Node-Red Flow Samples/Sharing
Quick update to the above subflow... it did not handle commas in the reported numbers. Decided to leave the threshold check in for now.
Here is the latest (this node instance example points to NSF Live):
YouTube - Watching Now 1.1.0
[{"id":"bb498e1f93af0410","type":"subflow","name":"YT Watching Now","info":"","category":"","in":[{"x":50,"y":30,"wires":[{"id":"6c862a9df27e9568"}]}],"out":[{"x":1240,"y":300,"wires":[{"id":"0fc72446cbd9f29c","port":0},{"id":"3bcfae689e861aed","port":1}]}],"env":[{"name":"TITLE","type":"str","value":"YouTube Video Title"},{"name":"YT_VIDEO","type":"str","value":"mhJRzQsLZGg"},{"name":"THRESHOLD","type":"num","value":"1200"},{"name":"FILTER_OUTPUT","type":"bool","value":"true"}],"meta":{"version":"1.1.0","desc":"Scrape \"watching now\" value from YouTube streams"},"color":"#DDAA99","status":{"x":820,"y":300,"wires":[{"id":"875c4bbb68746856","port":1},{"id":"6886ed8ff0326333","port":0}]}},{"id":"875c4bbb68746856","type":"function","z":"bb498e1f93af0410","name":"Set return message based on current watchers","func":"//msg.payload = parseInt(msg.payload);\nvar currentWatchers = parseInt(msg.payload);\n//var currentWatchers = 5000;\nvar threshold = env.get(\"THRESHOLD\");\nvar title = env.get(\"TITLE\");\nmsg.payload = currentWatchers;\n\nvar status = {};\nvar retMsg = {\n    \"topic\": title\n    ,\"result\": {\n        \"title\": title\n        ,\"watching\": currentWatchers\n        ,\"lastChecked\": Date.now().toString()\n        ,\"url\": \"https://www.youtube.com/watch?v=\" + env.get(\"YT_VIDEO\")\n    }\n}\n\nif (!isNaN(currentWatchers)) {\n    if (currentWatchers < threshold ) {\n        retMsg.result.status = \"Stand Down\";\n        retMsg.payload = \"Stand Down\";\n        retMsg.result.thresholdExceeded = false;\n        status.payload = {fill:\"blue\",shape:\"dot\",text: \"watching: \" + currentWatchers.toString()};\n    } else {\n        retMsg.result.status = \"Go Time\";\n        retMsg.payload = \"Go Time\";\n        retMsg.result.thresholdExceeded = true;\n        status.payload = {fill:\"green\",shape:\"dot\",text: \"watching: \" + currentWatchers.toString()};\n    }\n    node.send([retMsg,status]);\n}\n\nreturn;","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":160,"wires":[["3bcfae689e861aed"],[]]},{"id":"a28cd78c8940c521","type":"exec","z":"bb498e1f93af0410","command":"","addpay":"payload","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"","x":170,"y":160,"wires":[["875c4bbb68746856"],[],["5f69170f12ca817e"]]},{"id":"d930ec2b502229ff","type":"template","z":"bb498e1f93af0410","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"curl -s https://www.youtube.com/watch?v={{payload}} | egrep -o '\\{\\\"text\\\":\\\"[0-9][0-9,]+\\\"\\},\\{\\\"text\\\":\\\" watching now\\\"\\}' | uniq | egrep -o '[0-9][0-9,]+'  | sed 's/[,]//'\n\n","output":"str","x":420,"y":80,"wires":[["a28cd78c8940c521"]]},{"id":"6c862a9df27e9568","type":"change","z":"bb498e1f93af0410","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"YT_VIDEO","tot":"env"},{"t":"set","p":"topic","pt":"msg","to":"TITLE","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":80,"wires":[["d930ec2b502229ff"]]},{"id":"0fc72446cbd9f29c","type":"rbe","z":"bb498e1f93af0410","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1130,"y":160,"wires":[[]]},{"id":"3bcfae689e861aed","type":"switch","z":"bb498e1f93af0410","name":"Filter Results?","property":"FILTER_OUTPUT","propertyType":"env","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":880,"y":160,"wires":[["0fc72446cbd9f29c"],[]]},{"id":"6886ed8ff0326333","type":"change","z":"bb498e1f93af0410","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"fill\":\"red\",\t   \"shape\":\"dot\",\t   \"text\": ( payload.code = 1 ? \"Stream Unavailable\" : \"Unknown Error\" )\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":300,"wires":[[]]},{"id":"5f69170f12ca817e","type":"switch","z":"bb498e1f93af0410","name":"","property":"payload.code","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":300,"wires":[["6886ed8ff0326333"]]},{"id":"52596f85517d818f","type":"subflow:bb498e1f93af0410","z":"b38ec3180db9ae33","name":"NSF - Starbase LIVE","env":[{"name":"TITLE","value":"NSF - Starbase LIVE","type":"str"},{"name":"THRESHOLD","value":"3000","type":"num"},{"name":"ALERT_ON_VIEWS","value":"3000","type":"num"}],"x":500,"y":680,"wires":[["bd4e12c456eb339e"]]}]
Self moderating from this thread - [BETA] Tesla Vehicle via TeslaMate MQTT
If you guys are going to this level of effort just to get a Tesla into Hubitat (not to mention additional hardware), I would highly recommend just biting the bullet and transitioning into node-red automation. It really opens up a bunch of new possibilities.
