KLossev Thank you for your Help !!
I tried the driver you sent and it works the switch but only sees it as one switch not 2 and when I click on the of or off buttons both switches toggle..
Here is the log your requested..
Logs
dev:1082023-04-05 08:56:50.840 AMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,0702,0B04,E000,E001,0000", outClusters:"0019,000A", model:"TS011F", manufacturer:"_TZ3000_yf8iuzil"
dev:1082023-04-05 08:56:50.796 AMtraceZCL version:03
dev:1082023-04-05 08:56:50.792 AMtraceSoftware Build Id:unknown
dev:1082023-04-05 08:56:50.791 AMtraceModel:TS011F
dev:1082023-04-05 08:56:50.790 AMtraceManufacturer:_TZ3000_yf8iuzil
dev:1082023-04-05 08:56:50.744 AMdebuggetting info for unknown Zigbee device...
dev:1082023-04-05 08:56:14.837 AMwarnKitchen 2 Gang Switch Child device 108-02 not found. Initialise parent device first
dev:1082023-04-05 08:56:14.834 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70200060800001001, dni:0CF7, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70200060800001001, dni: 0CF7, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:1082023-04-05 08:56:14.828 AMdebugKitchen 2 Gang Switch Kitchen 2 Gang Switch unprocessed EP: 02 cluster: 0006 attrId: null
dev:1082023-04-05 08:56:14.825 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:catchall: 0104 0006 02 01 0040 00 0CF7 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]] (description:catchall: 0104 0006 02 01 0040 00 0CF7 00 00 0000 0B 01 0100)
dev:1082023-04-05 08:56:14.819 AMwarnKitchen 2 Gang Switch Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:56:14.816 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70100060800001001, dni:0CF7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060800001001, dni: 0CF7, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:1082023-04-05 08:56:14.809 AMwarnKitchen 2 Gang Switch Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:56:14.806 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70100060800001001, dni:0CF7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060800001001, dni: 0CF7, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:1082023-04-05 08:56:14.796 AMdebugKitchen 2 Gang Switch Kitchen 2 Gang Switch unprocessed EP: 01 cluster: 0006 attrId: null
dev:1082023-04-05 08:56:14.793 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]] (description:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 0B 01 0100)
dev:1082023-04-05 08:56:14.737 AMinfoKitchen 2 Gang Switch Turning all child switches on
dev:1082023-04-05 08:56:12.303 AMwarnKitchen 2 Gang Switch Child device 108-02 not found. Initialise parent device first
dev:1082023-04-05 08:56:12.299 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70200060800001000, dni:0CF7, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70200060800001000, dni: 0CF7, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00)
dev:1082023-04-05 08:56:12.293 AMwarnKitchen 2 Gang Switch Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:56:12.289 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70100060800001000, dni:0CF7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060800001000, dni: 0CF7, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00)
dev:1082023-04-05 08:56:12.284 AMdebugKitchen 2 Gang Switch Kitchen 2 Gang Switch unprocessed EP: 02 cluster: 0006 attrId: null
dev:1082023-04-05 08:56:12.281 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:catchall: 0104 0006 02 01 0040 00 0CF7 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]] (description:catchall: 0104 0006 02 01 0040 00 0CF7 00 00 0000 0B 01 0000)
dev:1082023-04-05 08:56:12.275 AMwarnKitchen 2 Gang Switch Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:56:12.272 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70100060800001000, dni:0CF7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060800001000, dni: 0CF7, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00)
dev:1082023-04-05 08:56:12.261 AMdebugKitchen 2 Gang Switch Kitchen 2 Gang Switch unprocessed EP: 01 cluster: 0006 attrId: null
dev:1082023-04-05 08:56:12.258 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]] (description:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 0B 01 0000)
