What do I need at Ikea?
Ouch!
Oh, I agree that it generates a lot of traffic and needs to be sparingly used. I definitely wouldn’t use it for a Generic Switch/Button but they built ins could be even more specific about attributes.
(endpoint = *, cluster = 0x0406, attribute = 0x0000)  // Occupancy -> motion
(endpoint = *, cluster = 0x0400, attribute = 0x0000)  // Illuminance -> MeasuredValue (uint16, scaled)
(endpoint = *, cluster = 0x002F, attribute = 0x000C)  // PowerSource -> BatPercentRemaining
(endpoint = *, cluster = 0x002F, attribute = 0x000A)  // PowerSource -> BatVoltage (fallback)
Here it comes : "IKEA BILRESA Matter Buttons" :
 * IKEA BILRESA Matter Dual Button (events-based). Supports both dual button and scroll wheel models.
 * Last edited: 2026/05/16 10:49 PM
 * WARNING:
 * This driver runs on pure magic, optimism, and several offerings to the Hubitat gods.
 * Magic activation spell (do NOT remove):
import hubitat.device.HubAction
import hubitat.device.Protocol
metadata {
    definition(name: "IKEA BILRESA Matter Buttons w/ healthStatus", namespace: "community", author: "kkossev + ChatGPT + Claude", singleThreaded: true, importUrl: "https://raw.githubusercontent.com/kkossev/hubitat/development/Drivers/Ikea%20Matter/IKEA%20BILRESA%20Matter%20Buttons.groovy") {
        capability "Initialize"
        capability "Refresh"
        capability "Battery"
        capability "HealthCheck"
        capability "PushableButton"
        capability "HoldableButton"
        capability "DoubleTapableButton"
        capability "ReleasableButton"
        attribute "supportedButtonValues", "enum", ["pushed", "held", "doubleTapped", "tripleTapped", "released"]
        attribute "tripleTapped", "number"
        attribute "numberOfButtons", "number"
        attribute "healthStatus", "enum", ["online", "offline"]
        attribute "rtt", "number"
        command   "tripleTap", [[name: "buttonNumber", type: "NUMBER"]]
        fingerprint endpointId:"01", inClusters:"0003,001D,003B", outClusters:"", model:"BILRESA dual button", manufacturer:"IKEA of Sweden", controllerType:"MAT"
        fingerprint endpointId:"01", inClusters:"0003,001D,003B", outClusters:"", model:"BILRESA scroll wheel", manufacturer:"IKEA of Sweden", controllerType:"MAT"
    preferences {
        input name: "txtEnable",         type: "bool", title: "Enable descriptionText logging",                                    defaultValue: true
        input name: "logEnable",         type: "bool", title: "Enable debug logging",                                        defaultValue: false
        input name: "enableHealthCheck", type: "bool", title: "Enable health check (ping every 15 min)",                   defaultValue: true
        input name: "enableAutoReInit",  type: "bool", title: "Auto re-initialize after 2 consecutive ping failures",      defaultValue: true
void parse(String description) {
    logDebug "parse(String) called - ignored (newParse:true mode only)"
// parse(Map) - newParse:true format only
// Attribute report  : [callbackType:Report, endpointInt:0, clusterInt:47, attrInt:12, value:200]
// Switch event      : [callbackType:Event,  endpointInt:1, clusterInt:59, evtId:1,    value:[0:1]]
// MultiPressComplete: [callbackType:Event,  endpointInt:1, clusterInt:59, evtId:6,    value:[0:1, 1:2]]
void parse(Map msg) {
