Vacation Lighting. Anyone have it running?
I added 24h to the stop time and that gets the correct date:
2 2018-12-28 04:17:09.755 debugtimeWindowStop = Sat Dec 29 07:14:00 EST 2018 adjusted: Sat Dec 29 07:14:00 EST 2018
app:5602018-12-28 04:17:09.754 debugtimeWindowStop = Sat Dec 29 07:16:00 EST 2018 adjusted: Sat Dec 29 07:14:00 EST 2018
app:5602018-12-28 04:17:09.749 debugtimeWindowStart = Fri Dec 28 17:37:00 EST 2018
app:5602018-12-28 04:17:09.747 debugdaysOk = true
app:5602018-12-28 04:17:09.746 debugmodeOk = true
app:5602018-12-28 04:15:09.642 debugInstalled with settings: [frequency_minutes:17, number_of_active_lights:1, switches:[Living Dimmer, Dining Light, Hall Front Light, Bed Front Dimmer, Bed Side Dimmer, Master Bed Dimmer, Master Bath Light, Kitchen Dimmer, Bathroom Light], newMode:[Away], startTimeType:sunset, starting:2018-12-28T00:01:00.000-0500, endTimeType:sunrise, endTimeOffset:1440, people:[A, D]]
Tried starting 24h earlier: works fine.
Worked fine with a 1440 min delay:
app:5602018-12-28 17:39:00.284 debugreschedule 17 + 9 minutes
app:5602018-12-28 17:39:00.281 debugturned on Bed Side Dimmer
app:5602018-12-28 17:39:00.260 debuginactive switches: 9 numlight: 1
app:5602018-12-28 17:39:00.247 debugRunning
app:5602018-12-28 17:39:00.237 debughomeIsEmpty: true
app:5602018-12-28 17:39:00.218 debugtimeOk = true
app:5602018-12-28 17:39:00.196 debugtimeWindowStop = Sat Dec 29 07:16:00 EST 2018 adjusted: Sat Dec 29 07:14:00 EST 2018
app:5602018-12-28 17:39:00.193 debugtimeWindowStart = Fri Dec 28 17:37:00 EST 2018
app:5602018-12-28 17:39:00.191 debugdaysOk = true
app:5602018-12-28 17:39:00.189 debugmodeOk = true
app:5602018-12-28 17:37:00.050 debugstartTimeCheck
I will post some updates to vacation lighting director.
Some of the issues reported in times are related to differences in HE vs. Smartthings.
In Smartthings, the sunrise/sunset times adjust for scheduling into the future, where as in HE they do not, so code has to be added for this (new updates coming).
Another issue is the timeOfDayIsBetween, ST handles the above time adjustments, where HE does not.
Again the new code will fix this. Timehandling is incompatible in these functions between the platforms.
Thank you much.
Will test the new code when available.
Here is the beta version
importUrl: https://raw.githubusercontent.com/imnotbob/vacation-lighting-director/beta/smartapps/imnotbob/vacation-lighting-director.src/vacation-lighting-director.groovy
This is also available in HPM
Note this is branch beta
New code works great. Here is the log. I rebooted the hub at 3:44 am.
Both start and stop times say Saturday. It was Saturday when I installed the code.
The previous code would log wrong time and not start.
