Temp sensor w/ external probe support?
I’m looking for a temperature sensor I can use to monitor my water supply lines (to prevent freezing during winter months). I’m thinking an external probe attached directly to the outside of the pipe would be the best solution. Is there a “best” sensor out there that has Hubitat support?
That Qubino has the external sensor, and for FREE you get a Dry Contact relay :smiley: :smiley:
The Qubino's work with Generic Zwave drivers, but I don't have personal knowledge of the temp sensor & driver.
Isn't external, per se, but is battery driven so wherever it's mounted is sensed.
That ecolink device could work. Thanks!
and has the FREE Flood sensor too :smiley:
Do you happen to know if it for sure works with Hubitat? I would assume yes, but can’t find it mentioned previously anywhere.
I believe it's just a generic switch
Fundamentally it's their Door Sensor, with the probe added to their internal screw posts.
I just posted my setup in another thread. FGK-101 with DS18B20.
That Ecolink sensor doesn't report the temperature. It just sends a notification if the temp gets too low and there's no capability for that functionality so Hubitat only supports water detection for that device.
Well that’s unfortunate.
Fibaro's door sensor is basically the same idea:
https://manuals.fibaro.com/document/fgk-temperature-sensor/
Inside is a 4 screw header, Buy the DS18B20 temp sensor (I recently bought 6 - I have two expoxied into a 1/2" PVC plug if you need) and add it into the Door Sensor per those instructions.
I happen to have that Fibaro Door Sensor AND I have a spare DS18B20 -- I should wire it up and let us all know !!
I have one working already for my aquarium temperature sensor.
I have a Visonic MCT-340 E Contact Sensor that seems pretty reliable reporting temperature. I'm using the "Generic Zigbee contact sensor" driver.
Not sure what delay you would get if you used the complete unit, but if insulated with some foam you might be OK. I haven't opened it up to see if the sensor could be made remote. But it was only $19.99 on Amazon.
I wired up the DS18B20 sensor... the wires really need tinning to pass through the plastic housing and into the screw slot. Hope your solder skills are up to that.
Then I paired it and it shows as a Device, which I changed to the native Fibaro Door/Window Sensor 2 driver.
Current States
tamper : detected
syncStatus : 1 Pending Change
temperature : 74.30
battery : 70
contact : open
(@mike.maxwell you may want to add this: )
deviceType: 1793
    inClusters: 0x5E,0x85,0x59,0x22,0x20,0x80,0x70,0x56,0x5A,0x7A,0x72,0x8E,0x71,0x73,0x98,0x2B,0x9C,0x30,0x31,0x86,0x84
    deviceId: 8193
    manufacturer: 271
Which device model is this?
Fibaro FGK-10x
Got a bunch of other numbers on the box.. maybe they will help:
ZW5 v3.2 (101)
30/03/2017
I never paired it before because it uses that odd 1/2 AA (3.6v) battery.
not sure what's going on with Tamper and Pending Change
dev:1982018-11-15 12:56:21.859 pm infoFibaro DoorSensor: syncStatus is 1 Pending Change
dev:1982018-11-15 12:56:21.854 pm debugThe changes will be synced the next time the device wakes up.  You can force the device to wake up immediately by keeping the cover of the device on and pressing the TMP button on the bottom of the device.
dev:1982018-11-15 12:56:17.828 pm debugOpen/Close LED Indicator (Param #2) = 0
dev:1982018-11-15 12:56:17.742 pm infoFibaro DoorSensor: syncStatus is Syncing...
dev:1982018-11-15 12:56:17.737 pm debugConfigurationReport(configurationValue:[0], parameterNumber:2, size:1) scaledConfigurationValue: 0
dev:1982018-11-15 12:56:16.916 pm debugChanging Open/Close LED Indicator (Param #2) to "6" (Wake Up / Tampering)
dev:1982018-11-15 12:56:16.839 pm debugsyncDevice()...
dev:1982018-11-15 12:56:16.737 pm debugDevice Woke Up
dev:1982018-11-15 12:56:08.852 pm infoFibaro DoorSensor: syncStatus is 1 Pending Change
dev:1982018-11-15 12:56:08.848 pm debugThe changes will be synced the next time the device wakes up.  You can force the device to wake up immediately by keeping the cover of the device on and pressing the TMP button on the bottom of the device.
I tap the bottom button and it syncs then goes right back into pending. Tamper is set default to 5 seconds, still shows tamper: detected.
If I use that DH, the device drops off and stops reporting.
Using the one mentioned in the thread I quoted, it stays on line.
Here it is.
 *  Fibaro Z-Wave FGK-101 Temperature & Door/Window Sensor Handler [v0.9.7.2, 9 July 2017]
 *  Copyright 2014 Jean-Jacques GUILLEMAUD
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
/* IMPORTANT : This custom Handler works both for Z-Wave+ (aka ZW5) versions of the FGK-101 Fibaro sensor,
/*             as well as for pre-ZW5 versions of the FGK-101 hardware.
/*             It takes about 1mn for the FGK-101 to fully configure itself after the first (manual or otherwise) wakeup.