    logDebug "parse(Map) received: ${msg}"
    handleLiveness(msg)
    // Ping response (explicit) or implicit ping success (any msg while ping in-flight)
    if (state.pingStart != null) {
        unschedule("pingTimeout")
        Long rtt = now() - (state.pingStart as Long)
        if (msg.clusterInt == 0x0028 && msg.attrInt == 0x0000) {
            sendEvent(name: "rtt", value: rtt, unit: "ms", type: "digital", descriptionText: "Ping round-trip time: ${rtt} ms")
            logInfo "Ping RTT: ${rtt} ms"
            state.pingStart = null
            return   // ping response fully handled
        logDebug "Implicit ping success (msg arrived while ping in-flight), RTT: ${rtt} ms"
    boolean isEvent = msg.evtId != null
    // Battery report (EP0)  Example: [callbackType:Report, endpointInt:0, clusterInt:47, attrInt:12, value:200]
    if (msg.endpointInt == 0x00 && msg.clusterInt == 0x002F && msg.attrInt == 0x000C) {
        Integer raw = safeInt(msg.value)
        if (raw != null) {
            Integer pct = Math.round(raw / 2.0f)
            pct = Math.max(0, Math.min(100, pct))
            sendEvent(name: "battery", value: pct, unit: "%", descriptionText: "Battery is ${pct}%", type: "physical", isStateChange: true)
            logInfo "Battery is ${pct}%"
        return
    // SubscriptionResult: signals end of post-subscribe event burst — safe to accept events now
    // Example: [callbackType:SubscriptionResult, subscriptionId:3743154004]
    if (msg.callbackType == "SubscriptionResult") {
        clearInitPending()
        return
    // Switch event  Example: [callbackType:Event, endpointInt:2, clusterInt:59, evtId:4, value:[0:1]]
    if (isEvent && msg.clusterInt == 0x003B) {
        handleSwitchEvent(msg)
        return
    // Switch attribute reports - ignore explicitly
    if (msg.clusterInt == 0x003B && !isEvent) {
        logDebug "newParse(Map): ignoring switch attribute report ep=${msg.endpointInt} cluster=${msg.clusterInt} attr=${msg.attrInt} value=${msg.value}"
        return
    // Software version string (Basic Information cluster 0x0028, attr 0x000A)
    if (msg.clusterInt == 0x0028 && msg.attrInt == 0x000A) {
        String ver = msg.value?.toString() ?: ""
        device.updateDataValue("softwareVersion", ver)
        logInfo "softwareVersion=${ver}"
        return
    // ignore everything else
    logDebug "newParse(Map): unhandled msg: ${msg}"
// Handle switch events from cluster 0x003B (newParse:true format)
// Example: [callbackType:Event, endpointInt:1, clusterInt:59, evtId:1, value:[0:1]]
private void handleSwitchEvent(Map msg) {
    // Ignore noisy buffered events that arrive in the burst right after subscribing.
    // state.initPending is cleared when SubscriptionResult arrives (or after 120s fallback).
    if (state.initPending) {
        logDebug "Ignored switch event (ep=${msg.endpointInt} evtId=${msg.evtId}) - subscription still pending"
        return
    // Deduplicate by eventSerial: the same buffered events can be re-delivered across
    // multiple subscription bursts (e.g. after autoReInit). Reject clearly stale serials.
    // A tolerance window of 20 accommodates out-of-order delivery within a single press
    // sequence (the hub delivers even/odd serials in separate streams, a few apart).
    // Genuinely stale re-delivered events are typically 100s of serials behind.
