9 posts were split to a new topic: Harmony connectivity
I think I may start moving stuff across now I have the link working correctly! Then plan on using the ST app for some control and a presence device until HE has one. I'm still waiting for some devices to be fully support though but I think it's getting close
Use life life360 @BorrisTheCat it's working better than the ST presence ever did for me. Pushover for notification and sharptools.io to bridge the app gap until HE release there own app.
My ST hub is now turned off and HE is working great with a mix of fibaro, smartthings sensors, sonoff.
Turned my ST hub off today. I did have some minor stuff running that to be honest was just niceties but not really necessary.
Don't let me down HE.
RIP ST Hub - 10/3/2018
Here's to the future of Hubitat!
Turned my ST Hub off when I moved out of old house on 9/21/2018 Brought the HE hub online around 9/26/2018. Much to learn.
Side note, one of my laptops is running hot. So for now- my ST hub is used as a "block" to keep it in the air while a small fan blows under it. It hasn't failed doing its job since.
Sooo...your in North East PA and migrated from ST to Hubitat....care to show some love for a user in Fairview that just ordered a HE hub? I only have about 80-90 devices...webcore, BlueIris, Harmony, Google Home...
Thanks to Lock Code Manager I turned my smartthings off today.
I have some items left in SmartThings that dont seem to port over.
my list is:
Yale Lever lock
Doesnt work in Hubitat with the LCM, the unit gets discovered but never ends up finishing.
Harmony Hub
I have it integrated into Hubitat, just havent removed it form ST.
GarageIO Door opener
I am pulling this over from ST into SharpTools for my wall touchscreen setup, not sure if Hubitat is working on an integration (i suspect not)
Honestly if I could get these into Hubitat then my ST setup would be long gone!
I have gone far enough to consider replacing my garageIO setup with some Zwave Garage door controllers just to get those out of SmartThings.
Until the LCM lets me use my current lock and until it gets a tad more advanced like RBoy Apps I need to keep it where it is.
All this pains me, Hubitat is perfect for my home, it runs great, fast, it is growing every day.
The lock is seen by the driver, works via the driver and you can put in codes and delete them via the driver?
Click the question mark in Lock Code Manager to the right of the gear or select help from the kabob menu on the top right and you'll get to the Lock Code Manager documentation.
What happens is when i go to pair the lock (and this could be the Yale itself) it sees the unit, says it is complete, but the device in Hubitat never shows as communicating.
I can put in codes, but because the device wont respond, nothing happens and they just fail.
What @SmartHomePrimer said and.. I see: "never ends up finishing"
LCM is a Manager for Codes on a Lock.
LCM does not manage locks, it manages the codes that they save.
If you have a static lock code situation LCM doesn't bring much to the picnic. It allows you to change codes, but if you're not changing codes (or adding for a cleaning person, nanny, etc) then why fight with LCM?
You first need a LOCK fully, and properly working in Hubitat. And "never ends up finishing" makes me wonder if you do.
Locks MUST pair securely. If they pair, non-secure, you get the symptoms you describe.
So that's a joining issue or pairing issue (not sure if you have Z-Wave or Zigbee lock). That's nothing to do with LCM.
Thanks, i never said LCM was my issue, it is defintely the unit itself and i bet it doesnt pair securely.
We have a maid who comes once a week and I like to schedule their code access to just the time and day they arrive, i also add and schedule visitors. For example we have friends coming in from Wisconsin in December, its good to create them a code, send it to them, have it activate when they land at the airport, and have it disable/delete when they leave to go back home.
I love my Hubitat, just a few things i need to sort out. The lock is a YRL-220, I am going to go do some more research on how it pairs.
zwaveSecurePairingComplete: true
You need to see that in the Data row of the table at the bottom of the device page.
I don't see YRL-220 in any search results here.. so maybe you're the pioneer
Oh, and @SmartHomePrimer question is important: ZWave or Zigbee.. because I just gave you a ZWave answer.
Sorry. I misinterpreted your saying it doesn't work with Lock Code Manager. If it's joining securely (pairing is a Zigbee term), then you'll see 0x98 in the InClusters under the DATA field of the driver. I see this with my YRD256.
Thanks, no worries at all.
My unit is Z-Wave, i can buy a ZigBee module for the unit, i wonder if their Zwave module doesnt support the secure feature.
I think people are having more issues with the Zigbee module. I'm not certain, but I think your lock and mine probably use the same Z-Wave module. Mine is working great. Maybe your lock has an older version of the module? Is it Z-Wave Plus?
The ZWave spec is pretty specific about Barrier Devices. Garage Door Openers and Locks are common examples of Barrier Devices.
The spec says, (paraphrased) if they don't join securely they must not do anything. And that's certainly the most common comment I've been seeing over the past few months, related to Locks. "My lock paired just fine, but it won't respond to anything." Yep. That's what Barrier Devices are expected to do when not securely joined.
Therefore, I would begin with... the manufacturer (Yale) knows the spec and has a secure ZWave module in your lock.
