Hello,
installed your modified driver and unfortunately the result is not what we would like it to be.
Here a log from startup and a couple of switch on's.
dev:3152023-01-08 11:57:06.211debugWC_switch Parent switch on
dev:3152023-01-08 11:57:06.181debugWC_switch Parsed: [raw:AA880100060800001001, dni:AA88, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:57:06.170debugWC_switch WC_switch unprocessed EP: 01 cluster: 0006 attrId: null
dev:3152023-01-08 11:57:06.164debugWC_switch Parsed: [raw:catchall: 0104 0006 01 01 0040 00 AA88 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:3152023-01-08 11:57:06.063debugWC_switch sending componentOn 315-01
dev:3152023-01-08 11:53:08.481debugWC_switch Parent switch on
dev:3152023-01-08 11:53:08.469debugWC_switch Parsed: [raw:AA880200060800001001, dni:AA88, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:53:08.461debugWC_switch WC_switch unprocessed EP: 02 cluster: 0006 attrId: null
dev:3152023-01-08 11:53:08.458debugWC_switch Parsed: [raw:catchall: 0104 0006 02 01 0040 00 AA88 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:3152023-01-08 11:53:08.282debugWC_switch sending componentOn 315-02
dev:3152023-01-08 11:53:06.975debugWC_switch Parent switch off
dev:3152023-01-08 11:53:06.961debugWC_switch Parsed: [raw:AA880200060A00001000, dni:AA88, endpoint:02, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:53:06.749debugWC_switch sending componentRefresh 315-02 WC_switch EP02
dev:3152023-01-08 11:52:19.032debugWC_switch Parent switch off
dev:3152023-01-08 11:52:19.019debugWC_switch Parsed: [raw:AA880100060A00001000, dni:AA88, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:52:17.037debugWC_switch WC_switch unprocessed EP: 01 cluster: 0006 attrId: null
dev:3152023-01-08 11:52:17.034debugWC_switch Parsed: [raw:catchall: 0104 0006 01 01 0040 00 AA88 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:3152023-01-08 11:52:15.064debugWC_switch WC_switch unprocessed EP: 00 cluster: 8021 attrId: null
dev:3152023-01-08 11:52:15.061debugWC_switch Parsed: [raw:catchall: 0000 8021 00 00 0040 00 AA88 00 00 0000 00 00 9900, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[99, 00]]
dev:3152023-01-08 11:52:14.966debugWC_switch WC_switch unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:52:14.963debugWC_switch Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:52:14.955debugWC_switch WC_switch unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:52:14.953debugWC_switch Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:52:14.945debugWC_switch WC_switch unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:52:14.939debugWC_switch Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:52:14.930debugWC_switch Parent switch off
dev:3152023-01-08 11:52:14.911debugWC_switch Parsed: [raw:AA880200060A00001000, dni:AA88, endpoint:02, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:52:14.896debugWC_switch Parent switch off
dev:3152023-01-08 11:52:14.822debugWC_switch Parsed: [raw:AA880100060A00001000, dni:AA88, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:52:14.588debugWC_switch WC_switch unprocessed EP: null cluster: null attrId: 0004
dev:3152023-01-08 11:52:14.584debugWC_switch Parsed: [raw:AA8801000068040042105F545A333030305F66766833706A617A0000002003010000204105000042065453303031320700003003FEFF003000, dni:AA88, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_fvh3pjaz, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:41, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0012, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:3152023-01-08 11:52:14.568debugWC_switch sending componentRefresh 315-02 WC_switch EP02
dev:3152023-01-08 11:52:14.504infoWC_switch Creatung device 315-02
dev:3152023-01-08 11:52:14.496debugWC_switch sending componentRefresh 315-01 WC_switch EP01
dev:3152023-01-08 11:52:14.421infoWC_switch Creatung device 315-01
dev:3152023-01-08 11:52:14.418debugWC_switch Parent createChildDevices
dev:3152023-01-08 11:52:14.416debugWC_switch model: TS0012 buttons: 2
dev:3152023-01-08 11:52:14.412debugWC_switch Parent deleteChildren
dev:3152023-01-08 11:52:14.411debugWC_switch Parent setupChildDevices
dev:3152023-01-08 11:52:14.403debugWC_switch sendZigbeeCommands : [he raw 0xAA88 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xAA88 0x01 0x01 6 {540F57FFFE773EBA} {}, delay 2000, he cr 0xAA88 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xAA88 0x01 6 0 {}, delay 2000]
dev:3152023-01-08 11:52:14.389debugWC_switch configure()..
dev:3152023-01-08 11:52:14.387infoWC_switch InitializeVars()... fullInit = true
dev:3152023-01-08 11:52:14.386debugWC_switch Initializing...
