Release 2.5.0.123 Available
Changes from 2.4.4.156
Platform Changes
- Split built-in apps and added menu: "Integrations"/"Automations"/"Apps" app definition field.
- Added doNotFocus: true/false app definition field to stop auto focusing on the next empty input.
- Added MQTT device import integration that uses Home Assistant device config.
- Added tooling and UI to import zigbee2mqtt devices.
- Added tooling and UI to manually import MQTT devices and map topics.
- Added Home Assistant device config to MQTT modes export.
- Updated Bluetooth stack (again).
- Re-engineered app/driver update to avoid loading classes on version update.
- New Matter logs for troubleshooting.
- ZWave-JS Logs improved handling of line endings for easier to reading.
- Re-work of ZWave-JS value parsing to prevent possible stale values getting reported as new and improve reporting reliability.
- ZWave-JS Details page shows device battery %
- ZWave-JS driver function zwave.getStoredValues() - Can be used to skip initial polling since ZWave-JS already polled all CC values.
- ZWave-JS details page display controller firmware version.
- Z-Wave User Code V2 CC added.
- Z-Wave Long Range channel selection (Please read warning, LR devices will need re-including if you change the channel).
- Removed ZWave-JS Details page node route changes since ZWave-JS doesn’t report it.
- Refreshed Matter Details page.
- Node count added to ZWave/Zigbee/Matter Details pages.
- Added device type icon (Zigbee/Z-Wave/Matter, etc.) to devices and rooms pages.
- Added ZWave-JS node state browser UI added to Z-Wave Details page. (More)
- Added Device Firmware Updater in Hub UI on Z-Wave Details page.
- Added HomeKit bridge and smoke detector device support to HomeKit controller integration. Improved fan support.
- Added "identify hub" button in hub details screen. Clicking it makes hub's LED rotate colors blue -> red -> green several times.
- Hardened platform firmware update logic.
- Added an option to switch to new ChromeCast integration implementation back end.
- Added endpoints to generate charts (More).
- ChromeCast integration now finds and updates device IPs in the background.
New Apps
- Ring Integration - Ring doorbells/cameras/lights/sirens/chimes (more to come) (More)
- Comfort Engine (Beta)- Creates a child thermostat and adjusts the real thermostat based on how the room feels, not just the raw temperature. (More)
- Power and Energy Manager app including existing Power Aggregator app plus new child apps:
- Maximum Usage (turn devices off when power consumption, energy usage, or time on exceeds threshold)
- Load Shedding (turn devices off when power exceeds threshold and optionally turn back on after time below)
- Power and Energy tracker to chart energy usage or cost over time
New Devices
- Ikea Bilresa Scroll Button using Ikea Bilresa Matter Button driver (driver renamed from Ikea Bilresa Dual Matter Button)
- Open-Meteo Weather Driver
- UniFi Protect motion-capable sensors (via UniFi Protect integration app; experimental)
- Aeotec TriSensor 8
- Aqara Matter Multi-State Sensor P100
App Changes
- Device Firmware Updater app facelift / bug fixes.
- Added notes to MakerAPI device details endpoint.
- Simplified ChromeCast integration app UI.
New Devices
- Ring Doorbell
- Ring Spotlight/Floodlight Cams
- Ring Chime
- Ring Camera
- Ring Motion
- Ring Light
- Ring Alarm
- Contact Sensors
- Locks
- Motion Sensors
- Switches
- Dimmers
Bug Fixes
- Fixed MQTT export unable to start after app was deleted and re-installed.
- Possibly fixed HomeKit devices going "not responding".
- ZWave-JS prevent some duplicate reports caused by optimistic supervision responses.
- Fixed Matter error when a packet gets sent before initialization is complete.
- ZWave-JS Indicator Report v2+ fixed solicited report error
- Fixed ZWave-JS Switch Multilevel reporting issues.
- Fixed occasional z-wave discovery not completing on Zipgateway.
- Fixed Zipgateway Device Firmware Updater startup and abort.
- Device Firmware Updater firmware file sorting.
- Fix for ZWave-JS Radio Reset using Diagnostic Tool.