Things like:
  • Checking to see if the car is locked and locking it if it's not at bedtime (it also yells at me if it's not plugged in, but you can do that without node-red).
  • Tying it to Google calendar to preconditioning it before I go somewhere (super awesome in Chicago winters).
  • For unscheduled trips - I can just ask Google Home to warm up the car without pulling out my phone.
Just saying! I love tempting people down the same rabbit holes I've been sucked into. :grinning:
GottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferentGottaMakeItDifferent
I agree with this..
When using community apps and drivers the thing you have to be careful with HE is resource overhead. Going to a separate rules controller like NR helps reduce memory consumption etc. Also since you have more control over the NR environment you can add storage / memory as necessary.
For my home system I am now running HomeAssistant with the NR addon as a new companion server. Both HA and NR offer some nice capabilities while HE handles all the Zigbee/Z-Wave/Lutron devices and some cool additional system services like Alexa.
:exploding_head: Me too. I think there needs to be a beginner edition. Call it Node-Green.
I haven't see this posted anywhere before... Alexa voice commands for lighting with dynamic timers. For example, "Alexa, turn on the living room lights for 20 minutes." Or, "Alexa, turn off the lights for 45 seconds." Or even, "Alexa, disable office motion for 1 hour."
So, after creating some lighting flows with my motion sensors, I realized they often turned the lights off more quickly than I wanted, or kept them on longer than I wanted. Somewhere I found a flow that allowed me to disable the motion sensors whenever I gave a voice command to turn on the lights, but that still didn't really cut it for a variety of reasons. I got the idea of dynamic timers using Alexa voice commands and after a bunch of searching around I came across @stephen_nutt's post here at #116 (thank you kind sir!) After tinkering with his flows I came up with this...
There are essentially two different methods at play here. One is using "on" and "off" hubitat command nodes for my light groups. The other is on the other side of the link-out nodes where I use @yadomi/node-red-contrib-philipshue-events to take care of my lighting. Here is an example...
The reason for two methods is because I was originally using Hue Magic to control everything, but as luck would have it, it stopped working. So, I've been slowly converting everything over to method two as I have time. Frankly, once you figure it out, the philipshue-events method is way better than Hue Magic.
I've only been at this home automation thing for a few weeks, and I whipped this first flow out in the last three or four hours, so I'm sure it could use some work. I wanted to get it out though because I thought people might be interested in this particular application of using Alexa to turn on light groups with dynamic timers.
Besides the contrib mentioned above, these flows use node-red-contrib-stoptimer-varidelay, node-red-contrib-ecolect, node-red-contrib-alexa-remote2-applestrudel, and node-red-contrib-boolean-logic-ultimate. I should also mention these flows were created in Node-RED 3.0 beta 3. If anyone has any questions, suggestions or wants more information, please hit me up.
EDIT: One limitation I've discovered is the timer will only work for the last command you gave Alexa. So, if you told her to turn on your living room lights for an hour and then during that hour, told her to turn on your kitchen lights for 5 minutes, it will reset the timer to 5 minutes.
        "id": "25bc6f35f2a44cb7",
        "type": "tab",
        "label": "Flow 9",
        "disabled": false,
        "info": "",
        "env": []
        "id": "65e8c3c1e958d3ea",
        "type": "group",
        "z": "25bc6f35f2a44cb7",
        "style": {
            "stroke": "#000000",
            "label": true,
            "fill": "#addb7b",
            "color": "#000000"
        "nodes": [
            "98a49fe9e4e49101",
            "04a0a024d2811afd",
            "f1190985f2bc844f",
            "be315601ea68f849",
            "93ccf8606e4db7ec",
            "8f79b7c924abff02",
            "6bcdbfe69cafb699",
            "f629d61ac9189375",
            "baec9cd6f13d2225",
            "9be4a146ec75a4a7",
            "04562dfaf46c5bf3",
            "ed0794686d944bf3",
            "86f54ac3daaf7768",
            "e826ee85e975ffa4",
            "84ff480ae5725c14",
            "b072027c6d1d6e64",
            "8f7f56ba872e61f0",
            "6e1f8cc4f1ab07e0",
            "a8f3dd512cfb7be4",
            "919572594d214e9a"
        "x": 188,
        "y": 574,
        "w": 1444,
        "h": 1052
        "id": "a8f3dd512cfb7be4",
        "type": "group",
        "g": "65e8c3c1e958d3ea",
        "name": "Alexa Local Light Voice Control ",
        "style": {
            "fill": "#bfdbef",
            "label": true,
            "color": "#000000"
        "nodes": [
            "f547e027474194f6",
            "a27c511addeda301",
            "15adfeaf0f1dcb7a",
            "1a4c9334cd28463e",
            "2eef74b5af789246",
            "0c68db52072968f3",
            "0c6a84a9b1dadc54",
            "6f4ae984d0fb9410",
            "966b3c2392432a60",
            "6b5aeb1c80fc63eb",
            "05a0037e8e57b876",
            "eae5abcd46cb1c12",
            "62cfa8a173b8235d",
            "ba28246ca58d1781",
            "370756c64ae1a442",
            "626bd71df581ea5a",
            "6c0c3bf8a453a80c",
            "1b64c986a124f861",
            "5d43fb69a17a6eef",
            "4630e3f5d44bdf5b"
        "x": 214,
        "y": 899,
        "w": 1392,
        "h": 409.5
        "id": "8f7f56ba872e61f0",
        "type": "junction",
        "x": 1220,
        "y": 600,
        "wires": [
                "f1190985f2bc844f"
        "id": "6e1f8cc4f1ab07e0",
        "type": "junction",
        "x": 1220,
        "y": 1600,
        "wires": [
                "8f79b7c924abff02"
        "id": "eae5abcd46cb1c12",
        "type": "junction",
        "g": "a8f3dd512cfb7be4",
        "x": 1200,
        "y": 940,
        "wires": [
                "966b3c2392432a60"
        "id": "1b64c986a124f861",
        "type": "junction",
        "x": 560,
        "y": 1160,
