When i click enable api,
It fails...
What can i do??
Are you installed via HPM, or the built-in ?
I'll work with Victor on a fix. You will have to wait for us to get a fix out for the built-in version.
Sorry for the trouble. We'll get it.
Thankt alot!
So next build that HE pushes out should have a fix.
Once that is out let me know what you find.
I updated my Hub to version.138. And re-installed webcore...
But same... nothing changed
on me...I did not push the update to the repo....
Will work this...
So try again with latest HE firmware update.
Working now!
Is this graph only works in local network?
In general, yes local network (that is how hubigraphs operates). There are scenarios it uses a web socket to update data, and that only works local to the hub.
And where can i find "write to fuel stream" in action???
you want append to fuel stream to add data to a stream
It takes about a hour to show in the fuel stream.
you should be able to logout on the browser, then only login to what you want.
