Wink Automation in Hubitat
Long time reader, first time poster! I hope my search skills were on point and this topic hasn't been covered...
I've recently made the jump from Wink to Hubitat after 1) having an HE for months :smirk: and 2) Winks latest outages, almost 2 weeks. Unbearable. :face_with_symbols_over_mouth:
I'm absolutely sure HE can do what I want, I just don't quite know the proper steps (virtual devices, RM, Simple Automation, etc).
In Wink I had a shortcut (press an iOS widget button and go) that did many things when it was time to go to bed. For example:
  1. Turn OFF light A
  2. Turn OFF light B
  3. Turn ON light C
  4. Set light D to 20%
  5. Set house temp to 64
  6. Lock front door
  7. Shut garage
And so on and so on. In all it performed 22 different actions.
So my, obvious, question is: how do I easily achieve the same in HE?
Side issue: how do I get HE to recognize that my garage is open/closed (MyQ app installed) and why doesn't my button work to open/close it? :oncoming_automobile:
The forum has been incredibly helpful as I have been working through getting some issues worked out over the weekend when I was migrating over. :+1:t2:
Thanks a ton in advance!
Hubirat :rat:
From one Wink refuge to another. There is a learning curve, but after a few weeks you will wonder how you ever put up with Wink. I used Wink from 2015 till 2019 before coming here.
Here’s a guide I put together for exactly what you’re asking for.
Note: this was a few versions of iOs and Hubitat ago - so some of the interfaces will look slightly different and be named different things, but if you follow the steps you should be set.
Summary;
  • in Hubitat you’ll install the ‘rule machine’ app
  • you’ll create a ‘cloud end point’ trigger (just a drop down selection). This is literally just a unique URL that, when visited in any browser, will instantly cause the rule to do whatever you tell it to do.
  • you’ll set up the rule to do the A, B, C stuff above.
  • You’ll copy the Cloud End Point URL from Hubitat over to the iOS shortcut app where you can create a basic widget.
Happy to help if you run into any issues.
you could use Rule Machine (RM) for this. create a virtual switch (set with auto off to act as a button), then in RM, create a rule that whenever the switch is turned on, perform the actions you want
Hey Craig! I had actually seen your How To but I guess I didn't scroll far enough! (work, what a drag). I will spend this weekend combing thru this tutorial.
I have to admit, while I love the flexibility of HE, the Wink UI was super user friendly. My mom could figure Wink out but I'd have to spend HOURS with her if she migrated to HE. Oh well, such is the life I've chosen. :wink:
Thanks for the reply and link!
Hubirat :rat:
Aaaand I'm already wondering... :slight_smile: I was able to use your step-by-step (it might be outdated as several screens didn't look the same, but I managed) and got myself setup with a wicked sweet shortcut using the Apple app. Now to create more! :metal:
Thanks a ton!
I hate to mention this but if you like to tinker a bit there is a way for all your hubitat devices to show up in Apple HomeKit.
This requires the use of separate server (like a Raspberry PI), an app called HomeBridge, and an HE app called "Homebridge Plug-in"
Unfortunately you cannot do the reverse - expose HomeKit devices to HE.. but it works very well otherwise.
Just thought I'd mention it if you had any interest!!!
:grinning:
edit: Also the HomePod Mini makes a great Apple Home Hub and is the (or one of the) cheapest Apple gizmo(s) out there right now.
@Hubirat - to add to @erktrek's suggestion. There's even a pre-packaged version of Homebridge that can be purchased as a hardware device called "HOOBS". HOOBS is also available as a download that can be run on any RPi.
As an iPhone guy, I use HomeBridge to bring all my Hubitat devices into the Apple ecosphere. And on the rare occasion I need to directly control a Hubitat device, I just use the Home app.
I'll check it out! Thanks!
This is what Hubitat devices can look like in a room in the Home app
Oh... that's pretty sexy... :heart:
With zero effort. All it took was to get HomeBridge up and running and connected to Hubitat. The devices appear automatically in the Home app, and you can put them into rooms.
