Node-Red Flow Samples/Sharing
I am using Node-RED Dashboards to display data. I don't use them to control any devices (I use HomeKit for that). NR Dashboards are not the most intuitive things out there but once you get the hang of it, it gets easier.
Here are a few examples of what my Dashboards look like:
I log all "events" in a database and can sort them, select specific date, device or event type
This information is captured using @thebearmay 's Hub Information Driver and also stored. Graphs are generated using the dashboard chart node.
Another example, not HE related is for my Tesla Powerwall. The combo chart uses a Chart.js plugin and is displayed in a template node (since the native chart node cannot do combo charts).
Hope this helps. Give me a shout if you want additional details.
This is great. Any tips on getting started?
Do you put nodes into your flow that "feed" the dashboard indicators somehow, or else how do you connect them to data sources? How do you actually launch the dashboard? If you can't tell, I dipped in a toe but that's about it.
See the flow below - the standard NR nodes are used to get data and then the ui_nodes are used to display the data.
I thought I had posted my solution for saving and displaying the events but I can't find it here now.
EDIT: Here is one of the solutions that I had posted.
The dashboard is at the same IP address that you use for creating your flows except it as a /ui at the end of the url (IP:1880/ui)
There are a few YouTube videos on getting started with the dashboard. Here is one that I used in the beginning
Yep, same with the data monitoring only!
The Grafana graphs are an iframe within an NR dash.
Have you installed the node-red-contrib-alexa-remote2-applestrudel pallet. The data that comes out of the Alexa Event node might contain that information but it's not clear which value it is. In a quick review of all of the values, I am not sure. I am the only one home right now so I can't compare results when I ask Alexa who I am vs my wife doing the same.
I have a "quick" dashboard I use.. still needs some work tho as I'm more of an automation type guy.. Also has some other tabs like battery reporting etc.
Thanks again for the tips. Having some fun getting this up and running this morning (disclaimer: little bit of mspaint re-arranging just so the screenshots aren't so huge).
This is what control looks like. It's pretty quick and easy to edit, though I'm sure some of the logic will get more complicated as I get more into it.
Is there any way to control the ordering and layout on the ui panel?
Yes. For example:
Ah, thank you. I hadn't discovered the layout pane on the right-hand side. I was just getting "lucky" with the nodes I had dropped on the main sequence editing area. :wink:
Sorry - I should have stated that. I made the assumption you knew - my bad!
I wouldn't have known to look if you hadn't said it was possible, so you got me in the ballpark and "taught me to fish". Thanks again.
The other "trick" that I use is I put different sections of a dashboard tab in groups and give the group a fixed width. Then they don't move around too much if you resize your browser page (just my preference). I also set my ui_nodes to a "fixed" width
I learned a lot today, thanks again for the tips, @aaiyar and @rakeshg .
I am actually trying to do something more specific than this, but here's the proof of concept that I worked up. It's a generic switch, where there's a dropdown populated with devices of capability.switch. There's a single toggle that acts on whichever you select.
I have been struggling with making some of my logic in node-red dynamic with respect to Hubitat devices, because knowing the deviceId (DNI) is sort of cumbersome. This gets me past that, plus looks good on a dashboard, to boot.
I'd appreciate any tips if I'm doing brute force things that have a more elegant/cleaner way.
Don't see much that can/should change. One possible thing is that instead of a switch node (switch), use a change node to set msg.command to msg.payload coming from the ui_switch node. I think the ui_switch has "on"/"off" states only, so should match msg.command attributes.
The other thing is that you could possibly load the devices/all at NR startup (unless there is a need to populate it repeatedly) and/or if you see a hubStartup event. The use the ui_control node ( on the flow - connect event only) to populate msg.options and the device selection node.
Many ways to skin the cat! Have fun...
Thanks for the tips!
The value from the UI switch is true/false. I didn't see a shorter way to get that to on/off than the change node. Is there one?
You read my mind on refreshing devices. I did it that way so that anything new I added on the HE side would be populated. Unless the event of adding a device would be injected by any of the HE nodes (to cause the logic after it to flow), but I wasn't sure on that one.
I think that value can be on/off. For example, in this sequence:
Screen Shot 2022-08-14 at 11.22.06 AM
The switch node is configured as:
and the change node is configured as:
Perfect, the switch node configuration is the piece I was missing.