 *	Fibaro Z-Wave FGK-101 Marketing Description is at :
 *		http://www.fibaro.com/en/the-fibaro-system/door-window-sensor
 *  Fibaro FGK-10x Operating Manuals and Z-Wave Alliance Certificates can be downloaded at :
 *		Z-Wave / Firmware <= 2.5 		: http://www.fibaro.com/files/instrukcje/eng/DoorWindowSensor%20FGK-101-107%20ENG_v21-v23.pdf
 *										: http://products.z-wavealliance.org/products/1077
 *		Z-Wave+ / ZW5 / Firmware >= 3.2 : http://manuals.fibaro.com/content/manuals/en/FGK-10x/FGK-10x-EN-T-v2.0.pdf
 *										: http://products.z-wavealliance.org/products/1620
 *	The current version of this Handler is parameterized to force Device's wakeup :
 *		- on any open<->closed state change
 *		- in case of Tampering Alarm triggering
 *		- every 60mn (wakeUpIntervalSet(seconds:60*60), hard coded)
 *		- whenever Temperature delta change since last report is greater than 0.3°C (Parameter#12 or #51, hard coded)
 *		- every 4h when Temperature does not change
 *		also :
 *		- Temperature is natively reported by sensor in Celsius (SensorMultilevelReport[scale:0]);
 *		  convertion is needed for Fahrenheit display
 *  A few specificities of this device that are relevant to better understand some parts of this Handler :
 *		- it is a battery operated device, so Commands can only be sent to it whenever it wakes up
 *		- it is a multi-channel Device (pre-ZW5), and the multi-level temperature sensor reports only from EndPoint#2
 *		- specific configurable parameters are documented in the above Operating Manuals
 *		- some of those parameters must be modified to activate the anti-Tampering Alarm
 *		- some of the "scaffolding" has been left in place as comments, since it may help other people to understand/modify this Handler
 *		- BEWARE : the optional DS18B20 temperature sensor must be connected BEFORE the Device is activated (otherwise, reset the Device)
 *		- IMPORTANT : for debugging purpose, it is much better to change the wake-up period from the default 60mn to 1mn or so;
 *					but unless you force the early wake up of the sensor (forcing open/closed for instance), you will have to
 *					wait up to 60mn for the new value to become effective.
 * Z-Wave Device Class: GENERIC_TYPE_SENSOR_BINARY / SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
 * FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
 * Command Classes supported according to Z-Wave Certificate ZC08-14070004 for FGK-101\US :
 * 	 Used in Handler (pre-ZW5 and ZW5) :
 *		0x20 - 32  : BASIC					V1
 *		0x30 - 48  : SENSOR_BINARY			V2
 *		0x31 - 49  : SENSOR_MULTILEVEL		V5
 *		0x56 - 86  : CRC_16_ENCAP			V1
 *		0x70 - 112 : CONFIGURATION			V2
 *		0x80 - 128 : BATTERY				V1
 *		0x84 - 132 : WAKE_UP				V2
 *		0x85 - 133 : ASSOCIATION			V2
 *		0x86 - 134 : VERSION				V1
 *		0x9C - 156 : SENSOR_ALARM			V1
 * 	 Used in Handler (pre-ZW5 only) :
 *		0x60 - 96  : MULTI_CHANNEL			V3
 * 	 Used in Handler (ZW5 only) :
 *		0x71 - 113 : NOTIFICATION			V3
 *		0x98 - 152 : SECURITY				V1
 *	List of Known Bugs / Oddities / Missing Features :
 *		- valueTitle does not show displayNames on mobile Dashboard/Things page;
 *		  attempted workaround using : valueTile(){unit:'${displayName}') failed
 *		- valueTile behaves differently on mobile Dashboard (interpolated colors) from Simulator (step-wise colors)
 *		- using Preferences values instead of hard-coded values for some parameters would be nicer
 *		- ZW5 : Sensor Multilevel Report() received in answer to Sensor Multilevel Get() is buggy (+/- 1°C random error)
metadata {
	definition (name: "JJ's Fibaro FGK-10x ZW5 Handler", namespace: "JJG2014", author: "Jean-Jacques GUILLEMAUD") {
		capability "Contact Sensor"
		capability "Battery"
		capability "Configuration"
		capability "Temperature Measurement"
		capability "Sensor"
		capability "Alarm"
        capability "Tamper Alert"
        command "reportNext", ["string"]
        // Use Device Custom Attributes whenever state.xxx Attributes are too vulnerable to race conditions
        attribute "reportASAP", "number"
        attribute "forcedWakeUp", "number"
        attribute "ZW5set", "number"
        attribute "ZW5", "number"
        attribute "Configured", "number"
        // FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
		fingerprint deviceId: "0x2001", inClusters: "0x85, 0x20, 0x80, 0x70, 0x56, 0x72, 0x9C, 0x30, 0x31, 0x86, 0x84, 0x7A, 0x2B"  // fingerprint as intersection of ZW6 & non-ZW5 fingerprints
        // fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x85, 0x59, 0x22, 0x20, 0x80, 0x70, 0x56, 0x5A, 0x7A, 0x72, 0x8E, 0x71, 0x73, 0x98, 0x2B, 0x9C, 0x30, 0x31, 0x86, 0x84", outClusters: ""//actual NIF
	simulator {
		status "open":  "command: 2001, payload: FF"
		status "closed": "command: 2001, payload: 00"
        def T_values=[10,14,14.9,15,17,17.9,18,19,19.9,20,22,22.9,23,24,44,44.9,45,46,100]
        def float Ti
        for (int i = 0; i <= T_values.size()-1; i += 1) {
            Ti=T_values.get(i)
        	def theSensorValue = [(short)0, (short)0, (short)(Ti*100)/256, (short)(Ti*100)%256]
			status "temperature ${Ti}°C":  zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2).encapsulate(zwave.sensorMultilevelV5.sensorMultilevelReport(scaledSensorValue: i, precision: 2, scale: 0, sensorType: 1, sensorValue: theSensorValue, size:4)).incomingMessage()
	tiles {
    	valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
        	// label:'${name}', label:'${currentValue}', unit:"XXX" work, but NOT label:'${device.name}', label:'${displayName}', unit:'${unit}', ...
			state "temperature", label:'${currentValue}°', unit:"C", icon: "st.alarm.temperature.normal",
			// redondant lines added to avoid color interpolation on Dashboard (a feature or a bug ?!)
            backgroundColors:[							// ***on IDE Simulator***		// ***on iPad App***
                [value: 14, color: "#0033ff"],			//     °C <=14 : dark blue		//     °C <=14	: dark blue
				    //[value: 14.1, color: "#00ccff"],	<- decimal value IGNORED by the Tile !!!