I am using an Apple TV4 as my Home hub, but I agree with @erktrek - the HomePod mini is the cheapest way to go.
There are two Hubitat integrations to get devices into HomeBridge (or HOOBS). I'm using the one by @dan.t - it is super simple to setup.
And there's a lot of us using his integration for a long time - so plenty of help if you need any.
Welcome @Hubirat!
@erktrek and @aaiyar are correct about ways to stand up HomeBridge. It does make things slick for getting to/from Homekit.
You can pass states from Homekit to HE by setting up virtual devices in HE to mirror the Homekit ones you want to see in HE. You will have to create the necessary automations in Homekit to pass the Homekit device state through.
If you setup HomeBridge you can connect your MyQ garage door opener by adding a MyQ Bridge. It connects MyQ to Homekit. That's what I've done, and it works well.
You have successfully taken the ‘gateway drug’ for true home automation. :slight_smile:
Most of us here tend to spend WAY more on automation now than we did with Wink, not because we have to, but because of the nearly limitless possibilities and fun you can have.
A few months after I got my Hubitat, I got a Pi and setup Homebridge/HomeKit. Then I set up a PiHole since I already had the Pi... then, anytime I faced a minor annoyance in my house I thought ‘I bet I could automate that...’ and now I have 150 devices.
Hubitat is dangerous, because of how much it empowers you. 1 smart outlet is $30, not too bad... 20 outlets over 2 years adds up, but you won’t realize it till you one day hit a point where you’ve automated all the things. And then the system just works. Then you almost start to miss the process of setting up and tinkering with things... getting excited at the rare times when you think of a new application for automation and get a new smart plug, etc.
This is when you’ll think back to Wink and realize it was a really great interface for turning on and off things from your phone along with some basic automation. That’s when you’ll wonder how you got by with just Wink before you had Hubitat :slight_smile:
This.
I live alone - my most recent automation is a "deadman switch" - to automatically notify a few people if there's been no sign of life in my house for 12 hours, by virtue of monitoring state changes for things that require human intervention (eg. motion active, getting out of bed, opening/closing doors, raising/lowering toilet seat, turning TVs on/off, opening/closing fridge, using the kitchen garbage can, etc. etc).
That is a really good idea.
I think I'm so locked in the "Wink On/Off" level of automation that I'm struggling with the bigger picture that I know HE can bring. I have some Wyze cams and I'm fine they're in their own app. I have a home security system with it's own app and again, I'm Ok with that. I'm in the What else can I do? phase.
I think I need a "Here's a cool thing I did with HE!" section of the forum! :joy:
Hubirat :rat:
You mean something like this? :grinning:
Like this?
I would almost argue its the mundane, day to day stuff you can automate that makes it great.
Stuff like:
  • Controlling exterior lights based on lux and other things.
  • Dimming/Brightening lights based on lux..
  • Lights turning on when you go into a room then turning off after a period of no motion.
  • Bathroom Fans automatically coming on for 5 mins after a light is turned off.
  • Turning lights off that have been left on for an extended length of time.
  • Simulating occupancy when you are away.
  • Alerting you to leaks and being able to shut off the water main if necessary.
  • Garage door control..
etc etc etc...
edit: I do not mean to imply that the Wink "can't" do most of these... just that it will likely be more reliable/faster using HE.
This right here. You can’t do this with Wink and have good results because of the 3-4 second delay between a motion sensor and a light turning on.
With Hubitat, get an inexpensive Zigbee motion sensor. (Out of stock on Amazon but you can likely find them on eBay or elsewhere. https://www.amazon.com/dp/B01LXPGXQ1/ref=cm_sw_r_cp_api_glt_fabc_KFQJ1RYRDWXA4HSTXT5G?_encoding=UTF8&psc=1 )
Make a rule based on motion to turn on lights when you enter a room, and they come on in 0.2ms. Faster than you can reach for a light switch. After a while you’ll have your house full of these motion sensors and never touch another switch. Then you’ll go on vacation and your spouse will be thoroughly confused as to why the lights in the hotel bathroom don’t automatically turn on because of how used to automation you’ve become...
