Hi there, I’ve been searching for a driver for the Fibaro FGK-10x Door/Window sensors that also brings in temperature readings. Has anyone got them working ?
I’ve been able to test a few different drivers for door sensors so that part is working but as these Fibaro units have the temp sensor in them, I thought they might as well be utilized, if possible.
This is the driver I copied across from ST that works OK in ST for my fish tank temp.
I have converted it across to HE but as of yet not transferred across my sensor from ST to HE.
Your welcome to give it a try.
EDIT: Code in a post below.
Wow, cool, thx.
I just loaded it into the Driver Code and got ...
startup failed: Script1.groovy: 165: unexpected token: , @ line 165, column 62. / in English :'${linkText}' */, icon: "s ^ 1 error
Loaded OK for me.
Stupid question time.
You are loading a new driver not app.
Yes. Drivers code, under Advanced Menu.
Interestingly i just jumped onto a PC and tested and got slightly different error message, as.....
startup failed: Script1.groovy: 222: unexpected token: , @ line 222, column 66. / in English :'${linkText}' */, icon: "s ^ 1 error
Thx
Correction, same error message, different line number.
I copied the code in then put it in quotes.
I'll try removing them.
May have corrupted something.
Sorry, I can’t seem to get it working. The driver always throws an error.
Any help would be much appreciated.
Try again with this.
* Fibaro Z-Wave FGK-101 Temperature & Door/Window Sensor Handler [v0.9.7.2, 9 July 2017]
* Copyright 2014 Jean-Jacques GUILLEMAUD
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
/* IMPORTANT : This custom Handler works both for Z-Wave+ (aka ZW5) versions of the FGK-101 Fibaro sensor,
/* as well as for pre-ZW5 versions of the FGK-101 hardware.
/* It takes about 1mn for the FGK-101 to fully configure itself after the first (manual or otherwise) wakeup.
* Fibaro Z-Wave FGK-101 Marketing Description is at :
* http://www.fibaro.com/en/the-fibaro-system/door-window-sensor
* Fibaro FGK-10x Operating Manuals and Z-Wave Alliance Certificates can be downloaded at :
* Z-Wave / Firmware <= 2.5 : http://www.fibaro.com/files/instrukcje/eng/DoorWindowSensor%20FGK-101-107%20ENG_v21-v23.pdf
* : http://products.z-wavealliance.org/products/1077
* Z-Wave+ / ZW5 / Firmware >= 3.2 : http://manuals.fibaro.com/content/manuals/en/FGK-10x/FGK-10x-EN-T-v2.0.pdf
* : http://products.z-wavealliance.org/products/1620
* The current version of this Handler is parameterized to force Device's wakeup :
* - on any open<->closed state change
* - in case of Tampering Alarm triggering
* - every 60mn (wakeUpIntervalSet(seconds:60*60), hard coded)
* - whenever Temperature delta change since last report is greater than 0.3°C (Parameter#12 or #51, hard coded)
* - every 4h when Temperature does not change
* also :
* - Temperature is natively reported by sensor in Celsius (SensorMultilevelReport[scale:0]);
* convertion is needed for Fahrenheit display
* A few specificities of this device that are relevant to better understand some parts of this Handler :
* - it is a battery operated device, so Commands can only be sent to it whenever it wakes up
* - it is a multi-channel Device (pre-ZW5), and the multi-level temperature sensor reports only from EndPoint#2
* - specific configurable parameters are documented in the above Operating Manuals
* - some of those parameters must be modified to activate the anti-Tampering Alarm
* - some of the "scaffolding" has been left in place as comments, since it may help other people to understand/modify this Handler
* - BEWARE : the optional DS18B20 temperature sensor must be connected BEFORE the Device is activated (otherwise, reset the Device)
* - IMPORTANT : for debugging purpose, it is much better to change the wake-up period from the default 60mn to 1mn or so;
* but unless you force the early wake up of the sensor (forcing open/closed for instance), you will have to
* wait up to 60mn for the new value to become effective.