        "wires": [
                "f547e027474194f6",
                "15adfeaf0f1dcb7a"
        "id": "98a49fe9e4e49101",
        "type": "switch",
        "name": "Voice Commands",
        "property": "payload.description.summary",
        "propertyType": "msg",
        "rules": [
                "t": "cont",
                "v": "turn on",
                "vt": "str"
                "t": "cont",
                "v": "lights on",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 850,
        "y": 760,
        "wires": [
                "04a0a024d2811afd"
                "04a0a024d2811afd"
        "id": "04a0a024d2811afd",
        "type": "switch",
        "name": "Which Device?",
        "property": "payload.deviceSerialNumber",
        "rules": [
                "t": "eq",
                "v": "Alexa Serial Number Here",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 9,
        "x": 1080,
        "y": 760,
        "wires": [
                "8f7f56ba872e61f0"
                "8f7f56ba872e61f0",
                "be315601ea68f849",
                "86f54ac3daaf7768"
                "8f7f56ba872e61f0"
                "8f7f56ba872e61f0",
                "f629d61ac9189375"
                "8f7f56ba872e61f0",
                "e826ee85e975ffa4"
                "8f7f56ba872e61f0",
                "86f54ac3daaf7768",
                "be315601ea68f849"
                "8f7f56ba872e61f0",
                "9be4a146ec75a4a7"
                "8f7f56ba872e61f0"
                "8f7f56ba872e61f0"
        "outputLabels": [
            "Bedroom Echo",
            "Family Room Echo",
            "Garage Echo",
            "Guest Room Echo",
            "Hallway Echo",
            "Kitchen Echo",
            "Living Room Echo",
            "Master Bath Echo",
            "Office Echo"
        "id": "f1190985f2bc844f",
        "type": "debug",
        "name": "debug 515",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "targetType": "full",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1070,
        "y": 640,
        "wires": []
        "id": "be315601ea68f849",
        "type": "hubitat command",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 620,
        "wires": [
        "id": "93ccf8606e4db7ec",
        "type": "switch",
        "rules": [
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
                "t": "eq",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 9,
        "x": 1080,
        "y": 1440,
        "wires": [
                "6e1f8cc4f1ab07e0"
                "6e1f8cc4f1ab07e0",
                "6bcdbfe69cafb699",
                "ed0794686d944bf3"
                "6e1f8cc4f1ab07e0"
                "6e1f8cc4f1ab07e0",
                "baec9cd6f13d2225"
                "6e1f8cc4f1ab07e0",
                "84ff480ae5725c14"
                "6e1f8cc4f1ab07e0",
                "ed0794686d944bf3",
                "6bcdbfe69cafb699"
                "6e1f8cc4f1ab07e0",
                "04562dfaf46c5bf3"
                "6e1f8cc4f1ab07e0"
                "6e1f8cc4f1ab07e0"
        "outputLabels": [
            "Bedroom Echo",
            "Family Room Echo",
            "Garage Echo",
            "Guest Room Echo",
            "Hallway Echo",
            "Kitchen Echo",
            "Living Room Echo",
            "Master Bath Echo",
            "Office Echo"
        "id": "8f79b7c924abff02",
        "type": "debug",
        "name": "debug 516",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 1070,
        "y": 1560,
        "wires": []
        "id": "6bcdbfe69cafb699",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 1340,
        "wires": [
        "id": "f629d61ac9189375",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 680,
        "wires": [
        "id": "baec9cd6f13d2225",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 1400,
        "wires": [
        "id": "9be4a146ec75a4a7",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 860,
        "wires": [
        "id": "04562dfaf46c5bf3",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 1580,
        "wires": [
        "id": "ed0794686d944bf3",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 1520,
        "wires": [
        "id": "86f54ac3daaf7768",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 800,
        "wires": [
        "id": "e826ee85e975ffa4",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 740,
        "wires": [
        "id": "84ff480ae5725c14",
        "deviceLabel": "",
        "name": "",
        "server": "",
        "deviceId": "",
        "command": "",
        "commandArgs": "",
        "x": 1520,
        "y": 1460,
        "wires": [
        "id": "b072027c6d1d6e64",
        "type": "switch",
        "rules": [
                "t": "cont",
                "v": "lights off",
                "vt": "str"
                "t": "cont",
                "v": "turn off",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 850,
        "y": 1440,
        "wires": [
                "93ccf8606e4db7ec"
                "93ccf8606e4db7ec"
        "id": "f547e027474194f6",
        "type": "change",
        "name": "set numbers",
        "rules": [
                "t": "change",
                "p": "values.number",
                "pt": "msg",
                "from": "one",
                "fromt": "str",
                "to": "1",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "two",
                "fromt": "str",
                "to": "2",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "three",
                "fromt": "str",
                "to": "3",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "four",
                "fromt": "str",
                "to": "4",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "five",
                "fromt": "str",
                "to": "5",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "six",
                "fromt": "str",
                "to": "6",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "seven",
                "fromt": "str",
                "to": "7",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "eight",
                "fromt": "str",
                "to": "8",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "nine",
                "fromt": "str",
                "to": "9",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "ten",
