I have a rule setup that triggers a RL app, but for some reason the transition time for the light is not followed when using RM to trigger. The light goes to the correct level, but instantly instead of fading up.
If I trigger the RL app using the "activate" button from the RL app itself the transition time is followed properly.
Thanks I will take a look at this way as well. Although it still seems like a possible bug, as the RL app is not following the conditions as it should be.
Yeah I am finding these intricacies with RL, but overall it works well and I feel its a good upgrade over the old motion/mode lighting app.
Do you if its possible to fade up a light that is already on with motion as a trigger? Looking to have a light on in the evening at a low level and then fade up when someone walks in the room and then back down when motion is inactive.
