Nope. All you have to do is install and run and then go to http://IP-ADDRESS:3000/assistant/setup and it will guide you through authorizing Google Assistant API in order to use Broadcasts. It will then create a parent device called cast-web-api and it will have child devices for all of your google home devices you selected within the app. I would advise using the following modified drivers. They allow for the Device Notification capability which for the Cast-web device results in a broadcast or from the individual devices results in a cast to the individual device.
The device also allows for the music player capability to play tracks of mp3 files from accessible website or online storage (github).
Cast-web-API
* cast-web-api
* Copyright 2018 Tobias Haerke
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
preferences {
input("configLoglevel", "enum", title: "Log level?",
required: false, multiple:false, value: "nothing", options: ["0","1","2","3","4"])
input("syncNamesFromAPI", "bool", title: "Don't sync cast-device names from API?", required: false)
metadata {
definition (name: "cast-web-api", namespace: "vervallsweg", author: "Tobias Haerke") {
capability "Actuator"
capability "Audio Notification"
capability "Refresh"
capability "Speech Synthesis"
capability "Notification"
command "checkAssistant"
command "checkVersion"
command "setApiHost", ["string"]
command "delayedNotification", ["string","number"]
simulator {
// TODO: define status and reply messages here
String mphrase = 'phrase'
// parse events into attributes
//er('debug', "Parsing: "+description)
def message = parseLanMessage(description)
def children = getChildDevices()
logger('debug', "Parsing json: "+message.json + ", status"+message.status)
if(message.json) {
if(message.json.id) {
def foundTarget = false;
children.each { child ->
if ( child.deviceNetworkId == message.json.id ){
foundTarget = true;
logger('debug', "Parsing found target name: "+child.displayName+", dni: "+child.deviceNetworkId)
if(message.json.name) {
if(settings.syncNamesFromAPI != true) {
child.displayName = message.json.name
//if(message.json.connection) { //WTF: cannot be set by dev?!
// if( message.json.connection.equals("connected") ) {
// child.status = "ONLINE"
// if( message.json.connection.equals("disconnected") ) {
// child.status = "OFFLINE"
child.parse(description)
if(!foundTarget) {
logger('error', "Parsing found no target for: "+message.json.id)
if(message.json.api) {
if(message.json.api.version) {
if (message.json.api.version.this && message.json.api.version.latest) {
sendEvent(name: "updateStatus", value: ("Current: "+ message.json.api.version.this + "\nLatest: " + message.json.api.version.latest), displayed: false)
if(message.json.containsKey("assistant") && message.json.containsKey("ready")) {
logger('debug', "containsKey")
sendEvent(name: "assistantStatus", value: ("Assistant: "+ message.json.assistant + "\nready: " + message.json.ready + "\nIf you never used Google Assistant with cast-web go to service manager > Setup Google Assistant"), displayed: false)
def installed() {
installDevices( parseListFromString( getDataValue("devices") ) )
sendEvent(name: "updateStatus", value: "Click to check for updates", displayed: false)
def updated() {
def refresh() {
unschedule(refreshAll)
refreshAll()
runEvery5Minutes(refreshAll)
def refreshAll() {
def hub = location.hubs[0];
//sendHttpRequest("GET", getDataValue("apiHost"), "/device", '');
sendHttpRequest("POST", getDataValue("apiHost"), "/callback", '[{"url":"'+hub.localIP+':'+hub.localSrvPortTCP+'", "settings":""}]');
getChildDevices().each{child -> child.refresh()}
def installDevices(ids) {
def devicesToCreate = []
logger('debug', "installDevices() children: " + children.size() + ", ids: " + ids)
ids.each { id ->
def exists = false
if( id.equals( child.deviceNetworkId ) ) { //id has a nbsp added to the front
exists = true
if (exists) {
logger('debug', "installDevices() id: "+id+", exists!")
