a Zigbee sensor. Tomorrow I’ll try the driver y’all posted here. Thanks!
Care to elaborate on what your tweaks are? I just received one of these Sage Doorbell devices today as well. Thanks!
Just fixed an error and redo some logging stuffs.
Thanks. I’ll give your version a try this weekend.
@cuboy29 have you noticed the driver produces duplicate pushed events? I figured out a simple fix. Just comment out the “sendEvent()” calls as shown below.
def result = [:]
case 0:
break
case 1:
return result
The driver worked fine for me. I actually modified it for my purposes and made it a Contact Switch as opposed to Pushable Button. With it being a Contact Switch I now get notifications in HomeKit when the doorbell rings. Exactly what I needed. Thanks a lot for the driver.
Here's the modified code in case anybody's interested. I removed the "back door" doorbell but it's easy to add in. I also removed all other functionality (except the actual sensor opening/closing). The code below is all you need for the it to work as a sensor.
metadata {
capability "Contact Sensor"
capability "Sensor"
def ensureClosed(){
sendEvent(name: "contact", value: "closed", displayed: false, isStateChange: true)
if(cluster.profileId != 0x0104 || cluster.command == 0x0B || cluster.command == 0x07 || (cluster.data.size() > 0 && cluster.data.first() == 0x3e)){
return
if(cluster.clusterId == 0x0006){
//log.debug("ding dong")
sendEvent(name: "contact", value: "open", displayed: false, isStateChange: true)
runIn(1, ensureClosed)
def refresh() {
configure()
def configure() {
ensureClosed()
def updated()
configure()
Dan
I've already notified the poster of the driver.
The driver on github has different handling for button 1 and button 2. I wanted to get your advice on the correct code.
Below is the code as posted on github, the "result =" is different for button 1 and 2. For me button 1 (front) worked properly button 2 (rear) produced duplicate events, leading to your fix above.
However when I commented out the "sendEvent" line of button 1, no events occurred for button 1 and single events for button 2.
My question: Which "result" line would be the preferred code?
Mike
case 0:
//log.debug ("BUTTON2 PRESS!")
break
case 1:
//log.debug ("BUTTON1 PRESS!")
result = [ name: 'button', value: "pushed", data: [buttonNumber: 1], isStateChange: true]
return result
This is mine...
181
case 0:
182
183
184
185
186
187
188
189
break
190
191
case 1:
192
193
194
195
196
197
198
199
200
return result
Mike
here is my version of the driver. I've taken what others have done before, then added parameters to store custom names for each contact. Useful for logs.