* Z-Wave Device Class: GENERIC_TYPE_SENSOR_BINARY / SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
* FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
* Command Classes supported according to Z-Wave Certificate ZC08-14070004 for FGK-101\US :
* Used in Handler (pre-ZW5 and ZW5) :
* 0x20 - 32 : BASIC V1
* 0x30 - 48 : SENSOR_BINARY V2
* 0x31 - 49 : SENSOR_MULTILEVEL V5
* 0x56 - 86 : CRC_16_ENCAP V1
* 0x70 - 112 : CONFIGURATION V2
* 0x80 - 128 : BATTERY V1
* 0x84 - 132 : WAKE_UP V2
* 0x85 - 133 : ASSOCIATION V2
* 0x86 - 134 : VERSION V1
* 0x9C - 156 : SENSOR_ALARM V1
* Used in Handler (pre-ZW5 only) :
* 0x60 - 96 : MULTI_CHANNEL V3
* Used in Handler (ZW5 only) :
* 0x71 - 113 : NOTIFICATION V3
* 0x98 - 152 : SECURITY V1
* List of Known Bugs / Oddities / Missing Features :
* - valueTitle does not show displayNames on mobile Dashboard/Things page;
* attempted workaround using : valueTile(){unit:'${displayName}') failed
* - valueTile behaves differently on mobile Dashboard (interpolated colors) from Simulator (step-wise colors)
* - using Preferences values instead of hard-coded values for some parameters would be nicer
* - ZW5 : Sensor Multilevel Report() received in answer to Sensor Multilevel Get() is buggy (+/- 1°C random error)
metadata {
definition (name: "JJ's Fibaro FGK-10x ZW5 Handler", namespace: "JJG2014", author: "Jean-Jacques GUILLEMAUD") {
capability "Contact Sensor"
capability "Battery"
capability "Configuration"
capability "Temperature Measurement"
capability "Sensor"
capability "Alarm"
capability "Tamper Alert"
command "reportNext", ["string"]
// Use Device Custom Attributes whenever state.xxx Attributes are too vulnerable to race conditions
attribute "reportASAP", "number"
attribute "forcedWakeUp", "number"
attribute "ZW5set", "number"
attribute "ZW5", "number"
attribute "Configured", "number"
// FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
fingerprint deviceId: "0x2001", inClusters: "0x85, 0x20, 0x80, 0x70, 0x56, 0x72, 0x9C, 0x30, 0x31, 0x86, 0x84, 0x7A, 0x2B" // fingerprint as intersection of ZW6 & non-ZW5 fingerprints
// fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x85, 0x59, 0x22, 0x20, 0x80, 0x70, 0x56, 0x5A, 0x7A, 0x72, 0x8E, 0x71, 0x73, 0x98, 0x2B, 0x9C, 0x30, 0x31, 0x86, 0x84", outClusters: ""//actual NIF
simulator {
status "open": "command: 2001, payload: FF"
status "closed": "command: 2001, payload: 00"
def T_values=[10,14,14.9,15,17,17.9,18,19,19.9,20,22,22.9,23,24,44,44.9,45,46,100]
def float Ti
for (int i = 0; i <= T_values.size()-1; i += 1) {
Ti=T_values.get(i)
def theSensorValue = [(short)0, (short)0, (short)(Ti*100)/256, (short)(Ti*100)%256]
status "temperature ${Ti}°C": zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2).encapsulate(zwave.sensorMultilevelV5.sensorMultilevelReport(scaledSensorValue: i, precision: 2, scale: 0, sensorType: 1, sensorValue: theSensorValue, size:4)).incomingMessage()
tiles {
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
// label:'${name}', label:'${currentValue}', unit:"XXX" work, but NOT label:'${device.name}', label:'${displayName}', unit:'${unit}', ...
state "temperature", label:'${currentValue}°', unit:"C", icon: "st.alarm.temperature.normal",
// redondant lines added to avoid color interpolation on Dashboard (a feature or a bug ?!)
backgroundColors:[ // ***on IDE Simulator*** // ***on iPad App***
[value: 14, color: "#0033ff"], // °C <=14 : dark blue // °C <=14 : dark blue
//[value: 14.1, color: "#00ccff"], <- decimal value IGNORED by the Tile !!!
[value: 14.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated dark blue<-> light blue
[value: 15, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 17, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 17.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated light blue<->blue-green
[value: 18, color: "#ccffcc"], // 15< °C <=19 : light blue // 18<=°C <=19 : blue-green
[value: 19, color: "#ccffcc"], // 15< °C <=19 : light blue // 19°C : blue-green
[value: 19.5], // 19< °C <=21 : blue-green // 19< °C <20 : interpolated blue-green<->green
[value: 20, color: "#ccff00"], // 19< °C <=21 : blue-green // 20<=°C <=21 : green
[value: 22, color: "#ccff00"], // 21< °C <=23 : green // 22°C : green
[value: 22.5], // 23< °C <=45 : orange // 22< °C <23 : interpolated green<-> orange
[value: 23, color: "#ffcc33"], // 23< °C <=45 : orange // 23<=°C <=44 : orange
[value: 43, color: "#ffcc33"], // 23< °C <=45 : orange // 44°C : orange
[value: 43.5], // 45< °C : red // 44< °C <45 : interpolated orange <-> red
[value: 44, color: "#ff3300"] // 45< °C : red // 45<=°C : red
valueTile("temperatureF", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
state "temperature", label:'${currentValue}°', unit:"F", icon: "st.alarm.temperature.normal",
[value: 57, color: "#0033ff"], // °C <=14 : dark blue // °C <=14 : dark blue
//[value: 14.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated dark blue<-> light blue
[value: 59, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 63, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
//[value: 17.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated light blue<->blue-green
