mmWave presence sensors
Is anyone using reliable mmWave presence sensors available in the UK that are compatible with Hubitat? Preferably not Aqara as I find their stuff keeps disconnecting.
Is Linptech available in the UK? I use several of them.
https://www.amazon.co.uk/Linptech-Presence-Detection-Accuracy-bracket/dp/B0D97MYJ1R
Looks like this one is, I’ve never heard of them but willing to give them a try.
There are 3 drivers available for it -- a native/stock driver, kkossev's mmW driver, and then gassgs forked a skinnier Linptech-specific driver from kkossev's (wider) mmW driver.
This thread is about the forked version, but kkossev links to the wider mmW driver in the first post too.
I myself use kkossev's wider mmW driver as it has some add'l features I like using.
Lots info here, if you haven't seen it.
As @hydro311 and @danabw has stated those threads give a lot of information and are very popular on here. I also use kksossev's wider mmW driver on a couple of mine and then use the native Hubitat Linptech driver on my other other. Kkossev's driver gives more features and allows for more fine tuning which I find helpful in a couple of the applications. That is really the secret to them is to get them tuned in through experimenting as each person's use case is different.
Oh, also if you don't mind the wait check AliExpress for them. On there they are sold under the Moes brand but they are the exact same sensor and will use the exact same drivers. May save you a little coin there. One of my three in use and my backup are Moes brand so I can speak to them specifically.
I'm in the U.S. and use that one. It's pretty decent.