    Long serial = msg.eventSerial as Long
    if (serial != null) {
        Long lastSerial = (state.lastEventSerial ?: 0L) as Long
        if (serial < lastSerial - 20L) {
            logDebug "Stale event rejected (ep=${msg.endpointInt} evtId=${msg.evtId} eventSerial=${serial} lastSerial=${lastSerial})"
            return
        if (serial < lastSerial) {
            logWarn "Out-of-order event (possibly stale from prev gesture): ep=${msg.endpointInt} evtId=${msg.evtId} serial=${serial} lastSerial=${lastSerial} delta=${serial - lastSerial}"
        if (serial > lastSerial) { state.lastEventSerial = serial }
    Integer buttonNumber = msg.endpointInt as Integer
    logDebug "handleSwitchEvent: buttonNumber=${buttonNumber} evtId=${msg.evtId}"
    switch (msg.evtId) {
        case 1:     // evt 1 – InitialPress; usually followed by LongPress or ShortRelease/MultiPress*
            state.lastButtonNumber = buttonNumber
            state.lastAction = "initialPress"
            state.buttonInitialPressTime = now()
            if (logEnable) { log.debug "EVT_INITIAL_PRESS buttonNumber=${buttonNumber} buttonInitialPressTime=${state.buttonInitialPressTime}" }
            if (isWheelModel() && isWheelEndpoint(buttonNumber)) {
                state.wheelPressCount = (state.wheelPressCount ?: 0) + 1
                logDebug "Initial press for wheel ep=${buttonNumber} (sending 'pushed' event)"
                sendButtonEventFiltered("pushed", buttonNumber)
            } else if (!isWheelModel()) {
                // Dual button: cancel pending timers from the previous gesture, then start the
                // hold-simulation timer. If evtId=3 (ShortRelease) arrives within 750ms it cancels
                // this timer (short press). If 750ms elapses without evtId=3, holdSimulate() fires
                // "held" immediately (the device batches evtId=2+4 and delivers them only after release).
                unschedule("singlePressComplete")
                unschedule("holdSimulate")
                state.holdSimulateButtonNumber = buttonNumber
                runInMillis(750, "holdSimulate")
            break
        case 2:     // evt 2 – LongPress
            logDebug "EVT_LONG_PRESS buttonNumber=${buttonNumber}"
            unschedule("singlePressComplete")   // Dual button: cancel pending single-tap timer
            unschedule("holdSimulate")           // Dual button: cancel hold-simulation timer (defensive)
            if (!isWheelModel() && (state.holdSimulatedForButton as Integer) == buttonNumber) {
                // Dual button: holdSimulate() already fired "held" — suppress the duplicate
                // (evtId=2 arrives batched, seconds after the hold ends)
                logDebug "EVT_LONG_PRESS: held already simulated for button ${buttonNumber}, skipping"
                state.holdSimulatedForButton = null
            } else {
                sendButtonEventFiltered("held", buttonNumber)
            break
        case 3: // 3 – ShortRelease
            logDebug "EVT_SHORT_RELEASE buttonNumber=${buttonNumber}"
                logDebug "Short-release for wheel ep=${buttonNumber} (logged, continuing)"
                // Dual button: ShortRelease fires only for short presses (holds fire evtId=4, never evtId=3).
                // Cancel hold-simulation timer — this is a short press, not a hold.
                // Schedule single-tap 'pushed'; cancelled by the next evtId=1 (multi-tap) or evtId=5.
                // 400 ms gives the second press of a double-tap time to arrive and cancel the timer.
                runInMillis(400, "singlePressComplete")
            sendButtonEventFiltered("released", buttonNumber)
            break
        case 4:     // 4 – LongRelease
            logDebug "EVT_LONG_RELEASE buttonNumber=${buttonNumber}"
            break
        case 5:     // evt 5 – MultiPressOngoing; value:[0:previousPosition, 1:totalNumberOfPressesSoFar]
            // The dual button never sends evtId=6 (MultiPressComplete), so we use evtId=5 as the
            // trigger: store the running count and debounce-fire after 300 ms of silence.
            // The scroll wheel does send evtId=6, so skip the debounce for that model entirely.
            Integer ongoingCount = safeInt(msg.value[1])
            logDebug "EVT_MULTI_ONGOING buttonNumber=${buttonNumber} count=${ongoingCount}"
            if (ongoingCount != null && !isWheelModel()) {
                unschedule("singlePressComplete")   // Dual button: cancel single-tap timer, it's a multi-press
                state.multiPressCount = ongoingCount
                state.multiPressButtonNumber = buttonNumber
                runInMillis(150, "multiPressComplete")
            break
        case 6:     // evt 6 – MultiPressComplete; value:[0:previousPosition, 1:totalNumberOfPresses]
                // Dual button: evtId=6 always arrives late (stale from prev gesture; serial is adjacent
                // to the new gesture so dedup cannot filter it). Completely ignore it.