} else {
logger('warn', "installDevices() id: "+id+", doesn't exist")
devicesToCreate.add(id)
logger('debug', "installDevices() devicesToCreate: "+devicesToCreate)
createDevices(devicesToCreate)
def createDevices(ids) {
logger('debug', "createDevices() ids: " + ids)
ids.each {
if(it!=null&&it!="") {
logger('debug', "createDevices() adding id: " + it)
addChildDevice("vervallsweg", "cast-web-device", it, ["apiHost": getDataValue("apiHost")])
def parseListFromString(string) {
string = string.replace("[", "").replace("]", "").replace(" ", "")
def list = string.split(',').collect{it as String}
logger('debug', 'parseListFromString(), string: '+string+', list: ' + list)
return list
def checkVersion() {
sendHttpRequest("GET", getDataValue("apiHost"), "/config", "");
//sendHttpTest(getDataValue("apiHost"), "/config")
def checkAssistant() {
sendHttpRequest("GET", getDataValue("apiHost"), "/assistant", "");
def speak(phrase) {
logger('info', "speak(), phrase: " + phrase)
sendHttpRequest("POST", getDataValue("apiHost"), "/assistant/broadcast/", '{"message":"'+phrase+'"}');
def playText(message, level = 0, resume = false) {
logger('info', "playText, message: " + message + " level: " + level)
return speak(message)
def playTextAndResume(message, level = 0, thirdValue = 0) {
logger('info', "playTextAndResume, message: " + message + " level: " + level)
def playTextAndRestore(message, level = 0, thirdValue = 0) {
logger('info', "playTextAndRestore, message: " + message + " level: " + level)
def setApiHost(apiHost) {
log.warn "apiHost: "+apiHost
logger('info', 'setApiHost(), to: '+apiHost)
updateDataValue("apiHost", apiHost)
child.updateDataValue("apiHost", apiHost)
def sendHttpRequest(String method, String host, String path, def body="") {
logger('debug', "Executing 'sendHttpRequest' method: "+method+" host: "+host+" path: "+path+" body: "+body)
def bodyHead = "";
if(!body.equals("")) {
bodyHead = "Content-Type: application/json\r\nContent-Length:${body.length()+1}\r\n";
body = " "+body;
sendHubCommand(new hubitat.device.HubAction("""${method} ${path} HTTP/1.1\r\nHOST: $host\r\n${bodyHead}\r\n${body}""", hubitat.device.Protocol.LAN, host))
//DEBUGGING
def logger(level, message) {
def logLevel=1
if(settings.configLoglevel) {
logLevel = settings.configLoglevel.toInteger() ?: 0
if(level=="error"&&logLevel>0) {
log.error message
if(level=="warn"&&logLevel>1) {
log.warn message
if(level=="info"&&logLevel>2) {
log.info message
if(level=="debug"&&logLevel>3) {
log.debug message
def deviceNotification(phrase){
speak(phrase)
def delayedNotification(phrase,delay){
delay = (delay.toInteger())*60
mphrase = phrase
runIn (delay, delayedSpeak)
def delayedSpeak(){
speak(mphrase)
Cast-web-Device
* cast-web-device
* Copyright 2017 Tobias Haerke
import org.json.JSONObject
preferences {
input("configOn", "enum", title: "Switch on does?",
required: false, multiple:false, value: "nothing", options: ["Play","Pause","Stop","Play preset 1","Play preset 2","Play preset 3","Play preset 4","Play preset 5","Play preset 6"])
input("configOff", "enum", title: "Switch off does?",
input("configNext", "enum", title: "Next song does?",
required: false, multiple:false, value: "nothing", options: ["Play","Pause","Stop","Next preset","Previous preset","Play preset 1","Play preset 2","Play preset 3","Play preset 4","Play preset 5","Play preset 6"])
