Ring keypad v2
I have tried both the built in driver as well as the community driver.
OK so this is where I stand now. I have the keypad added to Hubitat. I can see it in my device list and my zwave details. I added the keypad to hubitat safety monitor.
In the device details page, I can arm away arm night and disarm the keypad and HSM also changes the status. And this works the other way as well. If i change the status in HSM the keypad recognizes it.
But it the keypad itself doesn't let me arm or disarm. I have added the code to the keypad and can see it in the details page. But if i type in the code and press the arm away button nothing happens. What trouble shooting steps are there to try and get the keypad to recognize codes and arming/disarming.
I ran into the same behavior when I got my first Ring Keypad. I actually thought I was missing something about how the keypad was supposed to work.
It is some weird connection issue, where the keypad and hubitat think they are happy together but are not. I went back and forth between S2/no S2, smart start/classic, etc. Eventually after pairing it showed the secureInClusters and everything started working.
I had a lot of trouble with it, and did all sorts of things that I dont know if mattered or not. But I remember unpairing the keypad gracefully from hubitat, resetting the keypad back to factory default, rebooting hubitat, pairing the keypad via smart-start with s2, and then i had to go in and finish with pairing something-or-other that didnt go all the way with smart-start (smart-start was just sitting/spinning/waiting for something). I have three keypads and paired them the same way, they've been solid for a year or so. HTH.
I think @bcopeland the ring stuff NEEDS to be paired at s2 for it to work correctly. I know my Ring sensors did but I think the keypad was an especially special case.
I have been fighting a new keypad v2 for hours now. I can only get it to communicate from the app to the keypad. But not the other way. What am i missing here?
I know this is old post but did you get it to work? I'm having the same problem
How are you pairing it? Keypads require encryption so you should pair it with smart start,.
I am running into the exact same issue.
I've tried all the suggestions in this post.
SmartStart does not work as the app says the "QR code is invalid", so I added it manually with security.
It's the only Zwave device on my hub. (It's a new hub, latest firmware).
I've tried legacy Zwave as well as ZwaveJS.
I can arm and disarm the keypad via the web interface, but it will not recognize my code on the keypad itself.
The current states panel shows my correct code.
Any suggestions on what I can try?
(I was able to do the SmartStarrt after a few tries - might have been the camera angle or lighting).
Keypad is still not responding to codes however.
Try resetting it and the immediately disable the proximity sensor. What deiver are you using.
@bcopeland may want to look at it.