dev:3152023-01-08 11:52:11.782warnWC_switch Child device 315-01 not found. Initialise parent device first
dev:3152023-01-08 11:52:11.780debugWC_switch Parsed: [raw:AA880100060A00001000, dni:AA88, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:52:09.793debugWC_switch WC_switch unprocessed EP: 01 cluster: 0006 attrId: null
dev:3152023-01-08 11:52:09.790debugWC_switch Parsed: [raw:catchall: 0104 0006 01 01 0040 00 AA88 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:3152023-01-08 11:52:07.848debugWC_switch WC_switch unprocessed EP: 00 cluster: 8021 attrId: null
dev:3152023-01-08 11:52:07.845debugWC_switch Parsed: [raw:catchall: 0000 8021 00 00 0040 00 AA88 00 00 0000 00 00 9000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[90, 00]]
dev:3152023-01-08 11:52:07.838debugWC_switch WC_switch unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:52:07.832debugWC_switch Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:52:07.812debugWC_switch WC_switch unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:52:07.809debugWC_switch Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:52:07.596debugWC_switch WC_switch unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:52:07.593debugWC_switch Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:52:07.586debugWC_switch WC_switch unprocessed EP: null cluster: null attrId: 0004
dev:3152023-01-08 11:52:07.582debugWC_switch Parsed: [raw:AA8801000068040042105F545A333030305F66766833706A617A0000002003010000204105000042065453303031320700003003FEFF003000, dni:AA88, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_fvh3pjaz, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:41, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0012, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:3152023-01-08 11:52:07.230debugWC_switch sendZigbeeCommands : [he raw 0xAA88 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xAA88 0x01 0x01 6 {540F57FFFE773EBA} {}, delay 2000, he cr 0xAA88 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xAA88 0x01 6 0 {}, delay 2000]
dev:3152023-01-08 11:52:07.220debugWC_switch configure()..
dev:3152023-01-08 11:51:31.225warnZemismart ZigBee Wall Switch Multi-Gang Child device 315-01 not found. Initialise parent device first
dev:3152023-01-08 11:51:31.222debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:AA880100060A00001000, dni:AA88, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:3152023-01-08 11:51:30.995debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: null cluster: null attrId: FFDF
dev:3152023-01-08 11:51:30.992debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:AA880100001CDFFF420A0A4E4D2B139B4E4D2B12, dni:AA88, endpoint:01, cluster:0000, size:1C, attrId:FFDF, encoding:42, command:0A, value:
NM+NM+, clusterInt:0, attrInt:65503]
dev:3152023-01-08 11:51:30.430debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: null cluster: null attrId: 0001
dev:3152023-01-08 11:51:30.425debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:AA880100001801002041E2FF201FE4FF2000, dni:AA88, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:41, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:3152023-01-08 11:51:29.368debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0006 attrId: null
dev:3152023-01-08 11:51:29.364debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0104 0006 01 01 0040 00 AA88 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:3152023-01-08 11:51:27.652warnZemismart ZigBee Wall Switch Multi-Gang Child device 315-02 not found. Initialise parent device first
dev:3152023-01-08 11:51:27.647debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:AA880200061C0000100001402100000240210000, dni:AA88, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:3152023-01-08 11:51:27.547warnZemismart ZigBee Wall Switch Multi-Gang Child device 315-01 not found. Initialise parent device first
dev:3152023-01-08 11:51:27.538debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:AA880100062C00001000014021000002402100000180300102803000, dni:AA88, endpoint:01, cluster:0006, size:2C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770]]]
dev:3152023-01-08 11:51:27.323debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8021 attrId: null
dev:3152023-01-08 11:51:27.319debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0000 8021 00 00 0040 00 AA88 00 00 0000 00 00 8200, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[82, 00]]
dev:3152023-01-08 11:51:27.311debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:51:27.308debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:51:27.300debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:51:27.295debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:51:27.049debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
dev:3152023-01-08 11:51:27.045debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0104 0000 01 01 0040 00 AA88 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AA88, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:3152023-01-08 11:51:27.037debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: null cluster: null attrId: 0004
dev:3152023-01-08 11:51:27.031debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:AA8801000068040042105F545A333030305F66766833706A617A0000002003010000204105000042065453303031320700003003FEFF003000, dni:AA88, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_fvh3pjaz, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:41, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0012, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:3152023-01-08 11:51:27.024infoZemismart ZigBee Wall Switch Multi-Gang InitializeVars()... fullInit = false
dev:3152023-01-08 11:51:27.021debugZemismart ZigBee Wall Switch Multi-Gang updating the settings from the current driver version null to the new version 0.2.14 2022/11/23 6:47 PM
dev:3152023-01-08 11:51:26.700debugZemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands : [he raw 0xAA88 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0xAA88 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xAA88 0x01 0x01 6 {540F57FFFE773EBA} {}, delay 2000, he cr 0xAA88 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xAA88 0x01 6 0 {}, delay 2000]
dev:3152023-01-08 11:51:26.665debugZemismart ZigBee Wall Switch Multi-Gang configure()..
dev:3152023-01-08 11:51:26.658debugZemismart ZigBee Wall Switch Multi-Gang Parent installed
The on/off status is updated automatically in HE but it seems that the switch-off event that still happens is not shown in the logs. I tried both switching on from HE and manually at the switch. Result is same for both.
One strange thing I've noticed (with original driver) is that sometimes one of the child switches has been staying on successfully when manually set to on state. This is child switch EP2. Behind this switch is only a couple of LED light => very low load. Wondering if this could be something that influences the behavior... Perhaps not but it's an observation so I wanted to let you know.
So, answers to your questions:
- It still switches off
- I do see in HE the status (looking on device page) also without refresh when actuated manually.