input("configPrev", "enum", title: "Previous song does?",
input("configResume", "enum", title: "Resume/restore (if nothing was playing before) plays preset?",
required: false, multiple:false, value: "nothing", options: ["1","2","3","4","5","6"])
required: false, multiple:false, value: "0", options: ["0","1","2","3","4"])
input("halt", "bool", title: "Stop after TTS?", required: false)
input("googleTTS", "bool", title: "Use Google's TTS voice?", required: false)
input("googleTTSLanguage", "enum", title: "Google TTS language?",
required: false, multiple:false, value: "nothing", options: ["cs-CZ","da-DK","de-DE","en-AU","en-CA","en-GH","en-GB","en-IN","en-IE","en-KE","en-NZ","en-NG","en-PH","en-ZA","en-TZ","en-US","es-AR","es-BO","es-CL","es-CO","es-CR","es-EC","es-SV","es-ES","es-US","es-GT","es-HN","es-MX","es-PA","es-PY","es-PE","es-PR","es-DO","es-UY","es-VE","eu-ES","fr-CA","fr-FR","it-IT","lt-LT","hu-HU","nl-NL","nb-NO","pl-P","pt-BR","pt-PT","ro-RO","sk-SK","sl-SI","fi-FI","sv-SE","ta-IN","vi-VN","tr-TR","el-GR","bg-BG","ru-RU","sr-RS","he-IL","ar-AE","fa-IR","hi-IN","th-TH","ko-KR","cmn-Hant-TW","yue-Hant-HK","ja-JP","cmn-Hans-HK","cmn-Hans-CN"])
metadata {
definition (name: "cast-web-device", namespace: "vervallsweg", author: "Tobias Haerke") {
capability "Music Player"
capability "Polling"
capability "Switch"
capability "Switch Level"
//capability "Health Check" //TODO: Implement health check
command "checkForUpdate"
simulator {
// Device handler states
def installed() {
logger('debug', "Executing 'installed'")
log.debug "installed"
//Preset, update-status tiles
refresh()
sendEvent(name: "updateStatus", value: ("Version "+getThisVersion() + "\nClick to check for updates"), displayed: false)
parsePresets()
refresh() //If callback exists already
def updated() {
logger('debug', "Executing 'updated'")
log.debug "updated"
refresh()
parsePresets()
def refresh() {
apiCall('/', true)
try {
logger('debug', "'parse', parsing: '${description}'")
def msg = parseLanMessage(description)
logger('debug', 'parse, msg.json: ' + msg.json)
if(msg.json!=null){
if(!msg.json.response) {
if(msg.json.status) {
setTrackData(msg.json.status)
generateTrackDescription()
if(msg.json.connection) {
logger('debug', "msg.json.connection: "+msg.json.connection)
sendEvent(name: "connection", value: msg.json.connection, displayed:false)
} else if( !msg.json.response.equals('ok') ) {
logger('error', "json response not ok: " + msg.json)
} catch (e) {
logger('error', "Exception caught while parsing data: "+e) //TODO: Health check
// handle commands
def play() {
logger('debug', "Executing 'play'")
apiCall('/play', true);
def pause() {
logger('debug', "Executing 'pause'")
apiCall('/pause', true);
def stop() {
logger('debug', "Executing 'stop'")
apiCall('/stop', true);
def nextTrack() {
logger('debug', "Executing 'nextTrack' encode: ")
selectableAction(settings.configNext)
def previousTrack() {
logger('debug', "Executing 'previousTrack'")
selectableAction(settings.configPrev)
def setLevel(level,duration=null) {
logger('debug', "Executing 'setLevel', level: " + level)
double lvl
try { lvl = (double) level; } catch (e) {
lvl = Double.parseDouble(level)
if( lvl == device.currentValue("level") ){
logger('debug', "Setting group level: " + level)
apiCall('/volume/'+lvl+'/group', true)
return
apiCall('/volume/'+lvl, true)
runIn(2, refresh)
def mute() {
