Did you remove the secondary controller from settings zwave details and the devices as well?
Everything has clusters
I did a exclusion and it removed both
Any busy messages in the log?
Nope no busy all just info.
I didn't see that you had tried to move this to various locations and see if that made a difference.
And did you try a Zwave repair, either a "complete" one, or one on just this Ring repeater?
I did a repair and 75% fail
And what about moving it? My Ring extender didn't do much when it was where I thought it would help, about 5 feet from the hub. It actually was much better when it was on the "wrong" side of where I was trying to repeat. In other words instead of hub > ring > device as you go across the house, it was better ring > hub > device.
And what is device 9, house well pump (brand and model) and why is is paired S0? S0 is pretty bad in most cases, it has more overhead than other security methods.
After adding the extenders it can take a while for the mesh to settle - in my case I had to stop messing with things and chill for a few days and let the devices themselves sort it out. Not saying that is your issue but it can exacerbate things.
I am still dealing with ghost routes - devices reporting as routing through devices that no longer exist on the mesh.
The logic of how things connect seems beyond the grasp of mere mortal folks such as we..
FWIW it seems to take my extenders about 72 hours to solidify.
Morning, it looks like the answer is in your statement "even doing a repair the power strip wot do anything". It appears that we may have another candidate to add to the ZOOZ Double Plug (MODEL ZEN25) Incident. Based on your logs, the power strips are overloading your Z-Wave network to the point that is locking your Z-Wave radio. Also, have you removed all of the Iris outlets as Z-Wave repeaters?
The power strip... Please make sure you are on the latest firmware for these.. and you tone down the power reports..
If you use the usb ports the firmware update is critical.. I’ve witnessed it flood my network.
here is a quick snap of my logs
dev:19 2020-12-12 10:57:39.115 am info (/device/edit/19) Green House Multi humidity is 63%
dev:19 2020-12-12 10:57:38.661 am info (/device/edit/19) Green House Multi temperature is 86.2°F
dev:19 2020-12-12 10:57:38.032 am info (/device/edit/19) Green House Multi temperature is 86.2°F
dev:52 2020-12-12 10:57:27.348 am info (/device/edit/52) Guest House power strip power is 0 W
dev:57 2020-12-12 10:57:27.253 am info (/device/edit/57) Zooz Power Strip - CH5 power is 0 W
dev:56 2020-12-12 10:57:27.152 am info (/device/edit/56) Zooz Power Strip - CH4 power is 0 W
dev:55 2020-12-12 10:57:27.053 am info (/device/edit/55) Zooz Power Strip - CH3 power is 0 W
dev:54 2020-12-12 10:57:26.954 am info (/device/edit/54) Zooz Power Strip - CH2 power is 0 W
dev:53 2020-12-12 10:57:26.885 am info (/device/edit/53) Zooz Power Strip - CH1 power is 0 W
dev:13 2020-12-12 10:57:16.617 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:18 2020-12-12 10:57:16.521 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:17 2020-12-12 10:57:16.324 am info (/device/edit/17) Zooz Power Strip - CH4 power is 0 W
dev:16 2020-12-12 10:57:16.221 am info (/device/edit/16) Zooz Power Strip - CH3 power is 0 W
dev:15 2020-12-12 10:57:16.121 am info (/device/edit/15) GH Zooz Power Strip - CH2 power is 0 W
dev:14 2020-12-12 10:57:16.057 am info (/device/edit/14) Zooz Power Strip - CH1 power is 1111.1 W
dev:11 2020-12-12 10:57:11.339 am info (/device/edit/11) Carport Attic Multi UV index is 0
dev:11 2020-12-12 10:57:11.194 am info (/device/edit/11) Carport Attic Multi illuminance is 0 Lux
