Moes Zigbee Button Press Creates Two Events
I have a few of these switches and they seem to be well used. I have noticed every few months a strange behaviour and I have been trying to narrow it down.
From time to time, with no obvious cause or remedy they register two actions. They turn the lights they are controlling on and then immediately off again (or vice versa).
I use Room Lighting but I dont think this is the cause.
From looking at the logs the button press is registered twice.
In the scenario below I pressed it once initially (two events and the button registered two events and the light turned on then off.
I then did a digital button press from within the device screen. This created one event and I could do another "press" and it went off.
I then did another physical press and it did the double event seen in the logs.
Device details are below
TZ3000_gbm10jnj
TS0043
I am using the Tuya Zigbee Scene Switch Driver
This behaviour has occured on multiple hub platform versions. I am currently on 2.4.0.125 and have a C8 Pro
This exact situation has plagued me recently. More than a year without ever having an issue, and then it started intermittently two months ago. Planned to attack it today, but then (of course) the button behaved properly.
I'm kinda glad it's happening to someone else.
Have to say WAF is suffering
There doesn't seem to be any reason why it starts to occur and what makes it go away
I can't explain why it's random for you but this sounds like the debouncing issue. I had the same issue using the Tuya Zigbee Scene Switch Driver. I had to increase the time of what was in the driver. I want to say I upped it to 3 seconds but it's been a while.
I've noticed that the phantom push is about 1 second after the first real push. (And, yes, the phantom pushes have resumed this afternoon :slight_smile:
Can you share more details about how you changed this? Was it a change to the driver code?
I think this driver is in built?
You can also try this driver, however I don't expect the strange behaviour to change.
Some Tuya scene controllers send two or three events after a button is pressed, and the custom driver has built-in debounce logic for these. However, your device is not on the problematic devices list.
The driver works like a champ for filtering out the phantom presses. Thanks!
I purchased 4 of these MOES buttons and had the same issue, double toggle.
I was using this driver:
When I switched to this driver the buttons are working fine.
I have ( 6 ) of these and also use : Tuya Scene Switch TS004F
They all work fine :slight_smile:
As a hobbyist community developer, I have the freedom to use magic and voodoos —something that a professional software engineer is not allowed to do. :crazy_face:
Thanks for your help and input.
I've tried the driver suggested. No change in the behaviour reported though :frowning:
I have added debouncing for your device. Please update manually to the latest 'Tuya Scene Switch TS004F' version 2.7.4 and let me know whether the duplicated button press issue is fixed.
Thanks for the amended driver. Have just uploaded/installed
Same behaviour
I think that I see where the problem is. All other problematic Tuya scene switches send the duplicated events 800 milliseconds apart. This device, however sends the duplicated events after about 1000 milliseconds....
Can you edit the code - on line 216 set the debounce time to 1500 :
Then click on the Save button within the code editor.
If this works, I will make the debouncing timer configurable.
No joy, I made the change and it still does it.
I continued to increase the number steadily up to 8000 and the issue remains.
Is your device TS0043 TZ3000_gbm10jnj ?
Can you select/copy & paste the complete Device Data section as text?
Details below - Not all the fields in the instructions were on any of the tabs for the Device, not sure if that's due to the version I am using? (2.4.0.125)
Device Details
Create Time
04/12/2023, 11:05:04
Last Update Time
02/12/2024, 14:57:29
Last Activity At
03/12/2024, 10:14:30
Controller Type
ZGB
Data
endpointId: 01
application: 42
manufacturer: _TZ3000_gbm10jnj
model: TS0043
The instructions for copying the Data Details section as text are not quite correct anymore with the HE beta platform 2.4.0.x anymore .. :frowning:
The last request for now - please select/copy/paste a series of duplicate debug logs (same as on your screenshot). The reason I am asking for it is that I can simulate your device messages on my test setup.
Very strange..... I started pressing the buttons to generate more logs and initially got the double event. But soon after it started working normally. This should be captured in the logs at some point.
