Pistons will trigger based on your selections. If you select both on and off events, both will trigger. Don’t recall that I had to change any of the pistons that I imported from ST (outside of the devices) to make them work as expected.
These are additional trigger types, and the existing trigger types are unchanged.
I hope this is the right group to ask this. I updated my Hubitat app to the latest Hubitat patches at the top of this topic - 0825. Now I am unable to access my pistons - it just gives me an error at the top that says dashboards could not be loaded - then it does nothing after that.
I have tried logging out then back in registering another browser - nothing works.
my pistons still work if I run them from hubitat - Any suggestion what I need to do to get my webcore interface running again?
---EDIT---
I reset all tokens, set new password, register new browser, went to dashboard.webcore.co - it eventually asked for password. Put in new password and exactly when the error message hit the browser, I got this log in my hubitat logs:
[app:13](http://xxxx/logs#app13)2021-08-27 04:17:31.828 pm [error](http://xxxx/installedapp/configure/13)groovy.lang.MissingMethodException: No signature of method: static hubitat.helper.RMUtils.getRuleList() is applicable for argument types: (java.lang.String) values: [4.1] Possible solutions: getRuleList() on line 4033 (api_intf_dashboard_load)
Thanks, TODDL
what version of HE firmware are you running?
(TODDL reply to what HE firmware)
Hubitat Elevation® Platform Version
2.2.7.128
Hardware Version
Rev C-7 (edit) looks like this is a few versions old --> I will try to update
FINAL UPDATE - upgrade ultimately fixed it - but had to revoke all tokens and register browser again - but thankfully I can now edit my pistons again and make sure I have good backups just in case. - Thanks to nh.schottfam for poking me in that direction. --TL
I also have the set variable issue. I have tried to update using HPM but it doesn't recognize webcore as being a managed package although it is listed in packages. Is there another way to update or repair?
you can update the webcore main and piston source file
Also, you can ask HPM to match again, or re-install HPM
Thanks! I didn't think about reinstalling HPM, I was obsessing over having to reinstall webcoRE. Reinstalling HPM was the ticket. Worked like a charm!
Hi Everyone I've been spending hours trying to get this to work without success
I would highly appreciate some help
When i click on Dashboard (in the HE app) i get this:
When i click on "register a browser" i get this:
I enabled full logs - yet, this is all i get:
Here is my settings:
Testing the local endpoint url:
App version (From HPM)
HE Version:
Here is the repo im using:
- tried https://github.com/jp0550/webCoRE.git as well with the same branch name without success
My apache config:
Here is the network log from the browser when i try to register
It looks like the url is missing some "/" and it also calls "https" and not "http"
online version without custom url works
i tried to clean all the cache and security and reinstall webCoRE and HPM and also reinstall webcore on pi and restart pi and the hub - it did not make a difference
Please help!
I went into Webcore to change something in a piston I hadn't touched in a very long time. Next to every Set Level xx% command for some zigbee bulbs there was "(?)". When I went into each command and saved it without changing anything, the question mark went away. What does (did) the question mark mean? Searched this topic and all of the HE forums and didn't find anything.
@ipaterson any thoughts?
I'm getting this error when I control Hue bulbs with an inovelli scene. What does it mean?
org.codehaus.groovy.runtime.InvokerInvocationException: java.lang.StackOverflowError (deviceHandler)
I would try a polite reboot of your HE hub. Not seen this before.
HE console -> settings -> reboot
You also could shutdown (politely), power off the hub for 1 min, and restart.
I have posted a new release (but have not forced it on everyone).
- use HPM repair to install it
It adds support for hub variables to webCoRE.
You should be running recent HE firmware to use this. (I suggest 2.2.9.134 or later)
Hub variables are referenced in webCoRE via @@variablename
So if you have a hub variable called 'foo'
in webCoRE you would reference this via @@foo
These work like other variables in webCoRE
- you can get events (trigger on them) if they change
- you can see them in the webCoRE IDE
Note that HE requires you to create hub variables via the HE console -> settings -> 'Hub Variables'
- once created, webCoRE can use them (read, or update, or trigger from them)
- also note that types are limited. (integer, bigdecimal, boolean, string, datetime (which for webCoRE should work for time, date, and datetime))
- webCoRE automatically maps webCoRE types to HE hub variable types.
- the webCoRE IDE can change the value of a @@ variable while you are in piston edit mode.
This change did not break webCoRE global variables @variable name
If you were using webCoRE super variables (the previous @@ format) - my apologies.
Feedback welcome
Few Q&A
do I do anything special to use them?
- not really - just use them like other webCoRE variables (albeit only for types supported) and webCoRE will handle and conversion between HE formats and webCoRE formats. Ie you can just assign values to them the way you do today with other variables.
- you can assign a webCoRE date, time or datetime to hub datetime type seamlessly
- same for string, integer, boolean and decimal webCoRE types
- you need to create them in HE console before you can use them
how do they update?
- they update in realtime, and changes can cause change events to be generated by the HE firmware.
should I use these all the time?
- your call, but if you don't want to clutter the hub variable view (or deal with name collisions), I suggest use them when you need to share data across apps (that are not webCoRE). Otherwise local variables and webCoRE globals are useful.
- scopes
- piston local variables - only piston sees them
- webCoRE global variables - only webCoRE pistons on this node can see them
- HE hub variables - all apps on this hub can see them, and perhaps other hubs in the future
- scopes
Can I create them in the webCoRE IDE? (when editing a piston)
- you use to be able to create them from the webCoRE IDE, but the HE folks have restricted this (for a variety of good reasons) that you can only create them from the HE console -> settings
- you can modify their value in the webCoRE IDE
- the webCoRE IDE will show their values
these also should work for remote access
webCoRE for Hubitat Updates - #904 by nh.schottfam
Just updated webcore and ran a simple rule I have to set day of week HE variables using the webcore constants. It said both HE variables were invalid, See below. It did work, however, I reset the HE variables before executing the webcore piston and they updated after running the piston to the correct values. I originally had them updating connectors, thought I would try the direct variable method? Is this not how you do it?
I received the same error and the hub variable is being updated correctly when reviewing in settings. Weird this would produce an error if it worked
I think I had the same issue, and I cleared the Webcore Cache.
I must recheck.
I am getting this error. The piston does what it should.
10/20/2021, 5:15:03 PM +462ms
+55ms ╔Received event [Home - Hub1].test = 1634764503462 with a delay of 0ms, canQueue: true, calledMyself: false
+61ms ║RunTime initialize > 60 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 58 56 4)
+66ms ║Runtime (5173 bytes) successfully initialized in 1ms (v0.3.113.20211005_HE)
+67ms ║╔Execution stage started
+70ms ║║Cancelling statement #1's schedules...
+74ms ║║Executed virtual command setVariable (2ms)
+88ms ║║Invalid variable @@Test
+91ms ║║Executed virtual command setVariable (13ms)
+97ms ║║Executed virtual command setVariable (1ms)
+101ms ║╚Execution stage complete. (33ms)
+104ms ╚Event processed successfully (51ms)
