Arrived! It's a little taller and wider than the Aqara, but still quite small. It comes in mercifully small, less wasteful packaging than the Aqara and other devices, and actually has readable color install instructions.
I just added it to my C8 Pro. Joined easily, but as a moisture sensor.
Changed to Device and cleared all states, etc., then changed to Generic Zigbee Contact (no temp) and worked normally. The LED flashes briefly when open/close state changes, which I like.
At one point when I was futzing about w/it the battery started reporting 200%. Probably would have cleared up over time, but I switched to your Tuya contact sensor driver and battery reporting is normal again. I also like having the Health attribute so I'll keep using your driver. Thank you!
The sensitivity of the sensor to the magnet depends very much on left or right position. Seems like more variable than other contact sensors I've used.
On the left side of the sensor (assuming LED at the bottom) there is an embossed line in the middle of the sensor - other contact sensors have this as well and I've always taken them to mean "we recommend you put the magnet on this side."
Anyway, if you put the magnet on that "left side" of the sensor, it switches between Open and Closed per below distances. It doesn't seem to matter if the magnet is vertically aligned w/the sensor, you can move the magnet up or down vertically and sensing is consistent.
Closed:
Open:
If you put the magnet on the right side of the sensor, things are different. If the magnet is aligned w/the middle of the sensor I can actually touch the magnet to the sensor and the sensor will still report Open. In below positions sensor reports Open.
If I slide the magnet down so the bottom of the magnet aligns w/the bottom of the sensor, the sensor then reports closed in this position, and reports open at a much closer distance than when on the left side, about 3/8".
I've seen "left/right) sensitivity differences in other sensors, but the differences on this one seem to be more significant. It does allow for some "customization" of the sensing distance that can be useful depending on your needs.
Interestingly, when I tried using a Aqara contact sensor magnet w/the Tuya sensor, no matter where I put it on the right side of the Tuya contact sensor while touching the sensor, the sensor never reported closed. The Aqara magnet worked normally on the left side of the Tuya sensor.
So thos are initial take-aways. I'm going to install it as a second sensor on one of my doors and let it run for a while and see if it seems reliable/dependable on the C8.
For now my very short-term response is these sensors seem like they could be a good contact sensor option for those looking for a small form factor. Assuming they are fully Zigbee 3.0 compatible, they should be more reliable than the Aqara have been on Hubitat hubs. (Though Aqara contacts have been working reliably for me on C7 and C8).
@mike.maxwell - can you update so this gets joined as a contact sensor, no temp?
