ya having 2 hubs and 5 locations .. local voice is not really for me.. i use the alexas in each place to give me the voice so that it doesnt matter where i am at the time.. now if i only had one location and one hub maybe.
I just got this siren
- manufacturer: _TZE204_t1blo2bj
- model: TS0601
and it seems to pair, and correctly select this driver, but none of the actions work. I have it plugged into USB only -- do I need to put in batteries?
Am I missing something? This is my first foray into Zigbee -- the odd thing I noticed was that the device seems to remain in pairing mode even after HE has figured out what it is and assigned the driver, etc...
Thanks!
ETA: I reset it and paired again -- I immediately pressed the "On" on the device page, and it sounded the siren. I pressed "Off" and it stopped. But I can't get it to do it again... ![]()
Here's what the debug logs show now:
dev:27292023-11-21 11:41:04.726debugSiren 1 sendZigbeeCommands(cmd=[he cmd 0x3C28 0x01 0xEF00 0x00 {C13F0D01000100} {}, delay 200])
dev:27292023-11-21 11:41:04.722debugSiren 1 sendTuyaCommand = [he cmd 0x3C28 0x01 0xEF00 0x00 {C13F0D01000100} {}, delay 200]
dev:27292023-11-21 11:41:04.712debugSiren 1 sendZigbeeCommands(cmd=[he raw 0x3C28 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:27292023-11-21 11:41:04.708debugSiren 1 wakeUpTuya()
dev:27292023-11-21 11:41:04.704debugSiren 1 swithing alarm off (presetBeepAndChimeSettings = fast)
dev:27292023-11-21 11:40:47.390debugSiren 1 sendZigbeeCommands(cmd=[he cmd 0x3C28 0x01 0xEF00 0x00 {A8D4050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:27292023-11-21 11:40:47.359debugSiren 1 sendZigbeeCommands(cmd=[he raw 0x3C28 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:27292023-11-21 11:40:47.354debugSiren 1 wakeUpTuya()
dev:27292023-11-21 11:40:47.350debugSiren 1 swithing alarm on (presetBeepAndChimeSettings = fast)
Seems like Hubitat Zigbee 3.0 connectivity issue - the device will stay connected to the hub for several seconds, and short after will leave the ZIgbee network.
This has been reported many times, but until now it affected mostly Tuya, Aqara, and other brands that are not officially supported by Hubitat.
If Inovelli fan switch issue reported recently is the same, I think that now there is a good chance this problem to be identified and fixed by Hubitat engineers. ![]()
The code does not work with this device, the siren does not work.
Is this a known bug or should it work?
- manufacturer: _TZE200_d0yu2xgi
- model: TS0601
Hi @sanlulafra ,
TS0601 _TZE200_d0yu2xgi is in the list of supported devices, so it should work if the pairing to your hub is successful. Is your hub a C-8 or C-7 ?
To verify the connectivity status:
- enable the Debug option and click on the Save Preferences button.
- open the live logs in another tab in the browser.
- click on the Configure button, filter the logs for this device only.
- power off the device for 5 seconds.
- power it back on
Is there anything in the live logs after powering on the siren?
Don't click on any buttons from the device web page. The powering off -> powering on should produce some debug logs, meaning the Zigbee connection is alive.
If nothing in the live logs after powering on the device, you can try to pair it again, very close to the hub, then try the power off -> power on test again.
After doing the indicated tests, it still doesn't work, I paste the entire log.
