Whose app code are you using for this? This would be a good question for whoever wrote/ported this particular version. The one by nhschottfam that also appears to be in HPM (there may be others with the same name, so not saying this is the only one it could be) is one I found with a quick search and does appear to subscribe only to location mode events in the equivalent line of code, as you suggest:
