I don't believe this is an issue with my rule because I haven't touched the rule in months and it worked flawlessly up until recently. When I open the door, light turns on as expected. When I close the door, despite the logs showing the door sensor correctly triggers a close, the rule doesn't fire:
Notice in the above screenshot it's set to turn off when the door is closed. Notice in the logs below you can see it turn on when the door is opened, you can see the log showing the door closed, but the light does not turn off.
that’s not the case. It never even sent the off command. It also doesn’t matter how long I wait. Before the log entry I reproduced it after leaving the door open for 5 minutes. It never sends the command. A zniffer confirmed no off command is sent.
Yeah I found same where off was never sent. Then another platform release came along and simple automation started working again. Really don’t understand it but moved it to a RM rule temporarily while disabling the SA rule. Then later went back to the SA rule and it worked again. I haven’t seen this issue in a while though.