					[value: 14.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated dark blue<-> light blue
                    [value: 15, color: "#00ccff"],		// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
                [value: 17, color: "#00ccff"],			// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
					[value: 17.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated light blue<->blue-green
                	[value: 18, color: "#ccffcc"],		// 15< °C <=19 : light blue		// 18<=°C <=19	: blue-green
				[value: 19, color: "#ccffcc"],			// 15< °C <=19 : light blue		// 19°C			: blue-green
                    [value: 19.5],					// 19< °C <=21 : blue-green		// 19< °C <20	: interpolated blue-green<->green
                	[value: 20, color: "#ccff00"],		// 19< °C <=21 : blue-green		// 20<=°C <=21	: green
				[value: 22, color: "#ccff00"],			// 21< °C <=23 : green			// 22°C			: green
					[value: 22.5],					// 23< °C <=45 : orange			// 22< °C <23	: interpolated green<-> orange
					[value: 23, color: "#ffcc33"],		// 23< °C <=45 : orange  		// 23<=°C <=44	: orange
				[value: 43, color: "#ffcc33"],			// 23< °C <=45 : orange  		// 44°C			: orange
					[value: 43.5],					// 45< °C      : red			// 44< °C <45	: interpolated orange <-> red
               		[value: 44, color: "#ff3300"]		// 45< °C      : red  			// 45<=°C		: red
        valueTile("temperatureF", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
			state "temperature", label:'${currentValue}°', unit:"F", icon: "st.alarm.temperature.normal",
				[value: 57, color: "#0033ff"],			//     °C <=14 : dark blue		//     °C <=14	: dark blue
					//[value: 14.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated dark blue<-> light blue
                    [value: 59, color: "#00ccff"],		// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
                [value: 63, color: "#00ccff"],			// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
					//[value: 17.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated light blue<->blue-green
                	[value: 64, color: "#ccffcc"],		// 15< °C <=19 : light blue		// 18<=°C <=19	: blue-green
				[value: 66, color: "#ccffcc"],			// 15< °C <=19 : light blue		// 19°C			: blue-green
                    //[value: 19.5],					// 19< °C <=21 : blue-green		// 19< °C <20	: interpolated blue-green<->green
                	[value: 68, color: "#ccff00"],		// 19< °C <=21 : blue-green		// 20<=°C <=21	: green
				[value: 72, color: "#ccff00"],			// 21< °C <=23 : green			// 22°C			: green
					//[value: 22.5],					// 23< °C <=45 : orange			// 22< °C <23	: interpolated green<-> orange
					[value: 73, color: "#ffcc33"],		// 23< °C <=45 : orange  		// 23<=°C <=44	: orange
				[value: 109, color: "#ffcc33"],			// 23< °C <=45 : orange  		// 44°C			: orange
					//[value: 43.5],					// 45< °C      : red			// 44< °C <45	: interpolated orange <-> red
               		[value: 111, color: "#ff3300"]		// 45< °C      : red  			// 45<=°C		: red
        standardTile("contact", "device.contact") {
			state "open", label: 'open'/* in English :'${name}' */, icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
			state "closed", label: 'closed'/* in English :'${linkText}' */, icon: "st.contact.contact.closed", backgroundColor: "#79b821"
        valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
			state "battery", label:'batt ${currentValue}%' /*battery*/, unit:""
        //Select temperatureF if Location temperature Scale is °F
        main(["temperature"])
		details(["temperature", "contact", "battery"])
        //main(["temperatureF"])
		//details(["temperatureF", "contact", "battery"])
// parse events into attributes
		//state.parseCount=state.parseCount+1
		//state.debugLevel = 2		// set to 1 or 2 when experimenting
		if (state.debugLevel>=1) {log.debug "--------------------------Parsing... ; state.parseCount: ${state.parseCount}--------------------------"}
		if (state.debugLevel>=2) {log.debug "Parsing... '${description}'"}
        def result = null
        def cmd = zwave.parse(description, [0x20:1, 0x30:2, 0x31:5, 0x56:1, 0x60:3, 0x70:2, 0x72:2, 0x80:1, 0x84:2, 0x85:2, 0x9C:1])
        if (cmd) {
                result = zwaveEvent(cmd)
                if (state.debugLevel>=1) {log.debug "Parsed ${cmd} to ${result.inspect()}"}
        } else {
                log.debug "Non-parsed event: ${description}"
        return result
//SmartThings v2 Hub forces some CRC16-encoded replies from FGK-101 Device (v1 Hub did not)
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
	log.debug "CRC16.......... cmd : ${cmd}"
    def versions = [0x20:1, 0x30: 2, 0x31: 5, 0x60: 3, 0x70: 2, 0x72: 2, 0x80: 1, 0x84: 2, 0x86: 1, 0x9C: 1]
	// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
	def version = versions[cmd.commandClass as Integer]
    log.debug "commandClass : ${cmd.commandClass}"
    log.debug "version : ${version}"
	def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
    log.debug "ccObj : ${ccObj}"
    log.debug "cmd.command : ${cmd.command}"
    log.debug "cmd.data : ${cmd.data}"
	def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
	if (!encapsulatedCommand) {
		log.debug "Could not extract command from ${cmd}"
	} else {
		zwaveEvent(encapsulatedCommand)
// ZW5 Devices that support the Security command class can send messages in an
