This isn't correct. All of the commands are being sent. What I was asking wasn't about the Scene device, but about the bulb device. The setColor command sends all of the values in a single command, and this is what Scene-1.2 uses. I suspect your first idea about the bulb not keeping up may be right, although I don't know for sure. The idea was to test the setColor command on the bulb device page.
I use a work around with "Simple Automation Rules" for cloning the group device to the real device but sometimes there is a different status between the real device and the group device....
I have done some investigations about issues specifically around Scenes and color bulbs. What I see is that setting a scene results in that two Driver functions are called in rapid succession in the device Driver, first the setColor message, and then the setLevel message.
The problem I see is that is seems that the bulb is missing the setLevel message, I guess the bulb is busy handling the previous message. I was wondering if bulking together the zigbee messages in a List state.cmds variable, and then using a runIn(...,...) function to pass the actual zigbee message to the bulb could do the trick. I haven't tested this, but have anyone tried this with a driver?
When Scene-1.2 sets a color bulb it sends a single command to the driver with hue, sat and level in the command -- the command is setColor(hue, sat, level, rate).
Any chance we can get groups for other device types? In my case, I have curtains grouped together. I had to select them as dimmers in this app. The only issue with that is that within Alexa, I can't use the regular curtain commands e.g. "open curtains" or "open curtains to 45%". I have to say "dim curtains to 45%". Controlling the individual curtain works fine though in Alexa.
I have a little issue with my scene, it activates if one of my devices in the scene activates. Is this how it is supposed to work?
My scene is simple:
Set Denon AVR to on
Set Denon AVR to Chromecast input
Turn off Family room lights.
When I turn off the scene, I have a rule (scene turns off trigger) to turn on the family room lights.
However, if I just turn on the Denon AVR (without activating the scene) the scene becomes active and if I turn it off it turns off the scene, which turns on the lights (not intended). I would have thought that I could use devices individually outside the scene and only activate the scene when I wanted that intended behaviour.
What do you mean by the Scene becoming active when you turn on the Denon AVR? Does turning it on cause the Kitchen Nook to turn off ? Your Scene only shows those two devices.
I could try that out. Usually when I turn on Denon AVR (device only)
the light is already off. I notice in my dashboard when I turn on Denon AVR, that the Scene activator turns to on, and then turns to off when I turn off the Denon AVR. This triggers my rule to turn the Kitchen nook light back on after the scene turns off (which I want evenings when I'm done watching a movie. Give me a sec and I'll check out the light being on 1st.
Ok interesting...If the Kitchen nook light is on 1st and I turn on the Denon AVR, the scene doesn't activate and the light doesn't turn off. So, only if all the devices that are in the scene are set the way the scene is does the scene go to active...and thus when one of them deactivates then the scene is turned off.
So specifically:
Case 1:
Movie Night Scene = Off
Kitchen nook light = on
Denon AVR = Off
Transition Denon AVR to On
Scene = Off
Transition Denon AVR to OFF
Scene = Off
But:
Case 2:
Movie Night Scene = off
Kitchen nook = off
Denon Avr = Off
Transition Denon AVR = On
Movie Night Scene Tranistions to ON (likely because all the devices match that state).
Transition Denon AVR to Off
Movie Night scene transitions to Off.
