The device only sends a test notification for smoke.. There is a separate notification for carbon monoxide, but the device doesn’t send that notification.
The topology may have not updated the neighbors yet.. This runs every 30 minutes
Thanks @bcopeland for your response.
I've two more questions:
Thanks.
Cetin.
I guess you could blow some smoke in it ![]()
Odd but not alarming.. I’ll see about getting node neighbor updates from sleepy devices once in a while for 2.2.5
Anytime
For anyone scratching their head on why the new driver isn’t working for them....
“Generic Z-Wave Plus Smoke/CO Detector”
And
“ Generic Z-Wave Smoke/CO Detector” look awfully similar to each other in the drop down!
You can actually purchase "canned smoke" to use to test detectors. I've no idea if this is a reliable way to test them:
Yes, I agree, will wonders never cease. ![]()
Pack of cigarettes would be cheaper
Shame on you for suggesting cigarettes to a minor.
(My wife is always telling me I behave like a child.)
I bought two of these and have been wrestling with them all evening. In chronological order of what I've done...
So what the heck? Can anybody help me?
@mike22 Do you have any advice, based on your experience (here)?
I'll be honest... I really struggled with the test mode on these fire alarms. I thought I had tons of problems and it wasn't reporting... but in reality it was working fine.
I'd recommend buying a can of fake smoke and actually triggering the alarm and test everything that way.
I wonder if you could test the CO detection by holding it near the exhaust of a car.
I tested mine with a lawnmower exhaust (snowblower would probably work also). Portable generator would also work (know this because I foolishly ran mine for a bit a few feet from a basement window opened just enough to pass a cord through; even though the opening was all taped up to prevent outside air getting in, it triggered one of the basement CO detectors-- great way to get killed. LESSON LEARNED). I think these smaller engines run dirtier (CO-wise) than cars nowadays.
I've got a pair of the Gen 2 ZCOMBO detectors that I'm setting up today to replace an expiring pair of Nest Protects. I had no problem adding them using the "Generic Z-Wave Plus Smoke/CO Detector" driver, but the one thing I can't figure out is how to create an association group so that if one goes off, the other does as well. According to the documentation, "The alarm supports one association group with up to 1 node, and sends its alarms to that group." How do I set that up in Hubitat? That association is the primary reason I bought these instead of splashing out for new Protects.
I was torn between resurrecting this thread and starting a new one and obviously decided on the former. If I should start a new thread instead, let me know. Thanks in advance.
This won't work.. For several reasons..
There is only 1 association slot and that is for the hub to get messages from the device.
The other ZCOMBOs won't be listening as they are sleepy devices and would never get a message from the other units..
UGH. Wish I'd understood that before purchasing. I think I'm still within the return period. Thanks for the info!
Anytime
The Generic Z-Wave Plus Smoke/CO detector diver doesnt have a refresh button, however the Generic Z-Wave Smoke detector does. My alarm state got stock on detected mode when i tested de unit and i had to change to the Generic Z-Wave Smoke to refresth the state to clear. @bcopeland
Ok.. Yea.. Refresh serves no purpose on battery (non-listening) z-wave devices.. But I suppose I could put a button to clear the alarm..
Yeas, for my recent experience, that would be great. Thanks!!