Greetings
dev:26992024-04-19 12:27:29.567debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:27:25.099debugSirena Casa sendZigbeeCommands(cmd=[he cmd 0xBF13 0x01 0xEF00 0x00 {27E7740400010267020004000000B4660400010B6801000101} {}, delay 200])
dev:26992024-04-19 12:27:25.080debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:26992024-04-19 12:27:25.077debugSirena Casa wakeUpTuya()
dev:26992024-04-19 12:27:25.074debugSirena Casa swithing alarm on (presetBeepAndChimeSettings = fast)
dev:26992024-04-19 12:27:19.466debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:27:16.744debugSirena Casa sendZigbeeCommands(cmd=[he cmd 0xBF13 0x01 0xEF00 0x00 {D6907404000102670200040000000166040001026801000101} {}, delay 200])
dev:26992024-04-19 12:27:16.711debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:26992024-04-19 12:27:16.707debugSirena Casa wakeUpTuya()
dev:26992024-04-19 12:27:16.705debugSirena Casa sending beep() beepVolume = high
dev:26992024-04-19 12:27:03.970infoSirena Casa humidity is 1.8 % RH
dev:26992024-04-19 12:27:03.967infoSirena Casa Neo Humidity Level is 1.8 %RH (18)
dev:26992024-04-19 12:26:38.933debugSirena Casa device has received Tuya cluster ZCL command 0x24 response 0x00 data = [24, 00]
dev:26992024-04-19 12:26:38.764debugSirena Casa sending time data : [he cmd 0xBF13 0x01 0xEF00 0x24 {0008662246DE662262FE}, delay 2000]
dev:26992024-04-19 12:26:38.758debugSirena Casa time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 BF13 01 00 0000 24 01 0003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BF13, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 03]]
dev:26992024-04-19 12:26:33.670debugSirena Casa application version is 53
dev:26992024-04-19 12:26:28.432debugSirena Casa device announcement
dev:26992024-04-19 12:26:02.538debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:26:02.419debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:26:02.317debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:26:02.296debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:26:02.284debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:26:02.266debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:26:02.251debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:26:02.220debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:26:02.177debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:25:58.171debugSirena Casa sendZigbeeCommands(cmd=[he cmd 0xBF13 0x01 0xEF00 0x00 {81BF7404000102670200040000000166040001026801000101} {}, delay 200])
dev:26992024-04-19 12:25:58.148debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:26992024-04-19 12:25:58.145debugSirena Casa wakeUpTuya()
dev:26992024-04-19 12:25:58.144debugSirena Casa sending beep() beepVolume = high
dev:26992024-04-19 12:25:49.170infoSirena Casa Debug logging is will be turned off after 24 hours
dev:26992024-04-19 12:25:49.106infoSirena Casa Debug logging is true; Description text logging is true
dev:26992024-04-19 12:25:49.104infoSirena Casa Updating Sirena Casa (Tuya Smart Siren Zigbee) model TS0601 manufacturer _TZE200_d0yu2xgi
dev:26992024-04-19 12:25:38.284infoSirena Casa Debug logging is will be turned off after 24 hours
dev:26992024-04-19 12:25:38.233infoSirena Casa Debug logging is true; Description text logging is true
dev:26992024-04-19 12:25:38.232infoSirena Casa Updating Sirena Casa (Tuya Smart Siren Zigbee) model TS0601 manufacturer _TZE200_d0yu2xgi
dev:26992024-04-19 12:25:34.409infoSirena Casa Debug logging is will be turned off after 24 hours
dev:26992024-04-19 12:25:34.363infoSirena Casa Debug logging is true; Description text logging is true
dev:26992024-04-19 12:25:34.361infoSirena Casa Updating Sirena Casa (Tuya Smart Siren Zigbee) model TS0601 manufacturer _TZE200_d0yu2xgi
dev:26992024-04-19 12:25:27.790infoSirena Casa Debug logging is will be turned off after 24 hours
dev:26992024-04-19 12:25:27.742infoSirena Casa Debug logging is true; Description text logging is true
dev:26992024-04-19 12:25:27.740infoSirena Casa Updating Sirena Casa (Tuya Smart Siren Zigbee) model TS0601 manufacturer _TZE200_d0yu2xgi
dev:26992024-04-19 12:25:26.540debugSirena Casa Tuya check-in
dev:26992024-04-19 12:25:14.448infoSirena Casa Debug logging is will be turned off after 24 hours
dev:26992024-04-19 12:25:14.398infoSirena Casa Debug logging is true; Description text logging is true
dev:26992024-04-19 12:25:14.397infoSirena Casa Updating Sirena Casa (Tuya Smart Siren Zigbee) model TS0601 manufacturer _TZE200_d0yu2xgi
dev:26992024-04-19 12:24:46.526debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:24:46.416infoSirena Casa alarm is off
dev:26992024-04-19 12:24:46.414infoSirena Casa confirmed alarm state off (0)
dev:26992024-04-19 12:24:46.412debugSirena Casa Neo Alarm status is 0
dev:26992024-04-19 12:24:46.293debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:24:46.175infoSirena Casa alarm is off
dev:26992024-04-19 12:24:46.163infoSirena Casa confirmed alarm state off (0)