Wanted to share a subflow I developed thanks to @stephen_nutt's desire to convert a sequence of button presses to a different button press...
Originally I wrote a subflow to incorporate the ideas we discussed but soon realized this could be abstracted even further... So here is a new subflow called "Trigger Convert"..
Trigger Convert
[{"id":"9540b0343c71fb98","type":"group","z":"b38ec3180db9ae33","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["68b640cb8870b75b","14c1f4cf77e27fa7","fcf0f568c4d33c32","8e3a37a649d03bbc","74dc2a23244c2645","c9e77e2065a59f70","14fd3f460f313439"],"x":74,"y":2519,"w":752,"h":262},{"id":"3b59914daaad2161","type":"subflow","name":"Trigger Convert","info":"","category":"","in":[{"x":40,"y":40,"wires":[{"id":"f4a31b548b18b7f0"}]}],"out":[{"x":740,"y":100,"wires":[{"id":"14dc4f13e03c8ecf","port":0}]}],"env":[{"name":"CHECK_TABLE","type":"json","value":"[{\"name\":\"Test 1\",\"inputVals\":[{\"topic\":\"Device1 Button\",\"input\":\"1\"},{\"topic\":\"Device2 Button\",\"input\":\"1\"},{\"topic\":\"Device2 Button\",\"input\":\"1\"}],\"output\":12},{\"name\":\"Test 2\",\"inputVals\":[{\"topic\":\"Device2 Button\",\"input\":\"3\"},{\"topic\":\"Device2 Button\",\"input\":\"4\"}],\"output\":11}]"},{"name":"DELAYMS","type":"num","value":"250"},{"name":"REQUIRE_SEQ","type":"bool","value":"false"},{"name":"TRIGGER_ONLY","type":"bool","value":"false"},{"name":"INPUT_PROP","type":"str","value":"payload.value"},{"name":"OUTPUT_PROP","type":"str","value":"payload"}],"meta":{},"color":"#FFCC66","icon":"node-red/swap.svg","status":{"x":740,"y":200,"wires":[{"id":"14dc4f13e03c8ecf","port":1}]}},{"id":"f4a31b548b18b7f0","type":"function","z":"3b59914daaad2161","name":"accumulate data","func":"var inputProp = env.get(\"INPUT_PROP\");\nvar input = getVal(msg,inputProp);\n\nvar presses = flow.get(\"presses\");\n\nif (!presses) {\n  presses = [];\n}\n\npresses.push({ \"topic\": msg.topic, \"input\": input, \"payload\": msg.payload});\n\nflow.set(\"presses\",presses)\n\nreturn msg;\n\nfunction getVal(obj,propName) {\n\n    var retVal;\n    var props = propName.split(\".\");\n    var name = props[0];\n\n    if (props.length > 1) {\n\n        props.shift();\n        var newProps = props.join(\".\");\n\n        if (!obj.hasOwnProperty(name)) {\n            obj[name] = {};\n        }\n        retVal = getVal(obj[name],newProps);\n\n\n    } else {\n        retVal = obj[name];\n    }\n\n    return retVal;\n\n}\n","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\ncontext.set(\"presses\",undefined)","finalize":"","libs":[],"x":220,"y":60,"wires":[["207f439b5db01e9a"]]},{"id":"207f439b5db01e9a","type":"timed-counter","z":"3b59914daaad2161","name":"","timelimit":"${DELAYMS}","timeunit":1,"withhold":true,"fixedtimeout":false,"pertopic":false,"x":220,"y":140,"wires":[["14dc4f13e03c8ecf"]]},{"id":"14dc4f13e03c8ecf","type":"function","z":"3b59914daaad2161","name":"convert incoming data","func":"const outputProp = env.get(\"OUTPUT_PROP\");\nconst checker = env.get(\"CHECK_TABLE\");\nconst reqSeq = env.get(\"REQUIRE_SEQ\");\nconst trigOnly = env.get(\"TRIGGER_ONLY\");\nconst presses = flow.get(\"presses\");\n\nvar matched = false;\nvar retVal;\nvar status = {\"payload\": {\"fill\":\"green\",\"shape\":\"dot\",\"text\": \"\" }};\n\nfor (var i=0;i<checker.length;i++){\n\n    var inputVals = checker[i].inputVals;\n    var origData = \"\";\n\n    if (presses.length == inputVals.length){\n        if (reqSeq) {\n            /*\n            matched = inputVals.every((v, idx) => {\n                v.input.toString() === presses[idx].input.toString() && v.topic === presses[idx].topic\n            });\n            */\n            \n            origData = \"\";\n            matched = true;\n            for (var k=0;k<presses.length;k++){\n                origData += (origData === \"\"? \"\" : \"/\") + presses[k].input.toString();\n\n                if (!