Had some fun yesterday ...
Loooove Sinopé thermostats !
@nclark he's left a place in refresh_misc() where you'll have to implement your own solution to get local outside temp. In an ideal world, you could easily pull it from an existing weather driver (but I don't believe 2 drivers can directly talk).
@scoulombe - two questions
on line 313 "if (outdoorTemp)" - if the temp is 0, then won't this section be skipped?
How are you getting the word "Out" to display on the thermostat itself?? For me, under normal operation it displays "Set" to indicate the setpoint, but when I've switched to yours and enabled external temp display, it just shows the temp with no text at all.
@scoulombe, from the tiles I see, you must be from QC. I am also a fellow Quebecer and actually from the same city that Sinope are based in.
@nclark Yes I am
How do you manage to send an outside temperature reading ? I can't find it anywhere
Btw I think we are all from Quebec or near of that. Messing with 240V line voltage thermostat seems to be a northern hobby. I live near the sinope factory too
In the method refresh_misc() ..
// Outdoor temperature
if (!settings.DisableOutdorTemperatureParam)
float outdoorTemp;
// Read some outdoor temperature here ...
if (outdoorTemp)
cmds += zigbee.writeAttribute(0xFF01, 0x0011, DataType.UINT16, 10800, [:], 1000) // Set the outdoor temperature timeout to 3 hours
cmds += zigbee.writeAttribute(0xFF01, 0x0010, DataType.INT16, zigbee.convertHexToInt(hex(outdoorTemp * 100)), [mfgCode: "0x119C"], 1000)
else
cmds += zigbee.writeAttribute(0xFF01, 0x0011, DataType.UINT16, 30) // Set the outdoor temperature timeout to 30sec
At first, I as getting (somehow) the temperature from Environment Canada ... I don't want to share publicly this code because it's not .. well .. right ...
But now, I read the temp from an exterior sensor with a RTL-SDR dongle ...
It's a nice hobby right now
I'm waiting for two more Sinopé TH1123ZB ...
Not sure exactly what you mean by "send it in C" (My hub is set to Celsius, if that's what you mean). Within the refresh_misc, even if I directly set outdoorTemp = 4 (for example) then it does display 4 on the screen but it's missing the "Out". This isn't the end of the world, as the fundamental part of the feature works - it just makes me wonder why I see a different experience. I wonder if I have a different fw on my thermostat?
Sorry guys for being late (December was a rather busy month for me!), but great job @scoulombe on taking-up the lead!
Here's my code:
https://github.com/kris2k2/hubitat/blob/master/drivers/kris2k2-Sinope-TH112XZB.groovy
(It's worth mentioning that I use this Thermostat driver in conjunction with HomeKit via HubConnect+HomeBridge)
@kris2k2 your link is broken
Fixed
@kris2k2 Nice! I see you receive the outdoor temp via some notification ... Is it a weather app ? Your approach is better than mine !
@putch Oh ! Sorry ! I thought the temperature was not displaying correctly ... For me the "Out" always show with the code I have ... Is there any way to get the FW version ?
Btw, my code was missing an important capability ... "Thermostat"
Without that capability, it was not possible to create Thermostat schedule ...
Yep! Using the built-in weather device driver to get the temperature, and then I configured a rule that whenever the temperature changes, to notify all my thermostats.
It was a quick hack until I figure-out how to access weather from another device and reuse the information that’s already there.
@kris2k2, nice implementation of getting the outside temperature, but I do have a question fo rthe rule to set up.
I started a new rule with the trigger ...
"Temperature of DarkSky Weather changed
but as the action, I can't seem to find a variable or attribute about outdoortemp for the thermostat? then looked at the code again, and then saw that you are waiting for a notification being sent to the device, yet for some reason, I can't seem to find the action to do this?
I'm probably just missing something so obvious that it's right in my face.
Thanks for any help!
EDIT: Found the notify action but %value% does not seem to have the info in it???
EDIT 2: ok just saw you're reply under this, will try that and let you know!
Ah right, I forgot this little quirk
Here’s how I got it setup using a local variable so I can use the notify function and pass it the local variable.
How I tested it first, is that I’d notify my mobile phone device to see the data, and once I was happy with it, I sent it to the thermostat.
@kris2k2, I setup the rule and everything seems to work except for a Javascript error on line 358
int outdoorTemp = Integer.parseInt(text)
Logs show me...
dev:332019-12-27 13:53:02.775 errorjava.lang.NumberFormatException: For input string: "5.5" on line 358 (deviceNotification)
dev:332019-12-27 13:53:02.699 infodeviceNotification() : Setting outdoor weather to 5.5
dev:332019-12-27 13:53:02.693 infodeviceNotification(5.5)
dev:2002019-12-27 13:53:01.477 infoDarkSky.net Weather Driver - INFO: Polling DarkSky.net
The local variable used in the rules is of type string and also tried type decimal, but both give the same error.
Here is my rule...
Integers aren't decimals
Try this:
int outdoorTemp = Math.round(text)
Admittedly, the temperature handling I integrated was lousy; I should probably re-write it!
Update: I committed a new version on github.
lol, I figured that one out, and was looking into it, I really need to get up to date with programming, haven't done much of it for the last 15 years or so. Will get back to me after a few things like this ![]()
Just installed the new version and all is working as intended with the DarkSky.net Weather Driver
Thanks again!
Hi guys, total newbie here but there is a tremendous amount of useful info on here!
I've been following the thread as I am having issues also with displaying the outside temperatures on Sinope TH1124ZB via Hubitat hub.
I pretty much figured out everything but I can't find the "Notify" action to send the updated outside temperature to the thermostats.
What am I missing?
Thanks!