dev:26992024-04-19 12:24:46.161debugSirena Casa Neo Alarm status is 0
dev:26992024-04-19 12:24:42.618debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:35.834debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:35.826debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:35.752debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:35.737debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:35.707debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:35.690debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:35.671debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:35.617debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:33.024debugSirena Casa sendZigbeeCommands(cmd=[he cmd 0xBF13 0x01 0xEF00 0x00 {FAE6740400010267020004000000B4660400010B6801000101} {}, delay 200])
dev:26992024-04-19 12:24:32.995debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:26992024-04-19 12:24:32.991debugSirena Casa wakeUpTuya()
dev:26992024-04-19 12:24:32.982debugSirena Casa swithing alarm siren (presetBeepAndChimeSettings = fast)
dev:26992024-04-19 12:24:31.134debugSirena Casa sendZigbeeCommands(cmd=[he cmd 0xBF13 0x01 0xEF00 0x00 {8D506801000100} {}, delay 200])
dev:26992024-04-19 12:24:31.132debugSirena Casa sendTuyaCommand = [he cmd 0xBF13 0x01 0xEF00 0x00 {8D506801000100} {}, delay 200]
dev:26992024-04-19 12:24:31.113debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:26992024-04-19 12:24:31.110debugSirena Casa wakeUpTuya()
dev:26992024-04-19 12:24:31.107debugSirena Casa swithing alarm off (presetBeepAndChimeSettings = fast)
dev:26992024-04-19 12:24:25.018debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:24:24.889debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:24:24.811debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:24.798debugSirena Casa Neo Siren Volume is (2)
dev:26992024-04-19 12:24:24.778debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:24.753debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:24.724debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:24.688debugSirena Casa device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:26992024-04-19 12:24:24.642debugSirena Casa basic cluster report : descMap = [raw:BF130100001605004206545330363031, dni:BF13, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:26992024-04-19 12:24:19.936debugSirena Casa sendZigbeeCommands(cmd=[he cmd 0xBF13 0x01 0xEF00 0x00 {626B740400010267020004000000B4660400010B6801000101} {}, delay 200])
dev:26992024-04-19 12:24:19.909debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:26992024-04-19 12:24:19.906debugSirena Casa wakeUpTuya()
dev:26992024-04-19 12:24:19.903debugSirena Casa swithing alarm on (presetBeepAndChimeSettings = fast)
dev:26992024-04-19 12:24:16.617debugSirena Casa NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 BF13 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BF13, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:26992024-04-19 12:24:16.589debugSirena Casa basic cluster report : descMap = [raw:BF1301000068040042105F545A453230305F64307975327867690000002003010000205305000042065453303630310700003003FEFF003000, dni:BF13, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_d0yu2xgi, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:53, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:26992024-04-19 12:24:16.271debugSirena Casa sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xBF13 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:26992024-04-19 12:24:16.265infoSirena Casa configure()..
dev:26992024-04-19 12:24:10.944infoSirena Casa Debug logging is will be turned off after 24 hours
dev:26992024-04-19 12:24:10.903infoSirena Casa Debug logging is true; Description text logging is true
dev:26992024-04-19 12:24:10.901infoSirena Casa Updating Sirena Casa (Tuya Smart Siren Zigbee) model TS0601 manufacturer _TZE200_d0yu2xgi
dev:26992024-04-19 12:23:59.126debugTuya Smart Siren Zigbee device has received Tuya cluster ZCL command 0x24 response 0x00 data = [24, 00]
dev:26992024-04-19 12:23:59.015debugTuya Smart Siren Zigbee sending time data : [he cmd 0xBF13 0x01 0xEF00 0x24 {00086622463F6622625F}, delay 2000]
dev:26992024-04-19 12:23:59.009debugTuya Smart Siren Zigbee time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 BF13 01 00 0000 24 01 0014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BF13, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 14]]
dev:26992024-04-19 12:23:54.034debugTuya Smart Siren Zigbee application version is 53
dev:26992024-04-19 12:23:53.676infoTuya Smart Siren Zigbee Neo Power Mode is 4
dev:26992024-04-19 12:23:53.567infoTuya Smart Siren Zigbee confirmed melody 1=Doorbell 1 (0)
dev:26992024-04-19 12:23:53.565debugTuya Smart Siren Zigbee received Neo Alarm melody 0
dev:26992024-04-19 12:23:53.442debugTuya Smart Siren Zigbee confirmed duration 10 s
dev:26992024-04-19 12:23:53.440debugTuya Smart Siren Zigbee received Neo Alarm duration 10