                "fromt": "str",
                "to": "10",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "fifteen",
                "fromt": "str",
                "to": "15",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "twenty",
                "fromt": "str",
                "to": "20",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "thirty",
                "fromt": "str",
                "to": "30",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "fourty",
                "fromt": "str",
                "to": "40",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "fifty",
                "fromt": "str",
                "to": "50",
                "tot": "num"
                "t": "change",
                "pt": "msg",
                "from": "sixty",
                "fromt": "str",
                "to": "60",
                "tot": "num"
                "t": "set",
                "p": "delay",
                "pt": "msg",
                "to": "values.number",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 670,
        "y": 1160,
        "wires": [
                "1a4c9334cd28463e"
        "id": "a27c511addeda301",
        "type": "stoptimer-varidelay",
        "duration": "60",
        "durationType": "num",
        "units": "Minute",
        "payloadtype": "str",
        "payloadval": "off",
        "name": "",
        "reporting": "last_minute_seconds",
        "persist": true,
        "ignoretimerpass": false,
        "x": 940,
        "y": 1260,
        "wires": [
                "05a0037e8e57b876",
                "93ccf8606e4db7ec"
        "id": "15adfeaf0f1dcb7a",
        "type": "change",
        "name": "set units",
        "rules": [
                "t": "set",
                "p": "units",
                "pt": "msg",
                "to": "values.units",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 680,
        "y": 1240,
        "wires": [
                "1a4c9334cd28463e"
        "id": "1a4c9334cd28463e",
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "array",
        "property": "payload",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 810,
        "y": 1200,
        "wires": [
                "a27c511addeda301"
        "id": "2eef74b5af789246",
        "type": "ecolect",
        "name": "Voice Commands for Lighting",
        "topics": [
                "name": "lights",
                "phrases": "turn {state} the {item} for {number} {units}\nturn {state} the {item} in the {area} for {number} {units}\nturn {state} the {item} in the {area}\n{state} {item}\n{item}{state}\nturn {state} the {area} {item} for {number} {units}\nturn {state} the {area} {item} \nturn {state} the {item} in the {area}\nturn {state} the {item} in the {area} for {number} {units}\n",
                "values": [
                        "name": "item",
                        "type": "enumeration",
                        "enumerations": [
                            "lights",
                            "light",
                            "motion",
                            "motion sensors",
                            "sensors"
                        "name": "units",
                        "enumerations": [
                            "seconds",
                            "minutes",
                            "hours"
                        "name": "state",
                        "enumerations": [
                            "on",
                            "off",
                            "disable",
                            "enable",
                            "activate",
                            "deactivate"
                        "name": "number",
                        "enumerations": [
                            "one",
                            "two",
                            "three",
                            "four",
                            "five",
                            "six",
                            "seven",
                            "eight",
                            "nine",
                            "ten",
                            "eleven",
                            "twelve",
                            "thirteen",
                            "fourteen",
                            "fifteen",
                            "sixteen",
                            "seventeen",
                            "eighteen",
                            "ninteen",
                            "twenty",
                            "twenty-one",
                            "twenty-two",
                            "twenty-three",
                            "twenty-four",
                            "twenty-five",
                            "thirty",
                            "fourty",
                            "fourty-five",
                            "fifty",
                            "sixty"
                        "name": "area",
                        "enumerations": [
                            "bathroom",
                            "bedroom",
                            "dining room",
                            "entryway",
                            "family room",
                            "garage",
                            "guest room",
                            "hallway",
                            "kitchen",
                            "laundry room",
                            "living room",
                            "master bathroom",
                            "master bath",
                            "office",
                            "outside"
        "outputs": 2,
        "x": 650,
        "y": 1080,
        "wires": [
                "0c6a84a9b1dadc54",
                "1b64c986a124f861"
        "id": "0c68db52072968f3",
        "type": "change",
        "name": "set payload from summary",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload.description.summary",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 480,
        "y": 1020,
        "wires": [
                "2eef74b5af789246"
        "id": "0c6a84a9b1dadc54",
        "type": "change",
        "name": "set state",
        "rules": [
                "t": "change",
                "p": "values.state",
                "pt": "msg",
                "from": "on",
