Debug log?
That is simply cosmetic. Is that the parent or child app?
sorry was just coming back to say this as realised it wasn't clear. child has one looks like it all updated.
I've hit a wall and can't figure out how to update an app through bundles.
I have a notification there are updates but where is the button to install the update?
Found it! I didn't update the version in Normal Stuff, so even though it was downloading it just fine, the version wouldn't update.
I just tried installing this both through HPM and using the code, and it doesn't show up in my apps list.
Hi @bptworld,
Sorry if I am a little dense but has this been corrected yet? I get notified that I have two updates available (BM and Normal Stuff. . . Currently at 1.1.3 and 1.0.2 respectively) but like @an39511 , no way to update (update procedure was working a couple of days ago). I do go out of the app and back in to see if these are being updated but versions stay the same. Did not know if you had a chance to fix this (seems like you found the problem in the code but may not have had a chance to change it?).
Just checking. Thanks for any help or indication when this will be fixed or if I am missing something obvious if it has already been fixed.
Edit: BM updated to 1.1.4 but Normal Stuff Library still no joy.
Many people are reporting 'Manifest Errors'...
The manifest error is actually HPM. Start at the link below and follow along...
New version...
1.1.5 - 06/10/22 - Fixed a mistake with Display updates, BM now recognizes when an app is updated right away, no need to wait for it to be opened or executed!
Like yesterday Bundle Manager shows 1 update but I have no option to update.
I've clicked "Checked for installed bundle updates" which turns on for a few seconds then off.
Is there something I am missing?
Gonna need a debug log to know
app:7872022-06-10 07:03:12.323 pm debug---------- End checkBundleHandler ----------
app:7872022-06-10 07:03:12.318 pm info**** 1 Update Available! ****
app:7872022-06-10 07:03:12.313 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: The Flasher
app:7872022-06-10 07:03:12.311 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: The Flasher
app:7872022-06-10 07:03:12.309 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: The Flasher
app:7872022-06-10 07:03:12.308 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Normal Stuff Library
app:7872022-06-10 07:03:12.306 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Normal Stuff Library
app:7872022-06-10 07:03:12.304 pm infoNormal Stuff Library - No update available.
app:7872022-06-10 07:03:12.303 pm infoApp: Normal Stuff Library - Checking version: 1.0.3 - VS - jsonVersion: 1.0.3
app:7872022-06-10 07:03:12.301 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Normal Stuff Library
app:7872022-06-10 07:03:12.299 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Life Event Calendar
app:7872022-06-10 07:03:12.298 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Life Event Calendar
app:7872022-06-10 07:03:12.295 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Life Event Calendar
app:7872022-06-10 07:03:12.293 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Life360 Tracker
app:7872022-06-10 07:03:12.290 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Life360 Tracker
app:7872022-06-10 07:03:12.288 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Life360 Tracker
app:7872022-06-10 07:03:12.286 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Home Tracker
app:7872022-06-10 07:03:12.283 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Home Tracker
app:7872022-06-10 07:03:12.281 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Home Tracker
app:7872022-06-10 07:03:12.279 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Follow Me
app:7872022-06-10 07:03:12.276 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Follow Me
app:7872022-06-10 07:03:12.274 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Follow Me
app:7872022-06-10 07:03:12.272 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Event Engine
app:7872022-06-10 07:03:12.270 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Event Engine
app:7872022-06-10 07:03:12.267 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Event Engine
app:7872022-06-10 07:03:12.265 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Error Monitor
app:7872022-06-10 07:03:12.263 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Error Monitor
app:7872022-06-10 07:03:12.261 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Error Monitor
app:7872022-06-10 07:03:12.258 pm infoDevice Watchdog - No update available.