- OpenWeatherMap driver now reports cloudiness attribute as number
- Likely fixed high CPU utilization issue when viewing Zigbee logs over remote admin.
- Fixed ZWave-JS Door Lock CC missing report.
- Fixed ZWave-JS occasional missed Notification report.
- Fixed some ZWave-JS SwitchMultilevel partial value updates missing report.
Release 2.5.0.126 Available
Changes from 2.5.0.123
Platform Changes
- Reworked Zigbee2MQTT and Home Assistant MQTT import workflows.
- Added mDNS device discovery page under Settings - Network (accessible directly at /hub/mdnsDevices endpoint).
- Added Tasmota devices detection and support (early beta).
- Added TLS support to build-in MQTT broker.
- Added an option to minimize pending SmartStart devices alert.
- Added network status support to existing ChromeCast (not new/beta) integration.
App Changes
- Improved Visual Rule Builder UI.
- Improved Power and Energy Tracker UI.
Bug Fixes
- Added F <-> C temperature conversion support for Zigbee2MQTT devices.
- Fixed unnecessary events raised by Zigbee2MQTT import integration.
- Fixed some Ring Floodlights being detected as normal cameras.
- Fixed Bluetooth stack restart logic.
- Added HSM event re-subscribe call on boot.
- Ensured proper integrations/apps/automations page landing when app is deleted.
- Added Ring Integration App UI tweaks / fixes for device install.
- Added more Ring device type detection fixes.
- Fixed Comfort Engine log spam issue.
- Fixed Ring Alarm error when arming/disarming.
- Possibly fixed lack of scrolling in Add Device - Virtual - device list dropdown on iOS devices.
Release 2.5.0.135 Available
Changes from 2.5.0.126
Platform Changes
- Added optional graphs to the home page.
- Added Shades & Blinds, Doors, Windows, and Garage doors to the summary.
- Added a way to manage home page summary stats devices and summary visibility.
- Added a separate historical data store for chartable attributes, with 31 day/1000 values history. It comes with an endpoint to fetch the raw data, e.g. /hub2/chart/data?deviceId=299&attribute=temperature for a sample temperature sensor.
Integration Changes
- Modified Tuya integration to create devices manually (on demand) instead of creating them automatically upon discovery.
New Devices
- Aeotec Door/Window Sensor 8
- Shelly Wave Door/Window
Bug Fixes
- Hopefully fixed the dropdown scrolling issue on iOS devices.
- Hopefully fixed high CPU utilization while using remote admin.
- Fixed hub mesh child devices not geting enabled/disabled along with parent.
- Reworked data access concurrency to hopefully fix the occasional long delays.
- Increase Ring websocket buffer size to accommodate more devices.
- Added Matter reinstall endpoint to fix broken installs.
- Fixed notification based ChromeCast status update in the new processing flow.
- Ensured that ChromeCast commands are attempted regardless of perceived online/offline status in the new processing flow.
- Fixed the issue with incomplete device delete and potential child devices left behind.
- Fixed the issue of zombie open connections for deleted devices.
- Hardened Matter installation check.
- Fixed the issue of detected MQTT devices dropping on reconnect.
- Fixed ZWave-JS invalid Switch Multilevel Report of > 99.
- Zooz Zen56 Driver multiple fixes.
- Hopefully fixed occasional long automation delays (if related to data cleanups).
- Fixed the issue with integration related mDNS listeners not starting if home page device discovery was turned off.
- Ring Bridge fixes.
- Ensured that power meters with no other relevant capabilities count towards the power summary bubble value.
Release 2.5.0.136 Available
Changes from 2.5.0.135
Bug Fixes
- Removed LIFX RSSI logging.
- Ring Integration log spam reduction and load reduction.
- Ring Location device mirror Ring Alarm Base when present.
- Added a way to exclude devices from power summary pill.
Release 2.5.0.143 Available
Changes from 2.5.0.136
Platform Changes
- Added date format setting in Settings - Hub details.