[value: 64, color: "#ccffcc"], // 15< °C <=19 : light blue // 18<=°C <=19 : blue-green
[value: 66, color: "#ccffcc"], // 15< °C <=19 : light blue // 19°C : blue-green
//[value: 19.5], // 19< °C <=21 : blue-green // 19< °C <20 : interpolated blue-green<->green
[value: 68, color: "#ccff00"], // 19< °C <=21 : blue-green // 20<=°C <=21 : green
[value: 72, color: "#ccff00"], // 21< °C <=23 : green // 22°C : green
//[value: 22.5], // 23< °C <=45 : orange // 22< °C <23 : interpolated green<-> orange
[value: 73, color: "#ffcc33"], // 23< °C <=45 : orange // 23<=°C <=44 : orange
[value: 109, color: "#ffcc33"], // 23< °C <=45 : orange // 44°C : orange
//[value: 43.5], // 45< °C : red // 44< °C <45 : interpolated orange <-> red
[value: 111, color: "#ff3300"] // 45< °C : red // 45<=°C : red
standardTile("contact", "device.contact") {
state "open", label: 'open'/* in English :'${name}' */, icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: 'closed'/* in English :'${linkText}' */, icon: "st.contact.contact.closed", backgroundColor: "#79b821"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'batt ${currentValue}%' /*battery*/, unit:""
//Select temperatureF if Location temperature Scale is °F
main(["temperature"])
details(["temperature", "contact", "battery"])
//main(["temperatureF"])
//details(["temperatureF", "contact", "battery"])
// parse events into attributes
state.parseCount=state.parseCount+1
state.debugLevel = 2 // set to 1 or 2 when experimenting
if (state.debugLevel>=1) {log.debug "--------------------------Parsing... ; state.parseCount: ${state.parseCount}--------------------------"}
if (state.debugLevel>=2) {log.debug "Parsing... '${description}'"}
def result = null
def cmd = zwave.parse(description, [0x20:1, 0x30:2, 0x31:5, 0x56:1, 0x60:3, 0x70:2, 0x72:2, 0x80:1, 0x84:2, 0x85:2, 0x9C:1])
if (cmd) {
result = zwaveEvent(cmd)
if (state.debugLevel>=1) {log.debug "Parsed ${cmd} to ${result.inspect()}"}
} else {
log.debug "Non-parsed event: ${description}"
return result
//SmartThings v2 Hub forces some CRC16-encoded replies from FGK-101 Device (v1 Hub did not)
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
log.debug "CRC16.......... cmd : ${cmd}"
def versions = [0x20:1, 0x30: 2, 0x31: 5, 0x60: 3, 0x70: 2, 0x72: 2, 0x80: 1, 0x84: 2, 0x86: 1, 0x9C: 1]
// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
def version = versions[cmd.commandClass as Integer]
log.debug "commandClass : ${cmd.commandClass}"
log.debug "version : ${version}"
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
log.debug "ccObj : ${ccObj}"
log.debug "cmd.command : ${cmd.command}"
log.debug "cmd.data : ${cmd.data}"
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
if (!encapsulatedCommand) {
log.debug "Could not extract command from ${cmd}"
} else {
zwaveEvent(encapsulatedCommand)
// ZW5 Devices that support the Security command class can send messages in an
// encrypted form; they arrive wrapped within a SecurityMessageEncapsulation
// command and must be unencapsulated
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
log.debug "cmd : ${cmd}"
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x30: 2, 0x70: 2, 0x71: 3, 0x84: 2, 0x85: 2, 0x98: 1, 0x9C: 1])
// can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
log.debug "ZW5 encapsulatedCommand : ${encapsulatedCommand}"
return zwaveEvent(encapsulatedCommand)
} else {
log.warn "ZW5 Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def temperatureScaleFC(tempvalue) {
//FGK-101 is natively °C; convert to °F if selected in Location settings
def float tempFC = tempvalue
if (location.temperatureScale == "F") {
tempFC = tempvalue * 1.8 + 32
return tempFC
def wakeUpResponse(cmdBlock0) {
def cmdBlock = []
cmdBlock += cmdBlock0
//Initialization... (executed only once, when the Handler has been updated)
//All untouched parameters are supposed to be DEFAULT (as factory-set)
if (state.debugLevel>=2) {log.debug "device.Configured : ${device.currentValue('Configured')}"}
if (!(device.currentValue('Configured'))) {
cmdBlock += configureDev()
log.debug "++++++++returned cmdBlock : ${cmdBlock}"
//Regular ZW5 & non-ZW5 Commands...
def long nowTime = new Date().getTime()
log.debug "state.lastReportBattery : ${state.lastReportBattery}"
if (state.batteryInterval) {
if (nowTime-state.lastReportBattery > state.batteryInterval) {
// batteryGet() should definitely NOT be CRC16 encoded ! [buggy ZW5 Fibaro handler !!]
cmdBlock << zwave.batteryV1.batteryGet().format()
cmdBlock << "delay ${state.shortDelay}"
//ZW5 : "wakeUpIntervalReport doesn’t work uint24FromBytes missing from response" : https://community.smartthings.com/t/wakeupintervalget-doesnt-work-uint24frombytes-missing-from-response/10577
//cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalGet()) // NB : may have to wait 60mn for that value to be refreshed !
//cmdBlock << "delay ${state.longDelay}"
if (device.currentValue('ZW5set')) {
// DS18B20 temperature measurement at 12bits accuracy takes more than 750ms...
if (device.currentValue('ZW5')) {
// sensorMultilevelGet() should be +++PROPERLY+++ CRC16-encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!!