dev:1082023-04-05 08:56:12.203 AMinfoKitchen 2 Gang Switch Turning all child switches off
dev:1082023-04-05 08:56:10.516 AMwarnKitchen 2 Gang Switch Child device 108-02 not found. Initialise parent device first
dev:1082023-04-05 08:56:10.512 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70200060800001001, dni:0CF7, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70200060800001001, dni: 0CF7, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:1082023-04-05 08:56:10.488 AMwarnKitchen 2 Gang Switch Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:56:10.483 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70100060800001001, dni:0CF7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060800001001, dni: 0CF7, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:1082023-04-05 08:56:10.472 AMdebugKitchen 2 Gang Switch Kitchen 2 Gang Switch unprocessed EP: 02 cluster: 0006 attrId: null
dev:1082023-04-05 08:56:10.469 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:catchall: 0104 0006 02 01 0040 00 0CF7 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]] (description:catchall: 0104 0006 02 01 0040 00 0CF7 00 00 0000 0B 01 0100)
dev:1082023-04-05 08:56:10.459 AMwarnKitchen 2 Gang Switch Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:56:10.456 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:0CF70100060800001001, dni:0CF7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060800001001, dni: 0CF7, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:1082023-04-05 08:56:10.447 AMdebugKitchen 2 Gang Switch Kitchen 2 Gang Switch unprocessed EP: 01 cluster: 0006 attrId: null
dev:1082023-04-05 08:56:10.445 AMdebugKitchen 2 Gang Switch Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]] (description:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 0B 01 0100)
dev:1082023-04-05 08:56:10.383 AMinfoKitchen 2 Gang Switch Turning all child switches on
dev:1082023-04-05 08:55:51.809 AMwarnZemismart ZigBee Wall Switch Multi-Gang parseBasicClusterAttribute cluster:null UNKNOWN attrId FFDF value:6,À+7,À+
dev:1082023-04-05 08:55:51.804 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF70100001CDFFF420A362CC02B13372CC02B12, dni:0CF7, endpoint:01, cluster:0000, size:1C, attrId:FFDF, encoding:42, command:0A, value:6,À+7,À+, clusterInt:0, attrInt:65503] (description:read attr - raw: 0CF70100001CDFFF420A362CC02B13372CC02B12, dni: 0CF7, endpoint: 01, cluster: 0000, size: 1C, attrId: FFDF, encoding: 42, command: 0A, value: 0A362CC02B13372CC02B12)
dev:1082023-04-05 08:55:51.573 AMdebugZemismart ZigBee Wall Switch Multi-Gang Attribite FFE4 : 00
dev:1082023-04-05 08:55:51.571 AMdebugZemismart ZigBee Wall Switch Multi-Gang Attribite FFE2 : 36
dev:1082023-04-05 08:55:51.569 AMdebugZemismart ZigBee Wall Switch Multi-Gang Applicaiton version: C0
dev:1082023-04-05 08:55:51.565 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF701000018010020C0E2FF2036E4FF2000, dni:0CF7, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:C0, clusterInt:0, attrInt:1, additionalAttrs:[[value:36, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]] (description:read attr - raw: 0CF701000018010020C0E2FF2036E4FF2000, dni: 0CF7, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: C0E2FF2036E4FF2000)
dev:1082023-04-05 08:55:44.934 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D010 value: 02
dev:1082023-04-05 08:55:44.930 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF702E0010810D03002, dni:0CF7, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:02, clusterInt:57345, attrInt:53264] (description:read attr - raw: 0CF702E0010810D03002, dni: 0CF7, endpoint: 02, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 02)
dev:1082023-04-05 08:55:44.885 AMinfoZemismart ZigBee Wall Switch Multi-Gang attribute 0006_4002 is: 0 (0)
dev:1082023-04-05 08:55:44.883 AMinfoZemismart ZigBee Wall Switch Multi-Gang attribute 0006_4001 is: 0 (0)
dev:1082023-04-05 08:55:44.882 AMwarnZemismart ZigBee Wall Switch Multi-Gang Child device 108-02 not found. Initialise parent device first
