So, while my Ecolink contact sensors now behave more appropriately, I find today that ALL of my (older) Ecolink motion sensors (Model: PIR-ZWAVE2) are exhibiting even worse behavior - reporting multiples of duplicate active/inactive events in a row...
Oddly, these "appear" to stop if you turn ON debug logging, but that may be an artifact of what the code reports depending upon the debug/info logging setting.
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 01:57:56.765 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:37:01.533 pm [warn](http://192.168.1.173/device/edit/1314)debug logging disabled...
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.700 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.690 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.589 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.571 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.567 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.417 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:56.131 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:55.732 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:55.556 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:55.215 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:55.138 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:55.102 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:54.942 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:54.899 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:54.817 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:53.219 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:53.122 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:25:53.090 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:22.390 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:22.373 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:22.341 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.891 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.823 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.795 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.659 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.615 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.584 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.050 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:20.003 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:19.967 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:19.933 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:18.705 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:21:18.662 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:20:25.079 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:19:24.555 pm [warn](http://192.168.1.173/device/edit/1314)description logging is: true
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:19:24.553 pm [warn](http://192.168.1.173/device/edit/1314)debug logging is: false
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:19:24.549 pm [info](http://192.168.1.173/device/edit/1314)updated...
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:13:22.934 pm [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:13:22.926 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:13:22.923 pm [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:07:11.933 pm [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: FF , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:07:11.927 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:07:11.924 pm [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:255)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:07:01.452 pm [warn](http://192.168.1.173/device/edit/1314)description logging is: true
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:07:01.449 pm [warn](http://192.168.1.173/device/edit/1314)debug logging is: true
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:07:01.446 pm [info](http://192.168.1.173/device/edit/1314)updated...
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:05:36.584 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:02:14.597 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:01:44.494 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:01:39.729 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:01:39.657 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 12:01:39.641 pm [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:34:06.226 am [warn](http://192.168.1.173/device/edit/1314)debug logging disabled...
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:27:03.175 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:27:03.167 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:27:03.160 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:23:11.480 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: FF , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:23:11.452 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:23:11.447 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:255)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:24.215 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:24.173 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:24.168 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:24.129 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:24.103 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:24.097 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.149 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.145 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.143 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.079 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.074 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.071 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.005 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:23.002 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:22.999 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:21.379 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:21.365 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:21.351 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:20.181 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:20.177 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:08:20.174 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:0)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:09.362 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 8003, payload: 64 , isMulticast: false' to [[name:battery, unit:%, value:100, descriptionText:Office Motion Sensor (old) battery is 100%], 8408]
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:09.357 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) battery is 100%
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:09.210 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 8407, payload: , isMulticast: false' to hubitat.device.HubMultiAction@95d207
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:09.196 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) tamper is clear
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:09.178 am [debug](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) woke up
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:01.917 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 7105, payload: 00 FF 00 FF 07 03 01 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:05:01.899 am [debug](http://192.168.1.173/device/edit/1314)NotificationReport(v1AlarmType:0, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:3, sequence:false, eventParametersLength:1, eventParameter:[0])
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:52.047 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 7105, payload: 00 FF 00 FF 07 03 01 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:52.044 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) tamper is detected
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:52.031 am [debug](http://192.168.1.173/device/edit/1314)NotificationReport(v1AlarmType:0, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:3, sequence:false, eventParametersLength:1, eventParameter:[0])
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:50.813 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 3003, payload: FF , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:50.809 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:50.806 am [debug](http://192.168.1.173/device/edit/1314)SensorBinaryReport(sensorValue:255)
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:49.627 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 8407, payload: , isMulticast: false' to hubitat.device.HubMultiAction@9f4fcc
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:49.600 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) tamper is clear
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:49.593 am [debug](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) woke up
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:36.210 am [debug](http://192.168.1.173/device/edit/1314)parsed 'zw device: 0D, command: 7105, payload: 00 FF 00 FF 07 03 01 00 , isMulticast: false' to []
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:36.206 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) tamper is detected
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:36.189 am [debug](http://192.168.1.173/device/edit/1314)NotificationReport(v1AlarmType:0, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:3, sequence:false, eventParametersLength:1, eventParameter:[0])
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:06.175 am [warn](http://192.168.1.173/device/edit/1314)configure...
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:02.299 am [warn](http://192.168.1.173/device/edit/1314)description logging is: true
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:02.296 am [warn](http://192.168.1.173/device/edit/1314)debug logging is: true
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 10:04:02.293 am [info](http://192.168.1.173/device/edit/1314)updated...
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:54:38.934 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:51:29.839 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:39:32.256 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) battery is null%
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:39:31.659 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) battery is null%
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:39:31.448 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) battery is null%
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:39:31.093 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) battery is null%
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:07:00.183 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 09:06:27.204 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:19.781 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:19.619 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:19.616 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:19.052 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:18.876 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:18.814 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:17.599 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:17.564 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:58:17.525 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:20.853 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:20.786 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:20.490 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:20.459 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:20.376 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:20.138 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:13.753 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:12.435 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:57:11.109 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:38.035 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:37.395 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:37.074 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:36.949 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:36.490 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:36.429 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:56:36.365 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is active
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:55:49.186 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:55:48.008 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
[dev:1314](http://192.168.1.173/logs#dev1314)2019-08-07 08:55:46.862 am [info](http://192.168.1.173/device/edit/1314)Office Motion Sensor (old) is inactive
@mike.maxwell - is there any chance these extraneous, repeated events can be eliminated also?