dev:26992024-04-19 12:23:53.316infoTuya Smart Siren Zigbee alarm is off
dev:26992024-04-19 12:23:53.309infoTuya Smart Siren Zigbee confirmed alarm state off (0)
dev:26992024-04-19 12:23:53.307debugTuya Smart Siren Zigbee Neo Alarm status is 0
dev:26992024-04-19 12:23:53.199infoTuya Smart Siren Zigbee temperature is 26.8 °C
dev:26992024-04-19 12:23:53.192infoTuya Smart Siren Zigbee Neo Temperature is 26.8 C (268)
dev:26992024-04-19 12:23:53.091infoTuya Smart Siren Zigbee humidity is 1.9 % RH
dev:26992024-04-19 12:23:53.080infoTuya Smart Siren Zigbee Neo Humidity Level is 1.9 %RH (19)
dev:26992024-04-19 12:23:52.959infoTuya Smart Siren Zigbee Neo Min Alarm Temperature is 10 C
dev:26992024-04-19 12:23:52.835infoTuya Smart Siren Zigbee Neo Max Alarm Temperature is 35 C
dev:26992024-04-19 12:23:52.723infoTuya Smart Siren Zigbee Neo Temperature Unit is Celsius (1)
dev:26992024-04-19 12:23:52.594infoTuya Smart Siren Zigbee Neo Alarm by Temperature status is disabled (0)
dev:26992024-04-19 12:23:52.481infoTuya Smart Siren Zigbee Neo Alarm by Humidity status is disabled (0)
dev:26992024-04-19 12:23:52.343infoTuya Smart Siren Zigbee Neo unknown parameter (x073) is 4
dev:26992024-04-19 12:23:52.199debugTuya Smart Siren Zigbee Neo Siren Volume is (2)
dev:26992024-04-19 12:23:50.235debugTuya Smart Siren Zigbee NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 BF13 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BF13, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:26992024-04-19 12:23:50.126debugTuya Smart Siren Zigbee basic cluster report : descMap = [raw:BF1301000068040042105F545A453230305F64307975327867690000002003010000205305000042065453303630310700003003FEFF003000, dni:BF13, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_d0yu2xgi, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:53, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:26992024-04-19 12:23:50.082infoTuya Smart Siren Zigbee InitializeVars()... fullInit = false
dev:26992024-04-19 12:23:50.008infoTuya Smart Siren Zigbee updating the settings from the current driver version null to the new version 1.2.2 2023/07/19 9:30 PM
dev:26992024-04-19 12:23:49.881debugTuya Smart Siren Zigbee sendZigbeeCommands(cmd=[he raw 0xBF13 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xBF13 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:26992024-04-19 12:23:49.868infoTuya Smart Siren Zigbee configure()..
dev:26992024-04-19 12:23:49.846infoTuya Smart Siren Zigbee installed()
Add that my hub is a C-5
greetings
Thank you for the logs!
The good news is that this device communicates OK to the HE hub and stays connected. However, it seems that no one has tried this particular model (w/ temperature and humidity sensors inside) with this driver, because the relative humidity readings are obviously not scaled correctly (most probably must be multiplied by 10, although 19% RH seems too low ....).
Hopefully, I will have the time to look at the code in the next few days and will notify you when there is a new version to try.
Your device is from the second group, which is supported by Marcus's driver - please see the link for downloading the right driver on the top post.
Hello, any chance of making this work as well? _TZE204_fncxk3ob TS0601
Tried the current driver and not reacting with it, thank you
Thank you very much as always for your responses. There is no need to include support for this device on my part, I am going to delete this device from my installation.
Greetings
@Hanks I looked at TS0601 _TZE204_fncxk3ob - it is an interesting new device, however it is rather different than the models that work with this driver.
The current driver has too many hacks and workarounds to simulate 3 different devices (alarm, chime, and tone/beep generator) out of a single siren device. I need to make a new driver - with fewer whistles and bells, but easier to maintain and easier to add new models/manufacturers. So I am sorry, but at this time I can't add your siren to this existing driver.
I understand, thanks for taking the time and having a look at it, please don't hesitate to reach out if I can help with it in the future
Does anyone have any experience with this new Tuya Solar Siren. I could not find the description in our forums.
This is the fingerprint
fingerprint profileId:"0104", endpointId:"01", inClusters:"0004,0005,EF00,0000,ED00", outClusters:"0019,000A" ,model:"TS0601", manufacturer:"_TZE284_nlrfgpny", deviceJoinName: "Tuya Smart Siren Blue"
Even after adding the fingerprint to @kkossev siren driver and re-pairing I can't get any sounds out of it, but it is and stays connected.
The siren readily pairs to my C7
This is the device https://www.aliexpress.us/item/3256807356222236.html?spm=a2g0o.order_list.order_list_main.11.18f91802oiYMDz&gatewayAdapt=glo2usa
It comes with an 18650 Lithium, so the battery life should be pretty good. It's very loud and seems decently made.