logger('debug', "Executing 'mute'")
apiCall('/muted/true', true)
def unmute() {
logger('debug', "Executing 'unmute'")
apiCall('/muted/false', true)
def setTrack(trackToSet) {
logger('debug', "Executing 'setTrack'")
return playTrack(trackToSet)
def resumeTrack(trackToSet) {
logger('debug', "Executing 'resumeTrack'")
def restoreTrack(trackToSet) {
logger('debug', "Executing 'restoreTrack'")
def on() {
logger('debug', "Executing 'on'")
selectableAction(settings.configOn)
def off() {
logger('debug', "Executing 'off'")
selectableAction(settings.configOff ?: 'Stop')
def speak(phrase, resume = false) {
if(settings.googleTTS && settings.googleTTSLanguage){
if(settings.googleTTS==true) {
return playTrack( phrase, 0, 0, true, settings.googleTTSLanguage )
//return playTrack( textToSpeech(phrase, true).uri, 0, 0, true )
return playTrack( textToSpeech(phrase.replaceAll("%20"," ")).uri, 0, 0, true )
//AUDIO NOTIFICATION, TEXT
def playText(message, level, resume = false) {
if (level!=0&&level!=null) { setLevel(level) }
return speak(message, true)
playText(message, level, true)
def playTextAndRestore(phrase, volume) {
def oldlevel = level
setLevel(volume)
//TODO: Reset level to level before the message was played
runIn (10,setLevel (oldlevel))
def playTrackAtVolume(trackToPlay, level = 0) {
logger('info', "playTrackAtVolume" + trackToPlay)
def url = "" + trackToPlay;
return playTrack(url, level)
//AUDIO NOTIFICATION, TRACK
def playTrack(uri, level = 0, thirdValue = 0, resume = false, googleTTS = false) {
if (halt){
runIn(20,stop)
logger('info', "Executing 'playTrack', uri: " + uri + " level: " + level + " resume: " + resume)
def data = '{ "mediaType":"audio/mp3", "mediaUrl":"'+uri+'", "mediaStreamType":"BUFFERED", "mediaTitle":"Hubitat", "mediaSubtitle":"Hubitat playback", "mediaImageUrl":"https://raw.githubusercontent.com/ryancasler/Hubitat_Ryan/master/Icons/Icon4.png"}'
if(googleTTS) {
data = '{ "mediaType":"audio/mp3", "mediaUrl":"", "mediaStreamType":"BUFFERED", "mediaTitle":"'+uri+'", "mediaSubtitle":"Hubitat notification", "mediaImageUrl":"https://raw.githubusercontent.com/ryancasler/Hubitat_Ryan/master/Icons/Icon4.png", "googleTTS":"'+googleTTS+'"}'
if(resume) {
def number = 0
JSONObject preset = null
if(settings.configResume) { number = settings.configResume }
if(getTrackData(['preset'])[0]) { number = getTrackData(['preset'])[0] }
log.warn 'number: '+number
if(number > 0) {
preset = getPresetObject(number)
if (preset) {
preset.each {
data = data + ', '+it.toString()
//data = data + ', '+preset.toString()
data = "["+data+"]"
log.warn 'playTrack() data: '+data
return setMediaPlaybacks(data)
def playTrackAndResume(uri, level = 0) {
logger('info', "Executing 'playTrackAndResume', uri: " + uri + " level: " + level)
return playTrack(uri, level, 0, true)
def playTrackAndRestore(uri, level = 0) {
logger('info', "Executing 'playTrackAndRestore', uri: " + uri + " level: " + level)
//TODO: Reset level to level before the track was played
def playTrackAndRestore(String uri, String duration, level = 0) {
logger('info', "Executing 'playTrackAndRestore', uri: " + uri + " duration: " + duration + " level: " + level)
def generateTrackDescription() {
def trackDescription = getTrackData(["title"])[0] + "\n" + getTrackData(["application"])[0] + "\n" + removePresetMediaSubtitle(getTrackData(["subtitle"])[0])