dev:11 2020-12-12 10:57:11.124 am info (/device/edit/11) Carport Attic Multi battery level is 100%
dev:11 2020-12-12 10:57:10.273 am info (/device/edit/11) Carport Attic Multi humidity is 62%
dev:11 2020-12-12 10:57:10.131 am info (/device/edit/11) Carport Attic Multi temperature is 60.2°F
dev:7 2020-12-12 10:57:06.689 am info (/device/edit/7) Pump House Multi UV index is 0
dev:7 2020-12-12 10:57:06.593 am info (/device/edit/7) Pump House Multi illuminance is 195 Lux
dev:7 2020-12-12 10:57:06.537 am info (/device/edit/7) Pump House Multi battery level is 100%
dev:7 2020-12-12 10:57:05.749 am info (/device/edit/7) Pump House Multi humidity is 71%
dev:7 2020-12-12 10:57:05.649 am info (/device/edit/7) Pump House Multi temperature is 59.3°F
dev:52 2020-12-12 10:56:57.347 am info (/device/edit/52) Guest House power strip power is 0 W
dev:57 2020-12-12 10:56:57.253 am info (/device/edit/57) Zooz Power Strip - CH5 power is 0 W
dev:56 2020-12-12 10:56:57.152 am info (/device/edit/56) Zooz Power Strip - CH4 power is 0 W
dev:55 2020-12-12 10:56:57.052 am info (/device/edit/55) Zooz Power Strip - CH3 power is 0 W
dev:54 2020-12-12 10:56:56.953 am info (/device/edit/54) Zooz Power Strip - CH2 power is 0 W
dev:53 2020-12-12 10:56:56.910 am info (/device/edit/53) Zooz Power Strip - CH1 power is 0 W
dev:19 2020-12-12 10:56:56.855 am info (/device/edit/19) Green House Multi UV index is 0
dev:13 2020-12-12 10:56:56.331 am info (/device/edit/13) Green House power strip energyDuration is 11.18 Hours
dev:13 2020-12-12 10:56:56.318 am info (/device/edit/13) Green House power strip energy is 12.05 kWh
dev:18 2020-12-12 10:56:56.231 am info (/device/edit/18) Zooz Power Strip - CH5 energyDuration is 11.18 Hours
dev:18 2020-12-12 10:56:56.223 am info (/device/edit/18) Zooz Power Strip - CH5 energy is 0 kWh
dev:17 2020-12-12 10:56:56.131 am info (/device/edit/17) Zooz Power Strip - CH4 energyDuration is 11.18 Hours
dev:17 2020-12-12 10:56:56.122 am info (/device/edit/17) Zooz Power Strip - CH4 energy is 0 kWh
dev:16 2020-12-12 10:56:56.040 am info (/device/edit/16) Zooz Power Strip - CH3 energyDuration is 11.18 Hours
dev:16 2020-12-12 10:56:56.025 am info (/device/edit/16) Zooz Power Strip - CH3 energy is 0.02 kWh
dev:15 2020-12-12 10:56:55.939 am info (/device/edit/15) GH Zooz Power Strip - CH2 energyDuration is 11.18 Hours
dev:15 2020-12-12 10:56:55.926 am info (/device/edit/15) GH Zooz Power Strip - CH2 energy is 0.01 kWh
dev:14 2020-12-12 10:56:55.837 am info (/device/edit/14) Zooz Power Strip - CH1 energyDuration is 11.18 Hours
dev:14 2020-12-12 10:56:55.827 am info (/device/edit/14) Zooz Power Strip - CH1 energy is 12.02 kWh
dev:13 2020-12-12 10:56:55.716 am info (/device/edit/13) Green House power strip power is 1110 W
dev:18 2020-12-12 10:56:55.624 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:17 2020-12-12 10:56:55.524 am info (/device/edit/17) Zooz Power Strip - CH4 power is 0 W
dev:16 2020-12-12 10:56:55.420 am info (/device/edit/16) Zooz Power Strip - CH3 power is 0 W
dev:15 2020-12-12 10:56:55.323 am info (/device/edit/15) GH Zooz Power Strip - CH2 power is 0 W
dev:15 2020-12-12 10:56:53.823 am info (/device/edit/15) GH Zooz Power Strip - CH2 power is 0 W
dev:19 2020-12-12 10:56:52.779 am info (/device/edit/19) Green House Multi illuminance is 2014 Lux
dev:19 2020-12-12 10:56:50.892 am info (/device/edit/19) Green House Multi illuminance is 2014 Lux
dev:14 2020-12-12 10:56:49.204 am info (/device/edit/14) Zooz Power Strip - CH1 power is 1111.1 W
dev:19 2020-12-12 10:56:48.101 am info (/device/edit/19) Green House Multi humidity is 64%