dev:1082023-04-05 08:55:44.877 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF70200061C0000100001402100000240210000, dni:0CF7, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]] (description:read attr - raw: 0CF70200061C0000100001402100000240210000, dni: 0CF7, endpoint: 02, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000)
dev:1082023-04-05 08:55:44.860 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D005 value: 00000000
dev:1082023-04-05 08:55:44.858 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D004 value: 00000000
dev:1082023-04-05 08:55:44.856 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D003 value: 00000000
dev:1082023-04-05 08:55:44.854 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D002 value: 00000000
dev:1082023-04-05 08:55:44.852 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D001 value: 00000000
dev:1082023-04-05 08:55:44.850 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D000 value: 00
dev:1082023-04-05 08:55:44.848 AMinfoZemismart ZigBee Wall Switch Multi-Gang Switch Type is: toggle (0)
dev:1082023-04-05 08:55:44.845 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: D010 value: 02
dev:1082023-04-05 08:55:44.833 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF701E0015E10D0300230D0300000D0200001D01B0000000002D0230000000003D0230000000004D0230000000005D02300000000, dni:0CF7, endpoint:01, cluster:E001, size:5E, attrId:D010, encoding:30, command:0A, value:02, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:00, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296], [value:00, encoding:20, attrId:D000, consumedBytes:4, attrInt:53248], [value:00000000, encoding:1B, attrId:D001, consumedBytes:7, attrInt:53249], [value:00000000, encoding:23, attrId:D002, consumedBytes:7, attrInt:53250], [value:00000000, encoding:23, attrId:D003, consumedBytes:7, attrInt:53251], [value:00000000, encoding:23, attrId:D004, consumedBytes:7, attrInt:53252], [value:00000000, encoding:23, attrId:D005, consumedBytes:7, attrInt:53253]]] (description:read attr - raw: 0CF701E0015E10D0300230D0300000D0200001D01B0000000002D0230000000003D0230000000004D0230000000005D02300000000, dni: 0CF7, endpoint: 01, cluster: E001, size: 5E, attrId: D010, encoding: 30, command: 0A, value: 0230D0300000D0200001D01B0000000002D0230000000003D0230000000004D0230000000005D02300000000)
dev:1082023-04-05 08:55:44.808 AMinfoZemismart ZigBee Wall Switch Multi-Gang Child Lock is: off (0)
dev:1082023-04-05 08:55:44.806 AMdebugZemismart ZigBee Wall Switch Multi-Gang processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: 5000 value: 01
dev:1082023-04-05 08:55:44.804 AMinfoZemismart ZigBee Wall Switch Multi-Gang Power On State is: Last state (2)
dev:1082023-04-05 08:55:44.802 AMinfoZemismart ZigBee Wall Switch Multi-Gang LED mode is: Lit when On (1)
dev:1082023-04-05 08:55:44.801 AMinfoZemismart ZigBee Wall Switch Multi-Gang attribute 0006_4002 is: 0 (0)
dev:1082023-04-05 08:55:44.799 AMinfoZemismart ZigBee Wall Switch Multi-Gang attribute 0006_4001 is: 0 (0)
dev:1082023-04-05 08:55:44.797 AMwarnZemismart ZigBee Wall Switch Multi-Gang Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:55:44.789 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF70100063C000010000140210000024021000001803001028030020050300100801000, dni:0CF7, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:02, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]]] (description:read attr - raw: 0CF70100063C000010000140210000024021000001803001028030020050300100801000, dni: 0CF7, endpoint: 01, cluster: 0006, size: 3C, attrId: 0000, encoding: 10, command: 0A, value: 000140210000024021000001803001028030020050300100801000)
dev:1082023-04-05 08:55:44.537 AMinfoZemismart ZigBee Wall Switch Multi-Gang attribute E000_D002 is: 02000A (02000A)
dev:1082023-04-05 08:55:44.533 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF701E0000C02D04802000A, dni:0CF7, endpoint:01, cluster:E000, size:0C, attrId:D002, encoding:48, command:0A, value:02000A, clusterInt:57344, attrInt:53250] (description:read attr - raw: 0CF701E0000C02D04802000A, dni: 0CF7, endpoint: 01, cluster: E000, size: 0C, attrId: D002, encoding: 48, command: 0A, value: 02000A)
dev:1082023-04-05 08:55:44.501 AMinfoZemismart ZigBee Wall Switch Multi-Gang attribute E000_D001 is: 20006 (20006)