logger('debug', "Executing 'generateTrackDescription', trackDescription: "+ trackDescription)
sendEvent(name: "trackDescription", value: trackDescription, displayed:false)
def setTrackData(newTrackData) {
JSONObject currentTrackData = new JSONObject( device.currentValue("trackData") ?: "{}" )
logger('debug', "setTrackData() currentTrackData: "+currentTrackData+", newTrackData: "+newTrackData)
def changed = false
newTrackData.each { key, value ->
if(key=='connection'||key=='volume'||key=='muted'||key=='application'||key=='status'||key=='title'||key=='subtitle'||key=='image'||key=='preset'||key=='groupPlayback') {
if(currentTrackData.has(key)) {
if(currentTrackData.get(key)==value) { return }
currentTrackData.put(key, value); changed=true;
if(currentTrackData.has('volume')) {
sendEvent(name: "level", value: currentTrackData.get('volume'), unit: "%", changed: true)
if(currentTrackData.has('muted')) {
if(currentTrackData.get('muted')) {
sendEvent(name: "mute", value: "muted", changed: true)
} else {
sendEvent(name: "mute", value: "unmuted", changed: true)
if(currentTrackData.has('status')) {
if( currentTrackData.get('status').equals("PLAYING") || currentTrackData.get('status').equals("PAUSED") ) {
if( currentTrackData.has('groupPlayback') ) {
if( currentTrackData.get('groupPlayback') ) {
sendEvent(name: "status", value: 'group', changed: true)
sendEvent(name: "switch", value: on, displayed: false)
} else {
sendEvent(name: "status", value: currentTrackData.get('status').toLowerCase(), changed: true)
} else {
} else if( currentTrackData.get('application').equals("") || currentTrackData.get('application').equals("Backdrop") ) {
sendEvent(name: "status", value: "ready", changed: true)
sendEvent(name: "switch", value: off, displayed: false)
if(currentTrackData.has('preset')) {
logger( 'debug', "setTrackData() sendEvent presetName playing for: "+ currentTrackData.get('preset') )
sendEvent(name: "preset"+currentTrackData.get('preset')+"Name", value: "Playing", displayed: false, changed: true)
parsePresets( currentTrackData.get('preset') )
if(changed){
logger('debug', "sendEvent trackdata, currentTrackData: "+currentTrackData)
sendEvent(name: "trackData", value: currentTrackData, displayed:false)
def getTrackData(keys) {
def returnValues = []
logger('debug', "getTrackData, keys: "+keys)
JSONObject trackData = new JSONObject( device.currentValue("trackData") ?: "{}" )
keys.each {
def defaultValue = null
if( it.equals('title') || it.equals('subtitle') ) { defaultValue="--" }
if( it.equals('application') ) { defaultValue="Ready to cast" }
returnValues.add( trackData.optString(it, defaultValue) ?: defaultValue )
return returnValues
def removeTrackData(keys) {
keys.each{
if( trackData.has( it ) ) {
if( it.equals('preset') ) {
logger('debug', 'removeTrackData, resetPresetName for: ' + getTrackData(['preset'])[0])
parsePresets()
logger('debug', "removeTrackData, removing key: "+it+", value: "+trackData.get(it))
trackData.remove(it)
sendEvent(name: "trackData", value: trackData, displayed:false)
// GOOGLE CAST
def setMediaPlayback(mediaType, mediaUrl, mediaStreamType, mediaTitle, mediaSubtitle, mediaImageUrl) {
apiCall("/playMedia", true, '[ { "contentType":"'+mediaType+'", "mediaUrl":"'+mediaUrl+'", "mediaStreamType":"'+mediaStreamType+'", "mediaTitle":"'+mediaTitle+'", "mediaSubtitle":"'+mediaSubtitle+'", "mediaImageUrl":"'+mediaImageUrl+'" } ]')