// encrypted form; they arrive wrapped within a SecurityMessageEncapsulation
// command and must be unencapsulated
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
		log.debug "cmd : ${cmd}"
        def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x30: 2, 0x70: 2, 0x71: 3, 0x84: 2, 0x85: 2, 0x98: 1, 0x9C: 1])
        // can specify command class versions here like in zwave.parse
        if (encapsulatedCommand) {
    			log.debug "ZW5 encapsulatedCommand : ${encapsulatedCommand}"
                return zwaveEvent(encapsulatedCommand)
        } else {
			log.warn "ZW5 Unable to extract encapsulated cmd from $cmd"
			createEvent(descriptionText: cmd.toString())
def temperatureScaleFC(tempvalue) {
	//FGK-101 is natively °C; convert to °F if selected in Location settings
	def float tempFC = tempvalue
	if (location.temperatureScale == "F") {
		tempFC = tempvalue * 1.8 + 32
	return tempFC
def wakeUpResponse(cmdBlock0) {
	def cmdBlock = []
	cmdBlock += cmdBlock0
	//Initialization... (executed only once, when the Handler has been updated)
    //All untouched parameters are supposed to be DEFAULT (as factory-set)
    if (state.debugLevel>=2) {log.debug "device.Configured : ${device.currentValue('Configured')}"}
    if (!(device.currentValue('Configured'))) {
		cmdBlock += configureDev()
		log.debug "++++++++returned cmdBlock : ${cmdBlock}"
	//Regular ZW5 & non-ZW5 Commands...
    def long nowTime = new Date().getTime()
    log.debug "state.lastReportBattery : ${state.lastReportBattery}"
    if (state.batteryInterval) {
    	if (nowTime-state.lastReportBattery > state.batteryInterval) {
        	// batteryGet() should definitely NOT be CRC16 encoded ! [buggy ZW5 Fibaro handler !!]
			cmdBlock << zwave.batteryV1.batteryGet().format()
        	cmdBlock << "delay ${state.shortDelay}"
    	//ZW5 : "wakeUpIntervalReport doesn’t work uint24FromBytes missing from response" : https://community.smartthings.com/t/wakeupintervalget-doesnt-work-uint24frombytes-missing-from-response/10577
    	//cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalGet()) // NB : may have to wait 60mn for that value to be refreshed !
    	//cmdBlock << "delay ${state.longDelay}"
    if (device.currentValue('ZW5set')) {
    	// DS18B20 temperature measurement at 12bits accuracy takes more than 750ms...
    	if (device.currentValue('ZW5')) {
        	// sensorMultilevelGet() should be +++PROPERLY+++ CRC16-encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!!
            // sensorMultilevelReport() synchronous answer to sensorMultilevelGet() is buggy for whatever reason (+/-1°C) => disable sensorMultilevelGet()
            //cmdBlock << crc16Encode(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0))
    	} else {
    		cmdBlock << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 2, destinationEndPoint: 2, commandClass:0x31, command:4).format()  //sensorMultiLevel.get()
	cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
        log.debug "wakeUpNoMoreInformation()"
        log.debug "cmdBlock : ${cmdBlock}"
    return cmdBlock
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
    	log.debug "wakeupv2.WakeUpNotification $cmd"
        def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: true, displayed: false)
        def cmdBlock = []
        cmdBlock = wakeUpResponse([])
        return [event, response(cmdBlock)]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
        	log.debug "SensorMultilevelReport.precision : ${cmd.precision}"
            log.debug "SensorMultilevelReport.scale : ${cmd.scale}"
            log.debug "SensorMultilevelReport.scaledSensorValue : ${cmd.scaledSensorValue}"
            log.debug "SensorMultilevelReport.sensorType : ${cmd.sensorType}"
            log.debug "SensorMultilevelReport.sensorValue : ${cmd.sensorValue}"
            log.debug "SensorMultilevelReport.size : ${cmd.size}"
        def float scaledSensorValue = cmd.scaledSensorValue
        // Adjust measured temperature based on previous manual calibration; FGK-101 is natively °C
        switch (device.name) {
            case 'T005' :										//JJG
            	scaledSensorValue = scaledSensorValue + 0.0554
    			log.debug "Temp Adjust for : ${device.name}"
                break;
            case 'T006' :										//MLE
            	scaledSensorValue = scaledSensorValue + 0.0297
                break;
            case 'T003' :										//MPT
            	scaledSensorValue = scaledSensorValue - 0.0603
                break;
            case 'T002' :										//NBN
            	scaledSensorValue = scaledSensorValue - 0.0758
                break;
            case 'T004' :										//SCU
            	scaledSensorValue = scaledSensorValue + 0.0011
                break;
            case 'T007' :										//FSU
            	scaledSensorValue = scaledSensorValue + 0.0025
                break;
            case 'T008' :
            	scaledSensorValue = scaledSensorValue - 0.0146
                break;
            case 'T009' :
            	scaledSensorValue = scaledSensorValue + 0.0383
                break;
            case 'T010' :
                break;
            case 'T011' :
            	scaledSensorValue = scaledSensorValue - 0.0889
                break;
            case 'T012' :