app:7152019-01-19 03:56:44.516 debugreschedule 20 + 2 minutes
app:7152019-01-19 03:56:44.514 debugturned on [Aeon LED Bulb]
app:7152019-01-19 03:56:44.388 debugturned on Living Dimmer
app:7152019-01-19 03:56:44.304 debuginactive switches: 10 numlight: 1
app:7152019-01-19 03:56:44.288 debugturned off Dining Light
app:7152019-01-19 03:56:44.064 debugRunning
app:7152019-01-19 03:56:44.012 debugtimeOk = true
app:7152019-01-19 03:56:43.953 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 03:56:43.926 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 03:44:11.678 debughad to reschedule 448, 1200
app:7152019-01-19 03:44:11.618 debugtimeOk = true
app:7152019-01-19 03:44:11.545 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 03:44:11.505 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 03:44:11.167 debugtimeOk = true
app:7152019-01-19 03:44:11.061 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 03:44:11.014 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 03:42:10.518 debugmodeChangeHandler com.hubitat.hub.domain.Event@541e9621
app:7152019-01-19 03:36:44.029 debugreschedule 20 + 3 minutes
app:7152019-01-19 03:36:44.028 debugturned on [Aeon LED Bulb]
app:7152019-01-19 03:36:43.993 debugturned on Dining Light
app:7152019-01-19 03:36:43.972 debuginactive switches: 10 numlight: 1
app:7152019-01-19 03:36:43.963 debugRunning
app:7152019-01-19 03:36:43.943 debugtimeOk = true
app:7152019-01-19 03:36:43.909 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 03:36:43.889 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 03:34:43.795 debugInstalled with settings: [frequency_minutes:20, number_of_active_lights:1, switches:[Living Dimmer, Dining Light, Hall Front Light, Bed Front Dimmer, Bed Side Dimmer, Garage Light, Master Bed Dimmer, Master Bath Light, Kitchen Dimmer, Bathroom Light], newMode:[Away], on_during_active_lights:[Aeon LED Bulb], startTimeType:sunset, endTimeType:sunrise, startTimeOffset:-15, people:[A, D]]
app:7152019-01-19 03:34:43.747 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 03:34:43.712 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
And here is the log from this morning. Worked perfect. The dates are correct.
app:7152019-01-19 07:48:41.434 debugmodeChangeHandler com.hubitat.hub.domain.Event@3b4971a4
app:7152019-01-19 07:48:41.383 debugmodeChangeHandler com.hubitat.hub.domain.Event@1bb93979
app:7152019-01-19 07:47:41.484 debugmodeChangeHandler com.hubitat.hub.domain.Event@dfba841
app:7152019-01-19 07:47:41.479 debugmodeChangeHandler com.hubitat.hub.domain.Event@5dca76b
app:7152019-01-19 07:47:41.408 debugmodeChangeHandler com.hubitat.hub.domain.Event@5a323a0e
app:7152019-01-19 07:47:41.208 debugmodeChangeHandler com.hubitat.hub.domain.Event@66333b71
app:7152019-01-19 07:47:41.007 debugmodeChangeHandler com.hubitat.hub.domain.Event@378e97be
app:7152019-01-19 07:35:42.224 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:35:42.195 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:35:42.150 debugSomeone is home - Stopping Schedule Vacation Lights
app:7152019-01-19 07:33:42.071 debugmodeChangeHandler com.hubitat.hub.domain.Event@259d368a
app:7152019-01-19 07:33:42.028 debugmodeChangeHandler com.hubitat.hub.domain.Event@6d132053
app:7152019-01-19 07:33:42.020 debugmodeChangeHandler com.hubitat.hub.domain.Event@7d99d8e
app:7152019-01-19 07:33:41.982 debugmodeChangeHandler com.hubitat.hub.domain.Event@537fcf68
app:7152019-01-19 07:33:41.950 debugmodeChangeHandler com.hubitat.hub.domain.Event@7b56e054
app:7152019-01-19 07:33:41.897 debugmodeChangeHandler com.hubitat.hub.domain.Event@1f2a9cc5
app:7152019-01-19 07:33:41.372 debugmodeChangeHandler com.hubitat.hub.domain.Event@28b6e328
app:7152019-01-19 07:33:41.165 debugmodeChangeHandler com.hubitat.hub.domain.Event@27ed269b
app:7152019-01-19 07:18:00.740 debugtimeOk = false
app:7152019-01-19 07:18:00.704 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.687 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.660 debugtimeOk = false
app:7152019-01-19 07:18:00.632 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.620 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.605 debugtimeOk = false
app:7152019-01-19 07:18:00.580 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.565 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.544 debugendTimeCheck
app:7152019-01-19 07:18:00.496 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.467 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.420 debugwrong time - Stopping Vacation Lights
app:7152019-01-19 07:18:00.416 debugtimeOk = false
app:7152019-01-19 07:18:00.376 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.353 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.312 debugtimeOk = false
app:7152019-01-19 07:18:00.247 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.206 debugmodeChangeHandler com.hubitat.hub.domain.Event@6dae1b14