app:7872022-06-10 07:03:12.256 pm infoApp: Device Watchdog - Checking version: 2.4.7 - VS - jsonVersion: 2.4.7
app:7872022-06-10 07:03:12.254 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Device Watchdog
app:7872022-06-10 07:03:12.252 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Device Watchdog
app:7872022-06-10 07:03:12.250 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Device Watchdog
app:7872022-06-10 07:03:12.247 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Device Transformer
app:7872022-06-10 07:03:12.245 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Device Transformer
app:7872022-06-10 07:03:12.242 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Device Transformer
app:7872022-06-10 07:03:12.238 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Device Check Plus
app:7872022-06-10 07:03:12.236 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Device Check Plus
app:7872022-06-10 07:03:12.234 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Device Check Plus
app:7872022-06-10 07:03:12.231 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Chromecast Helper
app:7872022-06-10 07:03:12.229 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Chromecast Helper
app:7872022-06-10 07:03:12.226 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Chromecast Helper
app:7872022-06-10 07:03:12.223 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Bundle Manager
app:7872022-06-10 07:03:12.219 pm debugIn checkBundleHandler - Needs Updating - Bundle Manager
app:7872022-06-10 07:03:12.215 pm infoBundle Manager - Update available!
app:7872022-06-10 07:03:12.212 pm infoApp: Bundle Manager - Checking version: 1.1.4 - VS - jsonVersion: 1.1.5
app:7872022-06-10 07:03:12.210 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Bundle Manager
app:7872022-06-10 07:03:12.207 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Bundle Manager
app:7872022-06-10 07:03:12.204 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: Averaging Plus
app:7872022-06-10 07:03:12.202 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: Averaging Plus
app:7872022-06-10 07:03:12.199 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: Averaging Plus
app:7872022-06-10 07:03:12.194 pm debugIn checkBundleHandler - Checking aName: Device Watchdog - VS - jsonName: At Home Simulator
app:7872022-06-10 07:03:12.192 pm debugIn checkBundleHandler - Checking aName: Bundle Manager - VS - jsonName: At Home Simulator
app:7872022-06-10 07:03:12.189 pm debugIn checkBundleHandler - Checking aName: Normal Stuff Library - VS - jsonName: At Home Simulator
app:7872022-06-10 07:03:11.987 pm debugIn getAllBundlesHandler - mainURL: https://raw.githubusercontent.com/bptworld/Hubitat/master/Bundles/myBundles.json
app:7872022-06-10 07:03:11.983 pm debug---------- In checkBundleHandler (1.1.4) ----------
app:7872022-06-10 07:03:11.698 pm info--------------- Getting All Bundles from https://raw.githubusercontent.com/bptworld/Hubitat/master/Bundles/myBundles.json ---------------
app:7872022-06-10 07:03:11.695 pm debugIn getAllBundlesHandler - mainURL: https://raw.githubusercontent.com/bptworld/Hubitat/master/Bundles/myBundles.json
app:7872022-06-10 07:03:11.691 pm debugIn getAllBundlesHandler (1.1.4)
app:7872022-06-10 07:03:11.686 pm debugIn getMasterBundleList - hName: BPTWorld - theLoc: https://raw.githubusercontent.com/bptworld/Hubitat/master/Bundles/myBundles.json
app:7872022-06-10 07:03:11.376 pm debugIn getMasterBundleList (1.1.4)
app:7872022-06-10 07:02:58.490 pm debugUpdated with settings: [pauseApp:false, checkMasterBundlesFirst:true, autoUpdate:false, showUpdates:false, pushUpdates:false, checkBundlesAt:false, deleteApp:false, deleteDriver:false, deleteBundle:false, clearMap:false, updateBundleListAt:false, inputBundle2:false, manCheck:false, pushNoUpdates:false, clearMap2:false, showMap:true, checkBundles:false, logEnable:true, logOffTime:1 Hour]
Thanks.
1st please read the first post on posting debug logs.
Now, please go to the Search page and re-download Bundle Manager. This will update you to the latest version which should also fix not being able to see the updates.
Sorry for my confusion, I didn't realize I had to go to the search and select to install it again. After doing that it updated.
Not at all, you don't usually have to do that. I had an issue with the update process, so re-downloading it gets you the code to fix it.
Tried to install At Home Simulator a few times but it's just not getting installed for some reason. Sorry, I'm on mobile let me know if you need more logs.
Stuff
So if we have several of your apps already installed and configured is there anyway to NOT have to redo everything?