- Added date/time format functions for apps and drivers to use:
String formatActivityDateTime(date) // yyyy-MM-dd h:mm:ss a z or yyyy-MM-dd HH:mm:ss z, depending on time format selection
String formatActivityDateTimeShort(date) // d/M h:mma, M/d h:mma, d/M HH:mm, or M/d HH:mm, depending on format selections
String formatTimeHourMinute(date) // h:mma or HH:mm, depending on time format selection
String formatTimeHourMinuteSecond(date) // h:mm:ss a or HH:mm:ss, depending on time format selection
String formatTimeHourMinuteSecondMillis(date) // h:mm:ss.SSS a or HH:mm:ss.SSS, depending on time format selection
String formatDate(date) // M/d/yyyy, d/M/yyyy, or yyyy/M/d, depending on date format selection
String formatShortDate(date) // d/M, M/d, or M/d, depending on date format selection
- Added title override for the home page graphs.
- Added more options for device summary on the home page.
- Added summary specific attribute override for device summary drilldown (e.g. show switch attribute status for lights on drilldown)
New App Features
- UniFi Protect integration now supports contact, temperature, humidity, and lux sensors
- Ring Mailbox Sensor support.
New Driver Features
- Zooz ZSE50: Added color and level control commands (replaces color preference); added additional configuration parameter preferences.
Bug Fixes
- Ensured Ethernet disconnect sticks until reboot.
- Maybe fixed incorrect ChromeCast device status while using beta integration.
- Maybe fixed high CPU after using remote admin.
- Ring camera light controls cause enough log spam to cause delays.
- More Ring device features exposed RSSI/Tamper/PowerSource.
- More Ring log/event spam reduction.
- Updated ChromeCast drivers to make IP override stick until manually removed.
- Fixed ZWave-JS node refresh bug.
- More Ring log/event spam cleanup.
- More Ring device capabilities that were missed.
- Fixed a rare Ring bug preventing alarm controls.
- Hardened Matter startup logic.
- Added special handling for the ChromeCast groups.
- Likely fixed the MissingPropertyException in the Ecobee integration.
- Added more mDNS info to the Settings - Network setup - Show mDNS page.
Release 2.5.0.153 Available
Changes from 2.5.0.143
Platform Changes
Updated IoT dependency libraries.
Added /hub/advanced/dumpThreadsToLog endpoint to log top 10 threads in the engineering log for troubleshooting.
Changed database settings to hopefully reduce database growth.
Updated the UI to reduce page load sizes and speed up initialization. This should be particularly relevant to the Remote Admin users.
New Device Drivers
- Added email notification driver with options to use free starter packs from Brevo, Mailjet, Resend, MailGun, Smtp2Go, MailerSend, and PostMark. Also supports plain SMTP configuration. [more]
New Driver Features
- Implemented “Strobe” command on Zooz ZSE50 (note: device uses predetermined color, not user-set value)
Bug Fixes
Fixed hub mesh not working when HTTPS only is enabled.
Fixed old sound names persisting if removed on Zooz ZSE50
Likely fixed https://community.hubitat.com/t/2-5-0-145-c8pro-js-runtime-exceptions-on-145/164136.
Fixed event filtering by date in Logs and Device logs.
Possible fix for the failing Matter pairing issue.
Fixed the failure to timely reconnect to a Matter device.
ZWave-JS userCode command class fixes for some missing reports.
Generic Z-Wave Lock driver getCodes reliability improvements.
Release 2.5.0.157 Available
Changes from 2.5.0.153
Platform Changes
Added “Temperature” summary item on the home page.
Added “suggested devices” section to Home page’s discovered devices section and Add device page.
Added a top left corner alert for when hub’s scheduler didn’t start.
Tweaked Easy Dashboard for faster loading.
New Devices
- Added HomeKit alarm driver.
Driver Changes
Added Gmail and Proton support to the email notification driver.
Added Subject:subject,body support to the email notification driver.
Bug Fixes
- Fixed missing refresh() command for generic Matter switch driver.
- Complete hub attribute responses for Zigbee Time Cluster (0x000A) read attribute requests.
Release 2.5.0.159 Available
Changes from 2.5.0.157
App Updates
Bug Fixes
- Added a timeout to Matter device refresh to avoid possible leaks.
