@bobbyD We're kind of begging here. It's a massive amount of junk in the logs.
To illustrate the issue: Here's 6 minutes of logs from last night. 6 minutes:
dev:24262022-12-02 12:26:28.728 AMinfoK3 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24262022-12-02 12:26:28.724 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24202022-12-02 12:26:28.679 AMinfoK2 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24202022-12-02 12:26:28.675 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24612022-12-02 12:26:28.611 AMinfoFront of House Bulbs level is 100%
dev:24582022-12-02 12:26:28.608 AMinfoK1 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24582022-12-02 12:26:28.605 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24612022-12-02 12:26:28.582 AMinfoFront of House Bulbs saturation was set to 0%
dev:24252022-12-02 12:26:28.581 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24612022-12-02 12:26:28.580 AMinfoFront of House Bulbs colorName is Orange
dev:24252022-12-02 12:26:28.577 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24612022-12-02 12:26:28.553 AMinfoFront of House Bulbs hue was set to 11%
dev:24562022-12-02 12:26:28.552 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
app:26632022-12-02 12:26:28.359 AMinfoEnd of Loop 64
dev:24562022-12-02 12:25:28.521 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24582022-12-02 12:25:28.440 AMinfoK1 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24582022-12-02 12:25:28.436 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24262022-12-02 12:25:28.409 AMinfoK3 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24262022-12-02 12:25:28.406 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24252022-12-02 12:25:28.393 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24252022-12-02 12:25:28.390 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24202022-12-02 12:25:28.360 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:6322022-12-02 12:24:34.194 AMinfoCabinet Room Motion temperature is 69.91°F
dev:24262022-12-02 12:24:28.346 AMinfoK3 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24262022-12-02 12:24:28.331 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24202022-12-02 12:24:28.318 AMinfoK2 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24202022-12-02 12:24:28.303 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24582022-12-02 12:24:28.179 AMinfoK1 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24582022-12-02 12:24:28.172 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24252022-12-02 12:24:28.153 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24252022-12-02 12:24:28.150 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24562022-12-02 12:24:28.130 AMinfoK6 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24562022-12-02 12:24:28.119 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:10882022-12-02 12:24:08.750 AMinfoBasement Bath Motion temperature is 69.79°F
dev:14902022-12-02 12:23:41.706 AMinfoStudio is off [physical]
dev:24202022-12-02 12:23:28.096 AMinfoK2 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24202022-12-02 12:23:28.088 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24262022-12-02 12:23:28.026 AMinfoK3 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:40, saturation:0, color_temp:0, err_code:0]]
dev:24262022-12-02 12:23:28.022 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":40,"saturation":0,"color_temp":0,"err_code":0}}}
dev:24582022-12-02 12:23:27.973 AMinfoK1 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24582022-12-02 12:23:27.959 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24252022-12-02 12:23:27.950 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24252022-12-02 12:23:27.947 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24562022-12-02 12:23:27.878 AMinfoK6 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24562022-12-02 12:23:27.875 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:11652022-12-02 12:22:42.303 AMinfoGarage Button Pusher Relay is off [physical]
dev:17472022-12-02 12:22:28.429 AMinfoLamp 2 is off [physical]
dev:24262022-12-02 12:22:27.907 AMinfoK3 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24262022-12-02 12:22:27.903 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24202022-12-02 12:22:27.817 AMinfoK2 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24202022-12-02 12:22:27.814 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24582022-12-02 12:22:27.790 AMinfoK1 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24582022-12-02 12:22:27.748 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24252022-12-02 12:22:27.727 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24252022-12-02 12:22:27.723 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24562022-12-02 12:22:27.704 AMinfoK6 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24562022-12-02 12:22:27.701 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24062022-12-02 12:22:26.275 AMinfoHighToday was set to 28°F
dev:17782022-12-02 12:22:26.238 AMinfoGarage Heat Index was set to 31°F
dev:24072022-12-02 12:22:26.227 AMinfoLowToday was set to 28°F
app:24692022-12-02 12:22:26.070 AMinfoEvent: Backyard temperature 28
dev:11122022-12-02 12:22:25.984 AMinfoBackyard was set to 28°F
dev:8562022-12-02 12:22:25.821 AMinfoRaw Temperature Sensor temperature is 27.63°F
dev:4682022-12-02 12:22:18.197 AMinfoPantry Motion Sensor temperature is 71.53°F
dev:24582022-12-02 12:21:27.714 AMinfoK1 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24582022-12-02 12:21:27.711 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24252022-12-02 12:21:27.588 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24252022-12-02 12:21:27.584 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24562022-12-02 12:21:27.558 AMinfoK6 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:360, saturation:100, color_temp:0, err_code:0]]
dev:24562022-12-02 12:21:27.555 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":360,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24202022-12-02 12:20:27.549 AMinfoK2 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24202022-12-02 12:20:27.545 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24582022-12-02 12:20:27.495 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24252022-12-02 12:20:27.480 AMinfoK4 RGB Bulb: setSysinfo: [status: [on_off:1, mode:normal, brightness:100, hue:119, saturation:100, color_temp:0, err_code:0]]
dev:24252022-12-02 12:20:27.473 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
dev:24262022-12-02 12:20:27.417 AMtrace{"smartlife.iot.smartbulb.lightingservice":{"transition_light_state":{"on_off":1,"mode":"normal","brightness":100,"hue":119,"saturation":100,"color_temp":0,"err_code":0}}}