                // singlePressComplete() and multiPressComplete() handle all dual-button events.
                logDebug "EVT_MULTI_COMPLETE: ignored for dual-button model (always arrives late/stale)"
                break
            // Wheel model only from here:
            unschedule("multiPressComplete")
            Integer count =  safeInt(msg.value[1])
            logDebug "EVT_MULTI_COMPLETE buttonNumber=${buttonNumber} count=${count}"
            if (count == null) {
                logDebug "Invalid MultiPressComplete event value: ${msg.value}"
                break
                Integer firedCount = (state.wheelPressCount ?: 0) as Integer
                Integer missed = Math.max(0, count - firedCount) as Integer
                logDebug "Multi complete for wheel ep=${buttonNumber} count=${count} firedCount=${firedCount} missed=${missed}"
                if (missed > 0) {
                    missed.times { sendButtonEventFiltered("pushed", buttonNumber) }
                state.wheelPressCount = 0
                return
            if (count == 1) {
            else if (count == 2) {
                sendButtonEventFiltered("doubleTapped", buttonNumber)
            else if (count == 3) {
                sendButtonEventFiltered("tripleTapped", buttonNumber)
            else {
            break
        default:
            logDebug "Unhandled switch event evtId=${msg.evtId} ep=${msg.endpointInt} msg=${msg}"
            break
void clearInitPending() {
    unschedule("clearInitPending")
        state.initPending = false
        logInfo "accepting button events now..."
// Fired 800 ms after evtId=1 when no evtId=5 (multi-press) or evtId=2 (hold) cancelled it.
// Handles single-tap 'pushed' for the dual button model.
// (evtId=6 is completely ignored for dual button — it always arrives ~17 s late.)
void singlePressComplete() {
    Integer button = state.lastButtonNumber as Integer
    logDebug "singlePressComplete() buttonNumber=${button}"
    if (button == null) { return }
    sendButtonEventFiltered("pushed", button)
// Fired 750ms after evtId=1 (InitialPress) when evtId=3 (ShortRelease) has not cancelled it first.
// Simulates 'held' immediately — the device batches evtId=2+4 and only delivers them after release.
// Sets holdSimulatedForButton so case 2 (LongPress) suppresses the duplicate when it arrives late.
void holdSimulate() {
    Integer button = state.holdSimulateButtonNumber as Integer
    logDebug "holdSimulate() buttonNumber=${button} - firing simulated held"
    state.holdSimulatedForButton = button
    sendButtonEventFiltered("held", button)
// Fired 150 ms after evtId=5 (MultiPressOngoing) for the dual button model.
// evtId=6 is completely ignored for dual button — it always arrives ~17 s late.
// count=2 → doubleTapped; any other count is ignored (dual button does not support triple-tap).
void multiPressComplete() {
    unschedule("singlePressComplete")   // Safety: hub can deliver evtId=3 after evtId=5 (out-of-order serials)
    unschedule("holdSimulate")           // Safety: cancel hold-simulation if still pending
    Integer count  = state.multiPressCount as Integer
    Integer button = state.multiPressButtonNumber as Integer
    logDebug "multiPressComplete() buttonNumber=${button} count=${count}"
    if (count == null || button == null) { return }
    if (count == 2) {
        sendButtonEventFiltered("doubleTapped", button)
    } else {
        logDebug "multiPressComplete: count=${count} unhandled, ignoring (button=${button})"
/* ---------- health check ---------- */
private void handleLiveness(Map msg) {
    // Cancel pending auto-reinit — any Matter message means the device is alive
    unschedule("autoReInit")
    // Reset consecutive fail counter on any activity
    state.pingConsecutiveFails = 0
    // If device is not yet online (null on first boot) or was offline, mark it online
    if (device.currentValue("healthStatus") != "online") {
        sendEvent(name: "healthStatus", value: "online", descriptionText: "${device.displayName} is online", type: "digital")
