Hubitat Elevation Platform update 2.2.1 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.2.0:
Drivers and Devices
- New drivers:
- Aeotec Dual Nano Switch (ZW132)
- Aeotec Smart Energy Switch (DSC06106)
- Aurora Zigbee Switch (smart socket, smart double socket)
- Aurora Zigbee Button Controller (AU-A1ZBRC)
- Ring Alarm Range Extender
- Ring Alarm Motion Sensor
- Ring Alarm Contact Sensor
- Ring Alarm Smoke/CO Listener
- HomeSeer Floodlight Sensor (HS-FLS100+)
- HomeSeer Multi-Sensor HSM200
- Everspring Illumination Sensor (ST815)
- RGBGenie Z-Wave Micro Controller (ZW-4001)
- Remotec Z-Wave-to-AC IR Extender (ZXT-120)
- Inovelli Z-Wave Smart Scene Dimmer S2 (LZW30)
- Inovelli Bulb Multi-Color (LZW42)
- Inovelli Bulb Multi-White (LZW41)
- New compatible devices
- Sunricher In-Wall Dimmer (SR-ZV9101SAC-HP) using RGBGenie Z-Wave Micro Controller
- New driver features
- Added physical/digital to Aeon dual micro driver.
- Lutron thermostat: Added supportedThermostatModes, supportedThermostatFanModes.
- Added transition time option to virtual shade driver.
New App Features
- Simple Automation Rule:
- Added Turn on and set color.
- Rule 4.0:
- Added support for read/write of local files. See this post.
- Added support for supportedThermostatModes, supportedThermostatFanModes.
Bug Fixes
- Rule 4.0:
- Fixed bug with Toggle Color Temperature setting level.
- Fixed bug with multiple trigger events with mode.
- Fixed bug where offset to sensor value not added as it should be when setting variable from sensor value.
- Fixed null pointer error for malformed variable reference.
- Fixed all selection for power source condition.
- Z-Wave command class multicmdv1.MultiCmdEncap:
- Fixed payload not parsed within encapsulatedCommands method.
- Added encapsulate method.
- Thermostat Scheduler: Fixed bug with Manual setpoint change.
- Notifier and HSM Rule: Fixed “Once in every x minutes” to only allow 1 to 59 minutes.
- Yale Zigbee Lock: fix code errors with encryption enabled.
Platform Changes
- Unit is now returned with device attribute state.
- New method to remove access token for oauth app: revokeAccessToken()
- New method to remove data values from devices: removeDataValue(String name)
- Z-Wave device data is populated before calls to installed() and configure() for newly added devices.
- Async Http GET, POST etc will now return a base64 encoded string if the response is binary data.
- Apps can now subscribe to all device events.
- Fixed headers map in App web requests: system was not placing headers in the correct headers map, instead it was placing them into the request map.
- Added getSetting() method to DeviceWraper and InstalledAppWrapper.
- All Z-Wave drivers: switchBinarySet and switchMultilevelSet commands will replace basicSet for devices that support the switchBinary and or switchMultilevel classes, this is a requirement of Z-Wave certification.
- New File Manager for local file storage. This feature is currently in beta.