// sensorMultilevelReport() synchronous answer to sensorMultilevelGet() is buggy for whatever reason (+/-1°C) => disable sensorMultilevelGet()
//cmdBlock << crc16Encode(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0))
} else {
cmdBlock << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 2, destinationEndPoint: 2, commandClass:0x31, command:4).format() //sensorMultiLevel.get()
cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
log.debug "wakeUpNoMoreInformation()"
log.debug "cmdBlock : ${cmdBlock}"
return cmdBlock
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
log.debug "wakeupv2.WakeUpNotification $cmd"
def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: true, displayed: false)
def cmdBlock = []
cmdBlock = wakeUpResponse([])
return [event, response(cmdBlock)]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
log.debug "SensorMultilevelReport.precision : ${cmd.precision}"
log.debug "SensorMultilevelReport.scale : ${cmd.scale}"
log.debug "SensorMultilevelReport.scaledSensorValue : ${cmd.scaledSensorValue}"
log.debug "SensorMultilevelReport.sensorType : ${cmd.sensorType}"
log.debug "SensorMultilevelReport.sensorValue : ${cmd.sensorValue}"
log.debug "SensorMultilevelReport.size : ${cmd.size}"
def float scaledSensorValue = cmd.scaledSensorValue
// Adjust measured temperature based on previous manual calibration; FGK-101 is natively °C
switch (device.name) {
case 'T005' : //JJG
scaledSensorValue = scaledSensorValue + 0.0554
log.debug "Temp Adjust for : ${device.name}"
break;
case 'T006' : //MLE
scaledSensorValue = scaledSensorValue + 0.0297
break;
case 'T003' : //MPT
scaledSensorValue = scaledSensorValue - 0.0603
break;
case 'T002' : //NBN
scaledSensorValue = scaledSensorValue - 0.0758
break;
case 'T004' : //SCU
scaledSensorValue = scaledSensorValue + 0.0011
break;
case 'T007' : //FSU
scaledSensorValue = scaledSensorValue + 0.0025
break;
case 'T008' :
scaledSensorValue = scaledSensorValue - 0.0146
break;
case 'T009' :
scaledSensorValue = scaledSensorValue + 0.0383
break;
case 'T010' :
break;
case 'T011' :
scaledSensorValue = scaledSensorValue - 0.0889
break;
case 'T012' :
scaledSensorValue = scaledSensorValue - 0.0532
break;
case 'T013' :
break;
case 'T014' : //*ext*//
scaledSensorValue = scaledSensorValue - 0.0160
break;
//Round to nearest 1 decimal temperature value; convert to °F if needed
def float ftempSign = temperatureScaleFC(scaledSensorValue) < 0 ? -1 : +1
def float ftemp = ftempSign * ((((int) (temperatureScaleFC(scaledSensorValue).abs()*100+5)/10)*1.0)/10)
log.debug "ftempSign : ${ftempSign}"
log.debug "ftemp : ${ftemp}"
log.debug "cmd.scaledSensorValue : ${cmd.scaledSensorValue}"
log.debug "correction : ${scaledSensorValue-cmd.scaledSensorValue}"
log.debug "device.displayName : ${device.displayName}"
log.debug "'Date().getTime()' : ${new Date().getTime()}"
log.debug "state.maxEventInterval : ${state.maxEventInterval}"
log.debug "state.lastReportTime : ${state.lastReportTime}"
log.debug "nowTime : ${nowTime}"
log.debug "device.forcedWakeUp : ${device.currentValue('forcedWakeUp')}"
log.debug "(nowTime-state.lastReportTime > state.maxEventInterval) : ${(nowTime-state.lastReportTime > state.maxEventInterval)}"
log.debug "state.lastReportedTemp: ${state.lastReportedTemp}"
// Adjust temperature report sensitivity for outside thermometers whose displayName starts with "*"
def float tempQuantum
if (device.displayName.substring(0,1).equals("*")) {
tempQuantum = temperatureScaleFC(0.9999)-temperatureScaleFC(0)
} else {
tempQuantum = temperatureScaleFC(0.0999)-temperatureScaleFC(0)
log.debug "((ftemp-state.lastReportedTemp).abs()>${tempQuantum}): ${(ftemp-state.lastReportedTemp).abs()>tempQuantum}"
// Spurious faulty Temperature Reports cropped when temparture gradient is unbelievable (?)
if ((((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime)) < (0.5/1000)) { // ignore temperature report when slope > 0.5°C/s
if (((ftemp-state.lastReportedTemp).abs()>tempQuantum) || ((nowTime-state.lastReportTime) > state.maxEventInterval) || device.currentValue('forcedWakeUp')) {
def map = [ displayed: true, value: ftemp.toString(), isStateChange:true, linkText:"${device.displayName}" ]
if (cmd.sensorType == 1) {
map.name = "temperature"
map.unit = cmd.scale == 1 ? "F" : "C"
//ignores Device's native temperature scale, ftemp already converted to °F if settings as such
map.unit = location.temperatureScale
log.debug "map.value : ${map.value}"
log.debug "map.unit : ${map.unit}"
log.debug "temperature Command : ${map.inspect()}"
state.lastReportedTemp = ftemp
state.lastReportTime = nowTime
sendEvent(name: "forcedWakeUp", value: 0, displayed: false)
// For Test purpose; redondant with reportNext() => device.forcedWakeUp=1
if (device.currentValue('reportASAP')==1) {sendEvent(name: "reportASAP", value: 0, isStateChange: true)}
return createEvent(map)
} else {
log.debug "+++++++++discarded temperature report : rate change : ${(((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime))*1000}°C/s"
def sensorValueEvent(value) {
if (value) {
createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open [sensorValueEvent]")
} else {
createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed [sensorValueEvent]")
// BasicReport should never occur since all status change notifications are asynchronous via BasicSet
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
sensorValueEvent(cmd.value)
if (state.debugLevel>=2) {log.debug "basicv1.BasicReport $cmd.value"}
def openClosed(cmd, cmdValue) {
def theState = cmdValue == 0 ? "closed" : "open"
if (state.debugLevel>=2) {log.debug "openClosed $cmd"}
// Use closed/open sensor notification to trigger push of updated Temperature value and immediate setting of updated device parameters
// Sometimes, Temperature forced refresh stops working : SensorMultilevelGet(sensorType: 1, scale: 0) Commands are stacked but not executed immediately;
// will restart after some time, and stacked Commands will be executed !
