but it is asking for tokens in the wyze app, I can not add a screen shot this chat is not allowing it.
Username*
Password*
Manually Enter Tokens (Troubleshooting)
Access Token
Click to set
Save
Refresh Token
I tried the key ID and API key in bot places for "token" as you say id dose not need a "token" get in both cases I get
[app1662]logs?tab=past&appId=1662#)2025-02-01 09:23:38.481 PM
error
[WyzeHub] API Call to apiwyzecam/app/user/refresh_token failed with Exception: java.lang.Exception: Invalid Response Data Code: 2001
(logs?tab=past&appId=1662#)2025-02-01 09:23:38.478 PM
error
[WyzeHub] API Response error!
(logs?tab=past&appId=1662#)2025-02-01 09:23:38.474 PM
error
[WyzeHub] API Call to/apiwyzecam/app/user/refresh_token failed with Exception: groovyxResponseException: status code: 500, reason phrase: Internal Server Error
(logs?tab=past&appId=1662#)2025-02-01 09:23:38.256 PM
error
[WyzeHub] Access Token Invalid. Attempting to refresh token.
It says "Manually" - it is optional. I have both token fields blank.
Which matches what it shows in the Wyze Api Console
I so appreciate your help and that you're able to add an image I wasn't able to I think that's awesome and extremely helpful as yours is showing asking for the API key and key ID mine does not have these fields I wonder if I have an old version of the wise hub app? My wise hub app only ask for name password and tokens..
this site still will not let me add am image but in the WyzeHub settings my only options are
| access_token | text | **** |
| logLevel | enum | 1 |
| password | password | *** |
| refresh_token | text | *** |
| username | text | b***.com |
I will try to find a newer version of the WyzeHub that has the KEY fields as yours is shown.
Using code from
https://raw.githubusercontent.com/jakelehner/Hubitat/master/WyzeHub/apps/wyzehub-app.groovy
I see the lines asking for the API in the code, soooo not even sure why the form is not showing them, even in other browsers.
Whats the status on the cam support? i think i tried this early and only wanted to add a couple of cameras but i have 35 between 4 properties.. and i want to keep them in one account and it was too taxing to try with all those?
I just want to try and use 1 of the cameras motion sensor to activate a zigbee spray water bottle I built to keep the cats of the dang counter
Wyze is picking up the cats far better than the zooz motion sensors I am using now..
That code is out of date.
Install WyzeHub via HPM (preferred) or from this link: https://raw.githubusercontent.com/fieldsjm/Hubitat-2/refs/heads/master/WyzeHub/apps/wyzehub-app.groovy
that makes sense.. Updating...
That was it THANK YOU, THANK YOU !!
Kitchen cam added to motion detection ![]()
You will be much, MUCH happier if you stop installing things manually and start using HPM.
AFAIK, Wyze does not support cam video access via their API. But you can control some things. For instance, I have a rule that turns on notifications on one particular cam.
This is a v3 cam with a floodlight.
@jakelehner Perhaps update the first post to say "Install via HPM".
I would appreciate that update, that is where I started, I have never heard of HPM.
THANK YOU for all the help though, most appreciated..
ok, trying to use the wyze cam as a motion switch but the WyzeHub has the error
java.lang.NullPointerException: Cannot invoke method getChildDevice() on null object on line 1119 (method deviceEventValueCallback)
might this be the WyzeHub code resulting in an error ?
app:16632025-02-04 10:43:02.824 PM
info
[WyzeHub] [kitchen cam] Refreshing Recorded Events
app:16632025-02-04 10:41:03.117 PM
error
app:16632025-02-04 10:41:02.955 PM
error
java.lang.NullPointerException: Cannot invoke method getChildDevice() on null object on line 1080 (method deviceEventsCallback)
app:16632025-02-04 10:41:02.694 PM
info
app:16632025-02-04 10:41:02.597 PM
info
[WyzeHub] [kitchen cam] Refresh Device Data
app:16632025-02-04 10:41:02.578 PM
warn
[WyzeHub] [kitchen cam] initialize()
app:16632025-02-04 10:41:02.567 PM
warn
[WyzeHub] [kitchen cam] installed()
app:16632025-02-04 10:41:02.504 PM
info
[WyzeHub] Adding device type Camera with mac ******F97
app:16632025-02-04 10:39:56.410 PM
info
[WyzeHub] Login Request was OK: 200
app:16632025-02-04 10:39:55.698 PM
info
[WyzeHub] Authenticating User...
I finally got some time to play with this. I ended up using the setAllNotifications('false') rather than motion_notify as I want to disable motion & sound triggers based on presence.
What I found was that this works perfectly for my older cam (v1 - Kitchen Cam). But has no affect on the newer OG Cams I picked up more recently (the other two).
My guess is that the OG Cam is using a different property to control those settings.
When can test if you are comfortable editing the WyzeHub Camera driver code.
Line 310 - remove the // from:
//logDebug(propertyList)
- Wyze app: Turn on motion notifications
- HE: refresh OG Cam
- HE: review logs for properties
- Wyze app: Turn off motion notifications
We can then compare the two logs and see what changed. If there really are differences, then we may need a new driver specific to the OG Cam.
removed from WyzeHub Camera code
testing, back with logs soon.
