I have been using Hubitat for years. I purchased a C-7 a year or more ago planning to do the upgrade from my C-4 but haven´t found the time to undertake that project since I must move devices and rules. I decided to bite the bullet but when I put the C-7 on the network, login to the interface and initiate a firmware update as the first task, the web interface becomes unreachable. The update is from 2.2.5.131 --> 2.3.3.140.
The restore tool can roll back to 2.2.5.131 but the same result on multiple upgrade tries. Anyone have any insight or solution to this issue? Obviously don´t want to start migrating devices and rules over until this update is successful. Appreciate any help.
I'm assuming because you used the restore tool to revert that the diagnostic tool is still available on port 8081? So the IP address didn't change? And you're trying to access the UI via its IP address?
In the hub Settings tab, do you have a static IP or dynamic IP address? Please set it to dynamic, and do an IP address reservation in your router, if you have not done so.
I thought of one other thing that’s a bit of a long shot but it shouldn’t hurt. The database format has changed since 2.2.5. Maybe a corrupt database is somehow wreaking havoc on the upgrade process.
You might consider making a backup and saving it locally then doing a soft reset followed by a restore. That will cleanse the database in the process. On newer versions a restore does a soft reset first but not I think on that old a version. Once that’s done try the upgrade again.
Again just a thought but since even BobbyD gets some time off for good behavior on the weekend it’s something to try.
By unresponsive ...once update is complete page comes back with message "This page isn't working. 192.168.1.194 has redirected you too many times. Try clearing your cookies."
I have tried clearing cookies, accessing from multiple computers and browsers. Can reach it using port 8081 to rollback but that is all. Tried your suggestion of upgrading and doing soft reset but same outcome
There's a similar thread that suggests maybe your browser is trying to force an https redirect. Is that a possibility?
There was also a change made a while ago that only allowed access from an RFC1918 non-routable IP. Is your browser is on the same subnet and is it a /24 subnet? From what you posted HE is definitely an RFC1918 subnet.... just checking to make sure your PC is too.
@brad5 thanks for the suggestions but no luck. I can reach hubitat.local when on the old version but not after the upgrade. I have tried on multiple computers and multiple browsers all with the same message.
Both computer and hub are on the same RFC1918 network 192.168.1.0/24
Thanks @bobbyD for the response. I did try these steps as were outlined above and will try the same thing again. I tried the Diagnostic Tool update to version 1.0.97 as I have 1.0.75 but it did not perform the upgrade. Message returned was:
{"success":true,"message":"No Update for Diagnostic Tool Available."}