dev:1082023-04-05 08:55:44.494 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF701E0000C01D048020006, dni:0CF7, endpoint:01, cluster:E000, size:0C, attrId:D001, encoding:48, command:0A, value:020006, clusterInt:57344, attrInt:53249] (description:read attr - raw: 0CF701E0000C01D048020006, dni: 0CF7, endpoint: 01, cluster: E000, size: 0C, attrId: D001, encoding: 48, command: 0A, value: 020006)
dev:1082023-04-05 08:55:43.839 AMwarnZemismart ZigBee Wall Switch Multi-Gang Child device 108-01 not found. Initialise parent device first
dev:1082023-04-05 08:55:43.832 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF70100060A00001000, dni:0CF7, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: 0CF70100060A00001000, dni: 0CF7, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00)
dev:1082023-04-05 08:55:41.840 AMdebugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0006 attrId: null
dev:1082023-04-05 08:55:41.836 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]] (description:catchall: 0104 0006 01 01 0040 00 0CF7 00 00 0000 07 01 00000000)
dev:1082023-04-05 08:55:40.038 AMdebugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8021 attrId: null
dev:1082023-04-05 08:55:40.035 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 8021 00 00 0040 00 0CF7 00 00 0000 00 00 D900, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D9, 00]] (description:catchall: 0000 8021 00 00 0040 00 0CF7 00 00 0000 00 00 D900)
dev:1082023-04-05 08:55:39.780 AMdebugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
dev:1082023-04-05 08:55:39.776 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0000 01 01 0040 00 0CF7 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:0CF7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]] (description:catchall: 0104 0000 01 01 0040 00 0CF7 00 00 0000 04 01 00)
dev:1082023-04-05 08:55:39.627 AMdebugZemismart ZigBee Wall Switch Multi-Gang Model Identifier: TS011F
dev:1082023-04-05 08:55:39.625 AMdebugZemismart ZigBee Wall Switch Multi-Gang Applicaiton version: C0
dev:1082023-04-05 08:55:39.623 AMdebugZemismart ZigBee Wall Switch Multi-Gang ZLC version: 03
dev:1082023-04-05 08:55:39.621 AMdebugZemismart ZigBee Wall Switch Multi-Gang Manufacturer name: _TZ3000_yf8iuzil
dev:1082023-04-05 08:55:39.605 AMdebugZemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:0CF701000068040042105F545A333030305F79663869757A696C000000200301000020C005000042065453303131460700003001FEFF003000, dni:0CF7, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_yf8iuzil, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:C0, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS011F, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] (description:read attr - raw: 0CF701000068040042105F545A333030305F79663869757A696C000000200301000020C005000042065453303131460700003001FEFF003000, dni: 0CF7, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F79663869757A696C000000200301000020C005000042065453303131460700003001FEFF003000)
dev:1082023-04-05 08:55:39.599 AMinfoZemismart ZigBee Wall Switch Multi-Gang InitializeVars()... fullInit = false
dev:1082023-04-05 08:55:39.593 AMdebugZemismart ZigBee Wall Switch Multi-Gang updating the settings from the current driver Zemismart ZigBee Wall Switch Multi-Gang version null to the new version 0.5.1 2023/04/05 7:27 AM [model TS011F, manufacturer _TZ3000_yf8iuzil, application C0, endpointId 01]
dev:1082023-04-05 08:55:39.516 AMdebugZemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands : [he raw 0x0CF7 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x0CF7 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x0CF7 0x01 0x01 6 {A4C138E7173AFF65} {}, delay 2000, he cr 0x0CF7 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0x0CF7 0x01 6 0 {}, delay 2000]
dev:1082023-04-05 08:55:39.503 AMdebugZemismart ZigBee Wall Switch Multi-Gang configure()..
dev:1082023-04-05 08:55:39.494 AMinfoZemismart ZigBee Wall Switch Multi-Gang model TS011F, manufacturer _TZ3000_yf8iuzil, application C0, endpointId 01
dev:1082023-04-05 08:55:39.491 AMinfoZemismart ZigBee Wall Switch Multi-Gang Parent installed, typeName Zemismart ZigBee Wall Switch Multi-Gang, version 0.5.1 2023/04/05 7:27 AM, deviceNetworkId 0CF7, zigbeeId A4C138E7173AFF65
Show more...