app:7152019-01-19 07:18:00.197 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.167 debugmodeChangeHandler com.hubitat.hub.domain.Event@13deaea0
app:7152019-01-19 07:18:00.157 debugtimeOk = false
app:7152019-01-19 07:18:00.102 debugtimeWindowStop = Sun Jan 20 07:18:00 EST 2019 Sun Jan 20 07:18:00 EST 2019
app:7152019-01-19 07:18:00.081 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:18:00.056 debugendTimeCheck
app:7152019-01-19 07:10:47.224 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 07:10:47.198 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:10:47.158 debugAll OFF
app:7152019-01-19 07:10:47.023 debugwrong time - Stopping Vacation Lights
app:7152019-01-19 07:10:47.021 debugtimeOk = false
app:7152019-01-19 07:10:46.989 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 07:10:46.978 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:10:46.953 debugtimeOk = false
app:7152019-01-19 07:10:46.930 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 07:10:46.918 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 07:10:46.906 debugtimeOk = false
app:7152019-01-19 07:10:46.882 debugtimeWindowStop = Sat Jan 19 07:18:00 EST 2019 Sat Jan 19 07:18:00 EST 2019
app:7152019-01-19 07:10:46.869 debugtimeWindowStart = Sat Jan 19 17:39:00 EST 2019 Sat Jan 19 17:39:00 EST 2019
app:7152019-01-19 06:50:46.788 debugreschedule 10 + 10 minutes
app:7152019-01-19 06:50:46.788 debugturned on [Aeon LED Bulb]
app:7152019-01-19 06:50:46.765 debugturned on Bed Front Dimmer
app:7152019-01-19 06:50:46.752 debuginactive switches: 9 numlight: 1
app:7152019-01-19 06:50:46.749 debugturned off Master Bath Light
app:7152019-01-19 06:50:46.730 debugRunning
app:7152019-01-19 06:50:46.708 debugtimeOk = true
Hi.. Is this the latest version? Does it only fire when all users are out of the geofence?
Do i need to set anything or,does it just turn on random devices at random times between sunset and a specific time?
When you install there are settings you apply in the HE console
  • what lights to use
  • when to turn on/off
  • what it is using to decide to run or not (could be presence, or a mode setting, etc).
So install, and apply setting you wish after installing.
Howdy, I just found this on Hubitat Package Manager and installed it for away and vacation coverage. It Looks great!
I noticed there’s an option for how long lights are to remain on, is this a Max on time and the actual duration is randomised within that range?
Btw, it’d be great if the end time could be a randomised definable off range eg
11:30pm = off time
Off Range = 1 hour (make user definable)
So then VLD would randomly switch off between 11:00pm and 12 midnight
This would make the simulated bed Time more realistic.
I use it and it works for my needs. I see you have Package Manager installed. Bryan (@bptworld) wrote a nice simulator you might be interested in. -Joel
Hi @nh.schottfam is there any chance you can add a seperate group of switches that can turn on & off switches (in my case virtual ones) to turn a (or more) speakers on & off. Could also turn your TV on & off.
Adding this would better simulate being home, although there would need to be 2 seperate times setup as naturally lights don't need to go on during daytime, & the speakers or TV would.
You can run a separate instance for this if needed:
see:
I haven't worked it out, so I've just done it with RM. I have 4 different rules, over alternating days, AM & PM was pretty easy to do
There is an updated version out today.
It further optimizes operations on HE, and has instructions if you want to install multiple versions.
It also can turn logging off after 2 hrs.
It is available in HPM. Vacation Lighting Director.
Thanks for this app, saved me hours of headaches....
A couple of questions, can I change it to leave the lights on between the selected times? I don't want them to cycle.
can I get a notification when it runs?
thanks again.
So you want it to leave a light on when VLD is off?
VLD can log, but it does not have push notifications...it seems this is more debugging that normal operating state?
No, I want the lights to stay on between the times I selected, for example Sunset to midnight.
If I am out of the house, I would like to receive a notification like Rule Machine does when the rule is triggered. is that too complicated to add?
thanks,
Sam
I think it is easiest for you to create a virtual switch, and have VLD turn it on for the duration of the run (it does this now) and it turns it off when done.
This will give you start and stop of VLD.
If you are using VLD from HPM it has the feature
I think I understand it. my question is with the top part of the app, where it says how often to switch the lights. does one override the other? it's mandatory so I couldn't skip it.
here's what I have