            	scaledSensorValue = scaledSensorValue - 0.0532
                break;
            case 'T013' :
                break;
            case 'T014' :										//*ext*//
            	scaledSensorValue = scaledSensorValue - 0.0160
                break;
        //Round to nearest 1 decimal temperature value; convert to °F if needed
        def float ftempSign = temperatureScaleFC(scaledSensorValue) < 0 ? -1 : +1
		def float ftemp = ftempSign * ((((int) (temperatureScaleFC(scaledSensorValue).abs()*100+5)/10)*1.0)/10)
        	log.debug "ftempSign : ${ftempSign}"
        	log.debug "ftemp : ${ftemp}"
        	log.debug "cmd.scaledSensorValue : ${cmd.scaledSensorValue}"
        	log.debug "correction : ${scaledSensorValue-cmd.scaledSensorValue}"
    		log.debug "device.displayName : ${device.displayName}"
    		log.debug "'Date().getTime()' : ${new Date().getTime()}"
            log.debug "state.maxEventInterval : ${state.maxEventInterval}"
    		log.debug "state.lastReportTime : ${state.lastReportTime}"
    		log.debug "nowTime : ${nowTime}"
            log.debug "device.forcedWakeUp : ${device.currentValue('forcedWakeUp')}"
    		log.debug "(nowTime-state.lastReportTime > state.maxEventInterval) : ${(nowTime-state.lastReportTime > state.maxEventInterval)}"
            log.debug "state.lastReportedTemp: ${state.lastReportedTemp}"
        // Adjust temperature report sensitivity for outside thermometers whose displayName starts with "*"
        def float tempQuantum
    	if (device.displayName.substring(0,1).equals("*")) {
        	tempQuantum = temperatureScaleFC(0.9999)-temperatureScaleFC(0)
        } else {
        	tempQuantum = temperatureScaleFC(0.0999)-temperatureScaleFC(0)
        //log.debug "((ftemp-state.lastReportedTemp).abs()>${tempQuantum}): ${(ftemp-state.lastReportedTemp).abs()>tempQuantum}"
        // Spurious faulty Temperature Reports cropped when temparture gradient is unbelievable (?)
        //if ((((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime)) < (0.5/1000)) { // ignore temperature report when slope > 0.5°C/s
        //if (((ftemp-state.lastReportedTemp).abs()>tempQuantum) || ((nowTime-state.lastReportTime) > state.maxEventInterval) || device.currentValue('forcedWakeUp')) {
        	def map = [ displayed: true, value: ftemp.toString(), isStateChange:true, linkText:"${device.displayName}" ]
        	if (cmd.sensorType == 1) {
                        map.name = "temperature"
                        map.unit = cmd.scale == 1 ? "F" : "C"
                        //ignores Device's native temperature scale, ftemp already converted to °F if settings as such
                        map.unit = location.temperatureScale
                        log.debug "map.value : ${map.value}"
                        log.debug "map.unit : ${map.unit}"
        		log.debug "temperature Command : ${map.inspect()}"
        	state.lastReportedTemp = ftemp
            state.lastReportTime = nowTime
            sendEvent(name: "forcedWakeUp", value: 0, displayed: false)
            // For Test purpose; redondant with reportNext() => device.forcedWakeUp=1
            if (device.currentValue('reportASAP')==1) {sendEvent(name: "reportASAP", value: 0, isStateChange: true)}
        	return createEvent(map)
      //  } else {
        log.debug "+++++++++discarded temperature report : rate change : ${(((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime))*1000}°C/s"
def sensorValueEvent(value) {
	if (value) {
		createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open  [sensorValueEvent]")
	} else {
		createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed  [sensorValueEvent]")
// BasicReport should never occur since all status change notifications are asynchronous via BasicSet
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	sensorValueEvent(cmd.value)
    if (state.debugLevel>=2) {log.debug "basicv1.BasicReport $cmd.value"}
def openClosed(cmd, cmdValue) {
    def theState = cmdValue == 0 ? "closed" : "open"
    if (state.debugLevel>=2) {log.debug "openClosed $cmd"}
    // Use closed/open sensor notification to trigger push of updated Temperature value and immediate setting of updated device parameters
    // Sometimes, Temperature forced refresh stops working : SensorMultilevelGet(sensorType: 1, scale: 0) Commands are stacked but not executed immediately;
    // will restart after some time, and stacked Commands will be executed !
    def event = createEvent(name:"contact", value:"${theState}", descriptionText:"${device.displayName} is ${theState}", isStateChange:true, displayed:true, linkText:"${device.displayName}")
    sendEvent(name: "forcedWakeUp", value: 1, displayed: false)
    return [event, response(wakeUpResponse([]))]
// pre-ZW5 : BasicSet alarm does not seem to wait for any Commands answers, going back to sleep immediately;
//           thus it cannot perform proper initial Configuration => use the Tamper switch and SensorAlarmReport instead
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
    log.debug "basicv1.BasicSet $cmd"
    if ((device.currentValue('ZW5set')) && (!(device.currentValue('ZW5')))) {
    	def cmdValue = cmd.value
		return openClosed(cmd, cmdValue)
// For pre-ZW5, SensorBinaryReport should never occur since all status change notifications are asynchronous via BasicSet...