        logInfo "Device is back online"
void ping() {
    deviceHealthCheck()
void deviceHealthCheck() {
    if (enableHealthCheck == false) { return }
        logDebug "deviceHealthCheck() skipped — subscription still pending"
        return
    logDebug "deviceHealthCheck() - sending DataModelRevision read"
    state.pingStart = now()
    List<Map<String,String>> paths = [matter.attributePath(0x00, 0x0028, 0x0000)]
    sendHubCommand(new HubAction(matter.readAttributes(paths), Protocol.MATTER))
    runIn(30, "pingTimeout")
    // Battery staleness check: if no battery report in the last 12 hours, request a fresh read
    def lastBat = device.currentState("battery")
    if (lastBat == null || (now() - lastBat.date.time) > 12 * 3600 * 1000L) {
        logWarn "No battery report in >12h — requesting battery attribute read"
        sendHubCommand(new HubAction(matter.readAttributes([matter.attributePath(0x00, 0x002F, 0x000C)]), Protocol.MATTER))
    } else {
        logDebug "Battery report is recent (last: ${lastBat.date})"
void pingTimeout() {
    state.pingConsecutiveFails = (state.pingConsecutiveFails ?: 0) + 1
    if (state.stats == null) { state.stats = [:] }
    state.stats.pingFailCounter = (state.stats.pingFailCounter ?: 0) + 1
    sendEvent(name: "rtt", value: -1, unit: "ms", type: "digital", descriptionText: "Ping timeout (consecutiveFails=${state.pingConsecutiveFails})")
    logWarn "Ping timeout! consecutiveFails=${state.pingConsecutiveFails} (total pingFails=${state.stats.pingFailCounter})"
    if (state.pingConsecutiveFails >= 2) {
        sendEvent(name: "healthStatus", value: "offline", descriptionText: "${device.displayName} is offline", type: "digital")
        logWarn "Device is OFFLINE after ${state.pingConsecutiveFails} consecutive ping failures"
        if (enableAutoReInit != false) {
            logWarn "Auto re-init scheduled in 30 seconds"
            runIn(30, "autoReInit")
void autoReInit() {
    state.stats.autoReInitCounter = (state.stats.autoReInitCounter ?: 0) + 1
    logWarn "Auto re-initializing after failed health checks (autoReInitCounter=${state.stats.autoReInitCounter})"
    initialize()
void installed() {
    state.stats = [initializeCounter: 0, pingFailCounter: 0, autoReInitCounter: 0]
    initialize()
void updated() {
    logInfo "updated..."
    if (logEnable) runIn(7200, "logsOff")
    initialize()
void logsOff() {
    device.updateSetting("logEnable", [value: "false", type: "bool"])
    log.warn "${device.displayName} Debug logging disabled"
void initialize() {
    if (state.stats == null) { state.stats = [initializeCounter: 0, pingFailCounter: 0, autoReInitCounter: 0] }
    state.stats.initializeCounter = (state.stats.initializeCounter ?: 0) + 1
    unschedule("deviceHealthCheck")
    logInfo "initialize... (initializeCounter=${state.stats.initializeCounter})"
    if (getDataValue("newParse") != "true") { device.updateDataValue("newParse", "true") }
    logInfo "model=${device.getDataValue('model') ?: device.model} endpoints=${endpointCount()} newParse=${getDataValue("newParse")} uptime=${location.hub.uptime}"
    configureButtons()
    subscribeToPaths()
    refresh()
    if (enableHealthCheck != false) { runEvery5Minutes("deviceHealthCheck") }
private void configureButtons() {
    Integer count = endpointCount()
    sendEvent(name: "numberOfButtons", value: count, isStateChange: true)
    // Wheel model supports triple-tap (evtId=6 count=3); dual button does not.
    def vals = isWheelModel()
        ? ["pushed", "held", "doubleTapped", "tripleTapped", "released"]
        : ["pushed", "held", "doubleTapped", "released"]
    sendEvent(name: "supportedButtonValues", value: vals.toString(), isStateChange: true)
// Return number of endpoints/buttons for this device model (2 or 9)
private Integer endpointCount() {
    String model = (device.getDataValue("model") ?: device.model ?: "").toString().toLowerCase().trim()
    if (model.contains("scroll")) return 9
    return 2
// Wheel helpers: preserved so callers can detect wheel models/endpoints.