I also remembered that the value you asked me to change is still where I left it at 8000
Here are the logs
Summary
dev:2182024-12-03 11:33:35.626 AM
info
Landing Lights button 1 was pushed
dev:2182024-12-03 11:33:35.625 AM
debug
Landing Lights catchall descMap: [raw:catchall: 0104 0006 01 01 0040 00 3FBE 01 00 0000 FD 00 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:3FBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:FD, direction:00, data:[00]]
dev:2182024-12-03 11:33:35.623 AM
debug
Landing Lights description is catchall: 0104 0006 01 01 0040 00 3FBE 01 00 0000 FD 00 00
dev:2182024-12-03 11:33:31.688 AM
info
dev:2182024-12-03 11:33:31.687 AM
debug
dev:2182024-12-03 11:33:31.685 AM
debug
dev:2182024-12-03 11:33:28.836 AM
info
Landing Lights button 2 was pushed
dev:2182024-12-03 11:33:28.834 AM
debug
Landing Lights catchall descMap: [raw:catchall: 0104 0006 02 01 0040 00 3FBE 01 00 0000 FD 00 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:3FBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:FD, direction:00, data:[00]]
dev:2182024-12-03 11:33:28.833 AM
debug
Landing Lights description is catchall: 0104 0006 02 01 0040 00 3FBE 01 00 0000 FD 00 00
dev:2182024-12-03 11:33:24.676 AM
info
dev:2182024-12-03 11:33:24.674 AM
debug
dev:2182024-12-03 11:33:24.673 AM
debug
dev:2182024-12-03 11:33:20.848 AM
info
dev:2182024-12-03 11:33:20.847 AM
debug
dev:2182024-12-03 11:33:20.845 AM
debug
dev:2182024-12-03 11:33:15.496 AM
info
dev:2182024-12-03 11:33:15.495 AM
debug
dev:2182024-12-03 11:33:15.493 AM
debug
dev:2182024-12-03 11:33:10.149 AM
info
dev:2182024-12-03 11:33:10.147 AM
debug
dev:2182024-12-03 11:33:10.146 AM
debug
dev:2182024-12-03 11:33:04.163 AM
info
dev:2182024-12-03 11:33:04.161 AM
debug
dev:2182024-12-03 11:33:04.160 AM
debug
dev:2182024-12-03 11:33:01.377 AM
info
dev:2182024-12-03 11:33:01.375 AM
debug
dev:2182024-12-03 11:33:01.374 AM
debug
dev:2182024-12-03 11:33:00.391 AM
info
dev:2182024-12-03 11:33:00.390 AM
debug
dev:2182024-12-03 11:33:00.388 AM
debug
dev:2182024-12-03 11:32:57.733 AM
info
dev:2182024-12-03 11:32:57.732 AM
debug
dev:2182024-12-03 11:32:57.730 AM
debug
dev:2182024-12-03 11:32:56.736 AM
info
dev:2182024-12-03 11:32:56.734 AM
debug
dev:2182024-12-03 11:32:56.733 AM
debug
dev:2182024-12-03 11:32:53.998 AM
info
dev:2182024-12-03 11:32:53.996 AM
debug
dev:2182024-12-03 11:32:53.995 AM
debug
dev:2182024-12-03 11:32:52.996 AM
info
dev:2182024-12-03 11:32:52.995 AM
debug
dev:2182024-12-03 11:32:52.993 AM
debug
dev:2182024-12-03 11:32:50.224 AM
info
dev:2182024-12-03 11:32:50.222 AM
debug
dev:2182024-12-03 11:32:50.221 AM
debug
dev:2182024-12-03 11:32:49.222 AM
info
dev:2182024-12-03 11:32:49.220 AM
debug
dev:2182024-12-03 11:32:49.219 AM
debug
dev:2182024-12-03 11:32:46.258 AM
info
Landing Lights button 3 was pushed
dev:2182024-12-03 11:32:46.257 AM
debug
Landing Lights catchall descMap: [raw:catchall: 0104 0006 03 01 0040 00 3FBE 01 00 0000 FD 00 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:3FBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:FD, direction:00, data:[00]]
dev:2182024-12-03 11:32:46.255 AM
debug
Landing Lights description is catchall: 0104 0006 03 01 0040 00 3FBE 01 00 0000 FD 00 00
dev:2182024-12-03 11:32:45.274 AM
info
dev:2182024-12-03 11:32:45.272 AM
debug
dev:2182024-12-03 11:32:45.271 AM