// ...but ZW5 uses it in addition to BasicSet and Notification
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
    log.debug "sensorbinaryv2.SensorBinaryReport $cmd"
    	def cmdValue = cmd.sensorValue
// ZW5 : it is assumed that default notification events are used
// (parameter 20 was not changed before device's re-inclusion)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
    def map = [:]
    if (cmd.notificationType == 6) {
    	switch (cmd.event) {
        	case 22:
            	map.name = "contact"
                map.value = "open"
                map.descriptionText = "${device.displayName} is open"
            	break
            case 23:
                map.value = "closed"
                map.descriptionText = "${device.displayName} is closed"
            	break
    // Contrary to pre-ZW5 Devices, the Tamper Notification does not occur for only a brief
    // push>release of the Tamper button. But it DOES occur when the Tamper button is released
    // 1mn or so after being pushed.
    } else if (cmd.notificationType == 7) {
        	case 0:
            	map.name = "tamper"
                map.value = "inactive"
                map.descriptionText = "${device.displayName} tamper detection enabled"
				break
        	case 3:
            	map.name = "tamper"
                map.value = "active"
                map.descriptionText = "${device.displayName} is tampered with !"
            	break
    def event = createEvent(map)
// SensorAlarmReport DOES wait for optional Commands answers, contrary to BasicSet
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
    if (state.debugLevel>=2) {log.debug "sensoralarmv1.SensorAlarmReport $cmd.sensorState"}
    if (!(device.currentValue('ZW5'))) {
    	def event = createEvent(name:"alarm", descriptionText:"${device.displayName} is tampered with !", isStateChange:true, displayed:true, linkText:"${device.displayName}")
    	def cmdBlock = []
    	cmdBlock=wakeUpResponse(cmdBlock)
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
    	log.debug "batteryv1.BatteryReport ${cmd.batteryLevel}"
    	log.debug "state.batteryInterval : ${state.batteryInterval}"
    if ((nowTime-state.lastReportBattery > state.batteryInterval) || device.currentValue('forcedWakeUp')) {
		def map = [ name: "battery", displayed: true, isStateChange:true, unit: "%" ]
		if (cmd.batteryLevel == 0xFF) {
			map.value = 1
			map.descriptionText = "${device.displayName} has a low battery"
			map.isStateChange = true
		} else {
			map.value = cmd.batteryLevel
    	state.lastReportBattery = nowTime
        log.debug "battery map : ${map}"
    	return [createEvent(map)]
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
    if (state.debugLevel>=2) {log.debug "ConfigurationReport - Parameter#${cmd.parameterNumber}: ${cmd.configurationValue}"}
	// Last configuration command execution; check UNIQUE(<>default) value is set
    // A bit of an overkill : checking the cmd.parameterNumber (12 or 51) should be enough...
	def byte tempQuantumSixteenth
		tempQuantumSixteenth = 16	/* 16/16=1°C = 1.8°F */
	} else {
		tempQuantumSixteenth = 4	/* 5/16=0.31°C = 0.56°F */
	if (device.currentValue('ZW5set') && !(device.currentValue('ZW5')) && (cmd.parameterNumber == 12) && (cmd.configurationValue == [tempQuantumSixteenth])) {
		sendEvent(name: "Configured", value: 1, isStateChange: true)
		log.debug ("++++++Non-ZW5 Device Configured++++++")
	def byte tempQuantumTenth
    	tempQuantumTenth = 10	/* 10/10=1°C = 1.8°F */
    } else {
    	tempQuantumTenth = 2	/* 3/10=0.3°C = 0.56°F */
	if (device.currentValue('ZW5set') && device.currentValue('ZW5') && (cmd.parameterNumber == 51) && (cmd.configurationValue == [0,tempQuantumTenth])) {
		log.debug ("++++++ZW5 Device Configured++++++")
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
	def result = []
	if (cmd.nodeId.any { it == zwaveHubNodeId }) {
		result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
	} else if (cmd.groupingIdentifier == 1) {
		// We're not associated properly to group 1, set association
		result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
		result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
	result
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelEndPointReport cmd) {
    if (state.debugLevel>=2) {log.debug "multichannelv3.MultiChannelCapabilityReport: ${cmd}"}
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
// ZW5 added : discriminate between ZW5 and pre-ZW5 Devices
// ZW5 : ${cmd.applicationVersion}.${cmd.applicationSubVersion}>=3.2 ; pre-ZW5 : <= 2.5
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
    //updateDataValue("version", "${cmd.applicationVersion}.${cmd.applicationSubVersion}")
    log.debug "versionv1.VersionReport: ${cmd}"
    log.debug "applicationVersion:      ${cmd.applicationVersion}"
    log.debug "applicationSubVersion:   ${cmd.applicationSubVersion}"
    def deviceFirmwareVersion = (short) cmd.applicationVersion*1000 + cmd.applicationSubVersion
    log.debug "deviceFirmwareVersion: ${deviceFirmwareVersion}"
    if (deviceFirmwareVersion >= 3002) {
        sendEvent(name: "ZW5", value: 1, isStateChange: true)
    } else {
        sendEvent(name: "ZW5", value: 0, isStateChange: true)
    sendEvent(name: "ZW5set", value: 1)
    log.debug "device.ZW5set: ${device.currentValue('ZW5set')}"
    log.debug "device.ZW5: ${device.currentValue('ZW5')}"
    return [response(wakeUpResponse([]))]
// MultiChannelCmdEncap and MultiInstanceCmdEncap are ways that devices can indicate that a message
// is coming from one of multiple subdevices or "endpoints" that would otherwise be indistinguishable
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 2, 0x31: 5]) // can specify command class versions here like in zwave.parse
	if (state.debugLevel>=2) {log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")}
// Catch All command Handler in case of unexpected message
def zwaveEvent(hubitat.zwave.Command cmd) {
	createEvent(descriptionText: "!!! $device.displayName: ${cmd}", displayed: false)
// When a Temperature Event got lost in transit, the Watchdog requests a forced report at next wake up
// The "reportNext()" alarm command is used to signal back from the Watchdog SmartApp to the sleepy device
def reportNext(commandMsg) {
	log.debug "reportNext !"