- endpointId: 01
- application: 4D
- manufacturer: _TZE284_nlrfgpny
- model: TS0601
Current States
- Info : driver updated to new version 1.2.2 2023/07/19 9:30 PM
- alarm : off
- duration : 1
- mute : unmuted
- soundName : 3=Westminster
- status : stopped
- switch : off
State Variables
- packetID : 0
- rxCounter : 79
- lastTx : {"cfgFailure":false,"cfgTimer":0,"humiCfg":"-1,-1,-1","humiCfgOK":false,"tempCfg":"-1,-1,-1","tempCfgOK":false}
- modelGroup : UNKNOWN
- lastRx : {"humiCfg":"-1,-1,-1","humiTime":1728005423720,"tempCfg":"-1,-1,-1","tempTime":1728005423602}
- stats : {"date":"2024-10-03","rejoins":0,"rxCtr":2,"txCtr":2}
- driverVersion : 1.2.2 2023/07/19 9:30 PM
- lastCommand : off
- txCounter : 1
- notPresentCounter : 0
- configState : 0
Setting the driver to "device' returns no info in the logs
Hi Rxich,
This driver currently does not support this solar-powered alarm, it is rather different than the other Tuya alarm/siren devices.... I will try to add at least the basic alarm on/off function in the next driver update,
This is a bit disappointing, are you sure the device stays connected to your hub Zigbee network? You may need to pair it again, using the Double luck vodoo.
Is there a way to switch the power off and then power the device back on? Or, as it is solar-powered with built-in accumulators there is no way to cut off the power?
Yes, I can cut power, by removing the 18650 cell from the siren. I will pair again using the double luck, but my hub is a C7. I do have a C8 and was going to see if that made a difference connecting to the C8, as I suspect this being a new device is Zigbee 3.0..maybe?
I'm assuming it's staying connected based on state variables not present = 0
Better wait for driver update …
If you enable the Debug logs, do you see anything sent periodically by the device!?
Please update to dev. branch version 1.3.0 2024/10/07 9:00 PM.
Click on the Configure button. Then enable the Debug Logging and click on the Save Preferences.
There is a new ''Refresh' button in the commands section. Click it - anything in the live logs?
If this device is staying connected to your hub, please remove and re-insert the 18650 cell from the siren. I will need the debug logs that follow the Refresh() command and the re-insertion of the battery. You can send me the logs in a DM.
Hey Krassimir, Thank you so much for your help. Here are the logs from fresh pairing after battery removal. I don't see a refresh button with the dev driver. Maybe I need to remove totally & re-pair?
Debug Log Tuya Solar Siren w/ Blue Light
dev:22362024-10-07 10:22:06.845 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:22:06.829 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:22:06.816 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:22:06.798 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:22:06.782 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:22:06.777 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:22:06.763 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:22:06.742 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:22:04.997 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x552E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:22362024-10-07 10:22:04.991 PMinfoSiren Tuya Blueya configure()..
dev:22362024-10-07 10:22:04.249 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {638E0D01000100} {}, delay 200])
dev:22362024-10-07 10:22:04.240 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {638E0D01000100} {}, delay 200]
dev:22362024-10-07 10:22:04.230 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:22:04.226 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:22:04.222 PMdebugSiren Tuya Blueya swithing alarm off (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:22:03.398 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {52C7050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:22:03.380 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:22:03.376 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:22:03.370 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:22:03.045 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {8455050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:22:03.027 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:22:03.023 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:22:03.018 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:22:02.588 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {ADC9050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:22:02.572 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:22:02.568 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:22:02.564 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:22:02.067 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {D98F050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:22:02.032 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:22:02.027 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:22:02.022 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:22:01.438 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:22:01.429 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:22:01.419 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:22:01.395 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:22:01.184 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {610C050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:22:01.138 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:22:01.133 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:22:01.129 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:58.666 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {76DD0504000100070200040000000115040001020D01000101} {}, delay 200])
dev:22362024-10-07 10:21:58.647 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:58.643 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:58.639 PMdebugSiren Tuya Blueya sending beep() beepVolume = low
dev:22362024-10-07 10:21:56.063 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:54.604 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {5F0D} {}, delay 200])
dev:22362024-10-07 10:21:54.600 PMdebugSiren Tuya Blueya setting volume=unknown
dev:22362024-10-07 10:21:54.596 PMdebugSiren Tuya Blueya matched volumelevel=33 to nearestLlevel=33 (volumeTuya=-1)
dev:22362024-10-07 10:21:35.896 PMdebugSiren Tuya Blueya NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 552E 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:552E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:22362024-10-07 10:21:35.791 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E01000068040042105F545A453238345F6E6C726667706E790000002003010000204D05000042065453303630310700003003FEFF003000, dni:552E, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_nlrfgpny, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:22362024-10-07 10:21:35.775 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:35.763 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:35.752 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:35.746 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:35.729 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:35.712 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:35.296 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x552E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:22362024-10-07 10:21:35.289 PMinfoSiren Tuya Blueya configure()..
