I did something neat that I think will work well. The thermostat does accurately report it's temperature changes, so I wrote a quick RM that refreshes the device only when a temperature change is detected, and will repeat it 3x times 15 seconds each. This basically looks to see if the temperature change hit the threshold to shut the AC.
This prevents endless polling of a device that doesn't need to be polled so often, but also gives me pretty quick response times.
Maybe that could get integrated into the device code, that is if the device truly doesn't report well on it's own. Based on other posts, I am not the only one with these CT101 issues.
Not everyone has issues with this, the unit I have doesn't, and unless there's some programitic way to tell those that do from those that don't, it's not fair to burden the driver and the hub with this task globally.
Excuse the ST screenshots, it was still accessible from the platform site, but contained the MSR and fw version and I am not sure if that data is exposed on my side of HE
All good, I have a pseudo workaround in place. Just looking to have everything as finely tuned as I can. I will look on the device itself for a FW version to see if anything differs. I can't find any google hits for upgrade able firmware.
I just set up my CT101 because the GoControl GC-TBZ48 was not keeping correct time. My thermostat is a z-wave version and it doesn't seem to have any of the problems mentioned above. Just an FYI.
yeah, different firmware and different product id.
current stock, ie non Iris branded
firmware: 9.7
deviceId: 13
So it would be possible to resolve this in the current driver, however I would prefer to have a loaner Lowes version to do this with, vs hacking and hoping for the best...
I can send you mine in a few months when the heat dies down. I wonder if anyone who replaced theirs with something else still has it and can send it in for testing.
On the thermostat, it does not say Iris anywhere and I bought mine directly from Lowe's. The label on back says Radio Thermostat
Model CT101
FCC ID: QO8-CT101R1
Speaks Z-Wave
Mine is available to send immediately since I am no longer using it.
I can send mine as well. I can't find it right now, but I asked a few people what their firmware levels were thinking there may have been some variation.
Which might be an issue, since as far as I can tell there’s no way to update the firmware. Several people have reached out to Radio Control and they’ve neglected to reply with any meaningful information.
It looks like mine is 9.0 which seems pretty low considering I see 9.1, 9.2 and 9.7 mentioned here. Might just be a throwaway at $45.