    log.debug "commandMsg : ${commandMsg}"
    sendEvent(name: "forcedWakeUp", value: 1)
    return []
// Initial Device Configuration and Handler Update
// Executed each time the Handler is updated
def updated() {
	log.debug "Updated !"
    def bytesToCRC = [0x56, 0x01, 0x31, 0x05, 0x01, 0x42, 0x09, 0x79]
//log.debug "checksum 0BD3/3027 : zwaveCrc16([0x56, 0x01, 0x31, 0x05, 0x01, 0x42,0x09, 0x79]) : ${zwaveCrc16(bytesToCRC as byte[])}"
    sendEvent(name: "ZW5set", value: 0)
    sendEvent(name: "ZW5", value: 0)
    sendEvent(name: "Configured", value: 0)  // set to true by the LAST Command Response from configureDev()
    // All state.xxx attributes are Device-local, NOT Location-wide
    // BEWARE : state.xxx attributes are vulnerable to race conditions; when not mostly read-only, use device.xxx instead
    state.lastReportedTemp = (float) -1000
    state.lastReportTime = (long) 0
    state.lastReportBattery = (long) 0
    state.longDelay = 1200
state.shortDelay = 1200
	// Real-time clock of sensors (ceramic resonator) is up to 3% inaccurate
    state.batteryInterval = (long) (24*60-45)*60*1000  // 83 700 000 : at least 1 Battery Report event every 23:15 hours
    state.maxEventInterval = (long) (2*60-20)*60*1000  // 13 200 000 : at least 1 Temperature Report event every 3:40 hours (4 hours at most)
    state.parseCount=(int) 0
    if (!(state.deviceID)) {state.deviceID = device.name}
    log.debug "state.deviceID: ${state.deviceID}"
    sendEvent(name: "reportASAP", value: 1)
    log.debug "device.currentValue('reportASAP') : ${device.currentValue('reportASAP')}"
    // configureDev()		// will be defered till first wakeup (forced or periodic)
    infos()
// If you add the Configuration capability to your device type, this command will be called right
// after the device joins to set device-specific configuration commands.
def configure() {
    return configureDev()
def configureDev() {
	def cmdBlock = []
    log.debug "device.Configured: ${device.currentValue('Configured')}"
    /////////////// Common configuration
    if (!(device.currentValue('ZW5set')))  {
    	log.debug "Configuring - Common Part............................................."
    	log.debug "cmdBlock: ${cmdBlock}"
		cmdBlock << zwave.versionV1.versionGet().format()
		log.debug "++++++Last Common Configuration Command SENT++++++"
		return cmdBlock
    /////////////// Non-ZW5 specific configuration
    if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && !(device.currentValue('ZW5'))) {
		log.debug  "Configuring - NON ZW5............................................."
        // Make sure sleepy battery-powered sensors send their WakeUpNotifications to the hub
		cmdBlock << zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format()
		} else {
			tempQuantumSixteenth = 2	/* 5/16=0.31°C = 0.56°F */
		log.debug "tempQuantumSixteenth : ${tempQuantumSixteenth}"
		// NOTE : any asynchronous temperature query thru SensorMultilevelGet(sensorType: 1, scale: 0) does NOT reset the delta-Temp base value (managed by DS18B20 hardware)
		cmdBlock << zwave.configurationV2.configurationSet(parameterNumber: 12/*for FGK101*/, size: 1, configurationValue: [tempQuantumSixteenth]).format()
		// inclusion of Device in Association#3 is needed to get delta-Temperature notification messages [cf Parameter#12 above]
		cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
        // inclusion of Device in Association#2 is needed to enable SensorAlarmReport() Command [anti-Tampering protection]
        cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
        // Should be last for proper checking of complete initialization (through configurationReport)
		cmdBlock << zwave.configurationV2.configurationGet(parameterNumber: 12/*for FGK101*/).format()
		//cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
        log.debug "++++++Last non-ZW5 Configuration Command SENT++++++"
    /////////////// ZW5 specific configuration
    if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && device.currentValue('ZW5')) {
    	log.debug "Configuring - ZW5............................................."
            //cmdBlock << "delay ${state.shortDelay}"
		cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId))
    	def short tempQuantumTenth
    	log.debug "device.displayName.substring(0,1) : ${device.displayName.substring(0,1)}"
    	} else {
    		tempQuantumTenth = 1	/* 3/10=0.3°C = 0.56°F */
    	// sensorMultilevelGet() should be +++PROPERLY+++ CRC16 encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!
        // ZW5 : completely buggy synchronous sensorMultilevelReport() : +/- 1°C vs unsolicited asynchronous reports : ???
        cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 3/*for FGK101*/, size: 1, configurationValue: [5]))  // LED blinks on Tampering & Open/Close
        // measuring temperature every 5mn drains the battery in a few months... but every hour creates a prejudiciable latency...
		cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 50/*for FGK101*/, size: 2, configurationValue: [0x03,0x84]))  // measure temperature every 15mn = 900s = 0x384
        cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 51/*for FGK101*/, size: 2, configurationValue: [0,tempQuantumTenth]))  // less than 256...