def event = createEvent(name:"contact", value:"${theState}", descriptionText:"${device.displayName} is ${theState}", isStateChange:true, displayed:true, linkText:"${device.displayName}")
sendEvent(name: "forcedWakeUp", value: 1, displayed: false)
return [event, response(wakeUpResponse([]))]
// pre-ZW5 : BasicSet alarm does not seem to wait for any Commands answers, going back to sleep immediately;
// thus it cannot perform proper initial Configuration => use the Tamper switch and SensorAlarmReport instead
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
log.debug "basicv1.BasicSet $cmd"
if ((device.currentValue('ZW5set')) && (!(device.currentValue('ZW5')))) {
def cmdValue = cmd.value
return openClosed(cmd, cmdValue)
// For pre-ZW5, SensorBinaryReport should never occur since all status change notifications are asynchronous via BasicSet...
// ...but ZW5 uses it in addition to BasicSet and Notification
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
log.debug "sensorbinaryv2.SensorBinaryReport $cmd"
def cmdValue = cmd.sensorValue
// ZW5 : it is assumed that default notification events are used
// (parameter 20 was not changed before device's re-inclusion)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
def map = [:]
if (cmd.notificationType == 6) {
switch (cmd.event) {
case 22:
map.name = "contact"
map.value = "open"
map.descriptionText = "${device.displayName} is open"
break
case 23:
map.value = "closed"
map.descriptionText = "${device.displayName} is closed"
break
// Contrary to pre-ZW5 Devices, the Tamper Notification does not occur for only a brief
// push>release of the Tamper button. But it DOES occur when the Tamper button is released
// 1mn or so after being pushed.
} else if (cmd.notificationType == 7) {
case 0:
map.name = "tamper"
map.value = "inactive"
map.descriptionText = "${device.displayName} tamper detection enabled"
break
case 3:
map.name = "tamper"
map.value = "active"
map.descriptionText = "${device.displayName} is tampered with !"
break
def event = createEvent(map)
// SensorAlarmReport DOES wait for optional Commands answers, contrary to BasicSet
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
if (state.debugLevel>=2) {log.debug "sensoralarmv1.SensorAlarmReport $cmd.sensorState"}
if (!(device.currentValue('ZW5'))) {
def event = createEvent(name:"alarm", descriptionText:"${device.displayName} is tampered with !", isStateChange:true, displayed:true, linkText:"${device.displayName}")
def cmdBlock = []
cmdBlock=wakeUpResponse(cmdBlock)
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
log.debug "batteryv1.BatteryReport ${cmd.batteryLevel}"
log.debug "state.batteryInterval : ${state.batteryInterval}"
if ((nowTime-state.lastReportBattery > state.batteryInterval) || device.currentValue('forcedWakeUp')) {
def map = [ name: "battery", displayed: true, isStateChange:true, unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastReportBattery = nowTime
log.debug "battery map : ${map}"
return [createEvent(map)]
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
if (state.debugLevel>=2) {log.debug "ConfigurationReport - Parameter#${cmd.parameterNumber}: ${cmd.configurationValue}"}
// Last configuration command execution; check UNIQUE(<>default) value is set
// A bit of an overkill : checking the cmd.parameterNumber (12 or 51) should be enough...
def byte tempQuantumSixteenth
tempQuantumSixteenth = 16 /* 16/16=1°C = 1.8°F */
} else {
tempQuantumSixteenth = 4 /* 5/16=0.31°C = 0.56°F */
if (device.currentValue('ZW5set') && !(device.currentValue('ZW5')) && (cmd.parameterNumber == 12) && (cmd.configurationValue == [tempQuantumSixteenth])) {
sendEvent(name: "Configured", value: 1, isStateChange: true)
log.debug ("++++++Non-ZW5 Device Configured++++++")
def byte tempQuantumTenth
tempQuantumTenth = 10 /* 10/10=1°C = 1.8°F */
} else {
tempQuantumTenth = 2 /* 3/10=0.3°C = 0.56°F */
if (device.currentValue('ZW5set') && device.currentValue('ZW5') && (cmd.parameterNumber == 51) && (cmd.configurationValue == [0,tempQuantumTenth])) {
log.debug ("++++++ZW5 Device Configured++++++")
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
def result = []
if (cmd.nodeId.any { it == zwaveHubNodeId }) {
result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
} else if (cmd.groupingIdentifier == 1) {
// We're not associated properly to group 1, set association
result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
result
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelEndPointReport cmd) {
if (state.debugLevel>=2) {log.debug "multichannelv3.MultiChannelCapabilityReport: ${cmd}"}
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
// ZW5 added : discriminate between ZW5 and pre-ZW5 Devices
// ZW5 : ${cmd.applicationVersion}.${cmd.applicationSubVersion}>=3.2 ; pre-ZW5 : <= 2.5
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
//updateDataValue("version", "${cmd.applicationVersion}.${cmd.applicationSubVersion}")
log.debug "versionv1.VersionReport: ${cmd}"
log.debug "applicationVersion: ${cmd.applicationVersion}"
log.debug "applicationSubVersion: ${cmd.applicationSubVersion}"
def deviceFirmwareVersion = (short) cmd.applicationVersion*1000 + cmd.applicationSubVersion
log.debug "deviceFirmwareVersion: ${deviceFirmwareVersion}"
if (deviceFirmwareVersion >= 3002) {
sendEvent(name: "ZW5", value: 1, isStateChange: true)
} else {
sendEvent(name: "ZW5", value: 0, isStateChange: true)
sendEvent(name: "ZW5set", value: 1)
log.debug "device.ZW5set: ${device.currentValue('ZW5set')}"
log.debug "device.ZW5: ${device.currentValue('ZW5')}"
return [response(wakeUpResponse([]))]
// MultiChannelCmdEncap and MultiInstanceCmdEncap are ways that devices can indicate that a message
// is coming from one of multiple subdevices or "endpoints" that would otherwise be indistinguishable
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 2, 0x31: 5]) // can specify command class versions here like in zwave.parse
if (state.debugLevel>=2) {log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")}
// Catch All command Handler in case of unexpected message
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "!!! $device.displayName: ${cmd}", displayed: false)
// When a Temperature Event got lost in transit, the Watchdog requests a forced report at next wake up
// The "reportNext()" alarm command is used to signal back from the Watchdog SmartApp to the sleepy device
def reportNext(commandMsg) {
log.debug "reportNext !"