                "fromt": "str",
                "to": "true",
                "tot": "bool"
                "t": "change",
                "pt": "msg",
                "from": "off",
                "fromt": "str",
                "to": "false",
                "tot": "bool"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "values.state",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 920,
        "y": 1040,
        "wires": [
                "6f4ae984d0fb9410"
        "id": "6f4ae984d0fb9410",
        "type": "switch",
        "name": "Room/Area",
        "property": "values.area",
        "rules": [
                "t": "eq",
                "v": "bathroom",
                "vt": "str"
                "t": "eq",
                "v": "bedroom",
                "vt": "str"
                "t": "eq",
                "v": "dining room",
                "vt": "str"
                "t": "eq",
                "v": "entryway",
                "vt": "str"
                "t": "eq",
                "v": "family room",
                "vt": "str"
                "t": "eq",
                "v": "garage",
                "vt": "str"
                "t": "eq",
                "v": "guest room",
                "vt": "str"
                "t": "eq",
                "v": "hallway",
                "vt": "str"
                "t": "eq",
                "v": "kitchen",
                "vt": "str"
                "t": "eq",
                "v": "laundry",
                "vt": "str"
                "t": "eq",
                "v": "living room",
                "vt": "str"
                "t": "eq",
                "v": "master bath",
                "vt": "str"
                "t": "eq",
                "v": "office",
                "vt": "str"
                "t": "eq",
                "v": "outside",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 14,
        "x": 1090,
        "y": 1080,
        "wires": [
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12",
                "370756c64ae1a442"
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12",
                "6b5aeb1c80fc63eb"
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12",
                "626bd71df581ea5a"
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12",
                "6c0c3bf8a453a80c"
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12",
                "62cfa8a173b8235d"
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12"
                "eae5abcd46cb1c12",
                "ba28246ca58d1781"
                "eae5abcd46cb1c12"
        "outputLabels": [
            "Bathroom",
            "Bedroom",
            "Dining Room",
            "Entryway",
            "Family Room",
            "Garage",
            "Guest Room",
            "Hallway",
            "Kitchen",
            "Laundry Room",
            "Living Room",
            "Master Bath",
            "Office",
            "Outside"
        "id": "966b3c2392432a60",
        "type": "debug",
        "name": "debug 517",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 1310,
        "y": 940,
        "wires": []
        "id": "6b5aeb1c80fc63eb",
        "type": "link out",
        "name": "Entryway Lights",
        "mode": "link",
        "links": [
            "1cbe1d67bbf89d7c"
        "x": 1500,
        "y": 1020,
        "wires": [],
        "icon": "node-red/light.svg",
        "l": true
        "id": "05a0037e8e57b876",
        "type": "change",
        "rules": [
                "t": "change",
                "pt": "msg",
                "from": "on",
                "fromt": "str",
                "to": "false",
                "tot": "bool"
                "t": "change",
                "pt": "msg",
                "from": "off",
                "fromt": "str",
                "to": "true",
                "tot": "bool"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 920,
        "y": 1120,
        "wires": [
                "6f4ae984d0fb9410"
        "id": "62cfa8a173b8235d",
        "type": "link out",
        "name": "Laundry Room Lights",
        "mode": "link",
        "links": [
            "2d4d225366c81a39"
        "x": 1480,
        "y": 1200,
        "wires": [],
        "l": true
        "id": "ba28246ca58d1781",
        "type": "link out",
        "name": "Office Lights",
        "mode": "link",
        "links": [
            "e127b95333e569fd",
            "27f951496da4f276",
            "5445e96a55d1da7f",
            "a03c0d4ba6e71fda"
        "x": 1510,
        "y": 1260,
        "wires": [],
        "l": true
        "id": "370756c64ae1a442",
        "type": "link out",
        "name": "Bedroom Lights",
        "mode": "link",
        "links": [
            "21ebd38950e29f43",
            "5c8badb0bd0992fe"
        "x": 1500,
        "y": 960,
        "wires": [],
        "l": true
        "id": "626bd71df581ea5a",
        "type": "link out",
        "name": "Garage Lights",
        "mode": "link",
        "links": [],
        "x": 1500,
        "y": 1080,
        "wires": [],
        "l": true
        "id": "6c0c3bf8a453a80c",
        "type": "link out",
        "name": "Hallway Lights",
        "mode": "link",
        "links": [
            "2d4d225366c81a39",
            "a7e452d41c38e273"
        "x": 1500,
        "y": 1140,
        "wires": [],
        "l": true
        "id": "5d43fb69a17a6eef",
        "type": "alexa-remote-event",
        "name": "",
        "account": "",
        "event": "ws-device-activity",
        "x": 330,
        "y": 1080,
        "wires": [
                "98a49fe9e4e49101",
                "b072027c6d1d6e64",
                "0c68db52072968f3"
        "id": "919572594d214e9a",
        "type": "comment",
        "name": "Regarding Hubitat Command Nodes",
        "info": "You will need ot add your own device info into\nthe command nodes. The top row are \"on\" nodes\nthe bottom row are \"off\" nodes.",
        "x": 1100,
        "y": 860,
        "wires": []
        "id": "4630e3f5d44bdf5b",
        "type": "comment",
        "name": "Conenct your alexa account here",
        "info": "Details for how to set this up can be found \nin the contrib",
        "x": 370,
        "y": 960,
        "wires": []
Sorry for the double post, but I ran out of characters for the second part of the flow. So, here it is...