(presses[k].input.toString() === inputVals[k].input.toString() && presses[k].topic === inputVals[k].topic)) {\n                    matched = false;\n                    break;\n                }\n            }\n            \n        } else {\n            var cmpArr = inputVals.slice();\n            \n            origData = \"\";\n            for (var j=0;j<presses.length;j++){\n                const topic = presses[j].topic.toString();\n                const input = presses[j].input.toString();\n                origData += (origData === \"\"? \"\" : \"/\") + input;\n                var foundIdx = cmpArr.findIndex( v => v.topic === topic && v.input === input )\n                if (foundIdx > -1) {\n                    cmpArr.splice(foundIdx,1);\n                }\n            }\n            matched = ((cmpArr.length == 0));\n        }\n\n    }\n\n    if ( matched ) {\n        \n        retVal = {\n            \"topic\": checker[i].name\n        }\n        \n        var output = {\n            \"name\": checker[i].name,\n            \"value\":checker[i].output,\n            \"data\": presses\n        }\n\n        setVal(retVal,outputProp, output)\n        status.payload.fill = \"green\";\n        status.payload.text = origData + \" => \" + checker[i].output;\n        break;\n    } \n}\n\n\nif (matched){\n    node.send([retVal,status]);\n} else {\n    \n    if (!trigOnly){\n        retVal = msg;\n        status.payload.fill = \"green\";\n        for(l=0;l<presses.length;l++){\n            retVal.topic = presses[l].topic\n            retVal.payload = presses[l].payload\n            status.payload.text += (status.payload.text !== \"\" ? \"/\" : \"\" ) + presses[l].input;\n            node.send([retVal,status]);\n        }\n    } else {\n        status.payload.fill = \"red\";\n        node.send([undefined,status]);\n    }\n}\n\nflow.set(\"presses\",undefined);\n\nreturn;\n\nfunction setVal(obj,propName,val) {\n    var props = propName.split(\".\");\n    var name = props[0];\n\n    if (props.length > 1) {\n        if (typeof obj[name] !== \"object\"){\n            obj[name] = {};\n        }\n        props.shift();\n        var newProps = props.join(\".\");\n        setVal(obj[name],newProps,val);\n\n    } else {\n        obj[name] = val;\n    }\n\n    return;\n\n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":140,"wires":[[],[]]},{"id":"68b640cb8870b75b","type":"debug","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"debug 7","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":720,"y":2660,"wires":[]},{"id":"14c1f4cf77e27fa7","type":"subflow:3b59914daaad2161","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"","env":[{"name":"CHECK_TABLE","value":"[{\"name\":\"Office Test 1\",\"inputVals\":[{\"topic\":\"Office Button\",\"input\":\"1\"},{\"topic\":\"Office Pico\",\"input\":\"1\"},{\"topic\":\"Office Pico\",\"input\":\"1\"}],\"output\":12},{\"name\":\"Office Test 2\",\"inputVals\":[{\"topic\":\"Office Pico\",\"input\":\"3\"},{\"topic\":\"Office Pico\",\"input\":\"4\"}],\"output\":11}]","type":"json"},{"name":"DELAYMS","value":"5000","type":"num"},{"name":"REQUIRE_SEQ","value":"true","type":"bool"}],"x":520,"y":2660,"wires":[["68b640cb8870b75b"]]},{"id":"fcf0f568c4d33c32","type":"inject","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"Office Button: Push 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Office Button","payload":"{\"name\":\"pushed\",\"value\":1,\"displayName\":\"Office Button\",\"deviceId\":\"1781\",\"descriptionText\":\"Office Button button 1 was pushed\",\"unit\":null,\"type\":\"digital\",\"data\":null,\"currentValue\":1,\"dataType\":\"NUMBER\"}","payloadType":"json","x":220,"y":2560,"wires":[["14c1f4cf77e27fa7"]]},{"id":"8e3a37a649d03bbc","type":"inject","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"Office Pico: Push 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Office Pico","payload":"{\"name\":\"pushed\",\"value\":1,\"displayName\":\"Office Pico\",\"deviceId\":\"33\",\"descriptionText\":\"Office Pico button 1 was pushed [physical]\",\"unit\":null,\"type\":\"physical\",\"data\":null,\"currentValue\":1,\"dataType\":\"NUMBER\"}","payloadType":"json","x":230,"y":2620,"wires":[["14c1f4cf77e27fa7"]]},{"id":"74dc2a23244c2645","type":"inject","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"Office