log.debug "commandMsg : ${commandMsg}"
sendEvent(name: "forcedWakeUp", value: 1)
return []
// Initial Device Configuration and Handler Update
// Executed each time the Handler is updated
def updated() {
log.debug "Updated !"
def bytesToCRC = [0x56, 0x01, 0x31, 0x05, 0x01, 0x42, 0x09, 0x79]
//log.debug "checksum 0BD3/3027 : zwaveCrc16([0x56, 0x01, 0x31, 0x05, 0x01, 0x42,0x09, 0x79]) : ${zwaveCrc16(bytesToCRC as byte[])}"
sendEvent(name: "ZW5set", value: 0)
sendEvent(name: "ZW5", value: 0)
sendEvent(name: "Configured", value: 0) // set to true by the LAST Command Response from configureDev()
// All state.xxx attributes are Device-local, NOT Location-wide
// BEWARE : state.xxx attributes are vulnerable to race conditions; when not mostly read-only, use device.xxx instead
state.lastReportedTemp = (float) -1000
state.lastReportTime = (long) 0
state.lastReportBattery = (long) 0
state.longDelay = 1200
state.shortDelay = 1200
// Real-time clock of sensors (ceramic resonator) is up to 3% inaccurate
state.batteryInterval = (long) (24*60-45)*60*1000 // 83 700 000 : at least 1 Battery Report event every 23:15 hours
state.maxEventInterval = (long) (2*60-20)*60*1000 // 13 200 000 : at least 1 Temperature Report event every 3:40 hours (4 hours at most)
state.parseCount=(int) 0
if (!(state.deviceID)) {state.deviceID = device.name}
log.debug "state.deviceID: ${state.deviceID}"
sendEvent(name: "reportASAP", value: 1)
log.debug "device.currentValue('reportASAP') : ${device.currentValue('reportASAP')}"
// configureDev() // will be defered till first wakeup (forced or periodic)
infos()
// If you add the Configuration capability to your device type, this command will be called right
// after the device joins to set device-specific configuration commands.
def configure() {
return configureDev()
def configureDev() {
def cmdBlock = []
log.debug "device.Configured: ${device.currentValue('Configured')}"
/////////////// Common configuration
if (!(device.currentValue('ZW5set'))) {
log.debug "Configuring - Common Part............................................."
log.debug "cmdBlock: ${cmdBlock}"
cmdBlock << zwave.versionV1.versionGet().format()
log.debug "++++++Last Common Configuration Command SENT++++++"
return cmdBlock
/////////////// Non-ZW5 specific configuration
if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && !(device.currentValue('ZW5'))) {
log.debug "Configuring - NON ZW5............................................."
// Make sure sleepy battery-powered sensors send their WakeUpNotifications to the hub
cmdBlock << zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format()
} else {
tempQuantumSixteenth = 2 /* 5/16=0.31°C = 0.56°F */
log.debug "tempQuantumSixteenth : ${tempQuantumSixteenth}"
// NOTE : any asynchronous temperature query thru SensorMultilevelGet(sensorType: 1, scale: 0) does NOT reset the delta-Temp base value (managed by DS18B20 hardware)
cmdBlock << zwave.configurationV2.configurationSet(parameterNumber: 12/*for FGK101*/, size: 1, configurationValue: [tempQuantumSixteenth]).format()
// inclusion of Device in Association#3 is needed to get delta-Temperature notification messages [cf Parameter#12 above]
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
// inclusion of Device in Association#2 is needed to enable SensorAlarmReport() Command [anti-Tampering protection]
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
// Should be last for proper checking of complete initialization (through configurationReport)
cmdBlock << zwave.configurationV2.configurationGet(parameterNumber: 12/*for FGK101*/).format()
//cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
log.debug "++++++Last non-ZW5 Configuration Command SENT++++++"
/////////////// ZW5 specific configuration
if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && device.currentValue('ZW5')) {
log.debug "Configuring - ZW5............................................."