dev:14 2020-12-12 10:56:47.483 am info (/device/edit/14) Zooz Power Strip - CH1 power is 1111.1 W
dev:19 2020-12-12 10:56:47.307 am info (/device/edit/19) Green House Multi humidity is 64%
dev:19 2020-12-12 10:56:45.863 am info (/device/edit/19) Green House Multi humidity is 64%
dev:19 2020-12-12 10:56:43.576 am info (/device/edit/19) Green House Multi humidity is 64%
dev:18 2020-12-12 10:56:42.894 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:19 2020-12-12 10:56:41.881 am info (/device/edit/19) Green House Multi temperature is 85.9°F
dev:18 2020-12-12 10:56:41.388 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:19 2020-12-12 10:56:40.573 am info (/device/edit/19) Green House Multi temperature is 85.9°F
dev:17 2020-12-12 10:56:38.647 am info (/device/edit/17) Zooz Power Strip - CH4 power is 0 W
dev:19 2020-12-12 10:56:38.585 am info (/device/edit/19) Green House Multi temperature is 85.9°F
dev:17 2020-12-12 10:56:36.789 am info (/device/edit/17) Zooz Power Strip - CH4 power is 0 W
dev:17 2020-12-12 10:56:35.398 am info (/device/edit/17) Zooz Power Strip - CH4 power is 0 W
dev:16 2020-12-12 10:56:30.751 am info (/device/edit/16) Zooz Power Strip - CH3 power is 0 W
dev:11 2020-12-12 10:56:29.668 am info (/device/edit/11) Carport Attic Multi UV index is 0
dev:16 2020-12-12 10:56:29.381 am info (/device/edit/16) Zooz Power Strip - CH3 power is 0 W
dev:11 2020-12-12 10:56:28.935 am info (/device/edit/11) Carport Attic Multi UV index is 0
dev:11 2020-12-12 10:56:27.829 am info (/device/edit/11) Carport Attic Multi UV index is 0
dev:52 2020-12-12 10:56:27.434 am info (/device/edit/52) Guest House power strip power is 0 W
dev:57 2020-12-12 10:56:27.262 am info (/device/edit/57) Zooz Power Strip - CH5 power is 0 W
dev:15 2020-12-12 10:56:27.247 am info (/device/edit/15) GH Zooz Power Strip - CH2 power is 0 W
dev:56 2020-12-12 10:56:27.154 am info (/device/edit/56) Zooz Power Strip - CH4 power is 0 W
dev:55 2020-12-12 10:56:27.069 am info (/device/edit/55) Zooz Power Strip - CH3 power is 0 W
dev:54 2020-12-12 10:56:26.957 am info (/device/edit/54) Zooz Power Strip - CH2 power is 0 W
dev:53 2020-12-12 10:56:26.859 am info (/device/edit/53) Zooz Power Strip - CH1 power is 0 W
dev:11 2020-12-12 10:56:26.516 am info (/device/edit/11) Carport Attic Multi UV index is 0
dev:15 2020-12-12 10:56:25.665 am info (/device/edit/15) GH Zooz Power Strip - CH2 power is 0 W
dev:11 2020-12-12 10:56:23.864 am info (/device/edit/11) Carport Attic Multi illuminance is 0 Lux
dev:11 2020-12-12 10:56:23.333 am info (/device/edit/11) Carport Attic Multi illuminance is 0 Lux
dev:84 2020-12-12 10:56:22.929 am info (/device/edit/84) Mailbox temperature is 59.00°F
dev:11 2020-12-12 10:56:22.286 am info (/device/edit/11) Carport Attic Multi illuminance is 0 Lux
dev:11 2020-12-12 10:56:21.513 am info (/device/edit/11) Carport Attic Multi battery level is 100%
dev:14 2020-12-12 10:56:20.972 am info (/device/edit/14) Zooz Power Strip - CH1 power is 1108.9 W
dev:11 2020-12-12 10:56:20.924 am info (/device/edit/11) Carport Attic Multi illuminance is 0 Lux
dev:11 2020-12-12 10:56:20.311 am info (/device/edit/11) Carport Attic Multi battery level is 100%
dev:11 2020-12-12 10:56:19.575 am info (/device/edit/11) Carport Attic Multi battery level is 100%
dev:14 2020-12-12 10:56:18.951 am info (/device/edit/14) Zooz Power Strip - CH1 power is 1108.9 W
dev:11 2020-12-12 10:56:18.228 am info (/device/edit/11) Carport Attic Multi battery level is 100%
dev:11 2020-12-12 10:56:18.218 am info (/device/edit/11) Carport Attic Multi humidity is 62%
dev:11 2020-12-12 10:56:18.176 am info (/device/edit/11) Carport Attic Multi battery level is 100%