private boolean isWheelModel() {
    return model.contains("scroll")
private boolean isWheelEndpoint(Integer ep) {
    if (ep == null) return false
    return [1,2,4,5,7,8].contains(ep)
/* ---------- subscriptions & refresh ---------- */
void refresh() {
    logDebug "refresh()"
    List<Map<String,String>> paths = []
    // Battery percent (raw 0..200)
    paths.add(matter.attributePath(0x00, 0x002F, 0x000C))
    // Software version string (Basic Information cluster)
    paths.add(matter.attributePath(0x00, 0x0028, 0x000A))
    // (0x00, 0x0033, 0x0002) = UpTime attribute in General Diagnostics cluster, useful for testing liveness and event flow during health check pings. Optional in Matter, but if supported by the device, it will be included in the refresh read and cause ping RTTs to be logged in the rtt attribute. If not supported, no harm done, just no RTT updates.
    paths.add(matter.attributePath(0x00, 0x0033, 0x0002))
    String cmd = matter.readAttributes(paths)
    sendHubCommand(new HubAction(cmd, Protocol.MATTER))
private void subscribeToPaths() {
    // Battery attribute
    // Subscribe per-endpoint for switch attributes & events (EP1..EPN)
    Integer epCount = endpointCount()
    // 0x003B attr 0x0001 = PresentValue(CurrentState)
    // Subscribing to this attribute seems to 'unlock' or keep events flowing.
    // Probably, other Matter switches also require any attribute subscription to activate event streams?
    for (int ep = 1; ep <= epCount; ep++) {
        paths.add(matter.attributePath(ep, 0x003B, -1))      // Switch cluster attribute 0x0001 (current position) seems to be enough
    // matter events are always enabled
        paths.add(matter.eventPath(ep, 0x003B, -1))         // We need to subscribe for ALL events from the switch cluster
    // General Diagnostics cluster: UpTime attribute
    // EP0 / Cluster 0x0033 / Attr 0x0002 = UpTime
    // This is optional in Matter, but useful to test whether the device reports periodic changes.
    paths.add(matter.attributePath(0x00, 0x0035, 0x0005))  // RSSI, if implemented
    String cmd = matter.cleanSubscribe(0, 600, paths)        // 05/2026 update: using 0-600s reporting interval
    logDebug "subscribeToPaths cmd=${cmd}"
    // Block events until SubscriptionResult confirms the burst is done; 120s fallback covers slow reconnects after hub reboot.
    state.initPending = true
    runIn(120, "clearInitPending")
    logInfo "subscribing to switch events (EP1..EP${epCount}) + battery (EP0/0x002F/0x000C)"
private void sendButtonEventFiltered(String type, Integer buttonNumber) {
    // Filter 'released' events: only allow if previous action for the same
    // button was 'held'. Otherwise ignore the release (single press).