        "id": "313c0097.f1216",
        "type": "subflow",
        "name": "HUE - Motion Sensor Event Filter",
        "info": "",
        "category": "",
        "in": [
                "x": 380,
                "y": 280,
                "wires": [
                        "id": "f00de543.b72668"
        "out": [
                "x": 960,
                "y": 200,
                "wires": [
                        "id": "6bf15156.15b6f",
                        "port": 0
                "x": 960,
                "y": 280,
                "wires": [
                        "port": 0
                        "id": "26f8a17a.e1b86e",
                        "port": 0
                "x": 960,
                "y": 360,
                "wires": [
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99"
        "id": "f00de543.b72668",
        "type": "switch",
        "z": "313c0097.f1216",
        "name": "payload.data.0.motion.motion",
        "property": "payload.data.0.motion.motion",
        "rules": [
                "t": "true"
                "t": "false"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 570,
        "y": 280,
        "wires": [
                "6bf15156.15b6f"
                "26f8a17a.e1b86e"
        "type": "change",
        "name": "true",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 830,
        "y": 240,
        "wires": [
        "type": "change",
        "name": "false",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 830,
        "y": 320,
        "wires": [
        "id": "94e24bce.4cf888",
        "type": "comment",
        "name": "PLEASE READ - DOUBLE CLICK",
        "info": "Output 1:\nWill send just an **true** when Motion is detected\n\nOutput 2:\nWill send an **true** when Motion is detected and a **false** if no motion is detected any longer.\n\nOutput 3:\nWill send just an **false** when no Motion is detected any longer.\n\n\n-----------------------\nAll outputs are boolean\n-----------------------\n\nMost easy Subflow, but convinient when lots of sensors need to be set up.",
        "x": 580,
        "y": 240,
        "wires": []
        "id": "3c1e2a8e.9361c6",
        "type": "comment",
        "name": "motion true",
        "info": "",
        "x": 1060,
        "y": 200,
        "wires": []
        "id": "dad8bfd3.3e71d",
        "type": "comment",
        "name": "motion false",
        "info": "",
        "x": 1070,
        "y": 360,
        "wires": []
        "id": "ed505a4f.d8e6d8",
        "type": "comment",
        "name": "motion true / false",
        "info": "",
        "x": 1090,
        "y": 280,
        "wires": []
        "id": "90cd7dbdce9813de",
        "type": "tab",
        "label": "Flow 13",
        "disabled": false,
        "info": "",
        "env": []
        "id": "1e8c0c2383272a95",
        "type": "group",
        "z": "90cd7dbdce9813de",
        "name": "Office",
        "style": {
            "fill": "#bfdbef",
            "label": true,
            "color": "#000000"
        "nodes": [
            "d8d99c143f6da609",
            "94fda84f9545bbb1",
            "92233f0422649d61",
            "d8be590aa66d05ee",
            "5bad0618defdff77",
            "acfc5c9fd8876a6e",
            "a03c0d4ba6e71fda",
            "ba0f961f9d691fbd",
            "d3ab02f1d575d876",
            "ef34b880d18038e4",
            "d71d10ef843fe35e",
            "24fc7357ef1e7118",
            "7dd59e39458f5f85",
            "7d149c75ac88f0ec",
            "18efe3a973fdd95a",
            "a011d7f9ebdff679",
            "0e3373c46e63ba00",
            "655d3b3f0c816b88",
            "61867b525430fd57",
            "abd6180e01d8c7df",
            "ccf5f024cdc85f58",
            "9f8f56f1212f0f3b",
            "0180b565ee3c5df3",
            "c19962b5d186eee4",
            "0ee55c2909231d48",
            "f06f62e72bda7a0c",
            "22282658e3aae18d",
            "6d0c2fd71bf88e7d"
        "x": 44,
        "y": 199,
        "w": 1882,
        "h": 382
        "id": "0ee55c2909231d48",
        "type": "junction",
        "g": "1e8c0c2383272a95",
        "x": 1060,
        "y": 300,
        "wires": [
                "5bad0618defdff77"
        "id": "f06f62e72bda7a0c",
        "type": "junction",
        "x": 380,
        "y": 300,
        "wires": [
                "0ee55c2909231d48"
        "id": "d8d99c143f6da609",
        "type": "FilterUltimate",
        "name": "On/Off",
        "x": 250,
        "y": 340,
        "wires": [
                "ba0f961f9d691fbd",
                "7d149c75ac88f0ec",
                "f06f62e72bda7a0c"
                "ba0f961f9d691fbd",
                "7d149c75ac88f0ec"
        "icon": "font-awesome/fa-lightbulb-o"
        "id": "94fda84f9545bbb1",
        "type": "link in",
        "name": "Hallway Motion / Sleep Presence",
        "links": [
            "1ae21f4d68f8c02c",
            "4195a8482f917cc9",
            "fd1054ebd817e7d6",
            "401995578a2312ef",
            "02fceb2a9fedad8a",
            "b6b811232ee4161b",
            "15087f3ae88fb8ad",
            "b94278acbee61495",
            "07f76a5ed54737a9",
            "79efc42d7e6397d2",
            "b01796562034455d",
            "345739aa08e13a64"
        "x": 1235,
        "y": 540,
        "wires": [
                "d3ab02f1d575d876"
        "icon": "font-awesome/fa-moon-o"
        "id": "92233f0422649d61",
        "type": "inject",
        "name": "On",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "true",
        "payloadType": "bool",
        "x": 105,
        "y": 300,
        "wires": [
                "d8d99c143f6da609"
        "outputLabels": [
            "On"
        "icon": "font-awesome/fa-toggle-on",
        "l": false
        "id": "d8be590aa66d05ee",
        "type": "inject",
        "name": "Off",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "false",
        "x": 105,
        "y": 380,
        "wires": [
                "d8d99c143f6da609"
        "outputLabels": [
            "Off"
        "icon": "font-awesome/fa-toggle-off",
        "l": false
        "id": "5bad0618defdff77",
        "type": "change",
        "name": "RESET",
        "rules": [
                "t": "set",
                "p": "reset",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1235,