dev:22362024-10-07 10:21:34.458 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {73780D01000100} {}, delay 200])
dev:22362024-10-07 10:21:34.451 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {73780D01000100} {}, delay 200]
dev:22362024-10-07 10:21:34.435 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:34.339 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:34.334 PMdebugSiren Tuya Blueya swithing alarm off (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:32.100 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {1C4F050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:21:32.080 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:32.076 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:32.072 PMdebugSiren Tuya Blueya swithing alarm both (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:30.711 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {4D300D01000100} {}, delay 200])
dev:22362024-10-07 10:21:30.705 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {4D300D01000100} {}, delay 200]
dev:22362024-10-07 10:21:30.689 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:30.685 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:30.681 PMdebugSiren Tuya Blueya swithing alarm off (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:25.398 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:25.393 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:25.332 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:25.323 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:25.047 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {6877050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:21:24.991 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:24.987 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:24.983 PMdebugSiren Tuya Blueya swithing alarm siren (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:23.849 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {302A0D01000100} {}, delay 200])
dev:22362024-10-07 10:21:23.845 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {302A0D01000100} {}, delay 200]
dev:22362024-10-07 10:21:23.832 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:23.829 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:23.825 PMdebugSiren Tuya Blueya swithing alarm off (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:19.992 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:19.984 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:16.723 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {91B3050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:21:16.665 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:16.662 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:21:16.658 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:21:14.668 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:21:14.659 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:21:11.796 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {E8B105040001FFFFFFFF070200040000000215040001000D01000101} {}, delay 200])
dev:22362024-10-07 10:21:11.792 PMdebugSiren Tuya Blueya playSound 1 (1=Doorbell 1) index=0, duration=2, volume=unknown(-1)
dev:22362024-10-07 10:21:11.756 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:21:11.751 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:20:59.327 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:58.895 PMdebugSiren Tuya Blueya setVolume beep high 100% (Tuya:2)
dev:22362024-10-07 10:20:58.891 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {38D20504000102} {}, delay 200])
dev:22362024-10-07 10:20:58.887 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {38D20504000102} {}, delay 200]
dev:22362024-10-07 10:20:49.011 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:46.100 PMdebugSiren Tuya Blueya setVolume chime high 100% (Tuya:2)
dev:22362024-10-07 10:20:46.096 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {75540504000102} {}, delay 200])
dev:22362024-10-07 10:20:46.092 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {75540504000102} {}, delay 200]
dev:22362024-10-07 10:20:43.698 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:43.333 PMdebugSiren Tuya Blueya setVolume chime low 33% (Tuya:0)
dev:22362024-10-07 10:20:43.324 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {27B40504000100} {}, delay 200])
dev:22362024-10-07 10:20:43.319 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {27B40504000100} {}, delay 200]
dev:22362024-10-07 10:20:38.382 PMinfoSiren Tuya Blueya confirmed melody 4=4 Key Chime (3)
dev:22362024-10-07 10:20:38.326 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:33.680 PMdebugSiren Tuya Blueya setMelody chime 4=4 Key Chime (3)
dev:22362024-10-07 10:20:33.677 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {51211504000103} {}, delay 200])
dev:22362024-10-07 10:20:33.672 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {51211504000103} {}, delay 200]
dev:22362024-10-07 10:20:33.012 PMinfoSiren Tuya Blueya confirmed melody 2=Fur Elise (1)
dev:22362024-10-07 10:20:32.961 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:29.227 PMdebugSiren Tuya Blueya setMelody chime 2=Fur Elise (1)
dev:22362024-10-07 10:20:29.222 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {AF7C1504000101} {}, delay 200])
dev:22362024-10-07 10:20:29.218 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {AF7C1504000101} {}, delay 200]
dev:22362024-10-07 10:20:27.644 PMinfoSiren Tuya Blueya confirmed melody 2=Fur Elise (1)
dev:22362024-10-07 10:20:27.589 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:24.624 PMdebugSiren Tuya Blueya setMelody chime 2=Fur Elise (1)
dev:22362024-10-07 10:20:24.620 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {AFA01504000101} {}, delay 200])
dev:22362024-10-07 10:20:24.616 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {AFA01504000101} {}, delay 200]
dev:22362024-10-07 10:20:22.275 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:20.241 PMdebugSiren Tuya Blueya setVolume alarm low 33% (Tuya:0)
dev:22362024-10-07 10:20:20.237 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {92DF0504000100} {}, delay 200])
dev:22362024-10-07 10:20:20.233 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {92DF0504000100} {}, delay 200]
dev:22362024-10-07 10:20:12.063 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=1 value=3 descMap.data = [00, 0D, 01, 04, 00, 01, 03]
dev:22362024-10-07 10:20:11.968 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=1 value=2 descMap.data = [00, 0B, 01, 04, 00, 01, 02]
dev:22362024-10-07 10:20:11.946 PMinfoSiren Tuya Blueya alarm is off
dev:22362024-10-07 10:20:11.942 PMinfoSiren Tuya Blueya confirmed alarm state off (0)
dev:22362024-10-07 10:20:11.397 PMinfoSiren Tuya Blueya alarm is off
dev:22362024-10-07 10:20:11.390 PMinfoSiren Tuya Blueya confirmed alarm state off (1)
dev:22362024-10-07 10:20:07.805 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:07.651 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:20:07.461 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {E25E0D01000100} {}, delay 200])
dev:22362024-10-07 10:20:07.457 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0x552E 0x01 0xEF00 0x00 {E25E0D01000100} {}, delay 200]
dev:22362024-10-07 10:20:07.439 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:20:07.435 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:20:07.430 PMdebugSiren Tuya Blueya swithing alarm off (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:20:06.288 PMinfoSiren Tuya Blueya confirmed melody 12=Alarm Siren (11)
dev:22362024-10-07 10:20:06.271 PMdebugSiren Tuya Blueya confirmed duration 180 s
dev:22362024-10-07 10:20:06.254 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:20:06.119 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100001605004206545330363031, dni:552E, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:20:06.100 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E01000068040042105F545A453238345F6E6C726667706E790000002003010000204D05000042065453303630310700003003FEFF003000, dni:552E, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_nlrfgpny, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:22362024-10-07 10:20:06.071 PMdebugSiren Tuya Blueya NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 552E 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:552E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:22362024-10-07 10:20:05.254 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0x552E 0x01 0xEF00 0x00 {6CCD050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:20:05.144 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:20:05.140 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:20:05.136 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:20:02.603 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x552E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:22362024-10-07 10:20:02.597 PMinfoSiren Tuya Blueya configure()..
dev:22362024-10-07 10:18:55.739 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E01000068040042105F545A453238345F6E6C726667706E790000002003010000204D05000042065453303630310700003003FEFF003000, dni:552E, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_nlrfgpny, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:22362024-10-07 10:18:50.510 PMdebugSiren Tuya Blueya Tuya check-in
dev:22362024-10-07 10:18:50.260 PMdebugSiren Tuya Blueya application version is 4D
dev:22362024-10-07 10:18:50.009 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100000ACFFF214038, dni:552E, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487]
dev:22362024-10-07 10:18:45.589 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=0 descMap.data = [00, 06, 06, 01, 00, 01, 00]
dev:22362024-10-07 10:18:43.495 PMdebugSiren Tuya Blueya NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 552E 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:552E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:22362024-10-07 10:18:43.484 PMdebugSiren Tuya Blueya device announcement
dev:22362024-10-07 10:18:42.769 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x552E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x552E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:22362024-10-07 10:18:42.763 PMinfoSiren Tuya Blueya configure()..
dev:22362024-10-07 10:18:19.248 PMdebugSiren Tuya Blueya NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CB6 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CB6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:22362024-10-07 10:18:19.146 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:7CB601000068040042105F545A453238345F6E6C726667706E790000002003010000204D05000042065453303630310700003003FEFF003000, dni:7CB6, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_nlrfgpny, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:22362024-10-07 10:18:17.810 PMdebugSiren Tuya Blueya device announcement
dev:22362024-10-07 10:18:17.352 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0x7CB6 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CB6 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:22362024-10-07 10:18:17.344 PMinfoSiren Tuya Blueya configure()..
dev:22362024-10-07 10:18:06.128 PMdebugSiren Tuya Blueya application version is 4D
dev:22362024-10-07 10:18:05.932 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:ACBF0100000ACFFF214038, dni:ACBF, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487]
dev:22362024-10-07 10:18:00.973 PMdebugSiren Tuya Blueya device announcement
dev:22362024-10-07 10:18:00.926 PMinfoSiren Tuya Blueya InitializeVars()... fullInit = false
dev:22362024-10-07 10:18:00.919 PMinfoSiren Tuya Blueya updating the settings from the current driver version 1.2.2 2023/07/19 9:30 PM to the new version 1.3.0 2024/10/07 9:00 PM
maybe this has more info?
Summary
dev:22362024-10-07 10:29:40.836 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:E66301000068040042105F545A453238345F6E6C726667706E790000002003010000204D05000042065453303630310700003003FEFF003000, dni:E663, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_nlrfgpny, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:22362024-10-07 10:29:35.705 PMdebugSiren Tuya Blueya Tuya check-in
dev:22362024-10-07 10:29:35.412 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=0 descMap.data = [00, 0D, 06, 01, 00, 01, 00]
dev:22362024-10-07 10:29:35.287 PMdebugSiren Tuya Blueya application version is 4D
dev:22362024-10-07 10:29:35.042 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:E6630100000ACFFF214038, dni:E663, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487]
dev:22362024-10-07 10:29:28.532 PMdebugSiren Tuya Blueya NOT PARSED : descMap = [raw:catchall: 0104 0000 01 01 0040 00 E663 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E663, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:22362024-10-07 10:29:28.522 PMdebugSiren Tuya Blueya device announcement
dev:22362024-10-07 10:29:27.819 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0xE663 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xE663 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:22362024-10-07 10:29:27.813 PMinfoSiren Tuya Blueya configure()..