    if (type == "released") {
        def lastNum = state.lastButtonNumber
        def lastAct = state.lastAction
        if (lastNum != buttonNumber || lastAct != "held") {
            logDebug "Ignored release for button ${buttonNumber} (previous=${lastAct} button=${lastNum})"
            return
    if (txtEnable) log.info "${device.displayName} button ${buttonNumber} ${type}"
    sendEvent(name: type, value: buttonNumber, isStateChange: true, type: "physical")
    // Persist last button event parameters for future filtering
    state.lastAction = type
    state.lastButtonTime = now()
/* ---------- dashboard commands ---------- */
void push(buttonNumber) {
    Integer btn = safeInt(buttonNumber)
    if (btn == null) return
    String descriptionText = "${device.displayName} button ${btn} was pushed"
    if (txtEnable) log.info descriptionText
    sendEvent(name: "pushed", value: btn, descriptionText: descriptionText, isStateChange: true, type: "digital")
void hold(buttonNumber) {
    String descriptionText = "${device.displayName} button ${btn} was held"
    sendEvent(name: "held", value: btn, descriptionText: descriptionText, isStateChange: true, type: "digital")
void doubleTap(buttonNumber) {
    String descriptionText = "${device.displayName} button ${btn} was doubleTapped"
    sendEvent(name: "doubleTapped", value: btn, descriptionText: descriptionText, isStateChange: true, type: "digital")
void tripleTap(buttonNumber) {
    String descriptionText = "${device.displayName} button ${btn} was tripleTapped"
    sendEvent(name: "tripleTapped", value: btn, descriptionText: descriptionText, isStateChange: true, type: "digital")
void release(buttonNumber) {
    String descriptionText = "${device.displayName} button ${btn} was released"
    sendEvent(name: "released", value: btn, descriptionText: descriptionText, isStateChange: true, type: "digital")
/* ---------- helpers ---------- */
private Integer safeInt(def v) {
    try {
        if (v == null) return null
        return Integer.parseInt(v.toString(), 10)
    } catch (Exception ignored) {
        return null
private void logDebug(String msg) {
    if (logEnable) log.debug "${device.displayName} ${msg}"
private void logInfo(String msg) {
    if (txtEnable) { log.info "${device.displayName} ${msg}" }
private void logWarn(String msg) {
    if (logEnable) { log.warn "${device.displayName} ${msg}" }
It’s very important to have a stable Thread network for these buttons to work reliably. Yesterday I had quite a few strange and unexplainable issues with the IKEA buttons and was close to giving up… :frowning:
After adding a mains-powered Matter-over-Thread device (Onvis Smart Plug S4) to the same Thread network where all the IKEA battery-powered gadgets were paired, the performance improved significantly. …I haven’t missed a keypress since.
Update: after rebooting the hub, the BILRESA dual button stopped sending keypress events again… :sob:
Back to the drawing board.
Update2: The problem was found and fixed (this device does not support wildcard subscription using the form paths.add(matter.eventPath(-1, 0x003B, -1))). Keypress events are now registered correctly even after a hub reboot.
Update3: Added support for BILRESA scroll wheel :
  • buttons #3, #6, #9 : pushed/doubleTapped/held/released events for each of the three groups (selected by pressing the lower button, the LED indicates the group). It can be used for switching a light on/off and to start/stop dimming.
  • Buttons 1 and 2: clockwise and counter-clockwise events for group #1 on wheel rotation.
  • Buttons 4 and 5: clockwise and counter-clockwise events for group #2 on wheel rotation.
  • Buttons 7 and 8: clockwise and counter-clockwise events for group #3 on wheel rotation.
    The wheel 'pushed' events are coming quickly and can be used for step dimming up/down a light.
Update4: added Magic activation spell :magic_wand:
Update5: added the missing standard HE methods pushed() hold() doubleTap() released() for use with HE dashboards.
Update6: temporarily patched code (enforcing newParse=false) as a workaround for the BILRESA dual button new firmware version 1.9.15. Single and double clicks are working, button held event does not work OK.
Update7: the code is now working with newParse=true (as the stock driver does).
Update8: softwareVersion is updated on refresh()
Update9: healthStatus and auto-reinitialize!
Update10: held event simulated for the Dual Button
Latest code is available on GitHub :
VOTE FOR Matter event subscriptions: expose EventPathIB.IsUrgent for low-latency Generic Switch / button events
All the excitement in this thread wore me down ...
Thank you.
Do I need a Matter hub for this to work? I have a Tapo matter plug and Kasa matter switches paired with Hubitat.
For IKEA Matter over Thread devices you will need a Thread Border Router (TBR) in your network, such as Apple TV 4K, HomePod mini, Google Nest Hub/Nest WiFi Pro, Amazon Echo with Thread, SmartThings Hub (Thread-enabled models), Aqara Matter hub, Tuya Matter hub with Thread radio, or IKEA Dirigera hub.
For Matter over Wifi devices (such as Tapo matter plug and Kasa matter switches) you do not need another hub.
I’ve got one more TBR than you. :slight_smile:
  • iPod Mini - tv=1.3.0 nn=MyHome61
  • Aqara M3 - tv=1.3.0 nn=MyHome61
  • DIRIGERA - tv=1.4.0 nn=MyHome61
  • SmartThings - tv=1.4.0 nn=ST-464545445
  • Tuya - tv=1.4.0 nn=TMSthread_1693
  • Tuya - tv=1.4.0 nn=TMSthread_8ce3
Does this mean that Apple, Aqara, and DIRIGERA have somehow managed to join and form a single Thread network? :thinking:
Yes, I believe so. I believe that since you probably commissioned all three of those systems using your iPhone, the respective apps on your iPhone all joined the same Apple Home's Thread Mesh Network. My guess is that this was a design choice by the developers of those apps (i.e. Aqara and IKEA) to do so. If your ST Hub was commissioned before Matter even existed, it might make sense that when ST added Matter support later, they just created their own Thread network. I wonder if a new ST hub was commissioned today using your iPhone, would it also join the same Apple Home thread network??? Not sure about the Tuya devices, as I have zero experience with those.
Which Tuya devices are these? I'm looking for some smart plus with Thread (the IKEA GRILLPLATS isn't available yet).
I can share that with the Samsung TV hubs that have thread, they still default to their own thread network rather than merge into an existing one even with an iPhone. I just set up a Samsung TV a few weeks ago with an iPhone and it created its own network.
I might just buy a SmartThings hub to see if I can get it onto the main thread network.
A bare pittance of TBRs here...two Homepods and a Google Nest Hub.
  • Both Homepods (commissioned w/iPhone) are on the same thread network: MyHome1078....
  • Google Nest Hub was set up via Android before the Homepods and is on its own thread network: Nest-Pan-2288
All three are tv 1.3.0 so I'm on the lagging devices (compared to IKEA, SmartThings, and Tuya) in terms of thread updates. :slight_smile:
Thanks, don't want to spend on additional hubs, maybe net version of Hubitat will have Thread Border Router.
Got an Ikea Contact sensor. Paired with Apple home no problem. Used Home to put it in pairing mode. Entered code in HE. HE never finds it. Just keeps saying searching for device. Light on contact sensor is blinking. Tried several times with same results.
Try rebooting your hubitat hub before pairing the Matter device with it using the Apple Home QR code.
I suppose you have other Matter devices already brought to HE the same way?
I do have other matter devices paired same way . Wil try the reboot.
Reboot didn’t help
I don’t know what to try next…
Probably removing the contact sensor from Apple Home and then pairing it again, and another attempt to pair it to HE?
I also have problems with the buttons, they stop sending events randomly to Hubitat and need re-initialization.
At the same time the performance on Apple Home is stable… :thinking:
This is really weird. When adding in HE it just shows searching for device. But quite by accident I noticed it was in the device list. Never did see a confirmation that it was added.
It used your driver by default. But the open/close was backwards. I changed the driver to the built in generic matter contact and then it is correct. I will have to play with it some more to verify everything, but at the moment it is working.
When using the generic matter contact sensor driver, every time the contact opens or closes I get the following messages in the log. I do have the debugging turned off.
dev:34082025-12-27 05:31:49.883 AMdebugdescMap: [endpoint:01, cluster:0045, attrId:0000, value:01, clusterInt:69, attrInt:0]
dev:34082025-12-27 05:31:47.194 AMdebugdescMap: [endpoint:01, cluster:0045, attrId:0000, value:00, clusterInt:69, attrInt:0]
When using your driver, the small one, I don't get the messages but the open/close is still backwards.
I will fix the ChatGPT driver later today.
This device is reporting the contact state and the battery level rather frequently (every 10 to 15 minutes), maybe it is a good idea to filter these frequent reports and to show the battery level (and the contact state) only once every 4 hours, as an indication that the device is online .