        "y": 460,
        "wires": [
                "22282658e3aae18d"
        "icon": "font-awesome/fa-refresh",
        "l": false
        "id": "acfc5c9fd8876a6e",
        "type": "switch",
        "name": "Home Mode",
        "property": "HomeMode",
        "propertyType": "global",
        "rules": [
                "t": "eq",
                "v": "Day",
                "vt": "str"
                "t": "eq",
                "v": "Evening",
                "vt": "str"
                "t": "eq",
                "v": "Night",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 3,
        "x": 1490,
        "y": 300,
        "wires": [
                "abd6180e01d8c7df"
                "c19962b5d186eee4"
                "61867b525430fd57"
        "icon": "font-awesome/fa-home"
        "id": "a03c0d4ba6e71fda",
        "type": "link in",
        "name": "Office Light Voice Control",
        "links": [
            "657ee5c0b4a5595c",
            "ad5f454508d872df",
            "c420b86918417d51",
            "ba28246ca58d1781"
        "x": 125,
        "y": 340,
        "wires": [
                "d8d99c143f6da609"
        "icon": "font-awesome/fa-bullhorn"
        "id": "ba0f961f9d691fbd",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "to": "grouped_light",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "your ID number here",
                "tot": "str"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "{\"on\":{\"on\":true}}",
                "tot": "json"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "{\"on\":{\"on\":false}}",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 450,
        "y": 340,
        "wires": [
                "18efe3a973fdd95a"
        "id": "d3ab02f1d575d876",
        "type": "change",
        "name": "Office Lights - OFF",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1510,
        "y": 540,
        "wires": [
                "ef34b880d18038e4"
        "id": "ef34b880d18038e4",
        "type": "link out",
        "name": "Hue",
        "mode": "link",
        "links": [
            "0763283cf82ea3ab"
        "x": 1850,
        "y": 540,
        "wires": [],
        "l": true
        "id": "d71d10ef843fe35e",
        "type": "hubitat device",
        "deviceLabel": "",
        "name": "Office",
        "server": "",
        "deviceId": "",
        "attribute": "",
        "sendEvent": false,
        "x": 130,
        "y": 240,
        "wires": [
        "id": "24fc7357ef1e7118",
        "type": "switch",
        "name": "D'Dee Sleep Status",
        "property": "state.DDeeSleepState.value",
        "rules": [
                "t": "eq",
                "v": "Awake",
                "vt": "str"
                "t": "eq",
                "v": "Asleep",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1270,
        "y": 380,
        "wires": [
                "7dd59e39458f5f85"
                "61867b525430fd57"
        "icon": "font-awesome/fa-bed"
        "id": "7dd59e39458f5f85",
        "type": "switch",
        "name": "Rich Sleep Status",
        "property": "state.RichSleepState.value",
        "rules": [
                "t": "eq",
                "v": "Awake",
                "vt": "str"
                "t": "eq",
                "v": "Asleep",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1270,
        "y": 320,
        "wires": [
                "acfc5c9fd8876a6e"
                "61867b525430fd57"
        "id": "7d149c75ac88f0ec",
        "type": "change",
        "name": "Motion Sensor",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "to": "motion",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "{\"enabled\":true}",
                "tot": "json"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "{\"enabled\":false}",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 460,
        "y": 380,
        "wires": [
                "18efe3a973fdd95a"
        "icon": "node-red-contrib-huemagic/hue-motion.svg"
        "id": "18efe3a973fdd95a",
        "type": "link out",
        "name": "Hue",
        "mode": "link",
        "links": [
            "0763283cf82ea3ab"
        "x": 630,
        "y": 400,
        "wires": [],
        "l": true
        "id": "a011d7f9ebdff679",
        "type": "switch",
        "name": "Motion Event Stream",
        "property": "payload.data.0.id",
        "rules": [
                "t": "cont",
                "v": "your ID numer here",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 860,
        "y": 400,
        "wires": [
                "0e3373c46e63ba00"
        "id": "0e3373c46e63ba00",
        "type": "subflow:313c0097.f1216",
        "name": "",
        "x": 920,
        "y": 480,
        "wires": [
                "5bad0618defdff77",
                "24fc7357ef1e7118"
                "22282658e3aae18d"
        "id": "655d3b3f0c816b88",
        "type": "link in",
        "name": "Events  IN",
        "links": [
            "d3cbfa9016794115"
        "x": 800,
        "y": 340,
        "wires": [
                "a011d7f9ebdff679"
        "l": true
        "id": "61867b525430fd57",
        "type": "change",
        "name": "Nightlight",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "to": "scene",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "{\"recall\":{\"action\":\"active\"}}",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1660,
        "y": 340,
        "wires": [
                "ef34b880d18038e4"
        "icon": "font-awesome/fa-star"
        "id": "abd6180e01d8c7df",
        "type": "change",
        "name": "Bright",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "to": "scene",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1650,
        "y": 260,
        "wires": [
                "ef34b880d18038e4"
        "id": "ccf5f024cdc85f58",
        "name": "On/Off",
        "x": 250,
        "y": 460,
        "wires": [
                "0180b565ee3c5df3"
                "0180b565ee3c5df3"
        "id": "9f8f56f1212f0f3b",
        "type": "link in",
        "name": "Voice Control Office Motion",
        "links": [
            "1353fc597bda05de",
            "3484300f1307bf98",
            "565fd1bf0358f579"
        "x": 95,
        "y": 460,
        "wires": [
                "ccf5f024cdc85f58"
