Three months ago I was totally cloud dependent. Today is a milestone for my home...between the websockets Harmony integration and the new Centralite Pearl thermostat I just finished installing, I'm off the cloud! (not counting Google Home, push notifications, or mobile presence since those are cloud-dependent by nature )
SmartThings -> Hubitat
webCoRE -> Rule Machine
MyQ -> Local control with a relay and a ported smartapp
Honeywell TCC -> Centralite Thermostat with Thermostat Scheduler
Harmony Cloud -> @ogiewon websockets integration
Google Assistant Relay -> native Chromecast integration
TP-Link Kasa outlets -> Iris zigbee outlets
Thanks to all of the Hubitat staff and community devs for your work, couldn't be happier to be a part of this community
Congratulations! It is amazing how far Hubitat Elevation has come in such a short time. Great product, great development/support team, and a great community!
Forgot to add, my Raspberry Pi is sitting unused now too, at one point on ST I was running 5 different node.js apps to translate between ST and various other things. Even better that everything I'm using now runs exclusively on the HE hub
Seeing this thread prompted me to finish swapping out 2 tp-link in-wall switches with jasco zigbees. This leaves 2 Broadlink IR mini blasters, then I'm off the (Chinese) cloud.
Recommendation: Upgrade is not required until you add (in the future) a new device type. However, the significant advantages are that the new integration is off the cloud and does not require a separate node.js server.
Generally, the upgrade instructions are relatively simple:
a. Replace the contents of the existing driver and (if applicable) application.
b. If you have an application, Run the application (this will update some of the data elements.
c. For each device:
1. Set the Bulb Preference "Default transition Time" to a desired value.
2. Set the Bulb Preference "Hue" to Low Rez.
3. For each device, "Save" the preferences.
