Mode change sent to keypad multiple times
Using 2.08 and Iris V2 Keypad Device as a virtual.
I've noticed when changing the mode or armstate from a dashboard the 'disarmed' command is sent 3 times, armedNight sent 2 times. Have not tested armHome or armAway.
Is this working as designed?
It likely won't do any harm, but does add substantial system overhead.
Device log follows for disarm.
tagging @mike.maxwell
dev:1952019-03-31 15:39:43.389 infoVirtual Iris Keypad was disarmed [digital]
dev:1952019-03-31 15:39:43.193 tracesendArmResponse- sucess, bin:1, armMode:00 -> armRequest:00, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
dev:1952019-03-31 15:39:43.136 infoVirtual Iris Keypad was disarmed [digital]
dev:1952019-03-31 15:39:42.942 tracesendArmResponse- sucess, bin:1, armMode:00 -> armRequest:00, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
dev:1952019-03-31 15:39:42.897 infoVirtual Iris Keypad was disarmed [digital]
dev:1952019-03-31 15:39:42.697 tracesendArmResponse- sucess, bin:1, armMode:01 -> armRequest:00, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
There are issues mentioned at the bottom of the release notes of the 2.0.9 update relating to arming / disarming v2 keypads. Pretty sure 2.08 had the same.
I just updated to 2.08.109 today. No mention of 2.09 on the settings page.
I'm aware there are some keypad operation issues in 2.08, but it does not mention excessive overhead. That is why I'm bringing this to the developers attention.
There's 3 or 4 threads going about the different issues with the Iris keypads presently.
If you're trying to get their attention, tag mike.maxwell. He's been the one leading work on the keypad issues.