        // ??? : parameter#52 seems to translate "1 second" into "1.92 second", based on actual measurements
        //       => downrate 14 400 to 7 510 to compensate
        //cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x38,0x40]))  // 0x3840 = 14400 = 4*3600 = 4 hours
        cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x1D,0x56]))  // 0x1D56 = 7510
        // 1st Association Group : "Lifeline" reports the device status and allows for assigning single device only (main controller by default)
        cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
        // 2nd Association Group : "Control" is assigned to the device status - reed sensor and IN input (sends alarm command frames).
        cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
		cmdBlock << encap(zwave.configurationV2.configurationGet(parameterNumber: 51/*for FGK101*/))
    	log.debug "++++++Last ZW5 Configuration Command SENT++++++"
    //log.debug "device.Configured: ${device.currentValue('Configured')}"
	return cmdBlock // Fully configured only after 2 Configure() calls
def infos() {
	if (!state.devices) { state.devices = [:] }
    log.debug "zwaveHubNodeId: ${zwaveHubNodeId}"				// -> "1"
    log.debug "device.displayName: ${device.displayName}"		// -> "JJG"
    log.debug "device.id: ${device.id}"							// -> "d93f6450-4c9b-4892-bfcb-d61353f4c793"
    log.debug "location.id: ${location.id}"						// -> "99e95fb7-726f-4c64-a4f5-7b2151cf166a"  [Le Puits Jamet]
    log.debug "device.name: ${device.name}"						// -> "T005"
    log.debug "device.label: ${device.label}"					// -> "JJG"
    log.debug "device.data: ${device.data}"   					// -> "[MSR: 010F-0700-2000, endpointId: 0, version: 2.1]"
    log.debug "device.rawDescription: ${device.rawDescription}"	// -> non-ZW5 : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
    // -> ZW5 : "zw:Ss type:0701 mfr:010F prod:0701 model:2001 cc:5E,59,22,80,56,7A,72,73,98,31,86 sec:85,20,70,5A,8E,71,2B,9C,30,84"
 *  Calculates the 16-bit CRC (CRC-CCITT) for a byte array.
 *  Uses initial crc of 0x1D0F, and poly of 0x1021, as per Z-wave specification.
 *  Reference: http://z-wave.sigmadesigns.com/wp-content/uploads/2016/08/SDS12652-13-Z-Wave-Command-Class-Specification-N-Z.pdf
 *  Thanks to CODERSAUR : https://community.smartthings.com/t/handling-crc-16-encapsulation-commands-crc16encap/76931/4
 private zwaveCrc16(byte[] bytes) {
    short crc = 0x1D0F // It's important this is a short (16-bit)
    short poly = 0x1021
    bytes.each { workData ->
        //for (bitMask = 0x80; bitMask != 0; bitMask >>= 1) {
        // Need to use a different way to iterate, as rightshift operator '>>' and unsigned rightshift '>>>' do not appear to work in SmartThings.
        [0b10000000,0b01000000,0b00100000,0b00010000,0b00001000,0b00000100,0b00000010,0b00000001].each { bitMask ->
            def newBit = ((workData & bitMask) != 0) ^ ((crc & 0x8000) != 0);
            crc <<= 1;
            if (newBit) { crc ^= poly; }
    return crc
// CRC16 Encoding for Hub's +++OUTGOING+++ Commands
private crc16Encode(hubitat.zwave.Command cmd) {
	log.debug "cmd: ${cmd}"
	def bytesToCRC = [0x56, 0x01, cmd.commandClassId, cmd.commandId]
    bytesToCRC += cmd.payload
	log.debug "bytesToCRC: ${bytesToCRC}"
	def short checksum = zwaveCrc16(bytesToCRC as byte[])
	log.debug  "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
	return "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
//ZW5 added
private secure(hubitat.zwave.Command cmd) {
	zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
//ZW5 added
private encap(hubitat.zwave.Command cmd) {
    def secureClasses = [0x20, 0x2B, 0x30, 0x5A, 0x70, 0x71, 0x84, 0x85, 0x8E, 0x9C]
    //todo: check if secure inclusion was successful
    //if not do not send security-encapsulated command
    if ((device.currentValue('ZW5set')) && (device.currentValue('ZW5'))) {
		if (secureClasses.find{ it == cmd.commandClassId }) {
    		secure(cmd)
    	} else {
        	// ??? : very dubious all UNsecure outgoing ZW5 commands have to be CRC16 encoded;
            //		 sensorMultiLevelGet() MUST be, but for sure
            //       batteryGet() and versionGet() need NOT be ! (but could be ?)
    		crc16Encode(cmd)  // crc16() Fibaro code w/ checksum = 0x0000 was buggy
    } else {
    	return cmd.format()
Seems to be a Battery Hog too. :slight_smile:
Current States
battery : 24
contact : open
tamper : detected
temperature : 89.37
I'm using the same driver. Temp works great for me. I am also seeing the persistent "1 pending change".
I "broke the seal" so to speak, on this device to help @murray.sean.d and I agree, it does temp. It's different from all the other temp devices I have (Aeon MultiSensor6, Dome, Iris) the temp doesn't just update time based, but the native driver has temp Threshold too.
I'll give that driver a try @bobbles -- thanks, because now that it's out of the box and paired, I may as well use it, at least til this battery dies :slight_smile:
