Continuing the discussion from WebCore Graph Oauth failed?:
This closed one year ago, but I am having the same problem. the OAuth seems to be failing. First question: since this graphing function is based on Hubigraphs code, do I have to delete the old (Unsupported) Hubigraphs? If this isn't the problem then I am at a loss.
I used to use Webcore on my Smartthings but after moving to Hubitat 5 years ago I have pretty much found a way to do everything I did in WebCore in RM. Now that you are supporting Hubigraphs, which I used quite a bit, and that Hubitat is supporting webCore, I may have to start looking back into using webCore for automation. I used to love it on Smartthings.
Also. I need to look into setting up my own webCore server. Why does the self-hosted option not support all the same features that the cloud-hosted version does? can someone point me to the instructions to setup my own server?
LJ