Pico: Push 2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Office Pico","payload":"{\"name\":\"pushed\",\"value\":2,\"displayName\":\"Office Pico\",\"deviceId\":\"33\",\"descriptionText\":\"Office Pico button 2 was pushed [physical]\",\"unit\":null,\"type\":\"physical\",\"data\":null,\"currentValue\":2,\"dataType\":\"NUMBER\"}","payloadType":"json","x":230,"y":2660,"wires":[["14c1f4cf77e27fa7"]]},{"id":"c9e77e2065a59f70","type":"inject","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"Office Pico: Push 3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Office Pico","payload":"{\"name\":\"pushed\",\"value\":3,\"displayName\":\"Office Pico\",\"deviceId\":\"33\",\"descriptionText\":\"Office Pico button 3 was pushed [physical]\",\"unit\":null,\"type\":\"physical\",\"data\":null,\"currentValue\":3,\"dataType\":\"NUMBER\"}","payloadType":"json","x":230,"y":2700,"wires":[["14c1f4cf77e27fa7"]]},{"id":"14fd3f460f313439","type":"inject","z":"b38ec3180db9ae33","g":"9540b0343c71fb98","name":"Office Pico: Push 4","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Office Pico","payload":"{\"name\":\"pushed\",\"value\":4,\"displayName\":\"Office Pico\",\"deviceId\":\"33\",\"descriptionText\":\"Office Pico button 4 was pushed [physical]\",\"unit\":null,\"type\":\"physical\",\"data\":null,\"currentValue\":4,\"dataType\":\"NUMBER\"}","payloadType":"json","x":230,"y":2740,"wires":[["14c1f4cf77e27fa7"]]}]
Why is this fun? Well for example you could have multiple light switches and based on a given sequence of switching you could do something like activate the hidden door to your secret lair... or trip an alarm etc etc.
The subflow accumulates a certain amount of msgs coming in for a predetermined time and then checks against a JSON array to see if any matches - if so then returns an output value.. The delay, devices (delineated by topic), trigger only vs all msgs can be configured via the subflow "properties" aka environment variables.
Here is an example included above- inject nodes standing in for the HE device nodes (in this case button pushed events):
You click on the "Office Button Push 1" once then the "Office Pico" twice (Note: this does not trap double-taps) and a value of 12 is returned.. here is the JSON array for the checking:
        "name": "Office Test 1",
        "inputVals": [
                "topic": "Office Button",
                "input": "1"
                "topic": "Office Pico",
                "input": "1"
                "input": "1"
        "output": 12
        "name": "Office Test 2",
        "inputVals": [
                "input": "3"
                "input": "4"
        "output": 11
edit: You DO need the "node-red-contrib-timed-counter" installed...
Hi everyone. I’m using one of these new Tuya presence sensors and it’s pretty good. However, I’m struggling to get the desired effect in my Node Red motion lighting routine. Maybe someone can help.
Here’s a snippet of the Node Red flow. It’s pretty standard I think.
The problem I have is this sensor (it’s at the top left of the flow, with various other PIR sensors below it that work fine) can be active but doesn’t spit that message out on a regular basis or when retriggered. It will just sit there saying active, but because it doesn’t output anything, my timer will time out and the lights go off even tho it’s still active.
Is there a better way to construct the flow to take account of this? Some way to retrigger the active status output regularly or suchlike?
I think you could add a Device Node for the Tuya Multi Sensor - Living Room sensor with Send Events turned off and a Switch node that passes "inactive" for msg.payload.value at the red arrow in your flow. Then, before turning off Living Room TV (Sony), the flow will make sure Tuya Multi Sensor - Living Room is inactive. Add an output for the Switch Node for "active" that routes back to the 3 Minute Timer so that time starts over.
