What triggers a creation of this tile attribure?
I set the switch to Create HTML MemberTIle and checked the Dashboard attributes.
I don't see a Member_Location, just location.
EDIT: never mind. took a while to show up in attibutes. Also, didn't sort alphabetically in the list.
That shouldn't matter. The tile data/colors are being pulled based on what the attributes in the driver are listed as. I did some shuffle in the code to allow it to add/remove the tile in the next version. Can you let me know if you see that again after the next update?
The location field will show the region you are in, or the address (if available) or lat/lon that you are currently at. Only the APK in post #2 displays addresses (the app and play store versions do not). I'll have an update tomorrow that will link in the ability for everyone to see the addresses.
The dual "Home,Home" means your phone has two 'Home' regions. If you check the regions on your phone, that is why. The geofence flags you as in both, hence the double tag!
Currently it requires a location to come in to trigger it. Next release will just create it automatically from the device attributes when it's enabled.
I have fire tablets on the walls running Fully Kiosk.
One thing I note, as I'm running the free version, is that popups are not available.
Says only (PLUS) version.
So, the VIew Larger Map won't work. Not a big deal just FYI.
Not a big deal, but the lastSpeed var doesn't seem to reset/get updated to 0 once you have stopped moving. It usually shows me going 3.728 mph when I am home. I may get up to that when I am refreshing my beverage but I usually don't carry my phone with me to do that.
@lpakula
A new error on the current build
Every few minutes dev:21382024-01-26 17:10:42.532errorjava.lang.NullPointerException: Cannot invoke method split() on null object on line 480 (method generatePresenceEvent)
She has been travelling up the freeway and has arrived in or town about 20 minutes ago, still in Sweden with log errors?
As I posted this an update came through and it's normal now, logs have stopped erroring?
I just got this app installed and configured and am working to support it in HD+ . So far everything looks good - the only thing I can't figure out is the thumbnails.
