aaiyar
January 9, 2021, 1:13am
45
Ok - I think I get what you’re saying. Are you referring to identifying a LAN device controlled by Hubitat by a fqdn (or equivalent), instead of an IP address? For example a Shelly switch?
Bob.ma
January 9, 2021, 1:15am
46
Exactly. This is also why I got into issues with "Label". The challenge is in managing all the roles and linkages.
Ah, that makes sense. I didn't think of that since I use basically no lan integrations in hubitat (they are all in node-red).
Yes, that would be useful at times.
Bob.ma
January 9, 2021, 1:17am
48
Just to appreciate my challenge
aaiyar
January 9, 2021, 1:18am
49
Ok - I’m not going to get into the Label discussion again, but it should be allowed to use fqdns (or locally resolved names) instead of only IP addresses. That’s a good and valid suggestion.
Some integrations (eg HubConnect) definitely permit the use of resolvable names.
Bob.ma
January 9, 2021, 2:01am
50
I'd like to learn more about how you coordinate hubitat and node-red
aaiyar
January 9, 2021, 2:06am
51
Can I urge you to post this question in one of the node-red threads?
Like most home automation platforms, there is a set of node-red nodes to integrate with Hubitat.
With those nodes it makes it very easy to pull in, an write back values to Hubitat. They use Maker API as the communication mechanism.
Why do I use and like node-red? Summarized here: Node-RED nodes for hubitat - #4299 by JasonJoel
Thread on the nodes themselves:
I want to share with you my recent development with Hubitat and Node-RED .
node-red-contrib-hubitat
It is some generic nodes to facilitate the integration with Hubitat. The challenge was to found the middle between generic and easy of use. I will be very happy to have your feedbacks and discuss about how to improve it
Note that I keep this post updated with every release, no need to read all posts to know new features or changes.
You can look at the CHANGELOG for news
How to u…
There are also oodles of use examples here as well:
Good idea!
This thread is being created to give users of the Node-Red platform a place to share 'flows' focused on HE. When posting a flow please be sure to follow the simple formatting outlined below.
Title - this will be used to link your post in the Index on post #1. Please keep them short but descriptive.
Summary - include a brief description of what your flows automates. If it is a complex flow, give as detailed description as possible.
Picture - let everyone visualize the flow and be…
And common pallet choices:
I'm opening this topic to ask if there's any reason to create a List of Modules for one's first installation of Node-Red.
I ask because it seems there's a few new users to NR every few days and the Flows that are being shared often use a Palette item not on everyone's installation.
Must Have:
node-red-contrib-hubitat (Node-RED to Hubitat communication)
node-red-node-rbe (continue down flow only if a value changes)
node-red-contrib-noop (Simple placeholder node to help visualizations)
Palett…