debug
dev:2182024-12-03 11:32:42.102 AM
info
dev:2182024-12-03 11:32:42.101 AM
debug
dev:2182024-12-03 11:32:42.071 AM
debug
dev:2182024-12-03 11:32:41.079 AM
info
dev:2182024-12-03 11:32:41.077 AM
debug
dev:2182024-12-03 11:32:41.076 AM
debug
dev:2182024-12-03 11:32:38.067 AM
info
dev:2182024-12-03 11:32:38.066 AM
debug
dev:2182024-12-03 11:32:38.064 AM
debug
dev:2182024-12-03 11:32:37.072 AM
info
dev:2182024-12-03 11:32:37.070 AM
debug
dev:2182024-12-03 11:32:37.069 AM
debug
dev:2182024-12-03 11:32:34.562 AM
info
dev:2182024-12-03 11:32:34.561 AM
debug
dev:2182024-12-03 11:32:34.559 AM
debug
dev:2182024-12-03 11:32:33.567 AM
info
dev:2182024-12-03 11:32:33.565 AM
debug
dev:2182024-12-03 11:32:33.564 AM
debug
dev:2182024-12-03 11:32:31.137 AM
info
dev:2182024-12-03 11:32:31.136 AM
debug
dev:2182024-12-03 11:32:31.134 AM
debug
dev:2182024-12-03 11:32:30.099 AM
info
dev:2182024-12-03 11:32:30.098 AM
debug
dev:2182024-12-03 11:32:30.097 AM
debug
dev:2182024-12-03 11:32:26.359 AM
info
dev:2182024-12-03 11:32:26.357 AM
debug
dev:2182024-12-03 11:32:26.356 AM
debug
dev:2182024-12-03 11:32:25.367 AM
info
dev:2182024-12-03 11:32:25.365 AM
debug
dev:2182024-12-03 11:32:25.363 AM
debug
dev:2182024-12-03 10:51:30.025 AM
debug
Landing Lights deviceHealthCheck - online (notPresentCounter=1)
dev:2182024-12-03 10:14:30.420 AM
info
dev:2182024-12-03 10:14:30.419 AM
debug
dev:2182024-12-03 10:14:30.418 AM
debug
dev:2182024-12-03 10:14:29.422 AM
info
dev:2182024-12-03 10:14:29.421 AM
debug
dev:2182024-12-03 10:14:29.420 AM
debug
dev:2182024-12-03 10:14:26.668 AM
info
dev:2182024-12-03 10:14:26.667 AM
debug
dev:2182024-12-03 10:14:26.666 AM
debug
dev:2182024-12-03 10:14:25.738 AM
info
dev:2182024-12-03 10:14:25.735 AM
debug
dev:2182024-12-03 10:14:25.734 AM
debug
dev:2182024-12-03 10:14:15.108 AM
info
dev:2182024-12-03 10:14:15.106 AM
debug
dev:2182024-12-03 10:14:15.105 AM
debug
dev:2182024-12-03 10:14:14.112 AM
info
dev:2182024-12-03 10:14:14.110 AM
debug
dev:2182024-12-03 10:14:14.109 AM
debug
dev:2182024-12-03 10:14:10.867 AM
info
dev:2182024-12-03 10:14:10.865 AM
debug
dev:2182024-12-03 10:14:10.864 AM
debug
dev:2182024-12-03 10:14:09.912 AM
info
dev:2182024-12-03 10:14:09.910 AM
debug
dev:2182024-12-03 10:14:09.909 AM
debug
dev:2182024-12-03 10:13:57.593 AM
info
dev:2182024-12-03 10:13:57.591 AM
debug
dev:2182024-12-03 10:13:57.590 AM
debug
dev:2182024-12-03 10:13:56.653 AM
info
dev:2182024-12-03 10:13:56.651 AM
debug
dev:2182024-12-03 10:13:56.649 AM
debug
dev:2182024-12-03 10:13:43.697 AM
info
dev:2182024-12-03 10:13:43.696 AM
debug
dev:2182024-12-03 10:13:43.694 AM
debug
dev:2182024-12-03 10:13:42.753 AM
info
dev:2182024-12-03 10:13:42.750 AM
debug
dev:2182024-12-03 10:13:42.748 AM
debug
dev:2182024-12-03 10:13:23.862 AM
info
dev:2182024-12-03 10:13:23.860 AM
debug
dev:2182024-12-03 10:13:23.859 AM
debug
dev:2182024-12-03 10:13:22.865 AM
info
dev:2182024-12-03 10:13:22.863 AM
debug
dev:2182024-12-03 10:13:22.862 AM
debug
dev:2182024-12-03 10:13:19.930 AM
info
dev:2182024-12-03 10:13:19.929 AM
debug
dev:2182024-12-03 10:13:19.928 AM
debug
dev:2182024-12-03 10:13:18.981 AM
info
dev:2182024-12-03 10:13:18.979 AM
debug
dev:2182024-12-03 10:13:18.978 AM
debug
dev:2182024-12-03 10:11:30.312 AM
info
dev:2182024-12-03 10:11:30.310 AM
debug
dev:2182024-12-03 10:11:30.309 AM
debug