//cmdBlock << "delay ${state.shortDelay}"
cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId))
def short tempQuantumTenth
log.debug "device.displayName.substring(0,1) : ${device.displayName.substring(0,1)}"
} else {
tempQuantumTenth = 1 /* 3/10=0.3°C = 0.56°F */
// sensorMultilevelGet() should be +++PROPERLY+++ CRC16 encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!
// ZW5 : completely buggy synchronous sensorMultilevelReport() : +/- 1°C vs unsolicited asynchronous reports : ???
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 3/*for FGK101*/, size: 1, configurationValue: [5])) // LED blinks on Tampering & Open/Close
// measuring temperature every 5mn drains the battery in a few months... but every hour creates a prejudiciable latency...
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 50/*for FGK101*/, size: 2, configurationValue: [0x03,0x84])) // measure temperature every 15mn = 900s = 0x384
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 51/*for FGK101*/, size: 2, configurationValue: [0,tempQuantumTenth])) // less than 256...
// ??? : parameter#52 seems to translate "1 second" into "1.92 second", based on actual measurements
// => downrate 14 400 to 7 510 to compensate
//cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x38,0x40])) // 0x3840 = 14400 = 4*3600 = 4 hours
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x1D,0x56])) // 0x1D56 = 7510
// 1st Association Group : "Lifeline" reports the device status and allows for assigning single device only (main controller by default)
cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
// 2nd Association Group : "Control" is assigned to the device status - reed sensor and IN input (sends alarm command frames).
cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
cmdBlock << encap(zwave.configurationV2.configurationGet(parameterNumber: 51/*for FGK101*/))
log.debug "++++++Last ZW5 Configuration Command SENT++++++"
//log.debug "device.Configured: ${device.currentValue('Configured')}"
return cmdBlock // Fully configured only after 2 Configure() calls
def infos() {
if (!state.devices) { state.devices = [:] }
log.debug "zwaveHubNodeId: ${zwaveHubNodeId}" // -> "1"
log.debug "device.displayName: ${device.displayName}" // -> "JJG"
log.debug "device.id: ${device.id}" // -> "d93f6450-4c9b-4892-bfcb-d61353f4c793"
log.debug "location.id: ${location.id}" // -> "99e95fb7-726f-4c64-a4f5-7b2151cf166a" [Le Puits Jamet]
log.debug "device.name: ${device.name}" // -> "T005"
log.debug "device.label: ${device.label}" // -> "JJG"
log.debug "device.data: ${device.data}" // -> "[MSR: 010F-0700-2000, endpointId: 0, version: 2.1]"
log.debug "device.rawDescription: ${device.rawDescription}" // -> non-ZW5 : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
// -> ZW5 : "zw:Ss type:0701 mfr:010F prod:0701 model:2001 cc:5E,59,22,80,56,7A,72,73,98,31,86 sec:85,20,70,5A,8E,71,2B,9C,30,84"
* Calculates the 16-bit CRC (CRC-CCITT) for a byte array.
* Uses initial crc of 0x1D0F, and poly of 0x1021, as per Z-wave specification.
* Reference: http://z-wave.sigmadesigns.com/wp-content/uploads/2016/08/SDS12652-13-Z-Wave-Command-Class-Specification-N-Z.pdf
* Thanks to CODERSAUR : https://community.smartthings.com/t/handling-crc-16-encapsulation-commands-crc16encap/76931/4
private zwaveCrc16(byte[] bytes) {
short crc = 0x1D0F // It's important this is a short (16-bit)
short poly = 0x1021
bytes.each { workData ->
//for (bitMask = 0x80; bitMask != 0; bitMask >>= 1) {
// Need to use a different way to iterate, as rightshift operator '>>' and unsigned rightshift '>>>' do not appear to work in SmartThings.
[0b10000000,0b01000000,0b00100000,0b00010000,0b00001000,0b00000100,0b00000010,0b00000001].each { bitMask ->
def newBit = ((workData & bitMask) != 0) ^ ((crc & 0x8000) != 0);
crc <<= 1;
if (newBit) { crc ^= poly; }
return crc
// CRC16 Encoding for Hub's +++OUTGOING+++ Commands
private crc16Encode(hubitat.zwave.Command cmd) {
log.debug "cmd: ${cmd}"
def bytesToCRC = [0x56, 0x01, cmd.commandClassId, cmd.commandId]
bytesToCRC += cmd.payload
log.debug "bytesToCRC: ${bytesToCRC}"
def short checksum = zwaveCrc16(bytesToCRC as byte[])
log.debug "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
return "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
//ZW5 added
private secure(hubitat.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
//ZW5 added
private encap(hubitat.zwave.Command cmd) {
def secureClasses = [0x20, 0x2B, 0x30, 0x5A, 0x70, 0x71, 0x84, 0x85, 0x8E, 0x9C]
//todo: check if secure inclusion was successful
//if not do not send security-encapsulated command
if ((device.currentValue('ZW5set')) && (device.currentValue('ZW5'))) {
if (secureClasses.find{ it == cmd.commandClassId }) {
secure(cmd)
} else {
// ??? : very dubious all UNsecure outgoing ZW5 commands have to be CRC16 encoded;
// sensorMultiLevelGet() MUST be, but for sure
// batteryGet() and versionGet() need NOT be ! (but could be ?)
crc16Encode(cmd) // crc16() Fibaro code w/ checksum = 0x0000 was buggy
} else {
return cmd.format()
Whoo hoo - saved with no errors.