dev:11 2020-12-12 10:56:17.569 am info (/device/edit/11) Carport Attic Multi humidity is 62%
dev:11 2020-12-12 10:56:16.818 am info (/device/edit/11) Carport Attic Multi humidity is 62%
dev:13 2020-12-12 10:56:16.027 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:11 2020-12-12 10:56:15.595 am info (/device/edit/11) Carport Attic Multi humidity is 62%
dev:13 2020-12-12 10:56:15.333 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:18 2020-12-12 10:56:15.318 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:13 2020-12-12 10:56:15.283 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:18 2020-12-12 10:56:15.146 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:13 2020-12-12 10:56:14.585 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:18 2020-12-12 10:56:14.509 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:13 2020-12-12 10:56:14.242 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:18 2020-12-12 10:56:14.201 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:11 2020-12-12 10:56:13.576 am info (/device/edit/11) Carport Attic Multi temperature is 60.0°F
dev:13 2020-12-12 10:56:12.959 am info (/device/edit/13) Green House power strip power is 1111.1 W
dev:13 2020-12-12 10:56:12.916 am error (/device/edit/13) groovy.lang.MissingMethodException: No signature of method: zoozPowerStrip.parse() is applicable for argument types:
(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest, java.lang.Short) values: [ApplicationRejectedRequest(status:33), 5] Possible solutions: parse(java.lang.String), wait(), run(), reset(), run(), any() (parse)
dev:11 2020-12-12 10:56:12.560 am info (/device/edit/11) Carport Attic Multi temperature is 60.0°F
dev:18 2020-12-12 10:56:11.827 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:11 2020-12-12 10:56:11.405 am info (/device/edit/11) Carport Attic Multi temperature is 60.0°F
dev:18 2020-12-12 10:56:10.091 am info (/device/edit/18) Zooz Power Strip - CH5 power is 0 W
dev:11 2020-12-12 10:56:10.037 am info (/device/edit/11) Carport Attic Multi temperature is 60.0°F
dev:7 2020-12-12 10:56:06.707 am info (/device/edit/7) Pump House Multi UV index is 0
dev:7 2020-12-12 10:56:06.611 am info (/device/edit/7) Pump House Multi illuminance is 130 Lux
dev:7 2020-12-12 10:56:06.585 am info (/device/edit/7) Pump House Multi battery level is 100%
dev:7 2020-12-12 10:56:05.782 am info (/device/edit/7) Pump House Multi humidity is 71%
dev:7 2020-12-12 10:56:05.619 am info (/device/edit/7) Pump House Multi temperature is 59.1°F
dev:17 2020-12-12 10:56:05.593 am info (/device/edit/17) Zooz Powe
Ugh. Still just doing the same thing works for a few then not at all. So done with this. Added repeaters and updated zooz firmware. I think there is a huge flaw somewhere or this hub is just bad. I mean when it won't command a device literally 3 feet from it something is wrong. I see other people are starting to experience similar problem on the forum. I mean if the devices are.flooding the zwave network then how can you fix that. They were on ST and didn't do that?
i hate to tell you but it looks to me your mesh is not near enough for pump house, green house, car port etc. locations that are most likely far from the hub. .one repeater is not going to do crap.. you need a switch or repeater every 30-40 feet.
Does it seem odd that devices that can't be controlled at all even ones that are the farthest from the hub can be controlled perfectly and lightning fast with the zstick as a secondary with pc commander and the hub and stuck are literally 18 inches apart. That tells me its not the end devices
The hub is in the pump house
