Don't worry, it can't.
Ok, this is a great list.
What jumps out:
IF On for 10 min THEN turn Off?Thanks @erktrek!
Hubirat ![]()
Planning on doing this today in my garage!
I'm curious, you mention Zigbee vs. Z-wave. Do you prefer Zigbee over Z-wave? The motion sensor I bought is z-wave... I've always just figured they were equivalent, are they not? Note: the 20 odd wall switches/dimmers I have are all z-wave so I figured I just keep riding that wave
considering the mesh network and all.
Thanks,
Hubirat ![]()
You can use illuminance as a trigger or condition.
Yup.
Yup. There are several controlled water valves that work with Hubitat. Here's the zigbee one that I use:
For this particular one, you need only the valve - it pairs directly to Hubitat (also worked with Wink!). You don't need their WiFi-zigbee gateway/hub.
There are many z-wave models.
I have a total of ~15 z-wave/zigbee leak sensors in my house. And an automation that notifies me as well as turns the valve off if there's a leak. It is also super-convenient to just tell Alexa to shut the main valve when I need to do any plumbing maintenance.
Let me add a few of my favorite automations to that list:
Lot a little things like that which make life easier!
Depends on the application. Personally I find Zigbee motion sensors respond faster than Zwave.
This might be less of an issue now with the new C-7. The difference for me was 1-2 seconds with a zwave Aeotec multi sensor vs 0.25-0.5s with the Zigbee sensors I linked above.
It could have been just the particular sensors, or my specific setup, that caused the time discrepancy however. I suggest asking others for a broader sample size.
Itās not the biggest deal in the world but when I walk into a dark room, 1-2 seconds stumbling blindly isnāt much fun for me. Having the lights come on virtually instantly is nice.
Itās like magic. When paired with a leak sensor - the Samsung smart thing sensors work well for me - itās a life saver. I put one on top of the drain in my basement and caught the drain backing up when the water rose by just a centimeter. Turned off the main, which stopped the sink that was filling up the pipe that needed to be snaked. Saved me a big mess. I now have water sensors under every faucet, next to every drain - the sensors also detect temperature so I can have my heater turn on if Iām away from home and temps drop too low - I donāt want frozen pipes up here in the Midwest.
My house was built in the 1920s so I went with this unit to turn off my main. Itās zwave. https://www.amazon.com/dp/B07DJZCFBH/
My z-wave+ and zigbee sensors respond approximately the same. Motion automations to turn on a light is under 200ms in both instances.
Surely you mean 0.25-0.5s? My automation response times are 130-200 ms using node-red.
Yeah I use the EcoNet bulldog which works great too...
For extra fun you can strap a cheap contact sensor on the handle and base and have secondary confirmation that the valve opened or closed. I also have a rule that triggers each month to open/close so the valve won't get stuck.
Simulating occupancy does not necessarily mean while you are away. I like to tell my clients that it is a good idea to set up a basic schedule of lights that happen regardless of whether you are home or not. That way it makes it less obvious when the house is empty. Once you are away different rules can kick in that are more aggressive - more notifications etc. Also maybe toggling additional lights not included in the schedule that you would normally do manually.
Yup. Typo. 0.25s-0.5s
