It uses the Hub Information to generate notifications. Just replaces writing rules for the notification.
Now we just need an RM action to update the hub and we have a proper hub automation system
It would also be nice if the hub told us the version number of the pending update, so that an assessment of its maturity could be made (eg. track each pending update and then decide which one to update at).
it is dangerous to do this automatically in my opinion.. occasionally there are glitches for known and unknown reasons and it would be better if you are around to handle them when they arise.. I belive a notification is enough
That's your choice. Others of us may like to automatically update our hubs based on rules related to the latest update version, if it has remained unchanged for several days, etc.
i was looking at integrating the new fw update stuff with my own modified version..
there is a typo/bug in your code
you call the new input paramter here
input("fwUpdatePollRate","number", title:"Poll rate (in seconds) for FW Update Check (Default:6000, Disable:0):", defaultValue:6000, submitOnChange:true)
fwUpdatePollRate
but reference it as a differnt name elsewhere fwUpdateCheckPollRate
if(fwUpdateCheckPollRate == null)
device.updateSetting("fwUpdateCheckPollRate",[value:6000,type:"number"])
if(fwUpdatePollRate > 0 ) updateCheck()
Thanks, I'll get that corrected.
For those that do not want to install your new app to notify here is a rule machine 5.1 rule to do the same.. the trigger is custom attribute. You cannot use notification app as you know as that does not support custom attributes.
Not that I don't appreciate your work.. I just need finer control over the contents of the html attribute to have it display what I want and fit into the hubigraph tile I have on my dashboard.
Not a problem, customization of the output (along with the desire to combine multiple hubs into one output) is one of the reasons I wrote
I don't believe there is a one size fits all. Target is to try and hit the sweet spot for 80-85%, and then help those that want a more custom solution.
To paraphrase The Beatles “Hold my hand”
Remember, I am an old fart. How the sam hill (sorry to any Sams here) do I use this? Read almost every post, and now I feel like I missed a few days of school.
This is a driver, so it needs to be associated with a device. Which one?
No chuckling please. This smart stuff is really stretching my capability.
It’s a virtual device driver, i.e. it is the device it defines.
Install device driver
Create a virtual device.
Assign it a name and then at the drop down list where you select the device driver use the Hub information driver you installed.
This device then becomes available for dashboards, RM, etc. For instance you could then put the Hub temp on a dashboard, just as you would put the temp of a temp sensor on a dashboard.
And, if you use the HTML device and corresponding tile, it puts all the useful information in a single tile.
Thanks for that I setup dashboards a while back with individual tiles and had not noticed the HTML attribute. That is much nicer.
IMHO, this set of steps should be in the OP. @thebarber75
What a nifty device... And using your hub monitor app really is the icing on the cake.
Hi @thebearmay
Just thought I'd pass on that I had defined a rule to notify me when a hub update was available as shown in you superb driver.
Guess what, notifications duly arrived on my phone. Brilliant.
Thanks again for this.
A couple things.
First, I could have sworn it had been discussed early on but what kind of numbers should we generally be concerned about (levels, that is)? Maybe add these as a suggested default value?
Also, is there an event that can be used as a trigger for when an update is started?
I posted my thoughts on CPU load as an edit on the first post some time back, but as for the rest everyone's setup, app/driver, and risk tolerance mix is different so it's difficult to say what is a good number.
For my hubs I'm using these numbers as alert levels, but they may or may not be acceptable for your use:
Max Temperature 140 °F (60 °C) - my C7s generally run between 98 °F-112 °F (36.7 °C - 44.5 °C) but will spike to as high as 141 °F (60.5 °C) at reboot
Max DB Size 80 - my production hub is generally in the neighborhood of 24-38, with my dev hub usually around 12-20
Min Free Memory 250000 - production hub usually drops to around 415000 a short time after reboot and then slowly drops over time, dev hub drops to about 520000 after settling in from a reboot and then very very slowly decreases over time
Assuming you mean an update of the hub firmware, I haven't seen anything directly but there are a couple of attributes you could look at and trigger on a change after update (firmwareVersionString, hubUpdateStatus).
