[RELEASE] Tile Builder - Build Beautiful Dashboards
I’m on vacation for a couple of weeks so I my support is a bit limited, but here goes.
Go to the Tile Builder Storage Device you are using and see how the tile renders there. Then find the tile in the state variables and copy the data, starts with [head]…..
Finally, copy the picture of the tile on the dash board.
DM me these three items.
Might be a few days before I can get back to you as I’m traveling.
Conclusion: In working with @scoob8000 it was determined that the incorrect rendering only happened on Firefox.
I get that, my first response was basically just to make sure it was know that someone had taken over Hubigraphs. Also IMO made a few improvements to it.
Also the fact that it is now part of HE means the chance of the developer deciding to leave HE and drop support, as is the case with any community based app, is pretty slim.
Hi @garyjmilne, I've just started with Tile Builder and it's quite an accomplishment, kudos to you! I hopefully have an easily answered question, is it possible to have the table use the Device Name instead of the Device Label? When I first started a couple years ago I setup a 3 digit code for the labels (floor, room, device) to be able to easily add new devices and used the Device Name to describe it. Thanks!
Thanks, I'm glad you like it. The short answer is no. But I have a new module called Multi Attribute monitor in which the device name field is fully editable. So with that you could make them match.
Not quite the same, but perhaps it would be enough.
New module should be released by the end of the month and probably sooner.
Ok, no problem, that works. I'll wait for the new release. Thanks again!
dummy question? how do you install the tile builder?
As stated in the first post of this thread,
strange, i am not seeing when i click add built in app? am i doing something wrong?
You have to install HPM first. Start here.
Once all the apps and drivers code saved on the hub manually or via HPM (recommended), you will need to use the "Add User App" button to install and configure it, not the "Add Builtin App" button.
thank you! figured it out!
Look at this post. Link to HPM inside it. This is a good post for someone just starting on hubitat. Helps avoid some gotchas. Also pay attention to the ghosts section
@garyjmilne, perhaps you're still on vacation, so I'll leave this for your return: wow, thank you! What an awesome contribution to the community. Phenomenal work!
I'm using the basic tile builder to generate various lists of battery devices so I can easily see what devices need new batteries. When I did that, I noticed a few issues (some of which may be EBKACs):
  1. I've noticed on longer tables (20-30 devices), there will typically be 1-2 devices that are missing and replaced with a duplicate from elsewhere on the list. Reordering doesn't resolve the problem.
  2. Two tables with the exact same parms will produce tables with different fonts and different row/text sizes. I imagine this is due to some of the tables being <1024 and the others being SVG (based on what I've read above). Is this expected behavior? And any advice on how to counter?
  3. If I append battery values with "%" or "_%", the symbol doesn't show up in the table.
Again - gratitude. My next project will be upgrading to Advanced. :slight_smile:
Hi Mark, I'm back from vacation and working on the next TB module. To answer your questions:
Only one thing that could be so just checked my code and sure enough, two typos for entries #22 and #27 causing results #12 and #17 instead. Thanks for bringing that to my attention. It will be fixed in the next release.
As a general tip, with free version if you do a reverse sort of devices by battery level and limit the list to say 10 devices, you will get a more concise list of what you really care about, those devices with low batteries. In the TB Advanced version you can have filtered lists, such as only show devices with battery level less than 50% for example and the size of the list will vary.
Yes, these can be tricky. The bottom line is that a tile < 1,024 bytes will inherit a lot of properties from Dashboard that are not inherited when it is run in an iFrame (> 1,024). So yes, you are likely to get different fonts as these are also determined in part by the platform and the availability of the font you selected.
In short you will get the most consistent results if you choose a web safe font.
(CSS Web Safe Fonts)
Yes, selecting the type of units populates the %Units% variable which you can then reference in any text field. To have the unit display on every line go to the Rows tab and enable "Append Units to Data" and it will display on every line as shown below.
Is there an option to have no logging? I have it set to zero. Thank you.
Seeing this in my logs:
Multi Attribute Monitor for Tile Builder has been released. You will find the notification here:
This makes no changes to either Attribute Monitor or Activity Monitor, the two modules that you are using today. Once MAM gets worked over I will incorporate a few of those innovations into Attribute Monitor or Activity Monitor.
A couple of things I should point out with this update to Tile Builder Parent 1.4.0.
  1. The settings under the Highlights tab are no longer saved as part of the Style for any module.
  2. I added some extra overrides categories as part of the parent. #1 Using webfonts from Google and cdnfonts.com. #2 Cell Operations which gives examples of how to highlight particular cells which is more relevant in MAM as the row numbers never change.
  3. MAM adds two extra level of compression which can typically recover 100-200 bytes on a 1K tile. These techniques will be retrofitted to AttrMon and ActMon in the next update to those.
Set the log level to -1. I think that should work.
Am I being dense? Where is that setting?
In the Storage Driver.
I must admit I was looking to do this as well.
When you look at 'Device' it says the following.
I know I'm being picky but perhaps it should be 0-3, with an explanation as to what logging is available at each level.
Like I say, no big deal.
Keep up the good work with this fantastic app. :+1:
