Hubitat Elevation Software update 1.1.0 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.0.9:
Additions / Changes
- timeOfDayIsBetween() method is now available to use in device driver code
- added app.clearSetting() which applies defaultValues without the need to use removeSetting()
- Added support for “capability” input elements and simple multi enum values ( [1,2,3] vs '["1","2","3"]' ) to app.updateSetting()
- added getChildAppByLabel() and getChildAppById() methods for parent Apps
- Added sendHubCommand() method for device driver code.
- Added multiinstancev1.MultiInstanceCmdEncap method
- Added encrypt(), decrypt() methods
- Added runEvery1Minute() method
- Added hub.localIP and hub.localSrvPortTCP properties
- Removed unintended/unused lockCode commands
- Added the following Capabilities:
- securityKeypad capability
- releaseableButton capability
- changeLevel capability (start and stop level change commands)
- colorMode capability (tracks RGB vs CT mode in RGBW capable devices)
- add filterStatus capability
- add pressureMeasurement capability
- Added driver for Orbit Iris Hose Faucet Water Timer
- Added driver for Aeotec Recessed Door Sensor (DS854-ZWUS)
- Added driver for Somfy 2 button controller
- Added driver for Zooz Motion Sensor (ZSE02)
- Added driver for Zooz Motion Sensor (ZSE18)
- Added driver for Zooz Power Switch (ZEN15)
- Added driver for Zooz Smart Plug (ZEN06)
- Added driver for Hank RGBW Bulb
- Added driver for Ecolink Smoke/CO Audio Detector (FF-ZWAVE5)
- Added driver for Generic Z-Wave Smoke/CO Detector
- Added driver for Generic Z-Wave Smoke Detector
- Added driver for First Alert Smoke/CO Alarm (ZCOMBO)
- Added driver for Everspring Smoke Detector (SF813)
- Added driver for Wireless Smoke Detector (ZWN-SD)
- Added driver for WaterCop Shut-Off Valve
- Added driver for Remotec zrc 90 8 button controller
- Added Virtual Thermostat driver
- Changes to Aeon Labs Doorbell driver, implemented Audio Volume and removed volume setting and improved reliability when joined secure.
- Changes to Life360 App, added refresh virtual device
- Added support for weather device with data from openweathermap.org
- Hubitat Dashboard added support for PIN code in Advanced
- Hubitat Dashboard added support for disabling cloud and/or local access
- Hubitat Dashboard added new menu for cloud and local links
- Hubitat Dashboard added valve tile template
- Added Alexa Skill Support (Alexa Skill Documentation )
Bug Fixes
- Added check for duplicate when adding new mode
- Fixed issue where hub may not reconnect after internet connection is lost
- Added warning message when a duplicate Device Network Id is entered on device screen
- Fixed 404 error in apps that use refreshInterval on Safari for Mac
- HubAction handles responses for image contentTypes
- Fixed duplicate commands bug in device detail view
- Fixed Z-Wave association reports v1 and v2
- Fixed issue on delete of app all the subscriptions for that installed app are now deleted
- Validate IP addresses entered in Hub Link App
- Fixed mode change bug in Zen Thermostat and Centralite Thermostat drivers
- Fixed bug in Remotec zrc-90
- Fixed Fibaro Motion Sensor ZW5 driver, improved reliability of configuration changes and refreshing sensor values, added doubleTap as a trigger event
