Based on this, Parameter 101 = Watts, Parameter 102 = KWH, and Parameter 103 = Amps
Parameters 111, 112, and 113 poll every 120 seconds.
Yet, whether I use this driver from @TechMedX or the built in driver in Hubitat, I'm getting the following for Power and Current:
I'm not sure the KWH calculations are correct either, I'm not using that much or perhaps its the cost amount I put in my settings. Either way, something isn't reporting properly and I am not able to determine why.
I just moved mine from a C-5 to my C-7 and it works fine. It is paired non-secure and running a driver that I found a while ago. I am not at home to look at the driver name but if you can't get it going let me know and I can tell you the author and even e-mail it to you if you need.
It is fully functional and the data is fed to a Google sheet for long term tracking that is graphed and fed into SharpTools.
I believe the driver will need to be modified to work with S0 with the C7 as I was told by Hubitat Staff that there isn't a way to force it to pair non- secure on the C7, unlike the previous gen hubs.
@halfrican.ak you are most likely correct, which is why I said this above...
As for updating the driver unfortunately I wouldn't know where to begin since I'm not a dev. Without HE or someone else picking up the torch I think this device dies with the C7
When I try and import this into my C7 I'm getting the following errors:
unable to resolve class physicalgraph.zwave.Zwave @ line 93, column 4. unable to resolve class physicalgraph.zwave.Zwave @ line 97, column 4. unable to resolve class physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation @ line 210, column 16. unable to resolve class physicalgraph.zwave.commands.securityv1.SecurityCommandsSupportedReport @ line 222, column 16. unable to resolve class physicalgraph.zwave.commands.configurationv1.ConfigurationReport @ line 226, column 16. unable to resolve class physicalgraph.zwave.commands.associationv2.AssociationReport @ line 230, column 16. unable to resolve class physicalgraph.zwave.commands.meterv3.MeterReport @ line 234, column 16. unable to resolve class physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap @ line 281, column 16. unable to resolve class physicalgraph.zwave.Command @ line 333, column 16. unable to resolve class physicalgraph.zwave.Command @ line 432, column 17.
Don't know if it matters but I did a hard reset on the HEM after removing from the C-5 and before including on the C-7. Everything during the process was unremarkable so I don't have any tricks to share.
Hard reset how? Holding the button in for 10 seconds? I’ve done that already multiple times. Interestingly enough I moved one of my HEMs back to my C4 with the same driver as we are using here and I’m still having the same issue. I’ve replied to Aeotec and waiting on a response.
@shawn.foist how are you feeding the data to Google sheets? This is what I really would like to do so that I can track day over day usage. Thanks in advance for any help you can provide.