def setMediaPlaybacks(def data) {
apiCall("/playMedia", true, data)
// NETWORKING STUFF
def apiCall(String path, def dev, def media=null) {
if (dev) {
path = '/device/' + device.deviceNetworkId + path
if ( path.contains('subscribe') ) {
path = path + '/' + hub.localIP + ':' + hub.localSrvPortTCP
if (media) {
sendHttpPost(getDataValue('apiHost'), path, media)
return
sendHttpRequest(getDataValue('apiHost'), path)
def sendHttpRequest(String host, String path, def defaultCallback=hubResponseReceived) {
logger('debug', "Executing 'sendHttpRequest' host: "+host+" path: "+path)
sendHubCommand(new hubitat.device.HubAction("""GET ${path} HTTP/1.1\r\nHOST: $host\r\n\r\n""", hubitat.device.Protocol.LAN, host, [callback: defaultCallback]))
def sendHttpPost(String host, String path, def data) {
logger('debug', "Executing 'sendHttpPost' host: "+host+" path: "+path+" data: "+data+" data.length():"+data.length()+1)
def ha = new hubitat.device.HubAction("""POST ${path} HTTP/1.1\r\nHOST: $host\r\nContent-Type: application/json\r\nContent-Length:${data.length()+1}\r\n\r\n ${data}""", hubitat.device.Protocol.LAN, host, [callback: hubResponseReceived])
logger('debug', "HubAction: "+ha)
sendHubCommand(ha)
void hubResponseReceived(hubitat.device.HubResponse hubResponse) {
parse(hubResponse.description)
// HELPERS
def getTimeStamp() {
Date now = new Date();
def timeStamp = (long)(now.getTime()/1000)
logger('info', "Timestamp generated: "+timeStamp)
return timeStamp;
def urlEncode(String) {
return java.net.URLEncoder.encode(String, "UTF-8")
def selectableAction(action) {
if( action.equals("Play") ) { play() }
if( action.equals("Pause") ) { pause() }
if( action.equals("Stop") ) { stop() }
if( action.equals("Play preset 1") ) { playPreset(1) }
if( action.equals("Play preset 2") ) { playPreset(2) }
if( action.equals("Play preset 3") ) { playPreset(3) }
if( action.equals("Play preset 4") ) { playPreset(4) }
if( action.equals("Play preset 5") ) { playPreset(5) }
if( action.equals("Play preset 6") ) { playPreset(6) }
if( action.equals("Next preset") ) { nextPreset() }
if( action.equals("Previous preset") ) { previousPreset() }
//UPDATE
def getThisVersion() {
return "1.0.0"
def getLatestVersion() {
try {
httpGet([uri: "https://raw.githubusercontent.com/vervallsweg/smartthings/master/devicetypes/vervallsweg/cast-web.src/version.json"]) { resp ->
logger('debug', "response status: ${resp.status}")
String data = "${resp.getData()}"
logger('debug', "data: ${data}")
if(resp.status==200 && data!=null) {
return parseJson(data)
} else {
return null
} catch (e) {
logger('error', "something went wrong: $e")
return null
def checkForUpdate() {
def latestVersion = getLatestVersion()
if (latestVersion == null) {
logger('error', "Couldn't check for new version, thisVersion: " + getThisVersion())
sendEvent(name: "updateStatus", value: ("Version "+getThisVersion() + "\n Error getting latest version \n"), displayed: false)
return null
} else {
logger('info', "checkForUpdate thisVersion: " + getThisVersion() + ", latestVersion: " + getLatestVersion().version)
sendEvent(name: "updateStatus", value: ("Current: "+getThisVersion() + "\nLatest: " + getLatestVersion().version), displayed: false)
//DEBUGGING
def logLevel=1
log.error message
log.warn message
log.info message
log.debug message
There is an issue with the STOP command that I've reported to vervallsweg (the author).