dev:2182024-12-03 10:11:29.324 AM
info
dev:2182024-12-03 10:11:29.322 AM
debug
dev:2182024-12-03 10:11:29.321 AM
debug
dev:2182024-12-03 10:11:26.472 AM
info
dev:2182024-12-03 10:11:26.471 AM
debug
dev:2182024-12-03 10:11:26.470 AM
debug
dev:2182024-12-03 10:11:25.478 AM
info
dev:2182024-12-03 10:11:25.476 AM
debug
dev:2182024-12-03 10:11:25.474 AM
debug
dev:2182024-12-03 10:11:22.651 AM
info
dev:2182024-12-03 10:11:22.650 AM
debug
dev:2182024-12-03 10:11:22.648 AM
debug
dev:2182024-12-03 10:11:21.653 AM
info
dev:2182024-12-03 10:11:21.652 AM
debug
dev:2182024-12-03 10:11:21.650 AM
debug
dev:2182024-12-03 10:11:19.199 AM
info
dev:2182024-12-03 10:11:19.198 AM
debug
dev:2182024-12-03 10:11:19.196 AM
debug
dev:2182024-12-03 10:11:18.197 AM
info
dev:2182024-12-03 10:11:18.195 AM
debug
dev:2182024-12-03 10:11:18.194 AM
debug
dev:2182024-12-03 10:11:14.987 AM
info
dev:2182024-12-03 10:11:14.985 AM
debug
dev:2182024-12-03 10:11:14.984 AM
debug
dev:2182024-12-03 10:11:14.035 AM
info
dev:2182024-12-03 10:11:14.032 AM
debug
dev:2182024-12-03 10:11:14.030 AM
debug
dev:2182024-12-03 09:17:32.204 AM
info
dev:2182024-12-03 09:17:32.202 AM
debug
dev:2182024-12-03 09:17:32.201 AM
debug
dev:2182024-12-03 09:17:31.211 AM
info
dev:2182024-12-03 09:17:31.210 AM
debug
dev:2182024-12-03 09:17:31.208 AM
debug
dev:2182024-12-03 09:17:27.401 AM
info
dev:2182024-12-03 09:17:27.399 AM
debug
dev:2182024-12-03 09:17:27.398 AM
debug
dev:2182024-12-03 09:17:26.403 AM
info
dev:2182024-12-03 09:17:26.401 AM
debug
dev:2182024-12-03 09:17:26.400 AM
debug
dev:2182024-12-03 09:17:21.149 AM
info
dev:2182024-12-03 09:17:21.147 AM
debug
dev:2182024-12-03 09:17:21.145 AM
debug
dev:2182024-12-03 09:17:20.139 AM
info
dev:2182024-12-03 09:17:20.136 AM
debug
dev:2182024-12-03 09:17:20.135 AM
debug
dev:2182024-12-03 09:17:14.678 AM
info
dev:2182024-12-03 09:17:14.676 AM
debug
dev:2182024-12-03 09:17:14.675 AM
debug
dev:2182024-12-03 09:17:13.681 AM
info
dev:2182024-12-03 09:17:13.679 AM
debug
dev:2182024-12-03 09:17:13.678 AM
debug
dev:2182024-12-03 09:17:08.826 AM
info
dev:2182024-12-03 09:17:08.824 AM
debug
dev:2182024-12-03 09:17:08.823 AM
debug
dev:2182024-12-03 09:17:07.822 AM
info
dev:2182024-12-03 09:17:07.820 AM
debug
dev:2182024-12-03 09:17:07.819 AM
debug
dev:2182024-12-03 09:16:54.623 AM
info
dev:2182024-12-03 09:16:54.586 AM
debug
dev:2182024-12-03 09:16:54.585 AM
debug
dev:2182024-12-03 09:16:53.593 AM
info
dev:2182024-12-03 09:16:53.591 AM
debug
dev:2182024-12-03 09:16:53.590 AM
debug
dev:2182024-12-03 09:16:12.543 AM
debug
Landing Lights updated()
dev:2182024-12-03 09:13:46.821 AM
info
dev:2182024-12-03 09:13:45.817 AM
info
dev:2182024-12-03 09:13:37.941 AM
info
dev:2182024-12-03 09:13:36.944 AM
info
dev:2182024-12-03 09:13:32.655 AM
info
dev:2182024-12-03 09:13:31.721 AM
info
dev:2182024-12-03 09:13:31.719 AM
info
Landing Lights is online
dev:2182024-12-03 09:13:31.683 AM
info
Landing Lights InitializeVars()... fullInit = false
dev:2182024-12-03 09:13:31.679 AM
debug
Landing Lights updating the settings from the current driver version 2.7.2 2024/05/06 11:24 PM to the new version 2.7.4 2024/12/03 7:43 AM
dev:2182024-12-03 07:55:56.032 AM
warn
Landing Lights is offline!
Its taken me a few mins to write this post. I tried it again before clicking Reply and the switch is still working.
I cant explain it