        "id": "0180b565ee3c5df3",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "to": "motion",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "tot": "json"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 460,
        "y": 460,
        "wires": [
                "18efe3a973fdd95a"
        "id": "c19962b5d186eee4",
        "type": "change",
        "name": "Dimmed",
        "rules": [
                "t": "set",
                "p": "endpoint",
                "pt": "msg",
                "to": "scene",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "json"
                "t": "set",
                "p": "verb",
                "pt": "msg",
                "to": "put",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1660,
        "y": 300,
        "wires": [
                "ef34b880d18038e4"
        "id": "22282658e3aae18d",
        "type": "trigger",
        "name": "3 Minutes",
        "op1": "",
        "op2": "false",
        "op1type": "nul",
        "op2type": "bool",
        "duration": "3",
        "extend": true,
        "overrideDelay": false,
        "units": "min",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 1320,
        "y": 500,
        "wires": [
                "d3ab02f1d575d876"
        "icon": "node-red-contrib-bigtimer/timer.png"
        "id": "6d0c2fd71bf88e7d",
        "type": "comment",
        "name": "Groups, lights and scenes info",
        "info": "You'll need to add your ID numbers to the lighting\nnodes if you want to use the hueevents method. \n",
        "x": 780,
        "y": 240,
        "wires": []
This may not be the best place to ask this, but I've gotten a lot of help from this group so here goes. I'd like to move my NodeRed installation from my raspberry pi to a VM on an Intel NUC I already have running other VM's. I like this setup for ease of backups and the safety net of checkpoints within hyper-v. I can setup NodeRed in a linux VM without issue, but does anyone have any info on the best way to move all my current flows and configs into the new installation?
Sure - just do a full export (All Flows)... then import on the new instance. You might have to tweak some things but it should work fine. If you used DHCP reservations you can change the IP from the RPi to the new VM.
I just did this when moving NR from an RPi running Ubuntu server to an RPi running HomeAssistant + NR Addon. Easy Peasy!
Thank you. That's interesting... I'm running home assistant in its own VM on that NUC already. What are your thoughts on using the home assistant NR Addon vs running NodeRed on its own?
So I really like it so far and think it might be worth playing around with - the only drawback is you are at the mercy of the maintainers to update it. So the new V3 release is a no go currently. There are also some additional tweaks you have to do - the webhook as an additional "/endpoint/" added to the URL..
I make regular backups of my Node-RED instance on a Pi (the .node-red folder). Just to make sure I could restore it on a different machine, I took the zipped file and copied the contents over to the Node-RED (fresh install) folder on my Mac. Apart from having to rename the flows file to whatever the new "hostname" is (default file name is flows_.json everything worked. If you don't do this, it will create a new flows file but will not overwrite the old one. Also, if you have your flows file defined in the settings.js, you may not need to do even rename the flows file.
Hope this helps.
Is this in reference to the Node-RED that comes with HA? I haven't seen any issues in the little bit of playing around that I have done (but mine is a standalone instance, just talking to Hubitat).
Yep - the NR addon maintainers have to release the update which is one of the drawbacks of using Home Assistant as an "app manager" but am not in a hurry on my production system. On my dev installation (an RPi) - easily upgraded to V3 and that has been working great. The new junction feature of the wires (right click on a wire and select junction!) is kinda cool but like others have traditionally used NO-OP.
Aaaaandd as I was typing I checked my HA and the update is in.. so upgrading now. Devs are fast apparently.
:wink:
Followup: NR V3 has been installed and is working fine so far.
Is that the only gotcha? I was meaning to migrate NR to HA OS a couple of weeks ago but haven't gotten around to it yet.
Migrated successfully. I set up Node-Red and installed all necessary modules. I exported all flows and shutdown the existing service on the raspberry pi. Imported all flows into the new install, Swapped IP addresses via DHCP reservation, rebooted and tested. All good.
Yes for the most part although you do have to restart the Node-RED addon a bit more than you would if it were standalone. The good news is that's easily done - settings/addons/NR/restart
One more tip. If you're going to migrate from one system to another and that includes changing IP addresses, make sure you remember what other services may have been running on the old platform. Changing the IP of your MQTT broker without preparation WILL cause problems. :rofl:
Is anyone using node-red dashboards or otherwise creating interactive experiences in node-red? I would appreciate any examples or tips to get started.
I'm still new to node-red, but I have the basics of how to write a flow to execute based on events and device commands using the excellent Hubitat community integration. But I'm at a loss on interactive things. Is there a native and/or preferred way to do this in node-red?
I'd like to create panels to help automate some things and also provide more responsive dashboard control related to my Broadlink remotes integration.
Is it possible to have alexa re-activate during a flow, to listen for additional information? Or if not, is it possible to extract who is speaking from the alexa nodes? I'm trying to add some sort of authorization to certain voice requests. Ideally, I'd like "alexa, do xyx", alexa says please authorize, "auth code", alexa says ok and executes. I feel like that's not possible right now, so I think you could possibly accomplish the same if you could verify the speaker and check for that value before continuing. Any thoughts or ideas?
