I'm setting up my first dashboards and I want to be able to show the state of a virtual switch (on or off) in a tile without the tile being able to change the switch state. Is there a way to do this?
You can also just put a blank tile over top of the switch tile. That way it can't be clicked. For example, if you don't use the image tile, you can change the image tile template to have a clear background. Then place this overtop of the switch tile and then it won't be able to be tapped. When stacking tiles, the one with the highest number is always on top.
