Configure command causing ZEN22 dimmers to become uknown
My ZEN22 FW 4.04 dimmers are becoming unrecognizable [edit out: when I enable parameter 13 for scene control]. The device model becomes unknown (deviceModel: UNK00) and the advanced parameter section disappears.
This is a second dimmer in a row that this has happened to today. I had to factory reset and re-pair the first one which was successful. I've power cycled the switch. I've restarted C8. I've tried generic dimmer. I've tried Configure and Refresh Parameters. Nothing seems to get the driver to recognize the ZEN22 again. What's odd is that I did this to another ZEN22 a couple of days ago and didn't have the problem.
I didn't do anything exotic, just Enabled Scene Control Events under Preferences, then Save Preferences, then Configure.
If the device is not responding it likely has nothing to do with this issue you have encountered.
Looks like you used Swap Apps on the device? A lot of that info you are showing in the States is supposed to be in the data at the bottom. Example below.
When you use Swap Apps it copies that to states and then is supposed to clean it all up and put it back where it belongs. Has been a rare bug in Swap Apps since it came out.
My driver uses some of that data to detect that you have a supported device, so if its not there all the settings get hidden but other the driver would continue to work as normal despite the warnings.
I will make another thread to discuss this issue since it is not really related to this driver.
I’m having trouble with my ZEN30 800LR v4.10. When I add the device using this driver, configure, create child device, turning the relay on and off using the child device doesn’t function. The parent device turns on the dimmer just fine. But I really need to turn the relay on and off. Ive rebooted.
One note is that I’ve added the device with security.
You are in luck because Zooz just alerted me of this yesterday, and I just finished what I think will fix it. You will need to run the "Configure" command after updating to this driver, so that it will detect the new endpoint setup on the v4 model.
Code: ZEN30 800LR v4 test code · GitHubIncluded in 2.0 Release
Use the "Raw" link on that page, then that URL can be used to import into the code editor in Hubitat.
If it is still having issues please enable debug logging and get some log screenshots for me. I also have one of the v4 models on the way to me so I can fully test it once I have one.
UPDATE 11-20-2023: Updated code linked above to include new settings for ZEN30 800LR model. Now going to work on getting all 3 drivers updated for a 2.0 driver release.
What actually happened is the light was already on and when motion was detected, the switch (Zen26) turned the light off. After 2 minutes, the light stayed off. I've been having this problem for a few months actually, but it's usually just a one off thing and I keep forgetting to check the logs. Today though my wife said it has been doing it all morning and seems to continue doing it so I finally got the logs.
I waited a bit and went into the laundry room again. The light was still off. It turned on as expected. I waited the elapsed time and the light didn't turn off.
When I look at the device and go to Events, I see an event from RL that seems to be a command to turn off. Then I see an event from the switch that says the switch turned off. What I don't know is if that is the switch telling the hub "Hey I turned off" of if it's your driver reporting "Hey I told the switch to turn off."
I tested it several more times and it seems to be alternating between these 2 states. So the light is on and it turns off with motion. The device page will report the light state as off and then change to on. So the opposite of reality. I don't quite understand though because if the light is on, if an on command is sent shouldn't nothing happen?
The second state is the light is off and activating it works normally. The device page says the light is off. It changes to on when activated. When the time is up, the device page changes the state to off, but the light doesn't actually turn off.
The driver only changes the state based on a confirmed response from the device. So the device is telling the hub that it turned off. The "command-off" is the off command being called, where the driver tells the device to turn off, and the "off" event is when the device responds that it is off.
If you want to edit the driver code and enable trace logging at the very bottom and reproduce it again you can see the full message the device is sending back (which I will understand).
Sounds like maybe the device is having a melt down. Have you tried power cycling it?
I was going to post the opposite scenario where the light is off, turns on as it should, but then doesn't turn off after but the log is identical.
Not yet. I wanted to gather some logs and troubleshoot first. It's annoying that the on/off switches don't have an air gap you can pull like the dimmers do.
So I'm wondering if I had a surge or something that damaged them. Both devices are among the very first I ordered when starting though, so I'm wondering what this means for the longevity of my switches, which are all Zooz.
If they are less than 5 years old and you registered them (which not sure what that entails even) then the warranty ids supposed to be 5 years. Might be worth putting in a claim.
Not yet, I am working on finishing up all my updates right now so hopefully by the end of the day. Brining all 3 drivers in this pack up to date with all my other improvements from other drivers.
OK, if you expect to merge that soon I might just wait for HPM version because its easier to maintain than manually installing a custom driver.... I bet it will fix my issue.... they update the official one I could optionally change back... or just keep using yours if it has advanced features anyway.
Ok I had been putting this off for too long. The last of my drivers to get re-based on my new code structure with a common library embedded at the end. So what matters to you? Updated parameters and a fix for the new ZEN30 800LR using different endpoints.
Homekit Integration fix for dimmers - Not sure if this is even still a problem but the HK integration was sending a Level command followed quickly by an On command which was setting the switch back to its prior level. I think I have got this working where it should block a On command that comes right after a Level command (before the level has even been set). If anyone was still having this issue can you please confirm if it is now fixed.
Forgot to mention in the changelog, the Brightness correction will be disabled with a message if the model/firmware has the same feature baked into the device firmware. Otherwise stacking my feature on top of it causes problems. This is ZEN77 10.20 or greater and ZEN30 800LR.
Version [2.0.0] - 2023-12-09
Rearranged functions and merged with library code
Removed unnecessary association attrbiutes
Depreciated the childDevices and refreshParams commands
Added doubleTapped events for better Button Controller support
Flash command now remembers last rate as default
Put in proper multichannel lifeline association for ZEN30
Fix for ZEN30 v4 firmware using different endpoint numbers
Added new settings for ZEN7x 10.20/10.40 base and ZEN30 800LR v4
Set Level Duration supports up to 7,620s (127 mins) for ZEN30 v4
Added possible workaround for Homekit integration issues (dimmers only)
I've got something weird going on with my new Zen30 800 series. With the default minimum brightness of 1% I can only only dim the light down to 43%, but that 43% is just barely on. It's a perfect nightlight level and what I wish I could set the minimum too. But, I set it to 40%.
But now with the minimum brightness configured to be 40% it barely dims at all. If I set the level to 3% (which should actually be 40%) it barely dims. I can set the level to 1% and it's barely dimmer than 1%.
I am not sure if it's needed, since it seems to sync after saving preferences, but I did press configure after each change. The log seems to indicate everything is normal.
EDIT: And I just swapped the bulbs with 3 identical bulbs currently on a Zen77 that I know can dim very low and are working fine and experienced the same behavior.
EDIT2: I don't know if this is possible... but could it somehow be the wiring between the plug and fixture, or the fixture itself? This Zen30 just replaced another Zen30 that was having really bad flickering when dimming.