dev:22362024-10-07 10:29:15.707 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=1 descMap.data = [00, 08, 06, 01, 00, 01, 01]
dev:22362024-10-07 10:29:14.055 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=0 descMap.data = [00, 07, 06, 01, 00, 01, 00]
dev:22362024-10-07 10:29:12.677 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=1 descMap.data = [00, 06, 06, 01, 00, 01, 01]
dev:22362024-10-07 10:28:49.040 PMdebugSiren Tuya Blueya Tuya check-in
dev:22362024-10-07 10:28:48.466 PMdebugSiren Tuya Blueya application version is 4D
dev:22362024-10-07 10:28:48.194 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100000ACFFF214038, dni:552E, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487]
dev:22362024-10-07 10:28:41.670 PMdebugSiren Tuya Blueya device announcement
dev:22362024-10-07 10:28:36.013 PMdebugSiren Tuya Blueya application version is 4D
dev:22362024-10-07 10:28:35.878 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:552E0100000ACFFF214038, dni:552E, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487]
dev:22362024-10-07 10:28:30.898 PMdebugSiren Tuya Blueya device announcement
dev:22362024-10-07 10:27:55.704 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=0 descMap.data = [00, 12, 06, 01, 00, 01, 00]
dev:22362024-10-07 10:27:41.353 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=6 value=1 descMap.data = [00, 11, 06, 01, 00, 01, 01]
Debug Logs right after fresh pairing->Turned on then off right after.
Turn on then off w/ debug-WOW it is LOUD!
dev:22362024-10-07 10:36:43.164 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=1 value=3 descMap.data = [00, 1A, 01, 04, 00, 01, 03]
dev:22362024-10-07 10:36:43.041 PMwarnSiren Tuya Blueya NOT PROCESSED Tuya cmd: dp=1 value=2 descMap.data = [00, 18, 01, 04, 00, 01, 02]
dev:22362024-10-07 10:36:43.031 PMinfoSiren Tuya Blueya alarm is off
dev:22362024-10-07 10:36:43.027 PMinfoSiren Tuya Blueya confirmed alarm state off (0)
dev:22362024-10-07 10:36:37.826 PMinfoSiren Tuya Blueya alarm is off
dev:22362024-10-07 10:36:37.820 PMinfoSiren Tuya Blueya confirmed alarm state off (1)
dev:22362024-10-07 10:36:32.619 PMinfoSiren Tuya Blueya confirmed melody 12=Alarm Siren (11)
dev:22362024-10-07 10:36:27.568 PMdebugSiren Tuya Blueya confirmed duration 180 s
dev:22362024-10-07 10:36:27.352 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:36:27.339 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:E6630100001605004206545330363031, dni:E663, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:36:27.318 PMdebugSiren Tuya Blueya device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:22362024-10-07 10:36:27.309 PMdebugSiren Tuya Blueya basic cluster report : descMap = [raw:E6630100001605004206545330363031, dni:E663, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0601, clusterInt:0, attrInt:5]
dev:22362024-10-07 10:36:25.954 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0xE663 0x01 0xEF00 0x00 {CE000D01000100} {}, delay 200])
dev:22362024-10-07 10:36:25.950 PMdebugSiren Tuya Blueya sendTuyaCommand = [he cmd 0xE663 0x01 0xEF00 0x00 {CE000D01000100} {}, delay 200]
dev:22362024-10-07 10:36:25.936 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0xE663 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:36:25.932 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:36:25.927 PMdebugSiren Tuya Blueya swithing alarm off (presetBeepAndChimeSettings = fast)
dev:22362024-10-07 10:36:22.683 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he cmd 0xE663 0x01 0xEF00 0x00 {4761050400010207020004000000B4150400010B0D01000101} {}, delay 200])
dev:22362024-10-07 10:36:22.667 PMdebugSiren Tuya Blueya sendZigbeeCommands(cmd=[he raw 0xE663 1 0x01 0x0000 {10 00 00 05 00}, delay 50])
dev:22362024-10-07 10:36:22.662 PMdebugSiren Tuya Blueya wakeUpTuya()
dev:22362024-10-07 10:36:22.658 PMdebugSiren Tuya Blueya swithing alarm on (presetBeepAndChimeSettings = fast)
Please update the driver again and test the Refresh command - it should be visible now.
