#3 is a ah ha moment as well. IR blaster will not report State, and this is why it isn't working. I too had this issue with my ZXT-600's and use an underlayed tile to change the color based on temperature. I used the fan tile and wrote a rule to change the fan state at a certain temperature, worked like a charm. The thermo tile on top I made transparent to let the color through.
I am thinking instead of using the Image tile from the back, to use the same tile as the switch background, so I could solve the color issue. Now I have to hide the switch icon and the device name text. What is the instruction for this?
Well, it's not as nice as the one our friends @sburke781 and @ymerj have, but it will already serve the initial purpose. Thank you @chad.andrews for all the help.
With today's teachings, and a little bit of thinking, I have improved temperature and humidity, but I am still left wanting to remove the decimal places, or get it adjusted to 1 position.
I took a brief look online earlier today and it feels like you would be best to handle this with a device or variable in HE, rather than CSS. I expect you could:
Setup a simple rule in Rule Machine to be triggered by a change in the temperature reading
Record the rounded value in a variable
Make that variable available in the dashboard
Add a tile to the dashboard that uses the variable, replacing the area where you are displaying the 31.65 in your screenshot
Problem solved, but instead of using the Rule Machine that has limitations and could not do the update, I used the Multi-Sensor Reactor (similar WebCore).
I've released my Simple CSS Editor if anyone is interested in taking a look. It can do a lot of the common stuff, and I plan to add much more to it over time. Feel free to check it out and offer any suggestions.
Yes! will do. Thanks for your great help.
My current question is how to change text color(s) on a tile.
For example:
The Code shown here is what I get when clicking on Inspect on the thermostat tile.
What CSS code can be added to change “78 F and cooling” text from white to different color?
And other Text if I chose to.
I will try to take a look in the next day or two (maybe tonight if you're lucky). What I would suggest is expanding those div elements to see the text inside them to give you an indication of which ones you need to reference in your css.
I'd also suggest you look at the recent discussion on this thread between Chad and Wilson to see how they referenced different thermostat elements.
Thanks, I don't know why I didn't expand the div elements? Trying to figure out what div means.
Yah looked at the thread between Chad and Wilson but just have not figured it out yet.
You will need to reference those in your css. I will need to look at it later if you still need a hand, but try right clicking the element in the dev tools window from your screen shot and try one of the copy path type options. You should see something similar to some of Chad's suggestions to Wilson. That will form the first part of the CSS entry, then inside the curly braces you need to use settings like font-family or size or color from memory. Try googling html css font and look at any w3schools links that show up. Alternatively, if you have installed my editor, adjust some text on another tile to get some examples for the text styling.
