The new Caseta Occupancy/Vacancy sensors PD-OSENS/PD-VSENS will be the only sensors that will be compatible with the Caseta system. Telnet will not be supported at this time with the sensors. You will also be able to change the timeout to one minute by following the same process as the Radio Power Saver sensors. Hope this helps!
If you have any further questions, please feel free to respond to this email. For immediate assistance please call the number below and refer to the case number in the subject line.
That is correct. At launch, Telnet will not be supported with the Caseta wireless sensors.
If you have any further questions, please feel free to respond to this email. For immediate assistance, please contact our 24/7 support team at 1-888-Lutron1 (588-7661) and refer to the case number on the subject line of this email. Thank you!
I just received a new Caseta Occupancy Sensor from Amazon today. I paired it with my Smart Bridge Pro2, and it works exactly as described above. The hidden 1 minute timeout feature works as shown in the video linked previously by @bertabcd1234. Unfortunately, I do not see anything in the Telnet logs for this sensor. Not a surprise based on the information from @mik3.
In HomeKit, I do not see any sign of the new Caseta Occupancy sensor.
I do have a Caseta plug-in dimmer that I use as a repeater. I may use that one dimmer as means to control a virtual motion sensor in Hubitat...
I feel a bit dense but I don't understand the difference between the Lutron Occupancy sensor and the Lutron Vacancy sensor . . . can someone break it down for me?
It's probably just as you believe. Occupancy sensors will both turn on and off the lights. Vacancy sensors will just turn off the lights. To add a little confusion the Lutron occupancy sensors can be run in vacancy mode. I believe, but may be mistaken, that California sometimes requires (or required) the vacancy only sensors.
They are, but don't report over the Telnet interface. So to work in Hubitat you'd have to rig it like @ogiewon did with a lamp module.
The NYCE Zigbee sensor batteries are supposed to last a long time, up to 5 years. Mine have lasted over a year. They're also smaller than the Lutron sensors and have humidity sensors too.
Oh, I get that. I have several areas where I could just use the Lutron capability as I don't need the extra smarts and configurability that Hubitat brings. I have four Nyce motion sensors and I have never seen anything close to 5 years of battery life with them. Not that I really believe the Lutron will give me 10 but even just several years would be nice. Also, this would allow me to redeploy some zigbee motion sensors to other locations.
The Lutron Caseta occupancy (a.k.a., motion) sensor works great. It has a set of buttons on the back that allow for three time-out settings, three motion-sensitivity settings (low, medium, high), and an auto-on (or not) setting. I set the time-out for five minutes as that pretty much duplicates my old rule. I joined the sensor to the Caseta Pro hub for the basement and, using the app, configured it to turn on the ceiling light in the workshop. I tested that and it worked fine so I added a MirrorMe app on Hubitat so that my work table lights (three 4 foot LED fixtures) will come on when the overhead light comes on (and also switch off when it switches off). Those lights are plugged into a Zooz ZEN06 plug. I can now re-purpose the motion sensors that had been in that room as the Lutron sensor covers the entire area. It responds very quickly - I think more quickly than the old configuration (which had three motion sensors - two zigbee and one z-wave).
