Try Lights On Motion Plus. I think it can do all this for you in the easiest way possible. There is also Rule Machine, and possibly the built-in (stock app) Motion Lighting that might be able to handle this. I don't have any of these motion switches, so I can't say for sure what method is best.
One thing to think about as well is which driver to use. This one by @JasonJoel is really good, but as i understand it doesn't or didn't a little while ago does recognise physical vs digital switch changes. Basically weather the switch changes state based on if the button is pushed or activated by a app rule.
Good point. When in occupancy mode you can't tell the difference between physical on from the switch and motion turning it on - both are reported identically from the device. No driver can distinguish between those two conditions, it is a device limitation.
In manual mode what I listed above would probably work though as the only on events would be physical from the switch or digital (hub initiated, which do show up as type=digital).
Yes, there is. Change to Jason Bottjen’s (@JasonJoel’s) Component driver for the Smart Motion Switch/Dimmer, which splits the GE/Jasco Switch/Dimmer into two logically separate devices, namely, a Motion Sensor and a Switch/Dimmer. Very elegant, makes writing Rules very easy. And, they can be installed/updated using Hubitat Package Manager (“HPM”).
While I don’t use the motion sensor in Alexa, I tried it just now for you, and it correctly exposes the motion sensor as a motion sensor to Alexa. Make sure you are using the Component drivers. Here is one of our several using Jason Bottjen’s Component drivers for switches/dimmers:
Rule Machine Rule
a. Trigger = motion
b. If mode=night
c. Cancel delayed action
d. setLevel=25%
e. light off, delayed 02:00 (cancellable)
Rule Machine Rule
a. Trigger = physical on
b. Cancel delayed actions
c. set level=99%
d. light off, delayed 02:00 (cancellable)
This isn't working for me. The device won't register a "physical on" if it is already on. In Smartthings there was a separate "button" device that would register button pushes regardless of the switch state. The problem is it would register ALL button pushes the same (on or off). If there was a way to separate out on or off button pushes regardless of switch state, it would be perfect.
I thought the driver did register a physical ON or physical OFF on the hub every time the button was physically pressed, regardless of current switch state. But maybe that got lost in one of the revisions (either intentionally or unintentionally), or maybe I did it differently on the component version versus the non-component version. Will have to look.
I looked, and it won't do duplicate on/off events due to a previous code update/streamlining I made. I know why I did it the way I did, but obviously I will have to do it differently.
I'll see about getting that fixed in an upcoming release. Shouldn't be too hard.
NOTE: On my dev dimmer/dev hub I would sometimes see the ON event happen 2x within a few hundred ms of each other.
Might be just my switch/dev mesh repeating some packets (I didn't have time to sniff the traffic), but be aware of this possibility in your logic as rapid-rife triggering of rules can do unexpected things/cause unexpected loading.
This is now working for me, but it does not allow me to manually adjust the dimmer setting. Any manual dimmer adjustment will initiate the rule triggered by the "Physical On" and will reset the level to 99%.
Yeah, I might go back and use basic for on/off and multilevel only for level. Then it would probably work the way you want. We'll see.
There was a reason I didn't do it that way to begin with, I just don't remember what it was. The code is still all in there under BasicSet to do it that way though (just commented out)... I'll play with it when I get time.
EDIT: I remember why now after trying it.... I'll have to think on this a bit.