I'll test it out.
@bobbles when you want to post "code" in a forum it will make it a LOT easier to cut and paste if you use the following prefix/suffix syntax.
[CODE] at the beginning
[/CODE] at the end
Just a tip.
Thanks for your participation in the forum.
That's a good Tip, cheers.
However, despite that unfortunately the driver is still not functioning correctly. Although it saved OK it's displaying some odd parameters for a Door/Window sensor such as SIREN and STROBE.
see image below...
It also doesn't detect an OPEN / CLOSE.
I'm using the "Aeon Recessed Door Sensor" as my fallback driver but I'd love to get temperature readings out of the Fibaro ones (they have the DS18B20's)
Thx
I only use it as a temp sensor so I ignore everything else.
@bobbles although the driver was able to be saved it's non-functional and throwing the error- "java.lang.NullPointerException: Cannot execute null+1 on line 191 (parse)" in the logs.
The BOTH command results in the following error being thrown..
" groovy.lang.MissingMethodException: No signature of method: dev15310023067451169816235.both() is applicable for argument types: () values: [] Possible solutions: with(groovy.lang.Closure), each(groovy.lang.Closure), notify(), wait(), run(), run() (both) "
I've been playing with the driver without really knowing what I'm doing.
I have managed to get this to report the following.
I'm still getting errors for strobe etc. but if I don't press them, no error.
* also :
metadata {
capability "Sensor"
capability "Alarm"
simulator {
def float Ti
Ti=T_values.get(i)
tiles {
//state.parseCount=state.parseCount+1
//state.debugLevel = 2 // set to 1 or 2 when experimenting
def result = null
if (cmd) {
} else {
return result
} else {
} else {
return tempFC
def cmdBlock = []
} else {
return cmdBlock
def cmdBlock = []
case 'T005' : //JJG
break;
case 'T006' : //MLE
break;
case 'T003' : //MPT
break;
case 'T002' : //NBN
break;
case 'T004' : //SCU
break;
case 'T007' : //FSU
break;
case 'T008' :
break;
case 'T009' :
break;
case 'T010' :
break;
case 'T011' :
break;
case 'T012' :
break;
case 'T013' :
break;
break;
} else {
//log.debug "((ftemp-state.lastReportedTemp).abs()>${tempQuantum}): ${(ftemp-state.lastReportedTemp).abs()>tempQuantum}"
//if ((((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime)) < (0.5/1000)) { // ignore temperature report when slope > 0.5°C/s
//if (((ftemp-state.lastReportedTemp).abs()>tempQuantum) || ((nowTime-state.lastReportTime) > state.maxEventInterval) || device.currentValue('forcedWakeUp')) {
// } else {
if (value) {
} else {
def map = [:]
case 22:
map.value = "open"
break
case 23:
break
case 0:
map.name = "tamper"
break
case 3:
map.name = "tamper"
break
def cmdBlock = []
map.value = 1
} else {
} else {
} else {
def result = []
result
} else {
return []
def updated() {
infos()
def configure() {
def cmdBlock = []
return cmdBlock
} else {
} else {
def infos() {
short poly = 0x1021
crc <<= 1;
return crc
//ZW5 added
//ZW5 added
secure(cmd)
} else {
} else {
return cmd.format()
oh, cool, thanks for the assistance. I'll give it a crack when I get home tonight.
FYI: The Fibaro Door/Window Sensor 2 driver that was included in the last firmware update does not seem to function with my generation of sensors.
@bobbles, thanks man, that looks to be working.
I’ll keep monitoring things but do far so good.
Awesome effort, thx
Just thought I'd update this as things have got a little better....
I found it odd that the 3 sensors I have were reporting different "Cluster" values so I spent the better part of a day trying to sort that out. Which I seem to have managed
Now they're reporting correctly with either driver....
- JJ's Fibaro FGK-10x ZW5 Handler
- The Fibaro Door/Window Sensor 2 driver is now also working
There's still some weird stuff like one of them does NOT flash its LED when Opening or Closing where as the others do and I struggled with one of them trying to reset it whilst it had a battery reporting 50%. Changed the battery to a new one and it reset straight away. Like I said, weird !
Thanks for the assistance
Sorry to revive an old thread: I have a Fibaro FGK-104 (https://www.amazon.com/gp/product/B00P2QAR8C/)
I'm trying to use the custom device driver code referenced above but I can't seem to get any updates from the device. I'm also confused where the commands "Siren", "Strobe", "Both" etc are coming from. I don't see any of these "commands" referenced in the driver code anywhere:
I see other users reporting the same issues for this device using this driver code. This driver appears to work fine in ST and there's no references to "Siren" or "Strobe" anywhere in the driver code so it seems like Hubitat is adding those on it's own somehow.
The only thing I need from this device are the temperature probe readings from the external DS18B20 I have wired to the device. I need this to get water line temperature readings for a hot water recirculating pump.
Has anyone gotten this device to work with Hubitat?
I could also potentially switch to a different temperature sensor if someone can suggest one that works better with Hubitat. I only went with the FGK-104 because it's so hard to find sensors with external temperature probe connections and it's been working with ST for years without issues (Other than battery replacements). I wouldn't mind switching to a hard wired (mains powered) option if that exists to avoid having to go into the attic to change batteries.
